path: root/drivers/isdn/hysdn/hysdn_boot.c
2018-07-04isdn: mark expected switch fall-throughsGustavo A. R. Silva
In preparation to enabling -Wimplicit-fallthrough, mark switch cases where we are expecting to fall through. Warning level 2 was used: -Wimplicit-fallthrough=2 Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-21isdn: whitespace coding style cleanupJoe Perches
isdn source code uses a not-current coding style. Update the coding style used on a per-line basis so that git diff -w shows only elided blank lines at EOF. Done with emacs and some scripts and some typing. Built x86 allyesconfig. No detected change in objdump -d or size. Signed-off-by: Joe Perches <joe@perches.com>
2010-03-15isdn: misplaced parenthesis in pof_handle_data()Roel Kluin
The parenthesis was misplaced. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[PATCH] isdn: replace kmalloc+memset with kzallocBurman Yan
Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] hysdn: remove custom typesAndrew Morton
hysdn defines its own types: ulong, uint, uchar and word. Problem is, the module_param macros rely upon some of those identifiers having special meanings too. The net effect is that module_param() and friends cannot be used in ISDN because of this namespace clash. So remove the hysdn-private defines and open-code them all. Cc: Karsten Keil <kkeil@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] drivers/isdn/: make some code staticAdrian Bunk
This patch makes some needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Armin Schindler <armin@melware.de> Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
