path: root/drivers/md/bitmap.c
2006-03-26[PATCH] mempool: use common mempool kmalloc allocatorMatthew Dobson
This patch changes several mempool users, all of which are basically just wrappers around kmalloc(), to use the common mempool_kmalloc/kfree, rather than their own wrapper function, removing a bunch of duplicated code. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (21 commits) BUG_ON() Conversion in drivers/video/ BUG_ON() Conversion in drivers/parisc/ BUG_ON() Conversion in drivers/block/ BUG_ON() Conversion in sound/sparc/cs4231.c BUG_ON() Conversion in drivers/s390/block/dasd.c BUG_ON() Conversion in lib/swiotlb.c BUG_ON() Conversion in kernel/cpu.c BUG_ON() Conversion in ipc/msg.c BUG_ON() Conversion in block/elevator.c BUG_ON() Conversion in fs/coda/ BUG_ON() Conversion in fs/binfmt_elf_fdpic.c BUG_ON() Conversion in input/serio/hil_mlc.c BUG_ON() Conversion in md/dm-hw-handler.c BUG_ON() Conversion in md/bitmap.c The comment describing how MS_ASYNC works in msync.c is confusing rcu: undeclared variable used in documentation fix typos "wich" -> "which" typo patch for fs/ufs/super.c Fix simple typos tabify drivers/char/Makefile ...
2006-03-25[PATCH] md/bitmap.c:bitmap_mask_state(): fix inconsequent NULL checkingAdrian Bunk
We dereference bitmap both one line above and one line below this check rendering this check quite useless. Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24BUG_ON() Conversion in md/bitmap.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner and can better optimized away Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: make sure bitmap updates are visible through filesystemNeilBrown
When we update a page_cache page in the kernel, we need to flush_dache_page or userspace might not see the change. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: define and use safe_put_page for mdNeilBrown
md sometimes call put_page on NULL pointers (treating it like kfree). This is not safe, so define and use a 'safe_put_page' which checks for NULL. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: remove inappropriate limits in md/bitmap configuration.NeilBrown
The kernel should not be imposing these policy limits: The time between bitmap updates should certainly be allowed to be more than 15 seconds, and if someone wants a bitmap chunk size in excess of 4MB, the kernel isn't the place to stop them. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: convert various kmap calls to kmap_atomicNeilBrown
2006-01-06[PATCH] md: convert md to use kzalloc throughoutNeilBrown
Replace multiple kmalloc/memset pairs with kzalloc calls. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: clean up 'page' related names in mdNeilBrown
Substitute: page_cache_get -> get_page page_cache_release -> put_page PAGE_CACHE_SHIFT -> PAGE_SHIFT PAGE_CACHE_SIZE -> PAGE_SIZE PAGE_CACHE_MASK -> PAGE_MASK __free_page -> put_page because we aren't using the page cache, we are just using pages. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: move bitmap_create to after md array has been initialisedNeilBrown
This is important because bitmap_create uses mddev->resync_max_sectors and that doesn't have a valid value until after the array has been initialised (with pers->run()). [It doesn't make a difference for current personalities that support bitmaps, but will make a difference for raid10] This has the added advantage of meaning with can move the thread->timeout manipulation inside the bitmap.c code instead of sprinkling identical code throughout all personalities. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[PATCH] md: don't pass a NULL file* into ->prepare_write()Neil Brown
Some filesystems go oops. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] md: support BIO_RW_BARRIER for md/raid1NeilBrown
We can only accept BARRIER requests if all slaves handle barriers, and that can, of course, change with time.... So we keep track of whether the whole array seems safe for barriers, and also whether each individual rdev handles barriers. We initially assumes barriers are OK. When writing the superblock we try a barrier, and if that fails, we flag things for no-barriers. This will usually clear the flags fairly quickly. If writing the superblock finds that BIO_RW_BARRIER is -ENOTSUPP, we need to resubmit, so introduce function "md_super_wait" which waits for requests to finish, and retries ENOTSUPP requests without the barrier flag. When writing the real raid1, write requests which were BIO_RW_BARRIER but which aresn't supported need to be retried. So raid1d is enhanced to do this, and when any bio write completes (i.e. no retry needed) we remove it from the r1bio, so that devices needing retry are easy to find. We should hardly ever get -ENOTSUPP errors when writing data to the raid. It should only happen if: 1/ the device used to support BARRIER, but now doesn't. Few devices change like this, though raid1 can! or 2/ the array has no persistent superblock, so there was no opportunity to pre-test for barriers when writing the superblock. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] md: make md on-disk bitmaps not host-endianNeilBrown
Current bitmaps use set_bit et.al and so are host-endian, which means not-portable. Oops. Define a new version number (4) for which bitmaps are little-endian. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] md: convert 'faulty' and 'in_sync' fields to bits in 'flags' fieldNeilBrown
This has the advantage of removing the confusion caused by 'rdev_t' and 'mddev_t' both having 'in_sync' fields. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: remaining bits of drivers/*Al Viro
2005-09-09[PATCH] md: tidy up daemon stop/start code in md/bitmap.cNeilBrown
The bitmap code used to have two daemons, so there is some 'common' start/stop code. But now there is only one, so the common code is just noise. This patch tidies this up somewhat. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: ensure bitmap_writeback_daemon handles shutdown properly.NeilBrown
mddev->bitmap gets clearred before the writeback daemon is stopped. So the write_back daemon needs to be careful not to dereference the 'bitmap' if it is NULL. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: fix bitmap/read_sb_page so that it handles errors properly.NeilBrown
read_sb_page() assumed that if sync_page_io fails, the device would be marked faultly. However it isn't. So in the face of error, read_sb_page would loop forever. Redo the logic so that this cannot happen. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: do not set mddev->bitmap until bitmap is fully initialisedNeilBrown
