path: root/drivers/md/raid10.c
2009-02-25md: avoid races when stopping resync.NeilBrown
There has been a race in raid10 and raid1 for a long time which has only recently started showing up due to a scheduler changed. When a sync_read request finishes, as soon as reschedule_retry is called, another thread can mark the resync request as having completed, so md_do_sync can finish, ->stop can be called, and ->conf can be freed. So using conf after reschedule_retry is not safe. Similarly, when finishing a sync_write, calling md_done_sync must be the last thing we do, as it allows a chain of events which will free conf and other data structures. The first of these requires action in raid10.c The second requires action in raid1.c and raid10.c Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2009-02-25md/raid10: Don't call bitmap_cond_end_sync when we are doing recovery.NeilBrown
For raid1/4/5/6, resync (fixing inconsistencies between devices) is very similar to recovery (rebuilding a failed device onto a spare). The both walk through the device addresses in order. For raid10 it can be quite different. resync follows the 'array' address, and makes sure all copies are the same. Recover walks through 'device' addresses and recreates each missing block. The 'bitmap_cond_end_sync' function allows the write-intent-bitmap (When present) to be updated to reflect a partially completed resync. It makes assumptions which mean that it does not work correctly for raid10 recovery at all. In particularly, it can cause bitmap-directed recovery of a raid10 to not recovery some of the blocks that need to be recovered. So move the call to bitmap_cond_end_sync into the resync path, rather than being in the common "resync or recovery" path. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2009-02-25md/raid10: Don't skip more than 1 bitmap-chunk at a time during recovery.NeilBrown
When doing recovery on a raid10 with a write-intent bitmap, we only need to recovery chunks that are flagged in the bitmap. However if we choose to skip a chunk as it isn't flag, the code currently skips the whole raid10-chunk, thus it might not recovery some blocks that need recovering. This patch fixes it. In case that is confusing, it might help to understand that there is a 'raid10 chunk size' which guides how data is distributed across the devices, and a 'bitmap chunk size' which says how much data corresponds to a single bit in the bitmap. This bug only affects cases where the bitmap chunk size is smaller than the raid10 chunk size. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2009-01-09md: use list_for_each_entry macro directlyCheng Renquan
The rdev_for_each macro defined in <linux/raid/md_k.h> is identical to list_for_each_entry_safe, from <linux/list.h>, it should be defined to use list_for_each_entry_safe, instead of reinventing the wheel. But some calls to each_entry_safe don't really need a safe version, just a direct list_for_each_entry is enough, this could save a temp variable (tmp) in every function that used rdev_for_each. In this patch, most rdev_for_each loops are replaced by list_for_each_entry, totally save many tmp vars; and only in the other situations that will call list_del to delete an entry, the safe version is used. Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2008-11-06md: fix bug in raid10 recovery.NeilBrown
Adding a spare to a raid10 doesn't cause recovery to start. This is due to an silly type in commit 6c2fce2ef6b4821c21b5c42c7207cb9cf8c87eda and so is a bug in 2.6.27 and .28-rc. Thanks to Thomas Backlund for bisecting to find this. Cc: Thomas Backlund <tmb@mandriva.org> Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2008-10-15md: build failure due to missing delay.hStephen Rothwell
Today's linux-next build (powerpc ppc64_defconfig) failed like this: drivers/md/raid1.c: In function 'sync_request': drivers/md/raid1.c:1759: error: implicit declaration of function 'msleep_interruptible' make[3]: *** [drivers/md/raid1.o] Error 1 make[3]: *** Waiting for unfinished jobs.... drivers/md/raid10.c: In function 'sync_request': drivers/md/raid10.c:1749: error: implicit declaration of function 'msleep_interruptible' make[3]: *** [drivers/md/raid10.o] Error 1 drivers/md/md.c: In function 'md_do_sync': drivers/md/md.c:5915: error: implicit declaration of function 'msleep' Caused by commit 6caa3b0bbdb474647f6bdd8a958ffc46f78d8d58 ("md: Remove unnecessary #includes, #defines, and function declarations"). I added the following patch. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: NeilBrown <neilb@suse.de>
2008-10-13md: Relax minimum size restrictions on chunk_size.NeilBrown
Currently, the 'chunk_size' of an array must be at-least PAGE_SIZE. This makes moving an array to a machine with a larger PAGE_SIZE, or changing the kernel to use a larger PAGE_SIZE, can stop an array from working. For RAID10 and RAID4/5/6, this is non-trivial to fix as the resync process works on whole pages at a time, and assumes them to be wholly within a stripe. For other raid personalities, this restriction is not needed at all and can be dropped. So remove the test on chunk_size from common can, and add it in just the places where it is needed: raid10 and raid4/5/6. Signed-off-by: NeilBrown <neilb@suse.de>
2008-10-09block: mark bio_split_pool staticDenis ChengRq
Since all bio_split calls refer the same single bio_split_pool, the bio_split function can use bio_split_pool directly instead of the mempool_t parameter; then the mempool_t parameter can be removed from bio_split param list, and bio_split_pool is only referred in fs/bio.c file, can be marked static. Signed-off-by: Denis ChengRq <crquan@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: move stats from disk to part0Tejun Heo
