path: root/drivers/media/platform/davinci/vpif.c
2014-10-20media: platform: davinci: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-09[media] vpif: Fix compilation with allmodconfigMauro Carvalho Chehab
When vpif is compiled as module, those errors happen: ERROR: "vpif_lock" [drivers/media/platform/davinci/vpif_display.ko] undefined! ERROR: "vpif_lock" [drivers/media/platform/davinci/vpif_capture.ko] undefined! That's because vpif_lock symbol is not exported. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-06-21[media] media: davinci: vpif: remove unnecessary braces around definesLad, Prabhakar
This patch removes unnecessary braces around defines. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-06-21[media] media: davinci: vpif: Convert to devm_* apiLad, Prabhakar
Use devm_ioremap_resource instead of reques_mem_region()/ioremap(). This ensures more consistent error values and simplifies error paths. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-06-21[media] media: davinci: vpif: remove unwanted header mach/hardware.h and ↵Lad, Prabhakar
sort the includes alphabetically This patch removes unwanted header include of mach/hardware.h and along side sorts the header inclusion alphabetically. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-04-14[media] davinci: vpif: add pm_runtime supportLad, Prabhakar
Add pm_runtime support to the TI Davinci VPIF driver. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-23[media] davinci: vpif: Fix module build for capture and displayLad, Prabhakar
export the symbols which are used by two modules vpif_capture and vpif_display. renamed "ch_params" to "vpif_ch_params" so as to avoid name collision. This patch fixes following error: ERROR: "ch_params" [drivers/media/platform/davinci/vpif_display.ko] undefined! ERROR: "vpif_ch_params_count" [drivers/media/platform/davinci/vpif_display.ko] undefined! ERROR: "vpif_base" [drivers/media/platform/davinci/vpif_display.ko] undefined! ERROR: "ch_params" [drivers/media/platform/davinci/vpif_capture.ko] undefined! ERROR: "vpif_ch_params_count" [drivers/media/platform/davinci/vpif_capture.ko] undefined! ERROR: "vpif_base" [drivers/media/platform/davinci/vpif_capture.ko] undefined! make[1]: *** [__modpost] Error 1 Reported-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-01-03Drivers: media: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21[media] media:davinci: clk - {prepare/unprepare} for common clkMurali Karicheri
As a first step towards migrating davinci platforms to use common clock framework, replace all instances of clk_enable() with clk_prepare_enable() and clk_disable() with clk_disable_unprepare(). Also fixes some issues related to clk clean up in the driver Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Lad, Prabhakar <prabhakar.lad@ti.com> Tested-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-26[media] vpif: replace preset with the timings APIHans Verkuil
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
