path: root/drivers/media/i2c/bt819.c
2013-06-17[media] bt819: fix querystdHans Verkuil
Return V4L2_STD_UNKNOWN if no signal is detected. Otherwise AND the standard mask with the detected standards. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-06-17[media] media/i2c: remove g_chip_ident opHans Verkuil
This is no longer needed since the core now handles this through DBG_G_CHIP_INFO. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-05-21[media] media: i2c: Convert to devm_kzalloc()Laurent Pinchart
Using the managed function the kfree() calls can be removed from the probe error path and the remove handler. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Move ancillary I2C drivers into drivers/media/i2c, in order to better organize them. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
