* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
This patch converts pci_table entries, where .subvendor=PCI_ANY_ID and
.subdevice=PCI_ANY_ID, .class=0 and .class_mask=0, to use the
PCI_VDEVICE macro, and thus improves readability.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Gilles Espinasse <g.esp@free.fr>
A few subdevice IDs seem to have been dropped when hfc_multi was
included upstream, just compare the list at
http://www.openvox.cn/viewvc/misdn/trunk/hfc_multi.c?revision=75&view=annotate#l175
with the IDs in drivers/isdn/hardware/mISDN/hfcmulti.c
Added PCIe 2 Port card and LED settings (same as PCI)
Do not use <linux/pci_ids.h> /KKe
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Karsten Keil <keil@b1-systems.de>
The error return should be negative. Its only caller that acts upon its
return, handle_bmsg(), transmits the positive error but can also return
negative errors.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
The code checked slot_rx twice. Check slot_tx by analogy with the bank
case.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression E;
*E && E
*E || E
// </smpl>
The returned error should stay negative
Acked-by: Karsten Keil <keil@b1-systems.de>
In the PCI probe function struct pci_device_id points to the matched
entry of the ID table, but for devices which are matched with
PCI_ANY_ID sub IDs we want display the IDs of the device itself.
Clearing B-channel is needed in every driver, so it makes sense
to have it as common function.
The new ID is validated by Cologne Chip.
LEDs control is also supported.
Signed-off-by: Andreas Eversberg <andreas@eversberg.eu>
This patch make debug printk's KERN_DEBUG and also fix some
codestyle issues.
new id for HFC-8S
New version without emulating arch specific stuff for the other
architectures, the special IO and init functions for the 8xx
microcontroller are in a separate include file.
DTMF digits were sent up to socket in locked state.
Receive audio stream was not enabled in certain condition.
Reduce stack size memory footprint of mISDN_dsp.
(From 1468 bytes for dsp_cmx_send on i386 down to 44).
Signed-off-by: Frank Seidel <frank@f-seidel.de>
Added tx-fifo information for calculation of current delay to sync tx and rx
streams for echo canceler.
This patch was made by Titus Moldovan and provides IOCTL functions for enabling
and disabling the controller's built in watchdog. The use is optional.
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f = E
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
In each case, if the NULL test is necessary, then the dereference should be
moved below the NULL test.
The semantic patch that makes this change is as follows:
// <smpl>
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
... when != E
when != i
if (E == NULL) S
+ i = E->fld;
// </smpl>
Signed-off-by: Karsten Keil <kkeil@suse.de>
Create /sys/class/mISDN and implement functions to handle
device renames.
Signed-Off-By: Matthias Urlichs <matthias@urlichs.de>
minor typo fix
compiler warning fix
Fix false irq detection on disabled irqs.
Add ISDN sample clock API to mISDN core (new file clock.c)
hfcmulti and mISDNdsp use clock API.
This prevents underrun of fifo when filled and in case of an underrun it
prevents subsequent underruns due to jitter.
Improve dsp, so buffers are kept filled with a certain delay, so moderate
jitter will not cause underrun all the time -> the audio quality is highly
improved. tones are not interrupted by gaps anymore, except when CPU is
stalling or in high load.
Remove references to external zaptel modules and some
cosmetic cleanups.
Impact: make use of the __iomem address space modifier, and change u_char *,
u_short * and u_int * to void *
Fix more than 30 sparse warnings of this or similar type:
drivers/isdn/hardware/mISDN/hfcmulti.c:261:31: warning: incorrect type in argument 2 (different address spaces)
drivers/isdn/hardware/mISDN/hfcmulti.c:261:31: got unsigned char [usertype] *
drivers/isdn/hardware/mISDN/hfcmulti.c:261:31: expected void volatile [noderef] <asn:2>*addr
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Acked-by: Karsten Keil <kkeil@suse.de>
Fix this sparse warnings:
drivers/isdn/hardware/mISDN/hfcmulti.c:794: warning: 'vpm_check' defined but not used
drivers/isdn/mISDN/dsp_cmx.c:1546: warning: 'dsp_start_jiffies' defined but not used
'plx_lock' is only used within hfcmulti.c.
Fix this warning:
drivers/isdn/hardware/mISDN/hfcmulti.c:176:1: warning: symbol 'plx_lock' shadows an earlier one
drivers/isdn/hardware/mISDN/hfcmulti.c:175:19: originally declared here
The warnings fixed by including an header file for the appropriate
prototype are marked with "*", for all others the corresonponding
symbol has been made static. This patch fixes all such issues in
mISDN.
drivers/isdn/hardware/mISDN/hfcmulti.c:174:5: warning: symbol 'plxsd_master' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:426:1: warning: symbol 'write_fifo_regio' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:447:1: warning: symbol 'write_fifo_pcimem' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:469:1: warning: symbol 'read_fifo_regio' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:491:1: warning: symbol 'read_fifo_pcimem' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:710:1: warning: symbol 'vpm_init' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:793:1: warning: symbol 'vpm_check' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:816:1: warning: symbol 'vpm_echocan_on' was not declared. Should it be static?
drivers/isdn/hardware/mISDN/hfcmulti.c:848:1: warning: symbol 'vpm_echocan_off' was not declared. Should it be static?
