path: root/drivers/md/dm-crypt.c
2015-09-02Merge tag 'dm-4.3-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper update from Mike Snitzer: - a couple small cleanups in dm-cache, dm-verity, persistent-data's dm-btree, and DM core. - a 4.1-stable fix for dm-cache that fixes the leaking of deferred bio prison cells - a 4.2-stable fix that adds feature reporting for the dm-stats features added in 4.2 - improve DM-snapshot to not invalidate the on-disk snapshot if snapshot device write overflow occurs; but a write overflow triggered through the origin device will still invalidate the snapshot. - optimize DM-thinp's async discard submission a bit now that late bio splitting has been included in block core. - switch DM-cache's SMQ policy lock from using a mutex to a spinlock; improves performance on very low latency devices (eg. NVMe SSD). - document DM RAID 4/5/6's discard support [ I did not pull the slab changes, which weren't appropriate for this tree, and weren't obviously the right thing to do anyway. At the very least they need some discussion and explanation before getting merged. Because not pulling the actual tagged commit but doing a partial pull instead, this merge commit thus also obviously is missing the git signature from the original tag ] * tag 'dm-4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm cache: fix use after freeing migrations dm cache: small cleanups related to deferred prison cell cleanup dm cache: fix leaking of deferred bio prison cells dm raid: document RAID 4/5/6 discard support dm stats: report precise_timestamps and histogram in @stats_list output dm thin: optimize async discard submission dm snapshot: don't invalidate on-disk image on snapshot write overflow dm: remove unlikely() before IS_ERR() dm: do not override error code returned from dm_get_device() dm: test return value for DM_MAPIO_SUBMITTED dm verity: remove unused mempool dm cache: move wake_waker() from free_migrations() to where it is needed dm btree remove: remove unused function get_nr_entries() dm btree: remove unused "dm_block_t root" parameter in btree_split_sibling() dm cache policy smq: change the mutex to a spinlock
2015-08-13block: kill merge_bvec_fn() completelyKent Overstreet
As generic_make_request() is now able to handle arbitrarily sized bios, it's no longer necessary for each individual block driver to define its own ->merge_bvec_fn() callback. Remove every invocation completely. Cc: Jens Axboe <axboe@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: drbd-user@lists.linbit.com Cc: Jiri Kosina <jkosina@suse.cz> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@kernel.org> Cc: ceph-devel@vger.kernel.org Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Neil Brown <neilb@suse.de> Cc: linux-raid@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Acked-by: NeilBrown <neilb@suse.de> (for the 'md' bits) Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com> [dpark: also remove ->merge_bvec_fn() in dm-thin as well as dm-era-target, and resolve merge conflicts] Signed-off-by: Dongsu Park <dpark@posteo.net> Signed-off-by: Ming Lin <ming.l@ssi.samsung.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-08-12dm: do not override error code returned from dm_get_device()Vivek Goyal
Some of the device mapper targets override the error code returned by dm_get_device() and return either -EINVAL or -ENXIO. There is nothing gained by this override. It is better to propagate the returned error code unchanged to caller. This work was motivated by hitting an issue where the underlying device was busy but -EINVAL was being returned. After this change we get -EBUSY instead and it is easier to figure out the problem. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-08-11block: don't access bio->bi_error after bio_put()Sasha Levin
Commit 4246a0b6 ("block: add a bi_error field to struct bio") has added a few dereferences of 'bio' after a call to bio_put(). This causes use-after-frees such as: [521120.719695] BUG: KASan: use after free in dio_bio_complete+0x2b3/0x320 at addr ffff880f36b38714 [521120.720638] Read of size 4 by task mount.ocfs2/9644 [521120.721212] ============================================================================= [521120.722056] BUG kmalloc-256 (Not tainted): kasan: bad access detected [521120.722968] ----------------------------------------------------------------------------- [521120.722968] [521120.723915] Disabling lock debugging due to kernel taint [521120.724539] INFO: Slab 0xffffea003cdace00 objects=32 used=25 fp=0xffff880f36b38600 flags=0x46fffff80004080 [521120.726037] INFO: Object 0xffff880f36b38700 @offset=1792 fp=0xffff880f36b38800 [521120.726037] [521120.726974] Bytes b4 ffff880f36b386f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.727898] Object ffff880f36b38700: 00 88 b3 36 0f 88 ff ff 00 00 d8 de 0b 88 ff ff ...6............ [521120.728822] Object ffff880f36b38710: 02 00 00 f0 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.729705] Object ffff880f36b38720: 01 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 ................ [521120.730623] Object ffff880f36b38730: 00 00 00 00 00 00 00 00 01 00 00 00 00 02 00 00 ................ [521120.731621] Object ffff880f36b38740: 00 02 00 00 01 00 00 00 d0 f7 87 ad ff ff ff ff ................ [521120.732776] Object ffff880f36b38750: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.733640] Object ffff880f36b38760: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.734508] Object ffff880f36b38770: 01 00 03 00 01 00 00 00 88 87 b3 36 0f 88 ff ff ...........6.... [521120.735385] Object ffff880f36b38780: 00 73 22 ad 02 88 ff ff 40 13 e0 3c 00 ea ff ff .s".....@..<.... [521120.736667] Object ffff880f36b38790: 00 02 00 00 00 04 00 00 00 00 00 00 00 00 00 00 ................ [521120.737596] Object ffff880f36b387a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.738524] Object ffff880f36b387b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.739388] Object ffff880f36b387c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.740277] Object ffff880f36b387d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.741187] Object ffff880f36b387e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.742233] Object ffff880f36b387f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ [521120.743229] CPU: 41 PID: 9644 Comm: mount.ocfs2 Tainted: G B 4.2.0-rc6-next-20150810-sasha-00039-gf909086 #2420 [521120.744274] ffff880f36b38000 ffff880d89c8f638 ffffffffb6e9ba8a ffff880101c0e5c0 [521120.745025] ffff880d89c8f668 ffffffffad76a313 ffff880101c0e5c0 ffffea003cdace00 [521120.745908] ffff880f36b38700 ffff880f36b38798 ffff880d89c8f690 ffffffffad772854 [521120.747063] Call Trace: [521120.747520] dump_stack (lib/dump_stack.c:52) [521120.748053] print_trailer (mm/slub.c:653) [521120.748582] object_err (mm/slub.c:660) [521120.749079] kasan_report_error (include/linux/kasan.h:20 mm/kasan/report.c:152 mm/kasan/report.c:194) [521120.750834] __asan_report_load4_noabort (mm/kasan/report.c:250) [521120.753580] dio_bio_complete (fs/direct-io.c:478) [521120.755752] do_blockdev_direct_IO (fs/direct-io.c:494 fs/direct-io.c:1291) [521120.759765] __blockdev_direct_IO (fs/direct-io.c:1322) [521120.761658] blkdev_direct_IO (fs/block_dev.c:162) [521120.762993] generic_file_read_iter (mm/filemap.c:1738) [521120.767405] blkdev_read_iter (fs/block_dev.c:1649) [521120.768556] __vfs_read (fs/read_write.c:423 fs/read_write.c:434) [521120.772126] vfs_read (fs/read_write.c:454) [521120.773118] SyS_pread64 (fs/read_write.c:607 fs/read_write.c:594) [521120.776062] entry_SYSCALL_64_fastpath (arch/x86/entry/entry_64.S:186) [521120.777375] Memory state around the buggy address: [521120.778118] ffff880f36b38600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [521120.779211] ffff880f36b38680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [521120.780315] >ffff880f36b38700: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [521120.781465] ^ [521120.782083] ffff880f36b38780: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [521120.783717] ffff880f36b38800: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc [521120.784818] ================================================================== This patch fixes a few of those places that I caught while auditing the patch, but the original patch should be audited further for more occurences of this issue since I'm not too familiar with the code. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-29block: add a bi_error field to struct bioChristoph Hellwig
Currently we have two different ways to signal an I/O error on a BIO: (1) by clearing the BIO_UPTODATE flag (2) by returning a Linux errno value to the bi_end_io callback The first one has the drawback of only communicating a single possible error (-EIO), and the second one has the drawback of not beeing persistent when bios are queued up, and are not passed along from child to parent bio in the ever more popular chaining scenario. Having both mechanisms available has the additional drawback of utterly confusing driver authors and introducing bugs where various I/O submitters only deal with one of them, and the others have to add boilerplate code to deal with both kinds of error returns. So add a new bi_error field to store an errno value directly in struct bio and remove the existing mechanisms to clean all this up. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-29dm crypt: add comments to better describe crypto processing logicMilan Broz
A crypto driver can process requests synchronously or asynchronously and can use an internal driver queue to backlog requests. Add some comments to clarify internal logic and completion return codes. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-05-05Revert "dm crypt: fix deadlock when async crypto algorithm returns -EBUSY"Rabin Vincent
This reverts Linux 4.1-rc1 commit 0618764cb25f6fa9fb31152995de42a8a0496475. The problem which that commit attempts to fix actually lies in the Freescale CAAM crypto driver not dm-crypt. dm-crypt uses CRYPTO_TFM_REQ_MAY_BACKLOG. This means the the crypto driver should internally backlog requests which arrive when the queue is full and process them later. Until the crypto hw's queue becomes full, the driver returns -EINPROGRESS. When the crypto hw's queue if full, the driver returns -EBUSY, and if CRYPTO_TFM_REQ_MAY_BACKLOG is set, is expected to backlog the request and process it when the hardware has queue space. At the point when the driver takes the request from the backlog and starts processing it, it calls the completion function with a status of -EINPROGRESS. The completion function is called (for a second time, in the case of backlogged requests) with a status/err of 0 when a request is done. Crypto drivers for hardware without hardware queueing use the helpers, crypto_init_queue(), crypto_enqueue_request(), crypto_dequeue_request() and crypto_get_backlog() helpers to implement