path: root/drivers/md/dm.c
2006-06-26[PATCH] dm: improve error message consistencyAlasdair G Kergon
Tidy device-mapper error messages to include context information automatically. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: prevent removal if openAlasdair G Kergon
If you misuse the device-mapper interface (or there's a bug in your userspace tools) it's possible to end up with 'unlinked' mapped devices that cannot be removed until you reboot (along with uninterruptible processes). This patch prevents you from removing a device that is still open. It introduces dm_lock_for_deletion() which is called when a device is about to be removed to ensure that nothing has it open and nothing further can open it. It uses a private open_count for this which also lets us remove one of the problematic bdget_disk() calls elsewhere. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: add exportsAlasdair G Kergon
Move definitions of core device-mapper functions for manipulating mapped devices and their tables to <linux/device-mapper.h> advertising their availability for use elsewhere in the kernel. Protect the contents of device-mapper.h with ifdef __KERNEL__. And throw in a few formatting clean-ups and extra comments. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: consolidate creation functionsAlasdair G Kergon
Merge dm_create() and dm_create_with_minor() by introducing the special value DM_ANY_MINOR to request the allocation of the next available minor number. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: fix block device initialisationJeff Mahoney
In alloc_dev(), we register the device with the block layer and then continue to initialize the device. But register_disk() makes the device available to be opened before we have completed initialising it. This patch moves the final bits of the initialization above the disk registration. [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: add module ref countingJeff Mahoney
The reference counting on dm-mod is zero if no mapped devices are open. This is incorrect, and can lead to an oops if the module is unloaded while mapped devices exist. This patch claims a reference to the module whenever a device is created, and drops it again when the device is freed. Devices must be removed before dm-mod is unloaded. [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: add DMF_FREEINGJeff Mahoney
There is a chicken and egg problem between the block layer and dm in which the gendisk associated with a mapping keeps a reference-less pointer to the mapped_device. This patch uses a new flag DMF_FREEING to indicate when the mapped_device is no longer valid. This is checked to prevent any attempt to open the device from succeeding while the device is being destroyed. [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: change minor_lock to spinlockJeff Mahoney
While removing a device, another another thread might attempt to resurrect it. This patch replaces the _minor_lock mutex with a spinlock and uses atomic_dec_and_lock() to serialize reference counting in dm_put(). [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: move idr_pre_getJeff Mahoney
idr_pre_get() can sleep while allocating memory. The next patch will change _minor_lock into a spinlock, so this patch moves idr_pre_get() outside the lock in preparation. [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: fix idr minor allocationJeff Mahoney
One part of the system can attempt to use a mapped device before another has finished initialising it or while it is being freed. This patch introduces a place holder value, MINOR_ALLOCED, to mark the minor as allocated but in a state where it can't be used, such as mid-allocation or mid-free. At the end of the initialization, it replaces the place holder with the pointer to the mapped_device, making it available to the rest of the dm subsystem. [akpm: too late for 2.6.17 - suitable for 2.6.17.x after it has settled] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] sem2mutex: drivers/mdArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm store geometryDarrick J. Wong
Allow drive geometry to be stored with a new DM_DEV_SET_GEOMETRY ioctl. Device-mapper will now respond to HDIO_GETGEO. If the geometry information is not available, zero will be returned for all of the parameters. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm table: store mdMike Anderson
Store an up-pointer to the owning struct mapped_device in every table when it is created. Access it with: struct mapped_device *dm_table_get_md(struct dm_table *t) Tables linked to md must be destroyed before the md itself. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm: tidy mdptrAlasdair G Kergon
Change dm_get_mdptr() to take a struct mapped_device instead of dev_t. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm: store md nameMike Anderson
The patch stores a printable device number in struct mapped_device for use in warning messages and with a proposed netlink interface. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm flush queue EINTRJun'ichi Nomura
If dm_suspend() is cancelled, bios already added to the deferred list need to be submitted. Otherwise they remain 'in limbo' until there's a dm_resume(). Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: use mempool_create_slab_pool()Matthew Dobson
Modify well over a dozen mempool users to call mempool_create_slab_pool() rather than calling mempool_create() with extra arguments, saving about 30 lines of code and increasing readability. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-22[PATCH] dm: bio split bvec fixAlasdair G Kergon
