path: root/drivers/leds/leds-atmel-pwm.c
2012-07-24leds: convert Atmel PWM LED driver to devm_kzalloc()Bryan Wu
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-04-17leds-atmel-pwm.c: Make pwmled_probe() __devinitNicolas Ferre
Commit 892a884 (leds: convert led platform drivers to module_platform_driver) is omitting the section mismatch error: so change annotation of the probe function to __devinit instead of __init. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Richard Purdie <richard.purdie@linuxfoundation.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2012-01-10leds: convert led platform drivers to module_platform_driverAxel Lin
Factor out some boilerplate code for platform driver registration into module_platform_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Haojian Zhuang <hzhuang1@marvell.com> [led-88pm860x.c] Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Michael Hennerich <hennerich@blackfin.uclinux.org> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31drivers/leds: Add module.h to files using it implicitlyPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in the leds dir are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-07-23leds: fix unsigned value overflow in atmel pwm driverLi Zefan
Fix an unsigned value overflow in the error handling code in the Atmel PWM driver. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-15leds: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable platform LED drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08PWM LED driverDavid Brownell
This is a LED driver using the PWM on newer SOCs from Atmel; brightness is controlled by changing the PWM duty cycle. So for example if you've set up two leds labeled "pwm0" and "pwm1": echo 0 > /sys/class/leds/pwm2/brightness # off (0%) echo 80 > /sys/class/leds/pwm2/brightness echo 255 > /sys/class/leds/pwm2/brightness # on (100%) Note that "brightness" here isn't linear; maybe that should change. Going from 4 to 8 probably doubles perceived brightness, while 244 to 248 is imperceptible. This is mostly intended to be a simple example of PWM, although it's realistic since LCD backlights are often driven with PWM to conserve battery power (and offer brightness options). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
