Store the cdev pointer in struct irctl, allocated dynamically as needed,
rather than having a static array. At the same time, recycle some of the
saved memory to nudge the maximum number of lirc devices supported up a
ways -- its not that uncommon these days, now that we have the rc-core
lirc bridge driver, to see a system with at least 4 raw IR receivers.
(consider a mythtv backend with several video capture devices and the
possible need for IR transmit hardware).
Signed-off-by: Jarod Wilson <jarod@redhat.com>
kobject_set_name() may fail with -ENOMEM, check for it.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: Jarod Wilson <jarod@redhat.com>
Sparse complains because there are no __user annotations.
drivers/media/rc/lirc_dev.c:156:27: warning:
incorrect type in initializer (incompatible argument 2 (different address spaces))
drivers/media/rc/lirc_dev.c:156:27: expected int ( *read )( ... )
drivers/media/rc/lirc_dev.c:156:27: got int ( extern [toplevel] *<noident> )( ... )
