path: root/drivers/md/raid5.c
2013-07-04md/raid5: allow 5-device RAID6 to be reshaped to 4-device.NeilBrown
There is a bug in 'check_reshape' for raid5.c To checks that the new minimum number of devices is large enough (which is good), but it does so also after the reshape has started (bad). This is bad because - the calculation is now wrong as mddev->raid_disks has changed already, and - it is pointless because it is now too late to stop. So only perform that test when reshape has not been committed to. Signed-off-by: NeilBrown <neilb@suse.de>
2013-06-14md: replace strict_strto*() with kstrto*()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-06-13Merge tag 'md-3.10-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull md bugfixes from Neil Brown: "A few bugfixes for md Some tagged for -stable" * tag 'md-3.10-fixes' of git://neil.brown.name/md: md/raid1,5,10: Disable WRITE SAME until a recovery strategy is in place md/raid1,raid10: use freeze_array in place of raise_barrier in various places. md/raid1: consider WRITE as successful only if at least one non-Faulty and non-rebuilding drive completed it. md: md_stop_writes() should always freeze recovery.
2013-06-13md/raid1,5,10: Disable WRITE SAME until a recovery strategy is in placeH. Peter Anvin
There are cases where the kernel will believe that the WRITE SAME command is supported by a block device which does not, in fact, support WRITE SAME. This currently happens for SATA drivers behind a SAS controller, but there are probably a hundred other ways that can happen, including drive firmware bugs. After receiving an error for WRITE SAME the block layer will retry the request as a plain write of zeroes, but mdraid will consider the failure as fatal and consider the drive failed. This has the effect that all the mirrors containing a specific set of data are each offlined in very rapid succession resulting in data loss. However, just bouncing the request back up to the block layer isn't ideal either, because the whole initial request-retry sequence should be inside the write bitmap fence, which probably means that md needs to do its own conversion of WRITE SAME to write zero. Until the failure scenario has been sorted out, disable WRITE SAME for raid1, raid5, and raid10. [neilb: added raid5] This patch is appropriate for any -stable since 3.7 when write_same support was added. Cc: stable@vger.kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-05-30raid5: Initialize bi_vcntKent Overstreet
The patch that converted raid5 to use bio_reset() forgot to initialize bi_vcnt. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: NeilBrown <neilb@suse.de> Cc: linux-raid@vger.kernel.org Tested-by: Ilia Mirkin <imirkin@alum.mit.edu> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-05-08Merge branch 'for-3.10/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core updates from Jens Axboe: - Major bit is Kents prep work for immutable bio vecs. - Stable candidate fix for a scheduling-while-atomic in the queue bypass operation. - Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging discard bios. - Tejuns changes to convert the writeback thread pool to the generic workqueue mechanism. - Runtime PM framework, SCSI patches exists on top of these in James' tree. - A few random fixes. * 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits) relay: move remove_buf_file inside relay_close_buf partitions/efi.c: replace useless kzalloc's by kmalloc's fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read() block: fix max discard sectors limit blkcg: fix "scheduling while atomic" in blk_queue_bypass_start Documentation: cfq-iosched: update documentation help for cfq tunables writeback: expose the bdi_wq workqueue writeback: replace custom worker pool implementation with unbound workqueue writeback: remove unused bdi_pending_list aoe: Fix unitialized var usage bio-integrity: Add explicit field for owner of bip_buf block: Add an explicit bio flag for bios that own their bvec block: Add bio_alloc_pages() block: Convert some code to bio_for_each_segment_all() block: Add bio_for_each_segment_all() bounce: Refactor __blk_queue_bounce to not use bi_io_vec raid1: use bio_copy_data() pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage pktcdvd: use bio_copy_data() block: Add bio_copy_data() ...