this behaviour correctly, while others implement this behaviour without these helpers (ccp, for example). dm-crypt (before the patch that needs reverting) uses this API correctly. It queues up as many requests as the hw queues will allow (i.e. as long as it gets back -EINPROGRESS from the request function). Then, when it sees at least one backlogged request (gets -EBUSY), it waits till that backlogged request is handled (completion gets called with -EINPROGRESS), and then continues. The references to af_alg_wait_for_completion() and af_alg_complete() in that commit's commit message are irrelevant because those functions only handle one request at a time, unlink dm-crypt. The problem is that the Freescale CAAM driver, which that commit describes as having being tested with, fails to implement the backlogging behaviour correctly. In cam_jr_enqueue(), if the hardware queue is full, it simply returns -EBUSY without backlogging the request. What the observed deadlock was is not described in the commit message but it is obviously the wait_for_completion() in crypto_convert() where dm-crypto would wait for the completion being called with -EINPROGRESS in the case of backlogged requests. This completion will never be completed due to the bug in the CAAM driver. Commit 0618764cb25 incorrectly made dm-crypt wait for every request, even when the driver/hardware queues are not full, which means that dm-crypt will never see -EBUSY. This means that that commit will cause a performance regression on all crypto drivers which implement the API correctly. Revert it. Correct backlog handling should be implemented in the CAAM driver instead. Cc'ing stable purely because commit 0618764cb25 did. If for some reason a stable@ kernel did pick up commit 0618764cb25 it should get reverted. Signed-off-by: Rabin Vincent <rabin.vincent@axis.com> Reviewed-by: Horia Geanta <horia.geanta@freescale.com> Cc: stable@vger.kernel.org Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-04-16dm crypt: fix missing error code return from crypt_ctr error pathWei Yongjun
Fix to return a negative error code from crypt_ctr()'s optional parameter processing error path. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-04-15dm crypt: fix deadlock when async crypto algorithm returns -EBUSYBen Collins
I suspect this doesn't show up for most anyone because software algorithms typically don't have a sense of being too busy. However, when working with the Freescale CAAM driver it will return -EBUSY on occasion under heavy -- which resulted in dm-crypt deadlock. After checking the logic in some other drivers, the scheme for crypt_convert() and it's callback, kcryptd_async_done(), were not correctly laid out to properly handle -EBUSY or -EINPROGRESS. Fix this by using the completion for both -EBUSY and -EINPROGRESS. Now crypt_convert()'s use of completion is comparable to af_alg_wait_for_completion(). Similarly, kcryptd_async_done() follows the pattern used in af_alg_complete(). Before this fix dm-crypt would lockup within 1-2 minutes running with the CAAM driver. Fix was regression tested against software algorithms on PPC32 and x86_64, and things seem perfectly happy there as well. Signed-off-by: Ben Collins <ben.c@servergy.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org
2015-04-15dm crypt: leverage immutable biovecs when decrypting on readMike Snitzer
Commit 003b5c571 ("block: Convert drivers to immutable biovecs") stopped short of changing dm-crypt to leverage the fact that the biovec array of a bio will no longer be modified. Switch to using bio_clone_fast() when cloning bios for decryption after read. Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-04-15dm crypt: update URLs to new cryptsetup project pageMilan Broz
Cryptsetup home page moved to GitLab. Also remove link to abandonded Truecrypt page. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: sort writesMikulas Patocka
Write requests are sorted in a red-black tree structure and are submitted in the sorted order. In theory the sorting should be performed by the underlying disk scheduler, however, in practice the disk scheduler only accepts and sorts a finite number of requests. To allow the sorting of all requests, dm-crypt needs to implement its own sorting. The overhead associated with rbtree-based sorting is considered negligible so it is not used conditionally. Even on SSD sorting can be beneficial since in-order request dispatch promotes lower latency IO completion to the upper layers. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: add 'submit_from_crypt_cpus' optionMikulas Patocka
Make it possible to disable offloading writes by setting the optional 'submit_from_crypt_cpus' table argument. There are some situations where offloading write bios from the encryption threads to a single thread degrades performance significantly. The default is to offload write bios to the same thread because it benefits CFQ to have writes submitted using the same IO context. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: offload writes to threadMikulas Patocka
