path: root/drivers/md/dm-io.c
2008-10-21dm: remove dm header from targetsMikulas Patocka
Change #include "dm.h" to #include <linux/device-mapper.h> in all targets. Targets should not need direct access to internal DM structures. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm: unplug queues in threadsMikulas Patocka
Remove an avoidable 3ms delay on some dm-raid1 and kcopyd I/O. It is specified that any submitted bio without BIO_RW_SYNC flag may plug the queue (i.e. block the requests from being dispatched to the physical device). The queue is unplugged when the caller calls blk_unplug() function. Usually, the sequence is that someone calls submit_bh to submit IO on a buffer. The IO plugs the queue and waits (to be possibly joined with other adjacent bios). Then, when the caller calls wait_on_buffer(), it unplugs the queue and submits the IOs to the disk. This was happenning: When doing O_SYNC writes, function fsync_buffers_list() submits a list of bios to dm_raid1, the bios are added to dm_raid1 write queue and kmirrord is woken up. fsync_buffers_list() calls wait_on_buffer(). That unplugs the queue, but there are no bios on the device queue as they are still in the dm_raid1 queue. wait_on_buffer() starts waiting until the IO is finished. kmirrord is scheduled, kmirrord takes bios and submits them to the devices. The submitted bio plugs the harddisk queue but there is no one to unplug it. (The process that called wait_on_buffer() is already sleeping.) So there is a 3ms timeout, after which the queues on the harddisks are unplugged and requests are processed. This 3ms timeout meant that in certain workloads (e.g. O_SYNC, 8kb writes), dm-raid1 is 10 times slower than md raid1. Every time we submit something asynchronously via dm_io, we must unplug the queue actually to send the request to the device. This patch adds an unplug call to kmirrord - while processing requests, it keeps the queue plugged (so that adjacent bios can be merged); when it finishes processing all the bios, it unplugs the queue to submit the bios. It also fixes kcopyd which has the same potential problem. All kcopyd requests are submitted with BIO_RW_SYNC. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-25dm: move include filesAlasdair G Kergon
Publish the dm-io, dm-log and dm-kcopyd headers in include/linux. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm io: clean interfaceHeinz Mauelshagen
Clean up the dm-io interface to prepare for publishing it in include/linux. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm io: rename error to error_bitsAlasdair G Kergon
Rename 'error' to 'error_bits' for clarity. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-03-28dm io: write error bits form long not intAlasdair G Kergon
write_err is an unsigned long used with set_bit() so should not be passed around as unsigned int. http://bugzilla.kernel.org/show_bug.cgi?id=10271 Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-12dm io: fix panic on large requestJun'ichi Nomura
bio_alloc_bioset() will return NULL if 'num_vecs' is too large. Use bio_get_nr_vecs() to get estimation of maximum number. Cc: stable@kernel.org Signed-off-by: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: remove old interfaceMilan Broz
Remove old dm-io interface. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: new interfaceHeinz Mauelshagen
Add a new API to dm-io.c that uses a private mempool and bio_set for each client. The new functions to use are dm_io_client_create(), dm_io_client_destroy(), dm_io_client_resize() and dm_io(). Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: prepare for new interfaceHeinz Mauelshagen
Introduce struct dm_io_client to prepare for per-client mempools and bio_sets. Temporary functions bios() and io_pool() choose between the per-client structures and the global ones so the old and new interfaces can co-exist. Make error_bits optional. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09dm io: delay dec_countHeinz Mauelshagen
Delay decrementing the 'struct io' reference count until after the bio has been freed so that a bio destructor function may reference it. Required by a later patch. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30[BLOCK] Don't pin lots of memory in mempoolsJens Axboe
Currently we scale the mempool sizes depending on memory installed in the machine, except for the bio pool itself which sits at a fixed 256 entry pre-allocation. There's really no point in "optimizing" this OOM path, we just need enough preallocated to make progress. A single unit is enough, lets scale it down to 2 just to be on the safe side. This patch saves ~150kb of pinned kernel memory on a 32-bit box. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-08[PATCH] dm io: fix bi_max_vecsHeinz Mauelshagen
The existing code allocates an extra slot in bi_io_vec[] and uses it to store the region number. This patch hides the extra slot from bio_add_page() so the region number can't get overwritten. Also remove a hard-coded SECTOR_SHIFT and fix a typo in a comment. Signed-off-by: Heinz Mauelshagen <hjm@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: Milan Broz <mbroz@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: use common mempool kmalloc allocatorMatthew Dobson
This patch changes several mempool users, all of which are basically just wrappers around kmalloc(), to use the common mempool_kmalloc/kfree, rather than their own wrapper function, removing a bunch of duplicated code. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] kill bio->bi_setPeter Osterlund
Jens: ->bi_set is totally unnecessary bloat of struct bio. Just define a proper destructor for the bio and it already knows what bio_set it belongs too. Peter: Fixed the bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