2013-04-24md/raid5: avoid an extra write when writing to a known-bad-block.NeilBrown
If we write to a known-bad-block it will be flags as having a ReadError by analyse_stripe, but the write will proceed anyway (as it should). Then the read-error handling will kick in an write again, then re-read. We don't need that 'write-again', so set R5_ReWrite so it looks like it has already been done. Then we will just get the re-read, which we want. Reported-by: majianpeng <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-04-24md/raid5: Change or of some order to improve efficiency.majianpeng
As the function call is the most expensive of these tests it should be done later in the chain so that it can be avoided in some cases. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-04-18Revert "block: add missing block_bio_complete() tracepoint"Linus Torvalds
This reverts commit 3a366e614d0837d9fc23f78cdb1a1186ebc3387f. Wanlong Gao reports that it causes a kernel panic on his machine several minutes after boot. Reverting it removes the panic. Jens says: "It's not quite clear why that is yet, so I think we should just revert the commit for 3.9 final (which I'm assuming is pretty close). The wifi is crap at the LSF hotel, so sending this email instead of queueing up a revert and pull request." Reported-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Requested-by: Jens Axboe <axboe@kernel.dk> Cc: Tejun Heo <tj@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-02Merge branch 'writeback-workqueue' of ↵Jens Axboe
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq into for-3.10/core Tejun writes: ----- This is the pull request for the earlier patchset[1] with the same name. It's only three patches (the first one was committed to workqueue tree) but the merge strategy is a bit involved due to the dependencies. * Because the conversion needs features from wq/for-3.10, block/for-3.10/core is based on rc3, and wq/for-3.10 has conflicts with rc3, I pulled mainline (rc5) into wq/for-3.10 to prevent those workqueue conflicts from flaring up in block tree. * Resolving the issue that Jan and Dave raised about debugging requires arch-wide changes. The patchset is being worked on[2] but it'll have to go through -mm after these changes show up in -next, and not included in this pull request. The three commits are located in the following git branch. git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq.git writeback-workqueue Pulling it into block/for-3.10/core produces a conflict in drivers/md/raid5.c between the following two commits. e3620a3ad5 ("MD RAID5: Avoid accessing gendisk or queue structs when not available") 2f6db2a707 ("raid5: use bio_reset()") The conflict is trivial - one removes an "if ()" conditional while the other removes "rbi->bi_next = NULL" right above it. We just need to remove both. The merged branch is available at git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq.git block-test-merge so that you can use it for verification. The test merge commit has proper merge description. While these changes are a bit of pain to route, they make code simpler and even have, while minute, measureable performance gain[3] even on a workload which isn't particularly favorable to showing the benefits of this conversion. ---- Fixed up the conflict. Conflicts: drivers/md/raid5.c Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-03-23Merge tag 'md-3.9-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull md fixes from NeilBrown: "A few bugfixes for md - recent regressions in raid5 - recent regressions in dmraid - a few instances of CONFIG_MULTICORE_RAID456 linger Several tagged for -stable" * tag 'md-3.9-fixes' of git://neil.brown.name/md: md: remove CONFIG_MULTICORE_RAID456 entirely md/raid5: ensure sync and DISCARD don't happen at the same time. MD: Prevent sysfs operations on uninitialized kobjects MD RAID5: Avoid accessing gendisk or queue structs when not available md/raid5: schedule_construction should abort if nothing to do.