Submitting write bios directly in the encryption thread caused serious performance degradation. On a multiprocessor machine, encryption requests finish in a different order than they were submitted. Consequently, write requests would be submitted in a different order and it could cause severe performance degradation. Move the submission of write requests to a separate thread so that the requests can be sorted before submitting. But this commit improves dm-crypt performance even without having dm-crypt perform request sorting (in particular it enables IO schedulers like CFQ to sort more effectively). Note: it is required that a previous commit ("dm crypt: don't allocate pages for a partial request") be applied before applying this patch. Otherwise, this commit could introduce a crash. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: remove unused io_pool and _crypt_io_poolMikulas Patocka
The previous commit ("dm crypt: don't allocate pages for a partial request") stopped using the io_pool slab mempool and backing _crypt_io_pool kmem cache. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: avoid deadlock in mempoolsMikulas Patocka
Fix a theoretical deadlock introduced in the previous commit ("dm crypt: don't allocate pages for a partial request"). The function crypt_alloc_buffer may be called concurrently. If we allocate from the mempool concurrently, there is a possibility of deadlock. For example, if we have mempool of 256 pages, two processes, each wanting 256, pages allocate from the mempool concurrently, it may deadlock in a situation where both processes have allocated 128 pages and the mempool is exhausted. To avoid such a scenario we allocate the pages under a mutex. In order to not degrade performance with excessive locking, we try non-blocking allocations without a mutex first and if that fails, we fallback to a blocking allocations with a mutex. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: don't allocate pages for a partial requestMikulas Patocka
Change crypt_alloc_buffer so that it only ever allocates pages for a full request. This is a prerequisite for the commit "dm crypt: offload writes to thread". This change simplifies the dm-crypt code at the expense of reduced throughput in low memory conditions (where allocation for a partial request is most useful). Note: the next commit ("dm crypt: avoid deadlock in mempools") is needed to fix a theoretical deadlock. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2015-02-16dm crypt: use unbound workqueue for request processingMikulas Patocka
Use unbound workqueue by default so that work is automatically balanced between available CPUs. The original behavior of encrypting using the same cpu that IO was submitted on can still be enabled by setting the optional 'same_cpu_crypt' table argument. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2014-12-08Merge tag 'dm-3.19-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper updates from Mike Snitzer: - Significant DM thin-provisioning performance improvements to meet performance requirements that were requested by the Gluster distributed filesystem. Specifically, dm-thinp now takes care to aggregate IO that will be issued to the same thinp block before issuing IO to the underlying devices. This really helps improve performance on HW RAID6 devices that have a writeback cache because it avoids RMW in the HW RAID controller. - Some stable fixes: fix leak in DM bufio if integrity profiles were enabled, use memzero_explicit in DM crypt to avoid any potential for information leak, and a DM cache fix to properly mark a cache block dirty if it was promoted to the cache via the overwrite optimization. - A few simple DM persistent data library fixes - DM cache multiqueue policy block promotion improvements. - DM cache discard improvements that take advantage of range (multiblock) discard support in the DM bio-prison. This allows for much more efficient bulk discard processing (e.g. when mkfs.xfs discards the entire device). - Some small optimizations in DM core and RCU deference cleanups - DM core changes to suspend/resume code to introduce the new internal suspend/resume interface that the DM thin-pool target now uses to suspend/resume active thin devices when the thin-pool must suspend/resume. This avoids forcing userspace to track all active thin volumes in a thin-pool when the thin-pool is suspended for the purposes of metadata or data space resize. * tag 'dm-3.19-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: (49 commits) dm crypt: use memzero_explicit for on-stack buffer dm space map metadata: fix sm_bootstrap_get_count() dm space map metadata: fix sm_bootstrap_get_nr_blocks() dm bufio: fix memleak when using a dm_buffer's inline bio dm cache: fix spurious cell_defer when dealing with partial block at end of device dm cache: dirty flag was mistakenly being cleared when promoting via overwrite dm cache: only use overwrite optimisation for promotion when in writeback mode dm cache: discard block size must be a multiple of cache block size dm cache: fix a harmless race when working out if a block is discarded dm cache: when reloading a discard bitset allow for a different discard block size dm cache: fix some issues with the new discard range support dm array: if resizing the array is a noop set the new root to the old one dm: use rcu_dereference_protected instead of rcu_dereference dm thin: fix pool_io_hints to avoid looking at max_hw_sectors dm thin: suspend/resume active thin devices when reloading thin-pool dm: enhance internal suspend and resume interface dm thin: do not allow thin device activation while pool is suspended dm: add presuspend_undo hook to target_type dm: return earlier from dm_blk_ioctl if target doesn't implement .ioctl dm thin: remove stale 'trim' message in block comment above pool_message ...