Move stats related fields - stamp, in_flight, dkstats - from disk to part0 and unify stat handling such that... * part_stat_*() now updates part0 together if the specified partition is not part0. ie. part_stat_*() are now essentially all_stat_*(). * {disk|all}_stat_*() are gone. * part_round_stats() is updated similary. It handles part0 stats automatically and disk_round_stats() is killed. * part_{inc|dec}_in_fligh() is implemented which automatically updates part0 stats for parts other than part0. * disk_map_sector_rcu() is updated to return part0 if no part matches. Combined with the above changes, this makes NULL special case handling in callers unnecessary. * Separate stats show code paths for disk are collapsed into part stats show code paths. * Rename disk_stat_lock/unlock() to part_stat_lock/unlock() While at it, reposition stat handling macros a bit and add missing parentheses around macro parameters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix diskstats accessTejun Heo
There are two variants of stat functions - ones prefixed with double underbars which don't care about preemption and ones without which disable preemption before manipulating per-cpu counters. It's unclear whether the underbarred ones assume that preemtion is disabled on entry as some callers don't do that. This patch unifies diskstats access by implementing disk_stat_lock() and disk_stat_unlock() which take care of both RCU (for partition access) and preemption (for per-cpu counter access). diskstats access should always be enclosed between the two functions. As such, there's no need for the versions which disables preemption. They're removed and double underbars ones are renamed to drop the underbars. As an extra argument is added, there's no danger of using the old version unconverted. disk_stat_lock() uses get_cpu() and returns the cpu index and all diskstat functions which access per-cpu counters now has @cpu argument to help RT. This change adds RCU or preemption operations at some places but also collapses several preemption ops into one at others. Overall, the performance difference should be negligible as all involved ops are very lightweight per-cpu ones. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: raid fixups for removal of bi_hw_segmentsJens Axboe
2008-10-09drop vmerge accountingMikulas Patocka
Remove hw_segments field from struct bio and struct request. Without virtual merge accounting they have no purpose. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-05Allow raid10 resync to happening in larger chunks.NeilBrown
The raid10 resync/recovery code currently limits the amount of in-flight resync IO to 2Meg. This was copied from raid1 where it seems quite adequate. However for raid10, some layouts require a bit of seeking to perform a resync, and allowing a larger buffer size means that the seeking can be significantly reduced. There is probably no real need to limit the amount of in-flight IO at all. Any shortage of memory will naturally reduce the amount of buffer space available down to a set minimum, and any concurrent normal IO will quickly cause resync IO to back off. The only problem would be that normal IO has to wait for all resync IO to finish, so a very large amount of resync IO could cause unpleasant latency when normal IO starts up. So: increase RESYNC_DEPTH to allow 32Meg of buffer (if memory is available) which seems to be a good amount. Also reduce the amount of memory reserved as there is no need to keep 2Meg just for resync if memory is tight. Thanks to Keld for the suggestion. Cc: Keld Jørn Simonsen <keld@dkuug.dk> Signed-off-by: NeilBrown <neilb@suse.de>
2008-08-01Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: raid10: wake up frozen array md: do not count blocked devices as spares md: do not progress the resync process if the stripe was blocked md: delay notification of 'active_idle' to the recovery thread md: fix merge error md: move async_tx_issue_pending_all outside spin_lock_irq
2008-08-01md: raid10: wake up frozen arrayArthur Jones
When rescheduling a bio in raid10, we wake up the md thread, but if the array is frozen, this will have no effect. This causes the array to remain frozen for eternity. We add a wake_up to allow the array to de-freeze. This code is nearly identical to the raid1 code, which has this fix already. Signed-off-by: Arthur Jones <ajones@riverbed.com> Signed-off-by: NeilBrown <neilb@suse.de>
2008-07-21Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (52 commits) md: Protect access to mddev->disks list using RCU md: only count actual openers as access which prevent a 'stop' md: linear: Make array_size sector-based and rename it to array_sectors. md: Make mddev->array_size sector-based. md: Make super_type->rdev_size_change() take sector-based sizes. md: Fix check for overlapping devices. md: Tidy up rdev_size_store a bit: md: Remove some unused macros. md: Turn rdev->sb_offset into a sector-based quantity. md: Make calc_dev_sboffset() return a sector count. md: Replace calc_dev_size() by calc_num_sectors(). md: Make update_size() take the number of sectors. md: Better control of when do_md_stop is allowed to stop the array. md: get_disk_info(): Don't convert between signed and unsigned and back. md: Simplify restart_array(). md: alloc_disk_sb(): Return proper error value. md: Simplify sb_equal(). md: Simplify uuid_equal(). md: sb_equal(): Fix misleading printk. md: Fix a typo in the comment to cmd_match(). ...
