path: root/drivers/isdn/i4l/isdn_ttyfax.c
2012-02-21isdn: whitespace coding style cleanupJoe Perches
isdn source code uses a not-current coding style. Update the coding style used on a per-line basis so that git diff -w shows only elided blank lines at EOF. Done with emacs and some scripts and some typing. Built x86 allyesconfig. No detected change in objdump -d or size. Signed-off-by: Joe Perches <joe@perches.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-03-04drivers/isdn: correct use of ! and &Julia Lawall
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337 ("wmi: (!x & y) strikes again"), a bug was fixed that involved converting !x & y to !(x & y). The code below shows the same pattern, and thus should perhaps be fixed in the same way. This is not tested and clearly changes the semantics, so it is only something to consider. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E1,E2; @@ ( !E1 & !E2 | - !E1 & E2 + !(E1 & E2) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fix ! versus & precedence in various placesAlexey Dobriyan
Fix various instances of if (!expr & mask) which should probably have been if (!(expr & mask)) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-06-25[PATCH] drivers/isdn/i4l/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - remove the following unused global function: - isdn_audio.c: isdn_audio_2adpcm_flush - remove the following unused struct: - isdn_net.c: isdn_concap_demand_dial_dops Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