2014-12-02dm crypt: use memzero_explicit for on-stack bufferMilan Broz
Use memzero_explicit to cleanup sensitive data allocated on stack to prevent the compiler from optimizing and removing memset() calls. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org
2014-10-14crypto, dm: LLVMLinux: Remove VLAIS usage from dm-cryptJan-Simon Möller
Replaced the use of a Variable Length Array In Struct (VLAIS) with a C99 compliant equivalent. This patch allocates the appropriate amount of memory using a char array using the SHASH_DESC_ON_STACK macro. The new code can be compiled with both gcc and clang. Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de> Signed-off-by: Behan Webster <behanw@converseincode.com> Reviewed-by: Mark Charlebois <charlebm@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: pageexec@freemail.hu Cc: gmazyland@gmail.com Cc: "David S. Miller" <davem@davemloft.net>
2014-08-28dm crypt: fix access beyond the end of allocated spaceMikulas Patocka
The DM crypt target accesses memory beyond allocated space resulting in a crash on 32 bit x86 systems. This bug is very old (it dates back to 2.6.25 commit 3a7f6c990ad04 "dm crypt: use async crypto"). However, this bug was masked by the fact that kmalloc rounds the size up to the next power of two. This bug wasn't exposed until 3.17-rc1 commit 298a9fa08a ("dm crypt: use per-bio data"). By switching to using per-bio data there was no longer any padding beyond the end of a dm-crypt allocated memory block. To minimize allocation overhead dm-crypt puts several structures into one block allocated with kmalloc. The block holds struct ablkcipher_request, cipher-specific scratch pad (crypto_ablkcipher_reqsize(any_tfm(cc))), struct dm_crypt_request and an initialization vector. The variable dmreq_start is set to offset of struct dm_crypt_request within this memory block. dm-crypt allocates the block with this size: cc->dmreq_start + sizeof(struct dm_crypt_request) + cc->iv_size. When accessing the initialization vector, dm-crypt uses the function iv_of_dmreq, which performs this calculation: ALIGN((unsigned long)(dmreq + 1), crypto_ablkcipher_alignmask(any_tfm(cc)) + 1). dm-crypt allocated "cc->iv_size" bytes beyond the end of dm_crypt_request structure. However, when dm-crypt accesses the initialization vector, it takes a pointer to the end of dm_crypt_request, aligns it, and then uses it as the initialization vector. If the end of dm_crypt_request is not aligned on a crypto_ablkcipher_alignmask(any_tfm(cc)) boundary the alignment causes the initialization vector to point beyond the allocated space. Fix this bug by calculating the variable iv_size_padding and adding it to the allocated size. Also correct the alignment of dm_crypt_request. struct dm_crypt_request is specific to dm-crypt (it isn't used by the crypto subsystem at all), so it is aligned on __alignof__(struct dm_crypt_request). Also align per_bio_data_size on ARCH_KMALLOC_MINALIGN, so that it is aligned as if the block was allocated with kmalloc. Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Tested-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2014-08-01dm crypt: use per-bio dataMikulas Patocka
Change dm-crypt so that it uses auxiliary data allocated with the bio. Dm-crypt requires two allocations per request - struct dm_crypt_io and struct ablkcipher_request (with other data appended to it). It previously only used mempool allocations. Some requests may require more dm_crypt_ios and ablkcipher_requests, however most requests need just one of each of these two structures to complete. This patch changes it so that the first dm_crypt_io and ablkcipher_request are allocated with the bio (using target per_bio_data_size option). If the request needs additional values, they are allocated from the mempool. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2014-07-10dm crypt, dm zero: update author name following legal name changeJana Saout
Signed-off-by: Jana Saout <jana@saout.de> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2014-05-14dm crypt: fix cpu hotplug crash by removing per-cpu structureMikulas Patocka
The DM crypt target used per-cpu structures to hold pointers to a ablkcipher_request structure. The code assumed that the work item keeps executing on a single CPU, so it didn't use synchronization when accessing this structure. If a CPU is disabled by writing 0 to /sys/devices/system/cpu/cpu*/online, the work item could be moved to another CPU. This causes dm-crypt crashes, like the following, because the code starts using an incorrect ablkcipher_request: smpboot: CPU 7 is now offline BUG: unable to handle kernel NULL pointer dereference at 0000000000000130 IP: [<ffffffffa1862b3d>] crypt_convert+0x12d/0x3c0 [dm_crypt] ... Call Trace: [<ffffffffa1864415>] ? kcryptd_crypt+0x305/0x470 [dm_crypt] [<ffffffff81062060>] ? finish_task_switch+0x40/0xc0 [<ffffffff81052a28>] ? process_one_work+0x168/0x470 [<ffffffff8105366b>] ? worker_thread+0x10b/0x390 [<ffffffff81053560>] ? manage_workers.isra.26+0x290/0x290 [<ffffffff81058d9f>] ? kthread+0xaf/0xc0 [<ffffffff81058cf0>] ? kthread_create_on_node+0x120/0x120 [<ffffffff813464ac>] ? ret_from_fork+0x7c/0xb0 [<ffffffff81058cf0>] ? kthread_create_on_node+0x120/0x120 Fix this bug by removing the per-cpu definition. The structure ablkcipher_request is accessed via a pointer from convert_context. Consequently, if the work item is rescheduled to a different CPU, the thread still uses the same ablkcipher_request. This change may undermine performance improvements intended by commit c0297721 ("dm crypt: scale to multiple cpus") on select hardware. In practice no performance difference was observed on recent hardware. But regardless, correctness is more important than performance. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org