2013-03-23raid5: use bio_reset()Kent Overstreet
Had to shuffle the code around a bit (where bi_rw and bi_end_io were set), but shouldn't really be anything tricky here Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de>
2013-03-23block: Use bio_sectors() more consistentlyKent Overstreet
Bunch of places in the code weren't using it where they could be - this'll reduce the size of the patch that puts bi_sector/bi_size/bi_idx into a struct bvec_iter. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: "Ed L. Cashin" <ecashin@coraid.com> CC: Nick Piggin <npiggin@kernel.dk> CC: Jiri Kosina <jkosina@suse.cz> CC: Jim Paris <jim@jtan.com> CC: Geoff Levand <geoff@infradead.org> CC: Alasdair Kergon <agk@redhat.com> CC: dm-devel@redhat.com CC: Neil Brown <neilb@suse.de> CC: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ed Cashin <ecashin@coraid.com>
2013-03-23block: Add bio_end_sector()Kent Overstreet
Just a little convenience macro - main reason to add it now is preparing for immutable bio vecs, it'll reduce the size of the patch that puts bi_sector/bi_size/bi_idx into a struct bvec_iter. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: Lars Ellenberg <drbd-dev@lists.linbit.com> CC: Jiri Kosina <jkosina@suse.cz> CC: Alasdair Kergon <agk@redhat.com> CC: dm-devel@redhat.com CC: Neil Brown <neilb@suse.de> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Heiko Carstens <heiko.carstens@de.ibm.com> CC: linux-s390@vger.kernel.org CC: Chris Mason <chris.mason@fusionio.com> CC: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com>
2013-03-20md/raid5: ensure sync and DISCARD don't happen at the same time.NeilBrown
A number of problems can occur due to races between resync/recovery and discard. - if sync_request calls handle_stripe() while a discard is happening on the stripe, it might call handle_stripe_clean_event before all of the individual discard requests have completed (so some devices are still locked, but not all). Since commit ca64cae96037de16e4af92678814f5d4bf0c1c65 md/raid5: Make sure we clear R5_Discard when discard is finished. this will cause R5_Discard to be cleared for the parity device, so handle_stripe_clean_event() will not be called when the other devices do become unlocked, so their ->written will not be cleared. This ultimately leads to a WARN_ON in init_stripe and a lock-up. - If handle_stripe_clean_event() does clear R5_UPTODATE at an awkward time for resync, it can lead to s->uptodate being less than disks in handle_parity_checks5(), which triggers a BUG (because it is one). So: - keep R5_Discard on the parity device until all other devices have completed their discard request - make sure we don't try to have a 'discard' and a 'sync' action at the same time. This involves a new stripe flag to we know when a 'discard' is happening, and the use of R5_Overlap on the parity disk so when a discard is wanted while a sync is active, so we know to wake up the discard at the appropriate time. Discard support for RAID5 was added in 3.7, so this is suitable for any -stable kernel since 3.7. Cc: stable@vger.kernel.org (v3.7+) Reported-by: Jes Sorensen <Jes.Sorensen@redhat.com> Tested-by: Jes Sorensen <Jes.Sorensen@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-03-20MD RAID5: Avoid accessing gendisk or queue structs when not availableJonathan Brassow
MD RAID5: Fix kernel oops when RAID4/5/6 is used via device-mapper Commit a9add5d (v3.8-rc1) added blktrace calls to the RAID4/5/6 driver. However, when device-mapper is used to create RAID4/5/6 arrays, the mddev->gendisk and mddev->queue fields are not setup. Therefore, calling things like trace_block_bio_remap will cause a kernel oops. This patch conditionalizes those calls on whether the proper fields exist to make the calls. (Device-mapper will call trace_block_bio_remap on its own.) This patch is suitable for the 3.8.y stable kernel. Cc: stable@vger.kernel.org (v3.8+) Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-03-20md/raid5: schedule_construction should abort if nothing to do.NeilBrown
Since commit 1ed850f356a0a422013846b5291acff08815008b md/raid5: make sure to_read and to_write never go negative. It has been possible for handle_stripe_dirtying to be called when there isn't actually any work to do. It then calls schedule_reconstruction() which will set R5_LOCKED on the parity block(s) even when nothing else is happening. This then causes problems in do_release_stripe(). So add checks to schedule_reconstruction() so that if it doesn't find anything to do, it just aborts. This bug was introduced in v3.7, so the patch is suitable for -stable kernels since then. Cc: stable@vger.kernel.org (v3.7+) Reported-by: majianpeng <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2013-03-05Merge tag 'md-3.9' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from NeilBrown: "Mostly little bugfixes. Only "feature" is a new RAID10 layout which slightly improves the number of sets of devices that can concurrently fail, without data loss." * tag 'md-3.9' of git://neil.brown.name/md: md: expedite metadata update when switching read-auto -> active md: remove CONFIG_MULTICORE_RAID456 md/raid1,raid10: fix deadlock with freeze_array() md/raid0: improve error message when converting RAID4-with-spares to RAID0 md: raid0: fix error return from create_stripe_zones. md: fix two bugs when attempting to resize RAID0 array. DM RAID: Add support for MD's RAID10 "far" and "offset" algorithms MD RAID10: Improve redundancy for 'far' and 'offset' algorithms (part 2) MD RAID10: Improve redundancy for 'far' and 'offset' algorithms (part 1) MD RAID10: Minor non-functional code changes md: raid1,10: Handle REQ_WRITE_SAME flag in write bios md: protect against crash upon fsync on ro array