When hot-adding a bitmap, bitmap_daemon_work could get called while the bitmap is being created, so don't set mddev->bitmap until the bitmap is ready. This requires freeing the bitmap inside bitmap_create if creation failed part-way through. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: make sure bitmap_daemon_work actually does work.NeilBrown
The 'lastrun' time wasn't being initialised, so it could be half a jiffie-cycle before it seemed to be time to do work again. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: add write-behind support for md/raid1NeilBrown
If a device is flagged 'WriteMostly' and the array has a bitmap, and the bitmap superblock indicates that write_behind is allowed, then write_behind is enabled for WriteMostly devices. Write requests will be acknowledges as complete to the caller (via b_end_io) when all non-WriteMostly devices have completed the write, but will not be cleared from the bitmap until all devices complete. This requires memory allocation to make a local copy of the data being written. If there is insufficient memory, then we fall-back on normal write semantics. Signed-Off-By: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: improve handling of bitmap initialisation.NeilBrown
When we find a 'stale' bitmap, possibly because it is new, we should just assume every bit needs to be set, but rather base the setting of bits on the current state of the array (degraded and recovery_cp). Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] md: make sure md bitmap updates are flushed when array is stopped.NeilBrown
The recent change to never ignore the bitmap, revealed that the bitmap isn't begin flushed properly when an array is stopped. We call bitmap_daemon_work three times as there is a three-stage pipeline for flushing updates to the bitmap file. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] md: always honour md bitmap being read from diskNeilBrown
The code currently will ignore the bitmap if the array seem to be in-sync. This is wrong if the array is degraded, and probably wrong anyway. If the bitmap says some chunks are not in in-sync, and the superblock says everything IS in sync, then something is clearly wrong, and it is safer to trust the bitmap. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-15[PATCH] md/raid1: clear bitmap when fullsync completesNeilBrown
We need to be careful differentiating between a resync of a complete array, in which we can clear the bitmap, and a resync of a degraded array, in which we cannot. This patch cleans all that up. Cc: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: make sure md/bitmap doesn't try to write a page with active ↵NeilBrown
writeback Due to the use of write-behind, it is possible for md to write a page to the bitmap file that is still completing writeback. This is not allowed. With this patch, we detect those cases and either force a sync write, or back off and try later, as appropriate. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: allow md intent bitmap to be stored near the superblock.NeilBrown
This provides an alternate to storing the bitmap in a separate file. The bitmap can be stored at a given offset from the superblock. Obviously the creator of the array must make sure this doesn't intersect with data.... After is good for version-0.90 superblocks. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: don't skip bitmap pages due to lack of bit that we just cleared.NeilBrown
When looking for pages that need cleaning we skip pages that don't have BITMAP_PAGE_CLEAN set. But if it is the 'current' page we will have cleared that bit ourselves, so skipping it is wrong. So: move the 'skip this page' inside 'if page != lastpage'. Also fold call of file_page_offset into the one place where the value (bit) is used. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: enable the bitmap write-back daemon and wait for it.NeilBrown
Currently we don't wait for updates to the bitmap to be flushed to disk properly. The infrastructure all there, but it isn't being used.... A separate kernel thread (bitmap_writeback_daemon) is needed to wait for each page as we cannot get callbacks when a page write completes. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: check return value of write_page, rather than ignore itNeilBrown
2005-06-21[PATCH] md: improve debug-printing of bitmap superblock.NeilBrown
- report sync_size properly - need /2 to convert sectors to KB - move everything over 2 spaces to allow proper spelling of "events cleared". Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md printk fixakpm@osdl.org
A u64 is not an unsigned long long. On power4 it is `long', and printk warns. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: make sure md bitmap is cleared on a clean start.NeilBrown
As the array-wide clean bit (in the superblock) is set more agressively than the bits in the bitmap are cleared, it is possible to have an array which is clean despite there being bits set in the bitmap. These bits will currently never get cleared, as they can only be cleared by a resync pass, which never happens. No, when reading bits from disk, be aware of whether the whole array is known to be in sync, and act accordingly. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: minor code rearrangement in bitmap_init_from_diskNeilBrown
2005-06-21[PATCH] md: print correct pid for newly created bitmap-writeback-daemon.NeilBrown
The debugging message printed the wrong pid, which didn't help remove bugs.... Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: a couple of tidyups relating to the bitmap file.NeilBrown
1/ When init from disk, it is a BUG if there is nowhere to init from, 2/ use seq_path to print path in /proc/mdstat Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: optimised resync using Bitmap based intent loggingNeilBrown
With this patch, the intent to write to some block in the array can be logged to a bitmap file. Each bit represents some number of sectors and is set before any update happens, and only cleared when all writes relating to all sectors are complete. After an unclean shutdown, information in this bitmap can be used to optimise resync - only sectors which could be out-of-sync need to be updated. Also if a drive is removed and then added back into an array, the recovery can make use of the bitmap to optimise reconstruction. This is not implemented in this patch. Currently the bitmap is stored in a file which must (obviously) be stored on a separate device. The patch only provided infrastructure. It does not update any personalities to bitmap intent logging. Md arrays can still be used with no bitmap file. This patch has minimal impact on such arrays. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
