path: root/drivers/md/dm-io.c
2007-07-12dm io: fix panic on large requestJun'ichi Nomura
bio_alloc_bioset() will return NULL if 'num_vecs' is too large. Use bio_get_nr_vecs() to get estimation of maximum number. Cc: stable@kernel.org Signed-off-by: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: remove old interfaceMilan Broz
Remove old dm-io interface. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: new interfaceHeinz Mauelshagen
Add a new API to dm-io.c that uses a private mempool and bio_set for each client. The new functions to use are dm_io_client_create(), dm_io_client_destroy(), dm_io_client_resize() and dm_io(). Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: prepare for new interfaceHeinz Mauelshagen
Introduce struct dm_io_client to prepare for per-client mempools and bio_sets. Temporary functions bios() and io_pool() choose between the per-client structures and the global ones so the old and new interfaces can co-exist. Make error_bits optional. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: delay dec_countHeinz Mauelshagen
Delay decrementing the 'struct io' reference count until after the bio has been freed so that a bio destructor function may reference it. Required by a later patch. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30[BLOCK] Don't pin lots of memory in mempoolsJens Axboe
Currently we scale the mempool sizes depending on memory installed in the machine, except for the bio pool itself which sits at a fixed 256 entry pre-allocation. There's really no point in "optimizing" this OOM path, we just need enough preallocated to make progress. A single unit is enough, lets scale it down to 2 just to be on the safe side. This patch saves ~150kb of pinned kernel memory on a 32-bit box. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-08[PATCH] dm io: fix bi_max_vecsHeinz Mauelshagen
The existing code allocates an extra slot in bi_io_vec[] and uses it to store the region number. This patch hides the extra slot from bio_add_page() so the region number can't get overwritten. Also remove a hard-coded SECTOR_SHIFT and fix a typo in a comment. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: use common mempool kmalloc allocatorMatthew Dobson
This patch changes several mempool users, all of which are basically just wrappers around kmalloc(), to use the common mempool_kmalloc/kfree, rather than their own wrapper function, removing a bunch of duplicated code. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] kill bio->bi_setPeter Osterlund
Jens: ->bi_set is totally unnecessary bloat of struct bio. Just define a proper destructor for the bio and it already knows what bio_set it belongs too. Peter: Fixed the bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
