path: root/drivers/media/platform/fsl-viu.c
2018-09-11media: replace strcpy() by strscpy()Mauro Carvalho Chehab
The strcpy() function is being deprecated upstream. Replace it by the safer strscpy(). Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-07-04media: fsl-viu: fix error handling in viu_of_probe()Alexey Khoroshilov
viu_of_probe() ignores fails in i2c_get_adapter(), tries to unlock uninitialized mutex on error path. The patch streamlining the error handling in viu_of_probe(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-04-17media: platform: fix some 64-bits warningsMauro Carvalho Chehab
The omap/omap3 and viu drivers are for 32 bit platforms only. There, a pointer has 32 bits. Now that those drivers build for 64 bits with COMPILE_TEST, they produce the following warnings: drivers/media/platform/omap/omap_vout_vrfb.c: In function 'omap_vout_allocate_vrfb_buffers': drivers/media/platform/omap/omap_vout_vrfb.c:57:10: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] memset((void *) vout->smsshado_virt_addr[i], 0, ^ drivers/media/platform/fsl-viu.c: In function 'viu_setup_preview': drivers/media/platform/fsl-viu.c:753:28: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] reg_val.field_base_addr = (u32)dev->ovbuf.base; ^ drivers/media/platform/omap/omap_vout.c: In function 'omap_vout_get_userptr': drivers/media/platform/omap/omap_vout.c:209:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] *physp = virt_to_phys((void *)virtp); ^ drivers/media/platform/omap3isp/ispccdc.c: In function 'ccdc_config': drivers/media/platform/omap3isp/ispccdc.c:738:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] (__force void __user *)fpc.fpcaddr, ^ Add some typecasts to remove those warnings when building for 64 bits. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2018-04-17media: fsl-viu: fix __iomem annotationsMauro Carvalho Chehab
Those annotations are wrong, causing this warning: drivers/media/platform/fsl-viu.c:1440:21: warning: incorrect type in assignment (different address spaces) drivers/media/platform/fsl-viu.c:1440:21: expected struct viu_reg *vr drivers/media/platform/fsl-viu.c:1440:21: got struct viu_reg [noderef] <asn:2>*[assigned] viu_regs Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2018-04-17media: fsl-viu: use %p to print pointersMauro Carvalho Chehab
Solve those warnings: drivers/media/platform/fsl-viu.c:299 restart_video_queue() warn: argument 3 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:506 buffer_queue() warn: argument 2 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:518 buffer_queue() warn: argument 2 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:528 buffer_queue() warn: argument 2 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:1219 viu_open() warn: argument 2 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:1219 viu_open() warn: argument 3 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:1219 viu_open() warn: argument 4 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:1329 viu_mmap() warn: argument 2 to %08lx specifier is cast from pointer drivers/media/platform/fsl-viu.c:1334 viu_mmap() warn: argument 2 to %08lx specifier is cast from pointer Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2018-04-17media: fsl-viu: allow building it with COMPILE_TESTMauro Carvalho Chehab
There aren't many things that would be needed to allow it to build with compile test. Add the needed bits. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2018-04-17media: fsl-viu: mark static functions as suchMauro Carvalho Chehab
There are several functions that are used only inside the driver. Stop exposing that to global symbolspace. Get rid of the following gcc warnings: drivers/media/platform/fsl-viu.c:240:17: warning: no previous prototype for ‘format_by_fourcc’ [-Wmissing-prototypes] struct viu_fmt *format_by_fourcc(int fourcc) ^~~~~~~~~~~~~~~~ drivers/media/platform/fsl-viu.c:253:6: warning: no previous prototype for ‘viu_start_dma’ [-Wmissing-prototypes] void viu_start_dma(struct viu_dev *dev) ^~~~~~~~~~~~~ drivers/media/platform/fsl-viu.c:262:6: warning: no previous prototype for ‘viu_stop_dma’ [-Wmissing-prototypes] void viu_stop_dma(struct viu_dev *dev) ^~~~~~~~~~~~ drivers/media/platform/fsl-viu.c:807:5: warning: no previous prototype for ‘vidioc_g_fbuf’ [-Wmissing-prototypes] int vidioc_g_fbuf(struct file *file, void *priv, struct v4l2_framebuffer *arg) ^~~~~~~~~~~~~ drivers/media/platform/fsl-viu.c:818:5: warning: no previous prototype for ‘vidioc_s_fbuf’ [-Wmissing-prototypes] int vidioc_s_fbuf(struct file *file, void *priv, const struct v4l2_framebuffer *arg) ^~~~~~~~~~~~~ drivers/media/platform/fsl-viu.c: In function ‘viu_open’: drivers/media/platform/fsl-viu.c:1170:6: warning: variable ‘status_cfg’ set but not used [-Wunused-but-set-variable] u32 status_cfg; ^~~~~~~~~~ drivers/media/platform/fsl-viu.c: At top level: drivers/media/platform/fsl-viu.c:1304:6: warning: no previous prototype for ‘viu_reset’ [-Wmissing-prototypes] void viu_reset(struct viu_reg *reg) ^~~~~~~~~ Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2018-02-11vfs: do bulk POLL* -> EPOLL* replacementLinus Torvalds
