path: root/drivers/isdn/hardware/eicon/message.c
2011-04-17isdn: eicon: Fix set-but-unused variables.David S. Miller
The variable 'best_id' is set but unused in diva_mnt_add_xdi_adapter(). Just kill it off. Similarly for the variable 'CIP' in connect_req(), 'Number' in sig_ind(), 'Info' in dtmf_confirmation() mixer_command() fax_connect_ack_command() fax_edata_ack_command() rtp_connect_b3_res_command() and rtp_connect_b3_res_command(), and 'a' in mixer_indication_coefs_set(), Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15i4l: change magic numbers in Eicon DIVA ISDN driver to symbolic namesIan Munsie
Replace references to the '20' magic number found throughout the Eicon ISDN driver for the length of the station_id field in the T30_INFO struct with the T30_MAX_STATION_ID_LENGTH symbolic constant. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Cc: Armin Schindler <mac@melware.de> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15i4l: silence compiler warnings for array access in Eicon DIVA ISDN driverIan Munsie
When compiling this driver, the compiler throws the following warnings: drivers/isdn/hardware/eicon/message.c:8426: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8427: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8434: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8435: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8436: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8447: warning: array subscript is above array bounds This arises from the particular semantics the driver is using to write to the nlc array (static byte[256]). The array has a length in byte 0 followed by a T30_INFO struct starting at byte 1. The T30_INFO struct has a number of variable length strings after the station_id entry, which cannot be explicitly defined in the struct and the driver accesses them with an array index to station_id beyond the length of station_id. This patch merely changes the semantics that the driver uses to access the entries after the station_id entry to use the original 256 byte nlc array taking the offset and length of the station_id entry to calculate where to write in the array, thereby silencing the warning. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Cc: Armin Schindler <mac@melware.de> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04isdn: eicon: Use offsetofJiri Slaby
Use offsetof instead of explicit implementation. * fixes bug with omitted & like: len = (byte)(((T30_INFO *) 0)->station_id + 20) * avoids compiler warnings with wrong sizes (pointer-to-char cast): len = (byte)(&(((T30_INFO *) 0)->universal_6)); * cleans up the code Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Karsten Keil <isdn@linux-pingi.de> Acked-by: Armin Schindler <armin@melware.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-25ISDN: ARRAY_SIZE changesKarsten Keil
These changes were a direct result of using a semantic patch More information can be found at http://www.emn.fr/x-info/coccinelle/ Modified some of the changes to avoid the extra define. Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-02-27drivers/isdn/hardware/eicon: fix sparse warnings: Should it be static?Hannes Eder
Impact: Make symbols static. Fix this sparse warnings: drivers/isdn/hardware/eicon/message.c:1197:6: warning: symbol 'connect_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1414:6: warning: symbol 'connect_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1570:6: warning: symbol 'connect_a_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1576:6: warning: symbol 'disconnect_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1631:6: warning: symbol 'disconnect_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1658:6: warning: symbol 'listen_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1707:6: warning: symbol 'info_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1816:6: warning: symbol 'info_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1822:6: warning: symbol 'alert_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:1852:6: warning: symbol 'facility_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:2602:6: warning: symbol 'facility_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:2608:6: warning: symbol 'connect_b3_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:2842:6: warning: symbol 'connect_b3_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:2957:6: warning: symbol 'connect_b3_a_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:2977:6: warning: symbol 'disconnect_b3_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3033:6: warning: symbol 'disconnect_b3_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3089:6: warning: symbol 'data_b3_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3166:6: warning: symbol 'data_b3_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3199:6: warning: symbol 'reset_b3_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3240:6: warning: symbol 'reset_b3_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3264:6: warning: symbol 'connect_b3_t90_a_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3298:6: warning: symbol 'select_b_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8692:6: warning: symbol 'sig_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8792:6: warning: symbol 'send_data' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16isdn: eicon: fix sparse warning: make global functions staticHannes Eder
Fix this sparse warnings by making the functions static: drivers/isdn/hardware/eicon/di.c:356:6: warning: symbol 'isdn_rc' was not declared. Should it be static? drivers/isdn/hardware/eicon/di.c:558:6: warning: symbol 'isdn_ind' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:595:6: warning: symbol 'api_parse' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:634:6: warning: symbol 'api_save_msg' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:666:6: warning: symbol 'api_load_msg' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3417:6: warning: symbol 'manufacturer_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:3745:6: warning: symbol 'manufacturer_res' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:4077:6: warning: symbol 'control_rc' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:4743:6: warning: symbol 'data_rc' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:4779:6: warning: symbol 'data_ack' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:4805:6: warning: symbol 'sig_ind' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:6173:6: warning: symbol 'SendInfo' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:6349:6: warning: symbol 'SendMultiIE' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:6468:6: warning: symbol 'nl_ind' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:7250:6: warning: symbol 'get_plci' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:7409:6: warning: symbol 'add_d' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:7427:6: warning: symbol 'add_ai' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:7448:6: warning: symbol 'add_b1' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:7912:6: warning: symbol 'add_b23' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8709:6: warning: symbol 'nl_req_ncci' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8731:6: warning: symbol 'send_req' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8866:6: warning: symbol 'listen_check' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8909:6: warning: symbol 'IndParse' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:8994:6: warning: symbol 'ie_compare' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:9003:6: warning: symbol 'find_cip' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:9071:6: warning: symbol 'SetVoiceChannel' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:9089:6: warning: symbol 'VoiceChannelOff' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:9102:6: warning: symbol 'AdvCodecSupport' was not declared. Should it be static? drivers/isdn/hardware/eicon/message.c:9198:6: warning: symbol 'CodecIdCheck' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-28eicon: fix sparse integer as NULL pointer warningsHarvey Harrison
drivers/isdn/hardware/eicon/message.c:745:47: warning: Using plain integer as NULL pointer drivers/isdn/hardware/eicon/message.c:761:45: warning: Using plain integer as NULL pointer drivers/isdn/hardware/eicon/message.c:9122:16: warning: Using plain integer as NULL pointer drivers/isdn/hardware/eicon/message.c:9147:16: warning: Using plain integer as NULL pointer drivers/isdn/hardware/eicon/message.c:9173:14: warning: Using plain integer as NULL pointer drivers/isdn/hardware/eicon/divasmain.c:396:23: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/isdn/hardware/eicon/message.c fix 'and' typo in eicons' AddInfo()Roel Kluin
'!' has a higher priority than '&'. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-05-23drivers/isdn/hardware/eicon/message.c warning fixesAndrew Morton
Squash these: drivers/isdn/hardware/eicon/message.c: In function 'api_put': drivers/isdn/hardware/eicon/message.c:536: warning: cast from pointer to integer of different size drivers/isdn/hardware/eicon/message.c: In function 'plci_free_msg_in_queue': drivers/isdn/hardware/eicon/message.c:1035: warning: cast to pointer from integer of different size drivers/isdn/hardware/eicon/message.c: In function 'data_b3_req': drivers/isdn/hardware/eicon/message.c:3121: warning: cast to pointer from integer of different size drivers/isdn/hardware/eicon/message.c:3154: warning: cast to pointer from integer of different size drivers/isdn/hardware/eicon/message.c: In function 'callback': drivers/isdn/hardware/eicon/message.c:4060: warning: cast to pointer from integer of different size drivers/isdn/hardware/eicon/message.c: In function 'nl_ind': drivers/isdn/hardware/eicon/message.c:7137: warning: cast from pointer to integer of different size Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] isdn-eicon: Use ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] drivers/isdn/hardware/eicon/: convert to generic boolean-valuesRichard Knutsson
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