* drivers/isdn/mISDN/l1oip_codec.c:224:1: warning: symbol 'l1oip_law_to_4bit' was not declared. Should it be static?
* drivers/isdn/mISDN/l1oip_codec.c:261:1: warning: symbol 'l1oip_4bit_to_law' was not declared. Should it be static?
* drivers/isdn/mISDN/l1oip_codec.c:281:1: warning: symbol 'l1oip_alaw_to_ulaw' was not declared. Should it be static?
* drivers/isdn/mISDN/l1oip_codec.c:294:1: warning: symbol 'l1oip_ulaw_to_alaw' was not declared. Should it be static?
* drivers/isdn/mISDN/l1oip_codec.c:311:1: warning: symbol 'l1oip_4bit_free' was not declared. Should it be static?
* drivers/isdn/mISDN/l1oip_codec.c:322:1: warning: symbol 'l1oip_4bit_alloc' was not declared. Should it be static?
drivers/isdn/mISDN/core.c:29:1: warning: symbol 'device_lock' was not declared. Should it be static?
drivers/isdn/mISDN/core.c:34:1: warning: symbol 'bp_lock' was not declared. Should it be static?
drivers/isdn/mISDN/core.c:196:1: warning: symbol 'mISDNInit' was not declared. Should it be static?
drivers/isdn/mISDN/core.c:227:6: warning: symbol 'mISDN_cleanup' was not declared. Should it be static?
drivers/isdn/mISDN/stack.c:40:1: warning: symbol 'mISDN_queue_message' was not declared. Should it be static?
* drivers/isdn/mISDN/layer1.c:388:1: warning: symbol 'l1_init' was not declared. Should it be static?
* drivers/isdn/mISDN/layer1.c:400:1: warning: symbol 'l1_cleanup' was not declared. Should it be static?
drivers/isdn/mISDN/layer2.c:469:1: warning: symbol 'iframe_error' was not declared. Should it be static?
drivers/isdn/mISDN/layer2.c:487:1: warning: symbol 'super_error' was not declared. Should it be static?
drivers/isdn/mISDN/layer2.c:496:1: warning: symbol 'unnum_error' was not declared. Should it be static?
drivers/isdn/mISDN/layer2.c:509:1: warning: symbol 'UI_error' was not declared. Should it be static?
drivers/isdn/mISDN/layer2.c:522:1: warning: symbol 'FRMR_error' was not declared. Should it be static?
drivers/isdn/mISDN/layer2.c:1069:1: warning: symbol 'enquiry_cr' was not declared. Should it be static?
* drivers/isdn/mISDN/layer2.c:2196:1: warning: symbol 'Isdnl2_Init' was not declared. Should it be static?
* drivers/isdn/mISDN/layer2.c:2210:1: warning: symbol 'Isdnl2_cleanup' was not declared. Should it be static?
drivers/isdn/mISDN/tei.c:397:1: warning: symbol 'random_ri' was not declared. Should it be static?
* drivers/isdn/mISDN/timerdev.c:277:1: warning: symbol 'mISDN_inittimer' was not declared. Should it be static?
* drivers/isdn/mISDN/timerdev.c:288:6: warning: symbol 'mISDN_timer_cleanup' was not declared. Should it be static?
drivers/isdn/mISDN/dsp_core.c:164:12: warning: symbol 'mISDN_dsp_revision' was not declared. Should it be static?
drivers/isdn/mISDN/dsp_cmx.c:1543:5: warning: symbol 'samplecount' was not declared. Should it be static?
drivers/isdn/mISDN/dsp_cmx.c:1546:5: warning: symbol 'dsp_start_jiffies' was not declared. Should it be static?
drivers/isdn/mISDN/dsp_cmx.c:1547:16: warning: symbol 'dsp_start_tv' was not declared. Should it be static?
drivers/isdn/mISDN/dsp_tones.c:239:3: warning: symbol 'pattern' was not declared. Should it be static?
drivers/isdn/mISDN/dsp_audio.c:33:4: warning: symbol 'dsp_audio_ulaw_to_alaw' was not declared. Should it be static?
Fix more than 100 (all remaining in mISDN) sparse warnings:
drivers/isdn/hardware/mISDN/hfcmulti.c:***:**: warning: Using plain integer as NULL pointer
drivers/isdn/mISDN/dsp_tones.c:***:**: warning: Using plain integer as NULL pointer
drivers/isdn/mISDN/dsp_pipeline.c:***:**: warning: Using plain integer as NULL pointer
Also the HFC-4S IOB4ST has DIP switches and jumpers to configure
the port.
The driver was not so bad at big endian at all, only the optimised fifo
read/write functions need a fix, with this fix the driver works on
a pegasus PPC machine.
The channelmap should have the same size on 32 and 64 bit systems
and should not depend on endianess.
Thanks to David Woodhouse for spotting this.
Enable support for cards with Cologne Chip AG's HFC multiport
chip.