2013-11-23block: Convert drivers to immutable biovecsKent Overstreet
Now that we've got a mechanism for immutable biovecs - bi_iter.bi_bvec_done - we need to convert drivers to use primitives that respect it instead of using the bvec array directly. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: NeilBrown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: dm-devel@redhat.com
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-09dm crypt: add TCW IV mode for old CBC TCRYPT containersMilan Broz
dm-crypt can already activate TCRYPT (TrueCrypt compatible) containers in LRW or XTS block encryption mode. TCRYPT containers prior to version 4.1 use CBC mode with some additional tweaks, this patch adds support for these containers. This new mode is implemented using special IV generator named TCW (TrueCrypt IV with whitening). TCW IV only supports containers that are encrypted with one cipher (Tested with AES, Twofish, Serpent, CAST5 and TripleDES). While this mode is legacy and is known to be vulnerable to some watermarking attacks (e.g. revealing of hidden disk existence) it can still be useful to activate old containers without using 3rd party software or for independent forensic analysis of such containers. (Both the userspace and kernel code is an independent implementation based on the format documentation and it completely avoids use of original source code.) The TCW IV generator uses two additional keys: Kw (whitening seed, size is always 16 bytes - TCW_WHITENING_SIZE) and Kiv (IV seed, size is always the IV size of the selected cipher). These keys are concatenated at the end of the main encryption key provided in mapping table. While whitening is completely independent from IV, it is implemented inside IV generator for simplification. The whitening value is always 16 bytes long and is calculated per sector from provided Kw as initial seed, xored with sector number and mixed with CRC32 algorithm. Resulting value is xored with ciphertext sector content. IV is calculated from the provided Kiv as initial IV seed and xored with sector number. Detailed calculation can be found in the Truecrypt documentation for version < 4.1 and will also be described on dm-crypt site, see: http://code.google.com/p/cryptsetup/wiki/DMCrypt The experimental support for activation of these containers is already present in git devel brach of cryptsetup. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2013-11-09dm crypt: properly handle extra key string in initializationMilan Broz
Some encryption modes use extra keys (e.g. loopAES has IV seed) which are not used in block cipher initialization but are part of key string in table constructor. This patch adds an additional field which describes the length of the extra key(s) and substracts it before real key encryption setting. The key_size always includes the size, in bytes, of the key provided in mapping table. The key_parts describes how many parts (usually keys) are contained in the whole key buffer. And key_extra_size contains size in bytes of additional keys part (this number of bytes must be subtracted because it is processed by the IV generator). | K1 | K2 | .... | K64 | Kiv | |----------- key_size ----------------- | | |-key_extra_size-| | [64 keys] | [1 key] | => key_parts = 65 Example where key string contains main key K, whitening key Kw and IV seed Kiv: | K | Kiv | Kw | |--------------- key_size --------------| | |-----key_extra_size------| | [1 key] | [1 key] | [1 key] | => key_parts = 3 Because key_extra_size is calculated during IV mode setting, key initialization is moved after this step. For now, this change has no effect to supported modes (thanks to ilog2 rounding) but it is required by the following patch. Also, fix a sparse warning in crypt_iv_lmk_one(). Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2013-08-23dm: stop using WQ_NON_REENTRANTTejun Heo
dbf2576e37 ("workqueue: make all workqueues non-reentrant") made WQ_NON_REENTRANT no-op and the flag is going away. Remove its usages. This patch doesn't introduce any behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Acked-by: Joe Thornber <ejt@redhat.com>
2013-03-23block: Convert some code to bio_for_each_segment_all()Kent Overstreet
