path: root/drivers/md/persistent-data/dm-block-manager.c
2013-03-01dm: add cache targetJoe Thornber
Add a target that allows a fast device such as an SSD to be used as a cache for a slower device such as a disk. A plug-in architecture was chosen so that the decisions about which data to migrate and when are delegated to interchangeable tunable policy modules. The first general purpose module we have developed, called "mq" (multiqueue), follows in the next patch. Other modules are under development. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Heinz Mauelshagen <mauelshagen@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21Merge tag 'dm-3.8-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull dm update from Alasdair G Kergon: "Miscellaneous device-mapper fixes, cleanups and performance improvements. Of particular note: - Disable broken WRITE SAME support in all targets except linear and striped. Use it when kcopyd is zeroing blocks. - Remove several mempools from targets by moving the data into the bio's new front_pad area(which dm calls 'per_bio_data'). - Fix a race in thin provisioning if discards are misused. - Prevent userspace from interfering with the ioctl parameters and use kmalloc for the data buffer if it's small instead of vmalloc. - Throttle some annoying error messages when I/O fails." * tag 'dm-3.8-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (36 commits) dm stripe: add WRITE SAME support dm: remove map_info dm snapshot: do not use map_context dm thin: dont use map_context dm raid1: dont use map_context dm flakey: dont use map_context dm raid1: rename read_record to bio_record dm: move target request nr to dm_target_io dm snapshot: use per_bio_data dm verity: use per_bio_data dm raid1: use per_bio_data dm: introduce per_bio_data dm kcopyd: add WRITE SAME support to dm_kcopyd_zero dm linear: add WRITE SAME support dm: add WRITE SAME support dm: prepare to support WRITE SAME dm ioctl: use kmalloc if possible dm ioctl: remove PF_MEMALLOC dm persistent data: improve improve space map block alloc failure message dm thin: use DMERR_LIMIT for errors ...
2012-12-21dm persistent data: use DMERR_LIMIT for errorsMike Snitzer
Nearly all of persistent-data is in the IO path so throttle error messages with DMERR_LIMIT to limit the amount logged when something has gone wrong. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm block manager: reinstate message when validator failsMike Snitzer
Reinstate a useful error message when the block manager buffer validator fails. This was mistakenly eliminated when the block manager was converted to use dm-bufio. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-10-29md: Fix typo in drivers/mdMasanari Iida
Correct spelling typo in drivers/md. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-27dm persistent data: introduce dm_bm_set_read_onlyJoe Thornber
Introduce dm_bm_set_read_only to switch the block manager into a read-only mode. To be used when dm-thin degrades due to io errors on the metadata device. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm persistent data: stop using dm_bm_unlock_move when shadowing blocks in tmJoe Thornber
Stop using dm_bm_unlock_move when shadowing blocks in the transaction manager as an optimisation and remove the function as it is then no longer used. Some code, such as the space maps, keeps using on-disk data structures from the previous transaction. It can do this because blocks won't be reallocated until the subsequent transaction. Using dm_bm_unlock_move to copy blocks sounds like a win, but it forces a synchronous read should the old block be accessed. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm persistent data: tidy transaction manager creation fnsJoe Thornber
Tidy the transaction manager creation functions. They no longer lock the superblock. Superblock locking is pulled out to the caller. Also export dm_bm_write_lock_zero. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm persistent data: create new dm_block_manager structJoe Thornber
This patch introduces a separate struct for the block_manager. It also uses IS_ERR to check the return value of dm_bufio_client_create instead of testing incorrectly for NULL. Prior to this patch a struct dm_block_manager was really an alias for a struct dm_bufio_client. We want to add some functionality to the block manager that will require extra fields, so this one to one mapping is no longer valid. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm persistent data: always unlock superblock in dm_bm_flush_and_unlockJoe Thornber
Unlock the superblock even if initial dm_bufio_write_dirty_buffers fails. Also, remove redundant flush calls. dm_bm_flush_and_unlock's calls to dm_bufio_write_dirty_buffers already result in dm_bufio_issue_flush being called. This avoids warnings about unflushed dirty buffers from bufio. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-31dm: add persistent data libraryJoe Thornber
The persistent-data library offers a re-usable framework for the storage and management of on-disk metadata in device-mapper targets. It's used by the thin-provisioning target in the next patch and in an upcoming hierarchical storage target. For further information, please read Documentation/device-mapper/persistent-data.txt Signed-off-by: Joe Thornber <thornber@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
