path: root/drivers/leds/leds-lp5521.c
2011-06-27drivers/leds/leds-lp5521.c: fix section mismatchesRalf Baechle
Fix this section mismatch: WARNING: drivers/leds/leds-lp5521.o(.text+0xf2c): Section mismatch in reference from the function lp5521_probe() to the function .init.text:lp5521_init_led() The function lp5521_probe() references the function __init lp5521_init_led(). This is often because lp5521_probe lacks a __init annotation or the annotation of lp5521_init_led is wrong. Fixing this mismatch triggers one more mismatch, fix that one as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/leds/leds-lp5521.c: world-writable sysfs engine* filesVasiliy Kulikov
Don't allow everybody to change LED settings. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13leds-lp5521: modify the way of setting led device nameArun Murthy
Currently the led device name is fetched from the device_type in I2C_BOARD_INFO which comes from the platform data. This name is in turn used to create an entry in sysfs. If there exists two or more lp5521 on a particular platform, the device_type in I2C_BOARD_INFO has to be the same, else lp5521 driver probe wont be called and if used so, results in run time warning "cannot create sysfs with same name" and hence a failure. The name that is used to create sysfs entry is to be passed by the struct led_platform_data. Hence adding an element of type const char * and change in lp5521 driver to use this name in creating the led device if present else use the name obtained by I2C_BOARD_INFO. Signed-off-by: Arun Murthy <arun.murthy@stericsson.com> Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13leds: lp5521: fix circular lockingSamu Onkalo
Driver contained possibility for circular locking. One lock is held by sysfs-core and another one by the driver itself. This happened when the driver created or removed sysfs entries dynamically. There is no real need to do those operations. Now all the sysfs entries are created at probe and removed at removal. Engine load sysfs entries are now visible all the time. However, access to the entries fails if the engine is disabled or running. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Arun Murthy <arun.murthy@stericsson.com> Reviewed-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13drivers/leds/leds-lp5521.c: fix potential buffer overflowVasiliy Kulikov
The code doesn't check first sscanf() return value. If first sscanf() failed then c contains some garbage. It might lead to reading uninitialised stack data in the second sscanf() call. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-25drivers/leds/leds-lp5521.c: perform SW reset before detectionSamu Onkalo
Chip detection may fail if the chip is in some odd state for example after system restart. Chip doesn't have HW reset line. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-25drivers/leds/leds-lp5521.c: adjust delays and add comments to themSamu Onkalo
Delays were little bit too long. Adjust delay times and add some comments to them. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-25drivers/leds/leds-lp5521.c: change some macros to functionsSamu Onkalo
Some small macros changed to inline functions to have proper type checking. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12leds: driver for National Semiconductor LP5521 chipSamu Onkalo
This patchset provides support for LP5521 and LP5523 LED driver chips from National Semicondutor. Both drivers supports programmable engines and naturally LED class features. Documentation is provided as a part of the patchset. I created "leds" subdirectory under Documentation. Perhaps the rest of the leds* documentation should be moved there. Datasheets are freely available at National Semiconductor www pages. This patch: LP5521 chip is three channel led driver with programmable engines. Driver provides support for that chip for direct access via led class or via programmable engines. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