2008-07-21md: Make mddev->array_size sector-based.Andre Noll
This patch renames the array_size field of struct mddev_s to array_sectors and converts all instances to use units of 512 byte sectors instead of 1k blocks. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2008-07-03Add bvec_merge_data to handle stacked devices and ->merge_bvec()Alasdair G Kergon
When devices are stacked, one device's merge_bvec_fn may need to perform the mapping and then call one or more functions for its underlying devices. The following bio fields are used: bio->bi_sector bio->bi_bdev bio->bi_size bio->bi_rw using bio_data_dir() This patch creates a new struct bvec_merge_data holding a copy of those fields to avoid having to change them directly in the struct bio when going down the stack only to have to change them back again on the way back up. (And then when the bio gets mapped for real, the whole exercise gets repeated, but that's a problem for another day...) Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Neil Brown <neilb@suse.de> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-28rationalise return value for ->hot_add_disk method.Neil Brown
For all array types but linear, ->hot_add_disk returns 1 on success, 0 on failure. For linear, it returns 0 on success and -errno on failure. This doesn't cause a functional problem because the ->hot_add_disk function of linear is used quite differently to the others. However it is confusing. So convert all to return 0 for success or -errno on failure and fix call sites to match. Signed-off-by: Neil Brown <neilb@suse.de>
2008-06-28Support adding a spare to a live md array with external metadata.Neil Brown
i.e. extend the 'md/dev-XXX/slot' attribute so that you can tell a device to fill an vacant slot in an and md array. Signed-off-by: Neil Brown <neilb@suse.de>
2008-06-28Ensure interrupted recovery completed properly (v1 metadata plus bitmap)Neil Brown
If, while assembling an array, we find a device which is not fully in-sync with the array, it is important to set the "fullsync" flags. This is an exact analog to the setting of this flag in hot_add_disk methods. Currently, only v1.x metadata supports having devices in an array which are not fully in-sync (it keep track of how in sync they are). The 'fullsync' flag only makes a difference when a write-intent bitmap is being used. In this case it tells recovery to ignore the bitmap and recovery all blocks. This fix is already in place for raid1, but not raid5/6 or raid10. So without this fix, a raid1 ir raid4/5/6 array with version 1.x metadata and a write intent bitmaps, that is stopped in the middle of a recovery, will appear to complete the recovery instantly after it is reassembled, but the recovery will not be correct. If you might have an array like that, issueing echo repair > /sys/block/mdXX/md/sync_action will make sure recovery completes properly. Cc: <stable@kernel.org> Signed-off-by: Neil Brown <neilb@suse.de>
2008-05-24md: restart recovery cleanly after device failure.NeilBrown
When we get any IO error during a recovery (rebuilding a spare), we abort the recovery and restart it. For RAID6 (and multi-drive RAID1) it may not be best to restart at the beginning: when multiple failures can be tolerated, the recovery may be able to continue and re-doing all that has already been done doesn't make sense. We already have the infrastructure to record where a recovery is up to and restart from there, but it is not being used properly. This is because: - We sometimes abort with MD_RECOVERY_ERR rather than just MD_RECOVERY_INTR, which causes the recovery not be be checkpointed. - We remove spares and then re-added them which loses important state information. The distinction between MD_RECOVERY_ERR and MD_RECOVERY_INTR really isn't needed. If there is an error, the relevant drive will be marked as Faulty, and that is enough to ensure correct handling of the error. So we first remove MD_RECOVERY_ERR, changing some of the uses of it to MD_RECOVERY_INTR. Then we cause the attempt to remove a non-faulty device from an array to fail (unless recovery is impossible as the array is too degraded). Then when remove_and_add_spares attempts to remove the devices on which recovery can continue, it will fail, they will remain in place, and recovery will continue on them as desired. Issue: If we are halfway through rebuilding a spare and another drive fails, and a new spare is immediately available, do we want to: 1/ complete the current rebuild, then go back and rebuild the new spare or 2/ restart the rebuild from the start and rebuild both devices in parallel. Both options can be argued for. The code currently takes option 2 as a/ this requires least code change b/ this results in a minimally-degraded array in minimal time. Cc: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14Remove blkdev warning triggered by using mdNeil Brown