This is the mindless scripted replacement of kernel use of POLL* variables as described by Al, done by this script: for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'` for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done done with de-mangling cleanups yet to come. NOTE! On almost all architectures, the EPOLL* constants have the same values as the POLL* constants do. But they keyword here is "almost". For various bad reasons they aren't the same, and epoll() doesn't actually work quite correctly in some cases due to this on Sparc et al. The next patch from Al will sort out the final differences, and we should be all done. Scripted-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-27media: annotate ->poll() instancesAl Viro
2017-11-27annotate poll_table_struct ->_keyAl Viro
Only POLL... bitmaps ever end up there and their only use is checking for POLL... bits in them. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-11-21treewide: setup_timer() -> timer_setup() (2 field)Kees Cook
This converts all remaining setup_timer() calls that use a nested field to reach a struct timer_list. Coccinelle does not have an easy way to match multiple fields, so a new script is needed to change the matches of "&_E->_timer" into "&_E->_field1._timer" in all the rules. spatch --very-quiet --all-includes --include-headers \ -I ./arch/x86/include -I ./arch/x86/include/generated \ -I ./include -I ./arch/x86/include/uapi \ -I ./arch/x86/include/generated/uapi -I ./include/uapi \ -I ./include/generated/uapi --include ./include/linux/kconfig.h \ --dir . \ --cocci-file ~/src/data/timer_setup-2fields.cocci @fix_address_of depends@ expression e; @@ setup_timer( -&(e) +&e , ...) // Update any raw setup_timer() usages that have a NULL callback, but // would otherwise match change_timer_function_usage, since the latter // will update all function assignments done in the face of a NULL // function initialization in setup_timer(). @change_timer_function_usage_NULL@ expression _E; identifier _field1; identifier _timer; type _cast_data; @@ ( -setup_timer(&_E->_field1._timer, NULL, _E); +timer_setup(&_E->_field1._timer, NULL, 0); | -setup_timer(&_E->_field1._timer, NULL, (_cast_data)_E); +timer_setup(&_E->_field1._timer, NULL, 0); | -setup_timer(&_E._field1._timer, NULL, &_E); +timer_setup(&_E._field1._timer, NULL, 0); | -setup_timer(&_E._field1._timer, NULL, (_cast_data)&_E); +timer_setup(&_E._field1._timer, NULL, 0); ) @change_timer_function_usage@ expression _E; identifier _field1; identifier _timer; struct timer_list _stl; identifier _callback; type _cast_func, _cast_data; @@ ( -setup_timer(&_E->_field1._timer, _callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, &_callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, &_callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)_callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)&_callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, &_callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, &_callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | _E->_field1._timer@_stl.function = _callback; | _E->_field1._timer@_stl.function = &_callback; | _E->_field1._timer@_stl.function = (_cast_func)_callback; | _E->_field1._timer@_stl.function = (_cast_func)&_callback; | _E._field1._timer@_stl.function = _callback; | _E._field1._timer@_stl.function = &_callback; | _E._field1._timer@_stl.function = (_cast_func)_callback; | _E._field1._timer@_stl.function = (_cast_func)&_callback; ) // callback(unsigned long arg) @change_callback_handle_cast depends on change_timer_function_usage@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; identifier _handle; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { ( ... when != _origarg _handletype *_handle = -(_handletype *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg | ... when != _origarg _handletype *_handle = -(void *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(_handletype *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(void *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg ) } // callback(unsigned long arg) without existing variable @change_callback_handle_cast_no_arg depends on change_timer_function_usage && !change_callback_handle_cast@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { + _handletype *_origarg = from_timer(_origarg, t, _field1._timer); + ... when != _origarg - (_handletype *)_origarg + _origarg ... when != _origarg } // Avoid already converted callbacks. @match_callback_converted depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier t; @@ void _callback(struct timer_list *t) { ... } // callback(struct something *handle) @change_callback_handle_arg depends on change_timer_function_usage && !match_callback_converted && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; @@ void _callback( -_handletype *_handle +struct timer_list *t ) { + _handletype *_handle = from_timer(_handle, t, _field1._timer); ... } // If change_callback_handle_arg ran on an empty function, remove // the added handler. @unchange_callback_handle_arg depends on change_timer_function_usage && change_callback_handle_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; identifier t; @@ void _callback(struct timer_list *t) { - _handletype *_handle = from_timer(_handle, t, _field1._timer); } // We only want to refactor the setup_timer() data argument if we've found // the matching callback. This undoes changes in change_timer_function_usage. @unchange_timer_function_usage depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg && !change_callback_handle_arg@ expression change_timer_function_usage._E; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type change_timer_function_usage._cast_data; @@ ( -timer_setup(&_E->_field1._timer, _callback, 0); +setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E); | -timer_setup(&_E._field1._timer, _callback, 0); +setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E); ) // If we fixed a callback from a .function assignment, fix the // assignment cast now. @change_timer_function_assignment depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression change_timer_function_usage._E; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_func; typedef TIMER_FUNC_TYPE; @@ ( _E->_field1._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_field1._timer.function = -&_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_field1._timer.function = -(_cast_func)_callback; +(TIMER_FUNC_TYPE)_callback ; | _E->_field1._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -&_callback; +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -(_cast_func)_callback +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; ) // Sometimes timer functions are called directly. Replace matched args. @change_timer_function_calls depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression _E; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_data; @@ _callback( ( -(_cast_data)_E +&_E->_field1._timer | -(_cast_data)&_E +&_E._field1._timer | -_E +&_E->_field1._timer ) ) // If a timer has been configured without a data argument, it can be // converted without regard to the callback argument, since it is unused. @match_timer_function_unused_data@ expression _E; identifier _field1; identifier _timer; identifier _callback; @@ ( -setup_timer(&_E->_field1._timer, _callback, 0); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, _callback, 0L); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, _callback, 0UL); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, 0); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, 0L); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, 0UL); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_field1._timer, _callback, 0); +timer_setup(&_field1._timer, _callback, 0); | -setup_timer(&_field1._timer, _callback, 0L); +timer_setup(&_field1._timer, _callback, 0); | -setup_timer(&_field1._timer, _callback, 0UL); +timer_setup(&_field1._timer, _callback, 0); | -setup_timer(_field1._timer, _callback, 0); +timer_setup(_field1._timer, _callback, 0); | -setup_timer(_field1._timer, _callback, 0L); +timer_setup(_field1._timer, _callback, 0); | -setup_timer(_field1._timer, _callback, 0UL); +timer_setup(_field1._timer, _callback, 0); ) @change_callback_unused_data depends on match_timer_function_unused_data@ identifier match_timer_function_unused_data._callback; type _origtype; identifier _origarg; @@ void _callback( -_origtype _origarg +struct timer_list *unused ) { ... when != _origarg } Signed-off-by: Kees Cook <keescook@chromium.org>
2017-08-27media: platform: make video_device constBhumika Goyal
Make these const as they are only used during a copy operation. Done using Coccinelle: @match disable optional_qualifier@ identifier s; @@ static struct video_device s = {...}; @ref@ position p; identifier match.s; @@ s@p @good1@ identifier match.s; expression list[3] es; position ref.p; @@ cx88_vdev_init(es,&s@p,...) @good2@ position ref.p; identifier match.s,f,c; expression e; @@ ( e = s@p | e = s@p.f | c(...,s@p.f,...) | c(...,s@p,...) ) @bad depends on !good1 && !good2@ position ref.p; identifier match.s; @@ s@p @depends on forall !bad disable optional_qualifier@ identifier match.s; @@ static + const struct video_device s; Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-26media: platform: constify videobuf_queue_ops structuresArvind Yadav
videobuf_queue_ops are not supposed to change at runtime. All functions working with videobuf_queue_ops provided by <media/videobuf-core.h> work with const videobuf_queue_ops. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Hans Verkuil <hansverk@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-07-19media: media/platform: add const to v4l2_file_operations structuresBhumika Goyal
Declare v4l2_file_operations structures as const as they are only stored in the fops field of video_device structures. This field is of type const, so declare v4l2_file_operations structures with similar properties as const. Cross compiled bfin_capture.o for blackfin arch. vpbe_display.o file did not cross compile for arm. Could not find any architecture matching the configuraion symbol for fsl-viu.c file. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-04-10[media] fsl-viu: use setup_timerGeliang Tang
Use setup_timer() instead of init_timer() to simplify the code. Signed-off-by: Geliang Tang <geliangtang@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2015-08-11[media] fsl-viu: drop format namesHans Verkuil
The names of the pixelformats is set by the core. So there no longer is any need for drivers to fill it in. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-11[media] fsl-viu: small fixesHans Verkuil
- Fix an off-by-one index check in vidioc_enum_fmt() - Fill in the pix.sizeimage field in vidioc_try_fmt_cap() - Fix an off-by-one index check in vidioc_s_input() Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-11[media] fsl-viu: add control event supportHans Verkuil
