path: root/drivers/media/radio/radio-gemtek-pci.c
2006-10-04V4L/DVB (4711): Radio: No need to return voidTobias Klauser
The module_exit function has return-type void and pci_unregister_driver() returns void anyway. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4370): Fix some typos on ioctl handling functionMauro Carvalho Chehab
2006-09-26V4L/DVB (4350): V4L2 conversion: radio_gemtek-pciMauro Carvalho Chehab
Driver conversion to V4L2 API. Require some testing, since this obsolete hardware is not common those days. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4068): Removed all references to kernel stuff from videodev.h and ↵Mauro Carvalho Chehab
videodev2.h The videodev.h and videodev2.h describe the public API for V4L and V4L2. It shouldn't have there any kernel-specific stuff. Those were moved to v4l2-dev.h. This patch removes some uneeded headers and include v4l2-common.h on all V4L driver. This header includes device implementation of V4L2 API provided on v4l2-dev.h as well as V4L2 internal ioctls that provides connections between master driver and its i2c devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3753): Whitespace cleanups at media/radioMauro Carvalho Chehab
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
2006-01-09[PATCH] drivers/block: Replace pci_module_init() with pci_register_driver()Richard Knutsson
Replace obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09V4L (926_2): Moves compat32 functions from fs to v4l subsystemArnd Bergmann
This moves the 32 bit ioctl compatibility handlers for Video4Linux into a new file and adds explicit calls to them to each v4l device driver. Unfortunately, there does not seem to be any code handling the v4l2 ioctls, so quite often the code goes through two separate conversions, first from 32 bit v4l to 64 bit v4l, and from there to 64 bit v4l2. My patch does not change that, so there is still much room for improvement. Also, some drivers have additional ioctl numbers, for which the conversion should be handled internally to that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