As setting and clearing queue flags now requires that we hold a spinlock on the queue, and as blk_queue_stack_limits is called without that lock, get the lock inside blk_queue_stack_limits. For blk_queue_stack_limits to be able to find the right lock, each md personality needs to set q->queue_lock to point to the appropriate lock. Those personalities which didn't previously use a spin_lock, us q->__queue_lock. So always initialise that lock when allocated. With this in place, setting/clearing of the QUEUE_FLAG_PLUGGED bit will no longer cause warnings as it will be clear that the proper lock is held. Thanks to Dan Williams for review and fixing the silly bugs. Signed-off-by: NeilBrown <neilb@suse.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Jacek Luczak <difrost.kernel@gmail.com> Cc: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08misc: fix integer as NULL pointer warningsHarvey Harrison
drivers/md/raid10.c:889:17: warning: Using plain integer as NULL pointer drivers/media/video/cx18/cx18-driver.c:616:12: warning: Using plain integer as NULL pointer sound/oss/kahlua.c:70:12: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30md: support blocking writes to an array on device failureDan Williams
Allows a userspace metadata handler to take action upon detecting a device failure. Based on an original patch by Neil Brown. Changes: -added blocked_wait waitqueue to rdev -don't qualify Blocked with Faulty always let userspace block writes -added md_wait_for_blocked_rdev to wait for the block device to be clear, if userspace misses the notification another one is sent every 5 seconds -set MD_RECOVERY_NEEDED after clearing "blocked" -kill DoBlock flag, just test mddev->external Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28raid: remove leading TAB on printk messagesNick Andrew
MD drivers use one printk() call to print 2 log messages and the second line may be prefixed by a TAB character. It may also output a trailing space before newline. klogd (I think) turns the TAB character into the 2 characters '^I' when logging to a file. This looks ugly. Instead of a leading TAB to indicate continuation, prefix both output lines with 'raid:' or similar. Also remove any trailing space in the vicinity of the affected code and consistently end the sentences with a period. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04md: the md RAID10 resync thread could cause a md RAID10 array deadlockK.Tanaka
This message describes another issue about md RAID10 found by testing the 2.6.24 md RAID10 using new scsi fault injection framework. Abstract: When a scsi error results in disabling a disk during RAID10 recovery, the resync threads of md RAID10 could stall. This case, the raid array has already been broken and it may not matter. But I think stall is not preferable. If it occurs, even shutdown or reboot will fail because of resource busy. The deadlock mechanism: The r10bio_s structure has a "remaining" member to keep track of BIOs yet to be handled when recovering. The "remaining" counter is incremented when building a BIO in sync_request() and is decremented when finish a BIO in end_sync_write(). If building a BIO fails for some reasons in sync_request(), the "remaining" should be decremented if it has already been incremented. I found a case where this decrement is forgotten. This causes a md_do_sync() deadlock because md_do_sync() waits for md_done_sync() called by end_sync_write(), but end_sync_write() never calls md_done_sync() because of the "remaining" counter mismatch. For example, this problem would be reproduced in the following case: Personalities : [raid10] md0 : active raid10 sdf1[4] sde1[5](F) sdd1[2] sdc1[1] sdb1[6](F) 3919616 blocks 64K chunks 2 near-copies [4/2] [_UU_] [>....................] recovery = 2.2% (45376/1959808) finish=0.7min speed=45376K/sec This case, sdf1 is recovering, sdb1 and sde1 are disabled. An additional error with detaching sdd will cause a deadlock. md0 : active raid10 sdf1[4] sde1[5](F) sdd1[6](F) sdc1[1] sdb1[7](F) 3919616 blocks 64K chunks 2 near-copies [4/1] [_U__] [=>...................] recovery = 5.0% (99520/1959808) finish=5.9min speed=5237K/sec 2739 ? S< 0:17 [md0_raid10] 28608 ? D< 0:00 [md0_resync] 28629 pts/1 Ss 0:00 bash 28830 pts/1 R+ 0:00 ps ax 31819 ? D< 0:00 [kjournald] The resync thread keeps working, but actually it is deadlocked. Patch: By this patch, the remaining counter will be decremented if needed. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04md: fix possible raid1/raid10 deadlock on read error during resyncNeilBrown
Thanks to K.Tanaka and the scsi fault injection framework, here is a fix for another possible deadlock in raid1/raid10 error handing. If a read request returns an error while a resync is happening and a resync request is pending, the attempt to fix the error will block until the resync progresses, and the resync will block until the read request completes. Thus a deadlock. This patch fixes the problem. Cc: "K.Tanaka" <k-tanaka@ce.jp.nec.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04md: don't attempt read-balancing for raid10 'far' layoutsKeld Simonsen