2013-02-28Merge branch 'for-3.9/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO core bits from Jens Axboe: "Below are the core block IO bits for 3.9. It was delayed a few days since my workstation kept crashing every 2-8h after pulling it into current -git, but turns out it is a bug in the new pstate code (divide by zero, will report separately). In any case, it contains: - The big cfq/blkcg update from Tejun and and Vivek. - Additional block and writeback tracepoints from Tejun. - Improvement of the should sort (based on queues) logic in the plug flushing. - _io() variants of the wait_for_completion() interface, using io_schedule() instead of schedule() to contribute to io wait properly. - Various little fixes. You'll get two trivial merge conflicts, which should be easy enough to fix up" Fix up the trivial conflicts due to hlist traversal cleanups (commit b67bfe0d42ca: "hlist: drop the node parameter from iterators"). * 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits) block: remove redundant check to bd_openers() block: use i_size_write() in bd_set_size() cfq: fix lock imbalance with failed allocations drivers/block/swim3.c: fix null pointer dereference block: don't select PERCPU_RWSEM block: account iowait time when waiting for completion of IO request sched: add wait_for_completion_io[_timeout] writeback: add more tracepoints block: add block_{touch|dirty}_buffer tracepoint buffer: make touch_buffer() an exported function block: add @req to bio_{front|back}_merge tracepoints block: add missing block_bio_complete() tracepoint block: Remove should_sort judgement when flush blk_plug block,elevator: use new hashtable implementation cfq-iosched: add hierarchical cfq_group statistics cfq-iosched: collect stats from dead cfqgs cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats() blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock block: RCU free request_queue blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge() ...
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-28md: remove CONFIG_MULTICORE_RAID456NeilBrown
This doesn't seem to actually help and we have an alternate multi-threading approach waiting in the wings, so just get rid of this config option and associated code. As a bonus, we remove one use of CONFIG_EXPERIMENTAL Cc: Dan Williams <djbw@fb.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: NeilBrown <neilb@suse.de>
2013-01-14block: add missing block_bio_complete() tracepointTejun Heo
bio completion didn't kick block_bio_complete TP. Only dm was explicitly triggering the TP on IO completion. This makes block_bio_complete TP useless for tracers which want to know about bios, and all other bio based drivers skip generating blktrace completion events. This patch makes all bio completions via bio_endio() generate block_bio_complete TP. * Explicit trace_block_bio_complete() invocation removed from dm and the trace point is unexported. * @rq dropped from trace_block_bio_complete(). bios may fly around w/o queue associated. Verifying and accessing the assocaited queue belongs to TP probes. * blktrace now gets both request and bio completions. Make it ignore bio completions if request completion path is happening. This makes all bio based drivers generate blktrace completion events properly and makes the block_bio_complete TP actually useful. v2: With this change, block_bio_complete TP could be invoked on sg commands which have bio's with %NULL bi_bdev. Update TP assignment code to check whether bio->bi_bdev is %NULL before dereferencing. Signed-off-by: Tejun Heo <tj@kernel.org> Original-patch-by: Namhyung Kim <namhyung@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: dm-devel@redhat.com Cc: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-12-18Merge tag 'md-3.8' of git://neil.brown.name/mdLinus Torvalds
Pull md update from Neil Brown: "Mostly just little fixes. Probably biggest part is AVX accelerated RAID6 calculations." * tag 'md-3.8' of git://neil.brown.name/md: md/raid5: add blktrace calls md/raid5: use async_tx_quiesce() instead of open-coding it. md: Use ->curr_resync as last completed request when cleanly aborting resync. lib/raid6: build proper files on corresponding arch lib/raid6: Add AVX2 optimized gen_syndrome functions lib/raid6: Add AVX2 optimized recovery functions md: Update checkpoint of resync/recovery based on time. md:Add place to update ->recovery_cp. md.c: re-indent various 'switch' statements. md: close race between removing and adding a device. md: removed unused variable in calc_sb_1_csm.