Convert the driver to use v4l2_fh in order to support control events. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-11[media] fsl-viu: fill in colorspace, always set field to interlacedHans Verkuil
- fill in the missing colorspace value. - don't reject incorrect field values, always replace with a valid value. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-11[media] fsl-viu: fill in bus_info in vidioc_querycapHans Verkuil
The bus_info field was never filled. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-11[media] fsl-viu: convert to the control frameworkHans Verkuil
Interestingly enough, the existing control handling code basically did nothing. At least the new code will inherit the controls from the saa7115 driver. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-05-12[media] constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) [mchehab@osg.samsung.com: fix a merge conflict at adv7604.c] Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-02[media] media/platform: fix querycapHans Verkuil
Querycap shouldn't set the version field (the core does that for you), but it should set the device_caps field. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Scott Jiang <scott.jiang.linux@gmail.com> Cc: Gerhard Sittig <gsi@denx.de> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-10-20media: platform: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-05-24[media] v4l: subdev: Move [gs]_std operation to video opsLaurent Pinchart
The g_std and s_std operations are video-related, move them to the video ops where they belong. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-12fsl-viu: adjust for OF based clock lookupGerhard Sittig
after device tree based clock lookup became available, the VIU driver need no longer use the previous global "viu_clk" name, but should use the "ipg" clock name specific to the OF node Cc: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: linux-media@vger.kernel.org Signed-off-by: Gerhard Sittig <gsi@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-08-23fsl-viu: cleanup clock API useGerhard Sittig
use devm_clk_get() for automatic put after device close, check for and propagate errors when enabling clocks, need to prepare clocks before they can get enabled, adjust code paths to correctly balance get/put and prepare/unprepare and enable/disable calls Cc: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Gerhard Sittig <gsi@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-06-17[media] fsl-viu: remove current_normHans Verkuil
The use of current_norm is deprecated, so remove it. This driver actually already implements g_std, which overrides current_norm, but the 'std' field was never initialized correctly. This has been fixed as well. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-24[media] v4l2: pass std by value to the write-only s_std ioctlHans Verkuil
This ioctl is defined as IOW, so pass the argument by value instead of by reference. I could have chosen to add const instead, but this is 1) easier to handle in drivers and 2) consistent with the s_std subdev operation. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-24Merge branch 'v4l_for_linus' into staging/for_v3.9Mauro Carvalho Chehab
* v4l_for_linus: (464 commits) [media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures [media] uvcvideo: Cleanup leftovers of partial revert [media] uvcvideo: Return -EACCES when trying to set a read-only control Linux 3.8-rc3 mm: reinstante dropped pmd_trans_splitting() check cred: Remove tgcred pointer from struct cred drm/ttm: fix fence locking in ttm_buffer_object_transfer ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms drm/prime: drop reference on imported dma-buf come from gem xen/netfront: improve truesize tracking ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array sctp: fix Kconfig bug in default cookie hmac selection EDAC: Cleanup device deregistering path ... Conflicts: drivers/media/pci/dm1105/dm1105.c drivers/media/platform/soc_camera/mx2_camera.c
2013-01-03Drivers: media: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-21[media] v4l: Convert drivers to use monotonic timestampsSakari Ailus
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the monotonic timer (CLOCK_MONOTONIC). Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-25[media] v4l2: use list_move_tail instead of list_del/list_add_tailWei Yongjun
Using list_move_tail() instead of list_del() + list_add_tail(). dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-05[media] fsl-viu: fix compiler warningHans Verkuil
drivers/media/platform/fsl-viu.c: In function 'vidioc_s_fbuf': drivers/media/platform/fsl-viu.c:867:32: warning: initialization discards 'const' qualifier from pointer target type [enabled by default] This is fall-out from this commit: commit e6eb28c2207b9397d0ab56e238865a4ee95b7ef9 Author: Hans Verkuil <hans.verkuil@cisco.com> [media] v4l2: make vidioc_s_fbuf const Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-26[media] v4l2: make vidioc_s_fbuf constHans Verkuil
Write-only ioctls should have a const argument in the ioctl op. Do this conversion for vidioc_s_fbuf. Adding const for write-only ioctls was decided during the 2012 Media Workshop. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