This patch changes the disk to be read for layout "far > 1" to always be the disk with the lowest block address. Thus the chunks to be read will always be (for a fully functioning array) from the first band of stripes, and the raid will then work as a raid0 consisting of the first band of stripes. Some advantages: The fastest part which is the outer sectors of the disks involved will be used. The outer blocks of a disk may be as much as 100 % faster than the inner blocks. Average seek time will be smaller, as seeks will always be confined to the first part of the disks. Mixed disks with different performance characteristics will work better, as they will work as raid0, the sequential read rate will be number of disks involved times the IO rate of the slowest disk. If a disk is malfunctioning, the first disk which is working, and has the lowest block address for the logical block will be used. Signed-off-by: Keld Simonsen <keld@dkuug.dk> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04md: fix deadlock in md/raid1 and md/raid10 when handling a read errorNeilBrown
When handling a read error, we freeze the array to stop any other IO while attempting to over-write with correct data. This is done in the raid1d(raid10d) thread and must wait for all submitted IO to complete (except for requests that failed and are sitting in the retry queue - these are counted in ->nr_queue and will stay there during a freeze). However write requests need attention from raid1d as bitmap updates might be required. This can cause a deadlock as raid1 is waiting for requests to finish that themselves need attention from raid1d. So we create a new function 'flush_pending_writes' to give that attention, and call it in freeze_array to be sure that we aren't waiting on raid1d. Thanks to "K.Tanaka" <k-tanaka@ce.jp.nec.com> for finding and reporting this problem. Cc: "K.Tanaka" <k-tanaka@ce.jp.nec.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: change ITERATE_RDEV to rdev_for_eachNeilBrown
As this is more in line with common practice in the kernel. Also swap the args around to be more like list_for_each. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: allow a maximum extent to be set for resyncingNeilBrown
This allows userspace to control resync/reshape progress and synchronise it with other activities, such as shared access in a SAN, or backing up critical sections during a tricky reshape. Writing a number of sectors (which must be a multiple of the chunk size if such is meaningful) causes a resync to pause when it gets to that point. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: Update md bitmap during resync.NeilBrown
Currently an md array with a write-intent bitmap does not updated that bitmap to reflect successful partial resync. Rather the entire bitmap is updated when the resync completes. This is because there is no guarentee that resync requests will complete in order, and tracking each request individually is unnecessarily burdensome. However there is value in regularly updating the bitmap, so add code to periodically pause while all pending sync requests complete, then update the bitmap. Doing this only every few seconds (the same as the bitmap update time) does not notciably affect resync performance. [snitzer@gmail.com: export bitmap_cond_end_sync] Signed-off-by: Neil Brown <neilb@suse.de> Cc: "Mike Snitzer" <snitzer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-09Add UNPLUG traces to all appropriate placesAlan D. Brunelle
Added blk_unplug interface, allowing all invocations of unplugs to result in a generated blktrace UNPLUG. Signed-off-by: Alan D. Brunelle <Alan.Brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16block: convert blkdev_issue_flush() to use empty barriersJens Axboe
Then we can get rid of ->issue_flush_fn() and all the driver private implementations of that. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-31md: handle writes to broken raid10 arrays gracefullyArne Redlich
When writing to a broken array, raid10 currently happily emits empty bio lists. IOW, the master bio will never be completed, sending writers to UNINTERRUPTIBLE_SLEEP forever. Signed-off-by: Arne Redlich <agr@powerkom-dd.de> Acked-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31md: raid10: fix use-after-free of bioMaik Hampel
In case of read errors raid10d tries to print a nice error message, unfortunately using data from an already put bio. Signed-off-by: Maik Hampel <m.hampel@gmx.de> Acked-By: NeilBrown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-17md: change bitmap_unplug and others to void functionsNeilBrown