2012-12-18md/raid5: add blktrace callsNeilBrown
This makes it easier to trace what raid5 is doing. Signed-off-by: NeilBrown <neilb@suse.de>
2012-12-17Merge branch 'for-3.8/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver update from Jens Axboe: "Now that the core bits are in, here are the driver bits for 3.8. The branch contains: - A huge pile of drbd bits that were dumped from the 3.7 merge window. Following that, it was both made perfectly clear that there is going to be no more over-the-wall pulls and how the situation on individual pulls can be improved. - A few cleanups from Akinobu Mita for drbd and cciss. - Queue improvement for loop from Lukas. This grew into adding a generic interface for waiting/checking an even with a specific lock, allowing this to be pulled out of md and now loop and drbd is also using it. - A few fixes for xen back/front block driver from Roger Pau Monne. - Partition improvements from Stephen Warren, allowing partiion UUID to be used as an identifier." * 'for-3.8/drivers' of git://git.kernel.dk/linux-block: (609 commits) drbd: update Kconfig to match current dependencies drbd: Fix drbdsetup wait-connect, wait-sync etc... commands drbd: close race between drbd_set_role and drbd_connect drbd: respect no-md-barriers setting also when changed online via disk-options drbd: Remove obsolete check drbd: fixup after wait_even_lock_irq() addition to generic code loop: Limit the number of requests in the bio list wait: add wait_event_lock_irq() interface xen-blkfront: free allocated page xen-blkback: move free persistent grants code block: partition: msdos: provide UUIDs for partitions init: reduce PARTUUID min length to 1 from 36 block: store partition_meta_info.uuid as a string cciss: use check_signature() cciss: cleanup bitops usage drbd: use copy_highpage drbd: if the replication link breaks during handshake, keep retrying drbd: check return of kmalloc in receive_uuids drbd: Broadcast sync progress no more often than once per second drbd: don't try to clear bits once the disk has failed ...
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-13md/raid5: use async_tx_quiesce() instead of open-coding it.NeilBrown
handle_stripe_expansion contains: if (tx) { async_tx_ack(tx); dma_wait_for_async_tx(tx); } which is very similar to the body of async_tx_quiesce(), except that the later handles an error from dma_wait_for_async_tx() (admittedly by panicing, but that decision belongs in the dma code, not the md code). So just us async_tx_quiesce(). Acked-by: Dan Williams <djbw@fb.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-11-30wait: add wait_event_lock_irq() interfaceLukas Czerner
New wait_event{_interruptible}_lock_irq{_cmd} macros added. This commit moves the private wait_event_lock_irq() macro from MD to regular wait includes, introduces new macro wait_event_lock_irq_cmd() instead of using the old method with omitting cmd parameter which is ugly and makes a use of new macros in the MD. It also introduces the _interruptible_ variant. The use of new interface is when one have a special lock to protect data structures used in the condition, or one also needs to invoke "cmd" before putting it to sleep. All new macros are expected to be called with the lock taken. The lock is released before sleep and is reacquired afterwards. We will leave the macro with the lock held. Note to DM: IMO this should also fix theoretical race on waitqueue while using simultaneously wait_event_lock_irq() and wait_event() because of lack of locking around current state setting and wait queue removal. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Neil Brown <neilb@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-22md/raid5: Make sure we clear R5_Discard when discard is finished.NeilBrown