More prep work for immutable bvecs: A few places in the code were either open coding or using the wrong version - fix. After we introduce the bvec iter, it'll no longer be possible to modify the biovec through bio_for_each_segment_all() - it doesn't increment a pointer to the current bvec, you pass in a struct bio_vec (not a pointer) which is updated with what the current biovec would be (taking into account bi_bvec_done and bi_size). So because of that it's more worthwhile to be consistent about bio_for_each_segment()/bio_for_each_segment_all() usage. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de> CC: Alasdair Kergon <agk@redhat.com> CC: dm-devel@redhat.com CC: Alexander Viro <viro@zeniv.linux.org.uk>
2013-03-01dm: rename request variables to biosAlasdair G Kergon
Use 'bio' in the name of variables and functions that deal with bios rather than 'request' to avoid confusion with the normal block layer use of 'request'. No functional changes. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-03-01dm: fix truncated status stringsMikulas Patocka
Avoid returning a truncated table or status string instead of setting the DM_BUFFER_FULL_FLAG when the last target of a table fills the buffer. When processing a table or status request, the function retrieve_status calls ti->type->status. If ti->type->status returns non-zero, retrieve_status assumes that the buffer overflowed and sets DM_BUFFER_FULL_FLAG. However, targets don't return non-zero values from their status method on overflow. Most targets returns always zero. If a buffer overflow happens in a target that is not the last in the table, it gets noticed during the next iteration of the loop in retrieve_status; but if a buffer overflow happens in the last target, it goes unnoticed and erroneously truncated data is returned. In the current code, the targets behave in the following way: * dm-crypt returns -ENOMEM if there is not enough space to store the key, but it returns 0 on all other overflows. * dm-thin returns errors from the status method if a disk error happened. This is incorrect because retrieve_status doesn't check the error code, it assumes that all non-zero values mean buffer overflow. * all the other targets always return 0. This patch changes the ti->type->status function to return void (because most targets don't use the return code). Overflow is detected in retrieve_status: if the status method fills up the remaining space completely, it is assumed that buffer overflow happened. Cc: stable@vger.kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: remove map_infoMikulas Patocka
This patch removes map_info from bio-based device mapper targets. map_info is still used for request-based targets. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-09-09block: Add bio_clone_bioset(), bio_clone_kmalloc()Kent Overstreet
Previously, there was bio_clone() but it only allocated from the fs bio set; as a result various users were open coding it and using __bio_clone(). This changes bio_clone() to become bio_clone_bioset(), and then we add bio_clone() and bio_clone_kmalloc() as wrappers around it, making use of the functionality the last patch adedd. This will also help in a later patch changing how bio cloning works. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de> CC: Alasdair Kergon <agk@redhat.com> CC: Boaz Harrosh <bharrosh@panasas.com> CC: Jeff Garzik <jeff@garzik.org> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Generalized bio pool freeingKent Overstreet
With the old code, when you allocate a bio from a bio pool you have to implement your own destructor that knows how to find the bio pool the bio was originally allocated from. This adds a new field to struct bio (bi_pool) and changes bio_alloc_bioset() to use it. This makes various bio destructors unnecessary, so they're then deleted. v6: Explain the temporary if statement in bio_put Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de> CC: Alasdair Kergon <agk@redhat.com> CC: Nicholas Bellinger <nab@linux-iscsi.org> CC: Lars Ellenberg <lars.ellenberg@linbit.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-07-27dm thin: commit before gathering statusAlasdair G Kergon
Commit outstanding metadata before returning the status for a dm thin pool so that the numbers reported are as up-to-date as possible. The commit is not performed if the device is suspended or if the DM_NOFLUSH_FLAG is supplied by userspace and passed to the target through a new 'status_flags' parameter in the target's dm_status_fn. The userspace dmsetup tool will support the --noflush flag with the 'dmsetup status' and 'dmsetup wait' commands from version 1.02.76 onwards. Tested-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: use bool bitfields in struct dm_targetAlasdair G Kergon
Use boolean bit fields for flags in struct dm_target. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm crypt: rename struct convert_context sector fieldMikulas Patocka
Rename sector to cc_sector in dm-crypt's convert_context struct. This is preparation for a future patch that merges dm_io and convert_context which both have a "sector" field. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm crypt: store crypt_config instead of dm_target structAlasdair G Kergon