bitmap_unplug only ever returns 0, so it may as well be void. Two callers try to print a message if it returns non-zero, but that message is already printed by bitmap_file_kick. write_page returns an error which is not consistently checked. It always causes BITMAP_WRITE_ERROR to be set on an error, and that can more conveniently be checked. When the return of write_page is checked, an error causes bitmap_file_kick to be called - so move that call into write_page - and protect against recursive calls into bitmap_file_kick. bitmap_update_sb returns an error that is never checked. So make these 'void' and be consistent about checking the bit. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16md: fix two raid10 bugsNeilBrown
1/ When resyncing a degraded raid10 which has more than 2 copies of each block, garbage can get synced on top of good data. 2/ We round the wrong way in part of the device size calculation, which can cause confusion. Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] md: fix raid10 recovery problem.NeilBrown
There are two errors that can lead to recovery problems with raid10 when used in 'far' more (not the default). Due to a '>' instead of '>=' the wrong block is located which would result in garbage being written to some random location, quite possible outside the range of the device, causing the newly reconstructed device to fail. The device size calculation had some rounding errors (it didn't round when it should) and so recovery would go a few blocks too far which would again cause a write to a random block address and probably a device error. The code for working with device sizes was fairly confused and spread out, so this has been tided up a bit. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] md: pass down BIO_RW_SYNC in raid{1,10}Lars Ellenberg
md raidX make_request functions strip off the BIO_RW_SYNC flag, thus introducing additional latency. Fixing this in raid1 and raid10 seems to be straightforward enough. For our particular usage case in DRBD, passing this flag improved some initialization time from ~5 minutes to ~5 seconds. Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Lars Ellenberg <lars@linbit.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] md: Don't assume that READ==0 and WRITE==1 - use the names explicitlyNeilBrown
Thanks Jens for alerting me to this. Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <raziebe@gmail.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] md: fix printk format warnings, seen on powerpc64:Randy Dunlap
drivers/md/raid1.c:1479: warning: long long unsigned int format, long unsigned int arg (arg 4) drivers/md/raid10.c:1475: warning: long long unsigned int format, long unsigned int arg (arg 4) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21[PATCH] md: fix calculation of ->degraded for multipath and raid10NeilBrown
Two less-used md personalities have bugs in the calculation of ->degraded (the extent to which the array is degraded). Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: define ->congested_fn for raid1, raid10, and multipathNeilBrown
raid1, raid10 and multipath don't report their 'congested' status through bdi_*_congested, but should. This patch adds the appropriate functions which just check the 'congested' status of all active members (with appropriate locking). raid1 read_balance should be modified to prefer devices where bdi_read_congested returns false. Then we could use the '&' branch rather than the '|' branch. However that should would need some benchmarking first to make sure it is actually a good idea. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: Improve locking around error handlingNeilBrown
The error handling routines don't use proper locking, and so two concurrent errors could trigger a problem. So: - use test-and-set and test-and-clear to synchonise the In_sync bits with the ->degraded count - use the spinlock to protect updates to the degraded count (could use an atomic_t but that would be a bigger change in code, and isn't really justified) - remove un-necessary locking in raid5 Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: remove 'working_disks' from raid10 stateNeilBrown
It isn't needed as mddev->degraded contains equivalent info. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: replace magic numbers in sb_dirty with well defined bit flagsNeilBrown
Instead of magic numbers (0,1,2,3) in sb_dirty, we have some flags instead: MD_CHANGE_DEVS Some device state has changed requiring superblock update on all devices. MD_CHANGE_CLEAN The array has transitions from 'clean' to 'dirty' or back, requiring a superblock update on active devices, but possibly not on spares MD_CHANGE_PENDING A superblock update is underway. We wait for an update to complete by waiting for all flags to be clear. A flag can be set at any time, even during an update, without risk that the change will be lost. Stop exporting md_update_sb - isn't needed. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
