path: root/drivers/md
2006-01-12[PATCH] md: remove slashes from disk names when creation dev names in sysfsNeil Brown
e.g. The sx8 driver uses names like sx8/0. This would make a md component dev name like /sys/block/md0/md/dev-sx8/0 which is not allowed. So we change the '/' to '!' just like fs/partitions/check.c(register_disk) does. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dm: don't enable bouncing by defaultJens Axboe
DM doesn't need to bounce bio's on its own, but the block layer defaults to that in blk_queue_make_request(). The lower level drivers should bounce ios themselves, that is what they need to do if not layered below dm anyways. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Decrease number of pointer derefs in multipath.cJesper Juhl
Decrease the number of pointer derefs in drivers/md/multipath.c Benefits of the patch: - Fewer pointer dereferences should make the code slightly faster. - Size of generated code is smaller - improved readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Alasdair G Kergon <agk@redhat.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Add block_device_operations.getgeo block device methodChristoph Hellwig
HDIO_GETGEO is implemented in most block drivers, and all of them have to duplicate the code to copy the structure to userspace, as well as getting the start sector. This patch moves that to common code [1] and adds a ->getgeo method to fill out the raw kernel hd_geometry structure. For many drivers this means ->ioctl can go away now. [1] the s390 block drivers are odd in this respect. xpram sets ->start to 4 always which seems more than odd, and the dasd driver shifts the start offset around, probably because of it's non-standard sector size. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jens Axboe <axboe@suse.de> Cc: <mike.miller@hp.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow sync-speed to be controlled per-deviceNeilBrown
Also export current (average) speed and status in sysfs. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: support adding new devices to md arrays via sysfsNeilBrown
Writing major:minor to md/new_dev will bind that device to the array. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow available size of component devices to be set via sysfsNeilBrown
2006-01-06[PATCH] md-export-rdev-data_offset-via-sysfs-fixAndrew Morton
drivers/md/md.c: In function `offset_show': drivers/md/md.c:1670: warning: long long unsigned int format, different type arg (arg 3) Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: export rdev->data_offset via sysfsNeilBrown
2006-01-06[PATCH] md: expose device slot information via sysfsNeilBrown
This the role that a device has in an array can be viewed and set. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: keep better track of dev/array size when assembling md arraysNeilBrown
Move the checks - that dev size is never less than array size - into bind_rdev_to_array to make sure it always happens properly (there is one place where currently it doesn't). Also reject any superblock which claims an array size smaller than the device in question can hold. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow md/raid_disks to be settableNeilBrown
If array is active, try to reshape, else just set the value. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: count corrected read errors per driveNeilBrown
Store this total in superblock (As appropriate), and make it available to userspace via sysfs. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow array level to be set textually via sysfsNeilBrown
2006-01-06[PATCH] md: expose md metadata format in sysfsNeilBrown
Allow it to be set to a particular version, or 'none'. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow md array component size to be accessed and set via sysfsNeilBrown
2006-01-06[PATCH] md: allow chunk_size to be settable through sysfsNeilBrown
... only before array is started of course. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: fix rdev->pending counts in raid1NeilBrown
When we do a user-requested check/repair, we lose count of the outstanding requests... Also make sure that when anything is written to md/sync_action, the RECOVERY_NEEDED flag is set and the thread is woken up so any changes take effect. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: make sure bitmap updates are visible through filesystemNeilBrown
When we update a page_cache page in the kernel, we need to flush_dache_page or userspace might not see the change. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] drivers/md/md.c: make md_new_event() staticAdrian Bunk
Make the needlessly global function md_new_event() static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: make a couple of names in md.c staticNeilBrown
.. because they aren't used outside md.c Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: fix typo in commentNeilBrown
2006-01-06[PATCH] md: helper function to match commands written to sysfs filesNeilBrown
Commands written to sysfs files may, or my not, be \n terminated. We want to accept with case. For this we use cmd_match. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: define and use safe_put_page for mdNeilBrown
md sometimes call put_page on NULL pointers (treating it like kfree). This is not safe, so define and use a 'safe_put_page' which checks for NULL. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: remove inappropriate limits in md/bitmap configuration.NeilBrown
The kernel should not be imposing these policy limits: The time between bitmap updates should certainly be allowed to be more than 15 seconds, and if someone wants a bitmap chunk size in excess of 4MB, the kernel isn't the place to stop them. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: fix possible problem in raid1/raid10 error overwritingNeilBrown
The code to overwrite/reread for addressing read errors in raid1/raid10 currently assumes that the read will not alter the buffer which could be used to write to the next device. This is not a safe assumption to make. So we split the loops into a overwrite loop and a separate re-read loop, so that the writing is complete before reading is attempted. Cc: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: remove personality numbering from mdNeilBrown
md supports multiple different RAID level, each being implemented by a 'personality' (which is often in a separate module). These personalities have fairly artificial 'numbers'. The numbers are use to: 1- provide an index into an array where the various personalities are recorded 2- identify the module (via an alias) which implements are particular personality. Neither of these uses really justify the existence of personality numbers. The array can be replaced by a linked list which is searched (array lookup only happens very rarely). Module identification can be done using an alias based on level rather than 'personality' number. The current 'raid5' modules support two level (4 and 5) but only one personality. This slight awkwardness (which was handled in the mapping from level to personality) can be better handled by allowing raid5 to register 2 personalities. With this change in place, the core md module does not need to have an exhaustive list of all possible personalities, so other personalities can be added independently. This patch also moves the check for chunksize being non-zero into the ->run routines for the personalities that need it, rather than having it in core-md. This has a side effect of allowing 'faulty' and 'linear' not to have a chunk-size set. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: break out of a loop that doesn't need to run to completionNeilBrown