The code that handles bios that span table target boundaries by breaking them up into smaller bios will not split an individual struct bio_vec into more than two pieces. Sometimes more than that are required. This patch adds a loop to break the second piece up into as many pieces as are necessary. Cc: "Abhishek Gupta" <abhishekgupt@gmail.com> Cc: Dan Smith <danms@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-18[PATCH] regularize blk_cleanup_queue() useAl Viro
2006-02-24[PATCH] dm: free minor after unlink gendiskJun'ichi Nomura
Minor number should be freed after del_gendisk(). Otherwise, there could be a window where 2 registered gendisk has same minor number. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] dm: missing bdput/thaw_bdev at removalJun'ichi Nomura
Need to unfreeze and release bdev otherwise the bdev inode with inconsistent state is reused later and cause problem. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] device-mapper disk statistics: timingJun'ichi "Nick" Nomura
Record I/O timing statistics The start time is added to struct dm_io, an existing structure allocated privately internally within dm and attached to each incoming bio. We export disk_round_stats() from block/ll_rw_blk.c instead of creating a private clone. Signed-off-by: Jun'ichi "Nick" Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] device-mapper statistics: basicKevin Corry
Record basic I/O statistics for mapped devices. Signed-off-by: Kevin Corry <kevcorry@us.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dm: don't enable bouncing by defaultJens Axboe
DM doesn't need to bounce bio's on its own, but the block layer defaults to that in blk_queue_make_request(). The lower level drivers should bounce ios themselves, that is what they need to do if not layered below dm anyways. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-06[PATCH] device-mapper: make lock_fs optionalAlasdair G Kergon
Devices only needs syncing when creating snapshots, so make this optional when suspending a device. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] device-mapper: rename frozen_bdevAlasdair G Kergon
Rename frozen_bdev to suspended_bdev and move the bdget outside lockfs. (This prepares for making lockfs optional.) Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] device-mapper: add dm_get_mdDavid Teigland
Add dm_get_dev() to get a mapped device given its dev_t. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] device-mapper: add dm_find_mdDavid Teigland
Abstract dm_find_md() from dm_get_mdptr() to allow use elsewhere. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] kill bio->bi_setPeter Osterlund
Jens: ->bi_set is totally unnecessary bloat of struct bio. Just define a proper destructor for the bio and it already knows what bio_set it belongs too. Peter: Fixed the bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] device-mapper: fix md->lock deadlocks in coreAlasdair G Kergon
This patch is an attempt to fix deadlocks discovered in the core dm. The problems boil down to md->lock having to be held in too many places, so I've split it into two: md->suspend_lock and md->io_lock. suspend_lock is now held throughout dm_suspended() as well as dm_resume() and dm_swap_table() so that these functions cannot run concurrently: there's no requirement for that and it added complexity. DMF_FS_LOCKED becomes redundant: DMF_SUSPENDED provides adequate protection. Signed-Off-By: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] device-mapper: fix deadlocks in coreAlasdair G Kergon
Avoid another bdget_disk which can deadlock. Signed-Off-By: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] device-mapper: fix deadlocks in core (prep)Alasdair G Kergon
Some code tidy-ups in preparation for the next patches. Change dm_table_pre/postsuspend_targets to accept NULL. Use dm_suspended() throughout. Signed-Off-By: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] device-mapper: Fix dm_swap_table error casesAlasdair G Kergon
Fix dm_swap_table() __bind error cases: a missing unlock, and EINVAL preferable to EPERM. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] device-mapper multipath: Avoid possible suspension deadlockAlasdair G Kergon
To avoid deadlock when suspending a multipath device after all its paths have failed, stop queueing any I/O that is about to fail *before* calling freeze_bdev instead of after. Instead of setting a multipath 'suspended' flag which would have to be reset if an error occurs during the process, save the previous queueing state and leave userspace to restore if it wishes. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] device-mapper multipath: Barriers not supportedAlasdair G Kergon
dm multipath will report barriers as not supported with this patch. Signed-off-by: Lars Marowsky-Bree <lmb@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] device-mapper: tidy dm_suspendAlasdair G Kergon
Tidy dm_suspend. Signed-Off-By: Alasdair G Kergon <agk@redhat.com> From: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] device-mapper: handle __lock_fs errorAlasdair G Kergon
Handle error from __lock_fs() Signed-Off-By: Alasdair G Kergon <agk@redhat.com> From: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] device-mapper: let freeze_bdev return errorAlasdair G Kergon
Allow freeze_bdev() to return an error. Signed-Off-By: Alasdair G Kergon <agk@redhat.com> From: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] device-mapper: __unlock_fs voidAlasdair G Kergon
Make __unlock_fs() void. From: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] device-mapper: store bdev while frozenAlasdair G Kergon
Store the struct block_device while device is frozen, saving us one call to bdget_disk(). Signed-Off-By: Alasdair G Kergon <agk@redhat.com> From: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