commit 9e44476851e91c86c98eb92b9bc27fb801f89072 MD: raid5 avoid unnecessary zero page for trim change raid5 to clear R5_Discard when the complete request is handled rather than when submitting the per-device discard request. However it did not clear R5_Discard for the parity device. This means that if the stripe_head was reused before it expired from the cache, the setting would be wrong and a hang would result. Also if the R5_Uptodate bit happens to be set, R5_Discard again won't be cleared. But R5_Uptodate really should be clear at this point. So make sure R5_Discard is cleared in all cases, and clear R5_Uptodate when a 'discard' completes. Signed-off-by: NeilBrown <neilb@suse.de>
2012-11-22md/raid5: move resolving of reconstruct_state earlier inNeilBrown
stripe_handle. The chunk of code in stripe_handle which responds to a *_result value in reconstruct_state is really the completion of some processing that happened outside of handle_stripe (possibly asynchronously) and so should be one of the first things done in handle_stripe(). After the next patch it will be important that it happens before handle_stripe_clean_event(), as that will clear some dev->flags bit that this code tests. Signed-off-by: NeilBrown <neilb@suse.de>
2012-11-20md/raid5: round discard alignment up to power of 2.NeilBrown
blkdev_issue_discard currently assumes that the granularity is a power of 2. So in raid5, round the chosen number up to avoid embarrassment. Cc: Shaohua Li <shli@kernel.org> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-29md: Fix typo in drivers/mdMasanari Iida
Correct spelling typo in drivers/md. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-13Merge tag 'md-3.7' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from NeilBrown: - "discard" support, some dm-raid improvements and other assorted bits and pieces. * tag 'md-3.7' of git://neil.brown.name/md: (29 commits) md: refine reporting of resync/reshape delays. md/raid5: be careful not to resize_stripes too big. md: make sure manual changes to recovery checkpoint are saved. md/raid10: use correct limit variable md: writing to sync_action should clear the read-auto state. Subject: [PATCH] md:change resync_mismatches to atomic64_t to avoid races md/raid5: make sure to_read and to_write never go negative. md: When RAID5 is dirty, force reconstruct-write instead of read-modify-write. md/raid5: protect debug message against NULL derefernce. md/raid5: add some missing locking in handle_failed_stripe. MD: raid5 avoid unnecessary zero page for trim MD: raid5 trim support md/bitmap:Don't use IS_ERR to judge alloc_page(). md/raid1: Don't release reference to device while handling read error. raid: replace list_for_each_continue_rcu with new interface add further __init annotations to crypto/xor.c DM RAID: Fix for "sync" directive ineffectiveness DM RAID: Fix comparison of index and quantity for "rebuild" parameter DM RAID: Add rebuild capability for RAID10 DM RAID: Move 'rebuild' checking code to its own function ...