2006-01-06[PATCH] md: convert recently exported symbol to GPLNeilBrown
...because that seems to be the preferred practice these days. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: convert various kmap calls to kmap_atomicNeilBrown
2006-01-06[PATCH] md: tidy up raid5/6 hash table codeNeilBrown
- replace open-coded hash chain with hlist macros - Fix hash-table size at one page - it is already quite generous, so there will never be a need to use multiple pages, so no need for __get_free_pages No functional change. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: convert md to use kzalloc throughoutNeilBrown
Replace multiple kmalloc/memset pairs with kzalloc calls. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: clean up 'page' related names in mdNeilBrown
Substitute: page_cache_get -> get_page page_cache_release -> put_page PAGE_CACHE_SHIFT -> PAGE_SHIFT PAGE_CACHE_SIZE -> PAGE_SIZE PAGE_CACHE_MASK -> PAGE_MASK __free_page -> put_page because we aren't using the page cache, we are just using pages. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: make /proc/mdstat pollableNeilBrown
With this patch it is possible to poll /proc/mdstat to detect arrays appearing or disappearing, to detect failures, recovery starting, recovery completing, and devices being added and removed. It is similar to the poll-ability of /proc/mounts, though different in that: We always report that the file is readable (because face it, it is, even if only for EOF). We report POLLPRI when there is a change so that select() can detect it as an exceptional event. Not only are these exceptional events, but that is the mechanism that the current 'mdadm' uses to watch for events (It also polls after a timeout). (We also report POLLERR like /proc/mounts). Finally, we only reset the per-file event counter when the start of the file is read, rather than when poll() returns an event. This is more robust as it means that an fd will continue to report activity to poll/select until the program clearly responds to that activity. md_new_event takes an 'mddev' which isn't currently used, but it will be soon. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: raid10 read-error handling - resync and read-onlyNeilBrown
Add in correct read-error handling for resync and read-only situations. When read-only, we don't over-write, so we need to mark the failed drive in the r10_bio so we don't re-try it. During resync, we always read all blocks, so if there is a read error, we simply over-write it with the good block that we found (assuming we found one). Note that the recovery case still isn't handled in an interesting way. There is nothing useful to do for the 2-copies case. If there are 3 or more copies, then we could try reading from one of the non-missing copies, but this is a bit complicated and very rarely would be used, so I'm leaving it for now. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: auto-correct correctable read errors in raid10NeilBrown
Largely just a cross-port from raid1. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: make sure read error on last working drive of raid1 actually ↵NeilBrown
returns failure We are inadvertently setting the R1BIO_Uptodate bit on read errors when we decide not to try correcting (because there are no other working devices). This means that the read error is reported to the client as success. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow raid1 to check consistencyNeilBrown
Where performing a user-requested 'check' or 'repair', we read all readable devices, and compare the contents. We only write to blocks which had read errors, or blocks with content that differs from the first good device found. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: support check-without-repair of raid10 arraysNeilBrown
Also keep count on the number of errors found. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: fix up some rdev rcu locking in raid5/6NeilBrown
There is this "FIXME" comment with a typo in it!! that been annoying me for days, so I just had to remove it. conf->disks[i].rdev should only be accessed if - we know we hold a reference or - the mddev->reconfig_sem is down or - we have a rcu_readlock handle_stripe was referencing rdev in three places without any of these. For the first two, get an rcu_readlock. For the last, the same access (md_sync_acct call) is made a little later after the rdev has been claimed under and rcu_readlock, if R5_Syncio is set. So just use that access... However R5_Syncio isn't really needed as the 'syncing' variable contains the same information. So use that instead. Issues, comment, and fix are identical in raid5 and raid6. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: handle errors when read-onlyNeilBrown
2006-01-06[PATCH] md: better handling for read error in raid1 during resyncNeilBrown
Handling of read errors during resync is separate from handling of read errors during normal IO in raid1. A previous patch added support for read errors during normal IO. This one adds support for read errors during resync or recovery. The key differences are that we don't need to freeze the array, because the normal handling of resync means that this part of the array will be idle except for resync, and the read/overwrite/re-read is needed in a separate piece of code. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: tidyup some issues with raid1 resync and prepare for catching ↵NeilBrown
read errors We are dereferencing ->rdev without an rcu lock! Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: attempt to auto-correct read errors in raid1NeilBrown
On a read-error we suspend the array, then synchronously read the block from other arrays until we find one where we can read it. Then we try writing the good data back everywhere and make sure it works. If any write or subsequent read fails, only then do we fail the device out of the array. To be able to suspend the array, we need to also keep track of how many requests are queued for handling by raid1d. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: improve handing of read errors with raid6NeilBrown
This is a simple port of match functionality across from raid5. If we get a read error, we don't kick the drive straight away, but try to over-write with good data first. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: fix raid6 resync check/repair codeNeilBrown
raid6 currently does not check the P/Q syndromes when doing a resync, it just calculates the correct value and writes it. Doing the check can reduce writes (often to 0) for a resync, and it is needed to properly implement the echo check > sync_action operation. This patch implements the appropriate checks and tidies up some related code. It also allows raid6 user-requested resync to bypass the intent bitmap. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: write intent bitmap support for raid10NeilBrown
2006-01-06[PATCH] md: move bitmap_create to after md array has been initialisedNeilBrown
This is important because bitmap_create uses mddev->resync_max_sectors and that doesn't have a valid value until after the array has been initialised (with pers->run()). [It doesn't make a difference for current personalities that support bitmaps, but will make a difference for raid10] This has the added advantage of meaning with can move the thread->timeout manipulation inside the bitmap.c code instead of sprinkling identical code throughout all personalities. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
