path: root/drivers/isdn/hysdn/hysdn_init.c
2012-02-21isdn: whitespace coding style cleanupJoe Perches
isdn source code uses a not-current coding style. Update the coding style used on a per-line basis so that git diff -w shows only elided blank lines at EOF. Done with emacs and some scripts and some typing. Built x86 allyesconfig. No detected change in objdump -d or size. Signed-off-by: Joe Perches <joe@perches.com>
2011-02-09isdn: hysdn: Kill (partially buggy) CVS regision log reporting.David S. Miller
Some cases try to modify const strings, and in any event the CVS revision strings have not changed in over ten years making these printouts completely worthless. Just kill all of this stuff off. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-12[ISDN] hysdn: convert to PCI hotplug APIJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-08[PATCH] isdn: replace kmalloc+memset with kzallocBurman Yan
Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] hysdn: remove custom typesAndrew Morton
hysdn defines its own types: ulong, uint, uchar and word. Problem is, the module_param macros rely upon some of those identifiers having special meanings too. The net effect is that module_param() and friends cannot be used in ISDN because of this namespace clash. So remove the hysdn-private defines and open-code them all. Cc: Karsten Keil <kkeil@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] drivers/isdn/: make some code staticAdrian Bunk
This patch makes some needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Armin Schindler <armin@melware.de> Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
