path: root/drivers/md/dm-snap-persistent.c
2010-08-12dm snapshot: persistent use define for disk header chunk sizeTomohiro Kusumi
This patch fixes hard-coded value for the size of a chunk that includes disk header for persistent snapshot. It should be changed to existing macro NUM_SNAPSHOT_HDR_CHUNKS instead of using hard-coded value 1. Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-02-16dm snapshot: persistent annotate work_queue as on stackMike Snitzer
chunk_io() declares its 'struct mdata_req' on the stack and then initializes its 'struct work_struct' member. Annotate the initialization of this workqueue with INIT_WORK_ON_STACK to suppress a debugobjects warning seen when CONFIG_DEBUG_OBJECTS_WORK is enabled. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm exception store: add merge specific methodsMikulas Patocka
Add functions that decide how many consecutive chunks of snapshot to merge back into the origin next and to update the metadata afterwards. prepare_merge provides a pointer to the most recent still-to-be-merged chunk and returns how many previous ones are consecutive and can be processed together. commit_merge removes the nr_merged most-recent chunks permanently from the exception store. The number must not exceed that returned by prepare_merge. Introduce NUM_SNAPSHOT_HDR_CHUNKS to show where the snapshot header chunk is accounted for. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: move cow ref from exception store to snap coreMike Snitzer
Store the reference to the snapshot cow device in the core snapshot code instead of each exception store. It can be accessed through the new function dm_snap_cow(). Exception stores should each now maintain a reference to their parent snapshot struct. This is cleaner and makes part of the forthcoming snapshot merge code simpler. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Mikulas Patocka <mpatocka@redhat.com>
2009-12-10dm snapshot: add allocated metadata to snapshot statusMike Snitzer
Add number of sectors used by metadata to the end of the snapshot's status line. Renamed dm_exception_store_type's 'fraction_full' to 'usage'. Renamed arguments to be clearer about what is being returned. Also added 'metadata_sectors'. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rename dm_snap_exception to dm_exceptionJon Brassow
The exception structure is not necessarily just a snapshot element (especially after we pull it out of dm-snap.c). Renaming appropriately. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: avoid else clause in persistent_read_metadataJon Brassow
Minor code touch-up. We don't need the 'else'. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: use unsigned integer chunk sizeMikulas Patocka
Use unsigned integer chunk size. Maximum chunk size is 512kB, there won't ever be need to use 4GB chunk size, so the number can be 32-bit. This fixes compiler failure on 32-bit systems with large block devices. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm snapshot: fix on disk chunk size validationMikulas Patocka
Fix some problems seen in the chunk size processing when activating a pre-existing snapshot. For a new snapshot, the chunk size can either be supplied by the creator or a default value can be used. For an existing snapshot, the chunk size in the snapshot header on disk should always be used. If someone attempts to load an existing snapshot and has the 'default chunk size' option set, the kernel uses its default value even when it is incorrect for the snapshot being loaded. This patch ensures the correct on-disk value is always used. Secondly, when the code does use the chunk size stored on the disk it is prudent to revalidate it, so the code can exit cleanly if it got corrupted as happened in https://bugzilla.redhat.com/show_bug.cgi?id=461506 . Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm snapshot: fix header corruption race on invalidationMikulas Patocka
If a persistent snapshot fills up, a race can corrupt the on-disk header which causes a crash on any future attempt to activate the snapshot (typically while booting). This patch fixes the race. When the snapshot overflows, __invalidate_snapshot is called, which calls snapshot store method drop_snapshot. It goes to persistent_drop_snapshot that calls write_header. write_header constructs the new header in the "area" location. Concurrently, an existing kcopyd job may finish, call copy_callback and commit_exception method, that goes to persistent_commit_exception. persistent_commit_exception doesn't do locking, relying on the fact that callbacks are single-threaded, but it can race with snapshot invalidation and overwrite the header that is just being written while the snapshot is being invalidated. The result of this race is a corrupted header being written that can lead to a crash on further reactivation (if chunk_size is zero in the corrupted header). The fix is to use separate memory areas for each. See the bug: https://bugzilla.redhat.com/show_bug.cgi?id=461506 Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm snapshot: refactor zero_disk_area to use chunk_ioMikulas Patocka
Refactor chunk_io to prepare for the fix in the following patch. Pass an area pointer to chunk_io and simplify zero_disk_area to use chunk_io. No functional change. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm snapshot: use barrier when writing exception storeMikulas Patocka
Send barrier requests when updating the exception area. Exception area updates need to be ordered w.r.t. data writes, so that the writes are not reordered in hardware disk cache. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-02dm snapshot: persistent fix dtr cleanupJonathan Brassow
The persistent exception store destructor does not properly account for all conditions in which it can be called. If it is called after 'ctr' but before 'read_metadata' (e.g. if something else in 'snapshot_ctr' fails) then it will attempt to free areas of memory that haven't been allocated yet. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm snapshot: move status to exception storeJonathan Brassow
Let the exception store types print out their status through the new API, rather than having the snapshot code do it. Adjust the buffer position to allow for the preceding DMEMIT in the arguments to type->status(). Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm snapshot: remove dm_snap header useJonathan Brassow
Move useful functions out of dm-snap.h and stop using dm-snap.h. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move cow pointerJonathan Brassow
Move COW device from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move chunk_fieldsJonathan Brassow
Move chunk fields from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: introduce registryJonathan Brassow
Move exception stores into a registry. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: separate type from instanceJonathan Brassow
Introduce struct dm_exception_store_type. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: extend exception store functionsJonathan Brassow
Supply dm_add_exception as a callback to the read_metadata function. Add a status function ready for a later patch and name the functions consistently. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: split out exception store implementationsAlasdair G Kergon
Move the existing snapshot exception store implementations out into separate files. Later patches will place these behind a new interface in preparation for alternative implementations. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