Store the crypt_config struct pointer directly in struct dm_crypt_io instead of the dm_target struct pointer. Target information is never used - only target->private is referenced, thus we can change it to point directly to struct crypt_config. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm crypt: move cipher data out of per_cpu structMikulas Patocka
Move static dm-crypt cipher data out of per-cpu structure. Cipher information is static, so it does not have to be in a per-cpu structure. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm crypt: rename pending fieldMikulas Patocka
There are two dm crypt structures that have a field called "pending". This patch renames them to "cc_pending" and "io_pending" to reduce confusion and ease searching the code. Also remove unnecessary initialisation of r in crypt_convert_block(). Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: replace simple_strtoulmajianpeng
Replace obsolete simple_strtoul() with kstrtou8/kstrtouint. Signed-off-by: majianpeng <majianpeng@gmail.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm: reject trailing characters in sccanf inputMikulas Patocka
Device mapper uses sscanf to convert arguments to numbers. The problem is that the way we use it ignores additional unmatched characters in the scanned string. For example, this `if (sscanf(string, "%d", &number) == 1)' will match a number, but also it will match number with some garbage appended, like "123abc". As a result, device mapper accepts garbage after some numbers. For example the command `dmsetup create vg1-new --table "0 16384 linear 254:1bla 34816bla"' will pass without an error. This patch fixes all sscanf uses in device mapper. It appends "%c" with a pointer to a dummy character variable to every sscanf statement. The construct `if (sscanf(string, "%d%c", &number, &dummy) == 1)' succeeds only if string is a null-terminated number (optionally preceded by some whitespace characters). If there is some character appended after the number, sscanf matches "%c", writes the character to the dummy variable and returns 2. We check the return value for 1 and consequently reject numbers with some garbage appended. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm crypt: add missing error handlingMikulas Patocka
Always set io->error to -EIO when an error is detected in dm-crypt. There were cases where an error code would be set only if we finish processing the last sector. If there were other encryption operations in flight, the error would be ignored and bio would be returned with success as if no error happened. This bug is present in kcryptd_crypt_write_convert, kcryptd_crypt_read_convert and kcryptd_async_done. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@kernel.org Reviewed-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-28dm crypt: fix mempool deadlockMikulas Patocka
This patch fixes a possible deadlock in dm-crypt's mempool use. Currently, dm-crypt reserves a mempool of MIN_BIO_PAGES reserved pages. It allocates first MIN_BIO_PAGES with non-failing allocation (the allocation cannot fail and waits until the mempool is refilled). Further pages are allocated with different gfp flags that allow failing. Because allocations may be done in parallel, this code can deadlock. Example: There are two processes, each tries to allocate MIN_BIO_PAGES and the processes run simultaneously. It may end up in a situation where each process allocates (MIN_BIO_PAGES / 2) pages. The mempool is exhausted. Each process waits for more pages to be freed to the mempool, which never happens. To avoid this deadlock scenario, this patch changes the code so that only the first page is allocated with non-failing gfp mask. Allocation of further pages may fail. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@kernel.org Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-03-20dm: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2011-09-25dm crypt: always disable discard_zeroes_dataMilan Broz
If optional discard support in dm-crypt is enabled, discards requests bypass the crypt queue and blocks of the underlying device are discarded. For the read path, discarded blocks are handled the same as normal ciphertext blocks, thus decrypted. So if the underlying device announces discarded regions return zeroes, dm-crypt must disable this flag because after decryption there is just random noise instead of zeroes. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-08-02dm crypt: optionally support discard requestsMilan Broz
Add optional parameter field to dmcrypt table and support "allow_discards" option. Discard requests bypass crypt queue processing. Bio is simple remapped to underlying device. Note that discard will be never enabled by default because of security consequences. It is up to the administrator to enable it for encrypted devices. (Note that userspace cryptsetup does not understand new optional parameters yet. Support for this will come later. Until then, you should use 'dmsetup' to enable and disable this.) Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
