path: root/drivers/md/persistent-data/dm-btree-spine.c
2013-03-01dm persistent data: add btree_walkJoe Thornber
Add dm_btree_walk to iterate through the contents of a btree. This will be used by the dm cache target. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm persistent data: use DMERR_LIMIT for errorsMike Snitzer
Nearly all of persistent-data is in the IO path so throttle error messages with DMERR_LIMIT to limit the amount logged when something has gone wrong. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm persistent data: rename node to btree_nodeMikulas Patocka
This patch fixes a compilation failure on sparc32 by renaming struct node. struct node is already defined in include/linux/node.h. On sparc32, it happens to be included through other dependencies and persistent-data doesn't compile because of conflicting declarations. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-31dm: add persistent data libraryJoe Thornber
The persistent-data library offers a re-usable framework for the storage and management of on-disk metadata in device-mapper targets. It's used by the thin-provisioning target in the next patch and in an upcoming hierarchical storage target. For further information, please read Documentation/device-mapper/persistent-data.txt Signed-off-by: Joe Thornber <thornber@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