2012-10-11md/raid5: be careful not to resize_stripes too big.NeilBrown
When a RAID5 is reshaping, conf->raid_disks is increased before mddev->delta_disks becomes zero. This can result in check_reshape calling resize_stripes with a number that is too large. This particularly happens when md_check_recovery calls ->check_reshape(). If we use ->previous_raid_disks, we don't risk this. Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11Subject: [PATCH] md:change resync_mismatches to atomic64_t to avoid racesJianpeng Ma
Now that multiple threads can handle stripes, it is safer to use an atomic64_t for resync_mismatches, to avoid update races. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11md/raid5: make sure to_read and to_write never go negative.NeilBrown
to_read and to_write are part of the result of analysing a stripe before handling it. Their use is to avoid some loops and tests if the values are known to be zero. Thus it is not a problem if they are a little bit larger than they should be. So decrementing them in handle_failed_stripe serves little value, and due to races it could cause some loops to be skipped incorrectly. So remove those decrements. Reported-by: "Jianpeng Ma" <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11md: When RAID5 is dirty, force reconstruct-write instead of read-modify-write.Alexander Lyakas
Signed-off-by: Alex Lyakas <alex@zadarastorage.com> Suggested-by: Yair Hershko <yair@zadarastorage.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11md/raid5: protect debug message against NULL derefernce.NeilBrown
The pr_debug in add_stripe_bio could race with something changing *bip, so it is best to hold the lock until after the pr_debug. Reported-by: "Jianpeng Ma" <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11md/raid5: add some missing locking in handle_failed_stripe.NeilBrown
We really should hold the stripe_lock while accessing 'toread' else we could race with add_stripe_bio and corrupt a list. Reported-by: "Jianpeng Ma" <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11MD: raid5 avoid unnecessary zero page for trimShaohua Li
We want to avoid zero discarded dev page, because it's useless for discard. But if we don't zero it, another read/write hit such page in the cache and will get inconsistent data. To avoid zero the page, we don't set R5_UPTODATE flag after construction is done. In this way, discard write request is still issued and finished, but read will not hit the page. If the stripe gets accessed soon, we need reread the stripe, but since the chance is low, the reread isn't a big deal. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11MD: raid5 trim supportShaohua Li
Discard for raid4/5/6 has limitation. If discard request size is small, we do discard for one disk, but we need calculate parity and write parity disk. To correctly calculate parity, zero_after_discard must be guaranteed. Even it's true, we need do discard for one disk but write another disks, which makes the parity disks wear out fast. This doesn't make sense. So an efficient discard for raid4/5/6 should discard all data disks and parity disks, which requires the write pattern to be (A, A+chunk_size, A+chunk_size*2...). If A's size is smaller than chunk_size, such pattern is almost impossible in practice. So in this patch, I only handle the case that A's size equals to chunk_size. That is discard request should be aligned to stripe size and its size is multiple of stripe size. Since we can only handle request with specific alignment and size (or part of the request fitting stripes), we can't guarantee zero_after_discard even zero_after_discard is true in low level drives. The block layer doesn't send down correctly aligned requests even correct discard alignment is set, so I must filter out. For raid4/5/6 parity calculation, if data is 0, parity is 0. So if zero_after_discard is true for all disks, data is consistent after discard. Otherwise, data might be lost. Let's consider a scenario: discard a stripe, write data to one disk and write parity disk. The stripe could be still inconsistent till then depending on using data from other data disks or parity disks to calculate new parity. If the disk is broken, we can't restore it. So in this patch, we only enable discard support if all disks have zero_after_discard. If discard fails in one disk, we face the similar inconsistent issue above. The patch will make discard follow the same path as normal write request. If discard fails, a resync will be scheduled to make the data consistent. This isn't good to have extra writes, but data consistency is important. If a subsequent read/write request hits raid5 cache of a discarded stripe, the discarded dev page should have zero filled, so the data is consistent. This patch will always zero dev page for discarded request stripe. This isn't optimal because discard request doesn't need such payload. Next patch will avoid it. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-11MD: change the parameter of md threadShaohua Li
Change the thread parameter, so the thread can carry extra info. Next patch will use it. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-09-24md/raid5: add missing spin_lock_init.NeilBrown
