path: root/drivers/isdn/hisax/isdnhdlc.c
2009-07-25ISDN: Make isdnhdlc usable for other ISDN driversKarsten Keil
isdnhdlc is useful for other ISDN drivers as well. Move the include file to a central location and the source to the central isdn location. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-12-08[PATCH] isdn/hisax: use bitrev8Akinobu Mita
Use bitrev8 for hisax_st5481 driver. Acked-by: Karsten Keil <kkeil@suse.de> Cc: Kai Germaschewski <kai.germaschewski@gmx.de> Cc: Frode Isaksen <fisaksen@bewan.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