commit b17459c05000fdbe8d10946570a26510f86ec0f raid5: add a per-stripe lock added a spin_lock to the 'stripe_head' struct. Unfortunately there are two places where this struct is allocated but the spin lock was only initialised in one of them. So add the missing spin_lock_init. Signed-off-by: NeilBrown <neilb@suse.de>
2012-09-19md/raid5: fix calculate of 'degraded' when a replacement becomes active.NeilBrown
When a replacement device becomes active, we mark the device that it replaces as 'faulty' so that it can subsequently get removed. However 'calc_degraded' only pays attention to the primary device, not the replacement, so the array appears to become degraded, which is wrong. So teach 'calc_degraded' to consider any replacement if a primary device is faulty. This is suitable for -stable as an incorrect 'degraded' value can confuse md and could lead to data corruption. This is only relevant for 3.3 and later. Cc: stable@vger.kernel.org Reported-by: Robin Hill <robin@robinhill.me.uk> Reported-by: John Drescher <drescherjm@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-09-19Revert "md/raid5: For odirect-write performance, do not set ↵NeilBrown
STRIPE_PREREAD_ACTIVE." This reverts commit 895e3c5c58a80bb9e4e05d9ac38b4f30e0f97d80. While this patch seemed like a good idea and did help some workloads, it hurts other workloads. Large sequential O_DIRECT writes were faster, Small random O_DIRECT writes were slower. Other changes (batching RAID5 writes) have improved the sequential writes using a different mechanism, so the net result of this patch is definitely negative. So revert it. Reported-by: Shaohua Li <shli@kernel.org> Tested-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-08-02Merge tag 'md-3.6' of git://neil.brown.name/mdLinus Torvalds
Pull additional md update from NeilBrown: "This contains a few patches that depend on plugging changes in the block layer so needed to wait for those. It also contains a Kconfig fix for the new RAID10 support in dm-raid." * tag 'md-3.6' of git://neil.brown.name/md: md/dm-raid: DM_RAID should select MD_RAID10 md/raid1: submit IO from originating thread instead of md thread. raid5: raid5d handle stripe in batch way raid5: make_request use batch stripe release
2012-08-02raid5: raid5d handle stripe in batch wayShaohua Li
Let raid5d handle stripe in batch way to reduce conf->device_lock locking. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-08-02raid5: make_request use batch stripe releaseShaohua Li
make_request() does stripe release for every stripe and the stripe usually has count 1, which makes previous release_stripe() optimization not work. In my test, this release_stripe() becomes the heaviest pleace to take conf->device_lock after previous patches applied. Below patch makes stripe release batch. All the stripes will be released in unplug. The STRIPE_ON_UNPLUG_LIST bit is to protect concurrent access stripe lru. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-08-01Merge branch 'for-3.6/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver changes from Jens Axboe: - Making the plugging support for drivers a bit more sane from Neil. This supersedes the plugging change from Shaohua as well. - The usual round of drbd updates. - Using a tail add instead of a head add in the request completion for ndb, making us find the most completed request more quickly. - A few floppy changes, getting rid of a duplicated flag and also running the floppy init async (since it takes forever in boot terms) from Andi. * 'for-3.6/drivers' of git://git.kernel.dk/linux-block: floppy: remove duplicated flag FD_RAW_NEED_DISK blk: pass from_schedule to non-request unplug functions. block: stack unplug blk: centralize non-request unplug handling. md: remove plug_cnt feature of plugging. block/nbd: micro-optimization in nbd request completion drbd: announce FLUSH/FUA capability to upper layers drbd: fix max_bio_size to be unsigned drbd: flush drbd work queue before invalidate/invalidate remote drbd: fix potential access after free drbd: call local-io-error handler early drbd: do not reset rs_pending_cnt too early drbd: reset congestion information before reporting it in /proc/drbd drbd: report congestion if we are waiting for some userland callback drbd: differentiate between normal and forced detach drbd: cleanup, remove two unused global flags floppy: Run floppy initialization asynchronous
2012-07-31md: remove plug_cnt feature of plugging.NeilBrown
This seemed like a good idea at the time, but after further thought I cannot see it making a difference other than very occasionally and testing to try to exercise the case it is most likely to help did not show any performance difference by removing it. So remove the counting of active plugs and allow 'pending writes' to be activated at any time, not just when no plugs are active. This is only relevant when there is a write-intent bitmap, and the updating of the bitmap will likely introduce enough delay that the single-threading of bitmap updates will be enough to collect large numbers of updates together. Removing this will make it easier to centralise the unplug code, and will clear the other for other unplug enhancements which have a measurable effect. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
