If the interrupt configuration matches the current configuration, then
don't bother writing the configuration again.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
The firmware parameter that contains the IRQ sense bits may also contain
other data. When return the IRQ type, bits outside of these sense bits
should be masked. If these bits are not masked and
irq_create_fwspec_mapping() is called to map an IRQ, then the comparison
of the type returned from irq_domain_translate() will never match
that returned by irq_get_trigger_type() (because this function masks the
none sense bits) and so we will always call irq_set_irq_type() to program
the type even if it was not really necessary.
Currently, the downside to this is unnecessarily re-programmming the type
but nevertheless this should be avoided.
The Tegra LIC and TI Crossbar irqchips all have client instances (from
reviewing the device-tree sources) where bits outside the IRQ sense bits
are set, but do not mask these bits. Therefore, ensure these bits are
masked for these irqchips.
The GICv3 driver wrongly assumes that it runs on the non-secure
side of a secure-enabled system, while it could be on a system
with a single security state, or a GICv3 with GICD_CTLR.DS set.
Either way, it is important to configure this properly, or
interrupts will simply not be delivered on this HW.
Cc: stable@vger.kernel.org
Reported-by: Peter Maydell <peter.maydell@linaro.org>
Tested-by: Peter Maydell <peter.maydell@linaro.org>
Alex Barba <alex.barba@broadcom.com> discovered Broadcom NS2 GICv2m
implementation has an erratum where the MSI data needs to be the SPI
number subtracted by an offset of 32, for the correct MSI interrupt
to be triggered.
Here we are adding the workaround based on readings from the MSI_IIDR
register, which contains a value unique to Broadcom NS2 GICv2m
Reported-by: Alex Barba <alex.barba@broadcom.com>
Signed-off-by: Ray Jui <ray.jui@broadcom.com>
of_platform_device_create() returns NULL on error, it never returns
error pointers.
Fixes: ed2a1002d25c ('irqchip/mbigen: Handle multiple device nodes in a mbigen module')
We are not checking whether the requested device identifier fits into
the device table memory or not. The function its_create_device()
assumes that enough memory has been allocated for whole DevID space
(reported by ITS_TYPER.Devbits) during the ITS probe() and continues
to initialize ITS hardware.
This assumption is not perfect, sometimes we reduce memory size either
because of its size crossing MAX_ORDER-1 or BASERn max size limit. The
MAPD command fails if 'Device ID' is outside of device table range.
Add a simple validation check to avoid MAPD failures since we are
not handling ITS command errors. This change also helps to return an
error -ENOMEM instead of success to caller.
Signed-off-by: Shanker Donthineni <shankerd@codeaurora.org>
The change adds improved support of NXP LPC32xx MIC, SIC1 and SIC2
interrupt controllers.
This is a list of new features in comparison to the legacy driver:
* irq types are taken from device tree settings, no more need to
hardcode them,
* old driver is based on irq_domain_add_legacy, which causes problems
with handling MIC hardware interrupt 0 produced by SIC1,
* there is one driver for MIC, SIC1 and SIC2, no more need to handle
them separately, e.g. have two separate handlers for SIC1 and SIC2,
* the driver does not have any dependencies on hardcoded register
offsets,
* the driver is much simpler for maintenance,
* SPARSE_IRQS option is supported.
Legacy LPC32xx interrupt controller driver was broken since commit
76ba59f8366f ("genirq: Add irq_domain-aware core IRQ handler"), which
requires a private interrupt handler, otherwise any SIC1 generated
interrupt (mapped to MIC hwirq 0) breaks the kernel with the message
"unexpected IRQ trap at vector 00".
The change disables compilation of a legacy driver found at
arch/arm/mach-lpc32xx/irq.c, the file will be removed in a separate
commit.
Fixes: 76ba59f8366f ("genirq: Add irq_domain-aware core IRQ handler")
Tested-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
When an IPI is generated by a CPU, the pattern looks roughly like:
<write shared data>
smp_wmb();
<write to GIC to signal SGI>
On the receiving CPU we rely on the fact that, once we've taken the
interrupt, then the freshly written shared data must be visible to us.
Put another way, the CPU isn't going to speculate taking an interrupt.
Unfortunately, this assumption turns out to be broken.
Consider that CPUx wants to send an IPI to CPUy, which will cause CPUy
to read some shared_data. Before CPUx has done anything, a random
peripheral raises an IRQ to the GIC and the IRQ line on CPUy is raised.
CPUy then takes the IRQ and starts executing the entry code, heading
towards gic_handle_irq. Furthermore, let's assume that a bunch of the
previous interrupts handled by CPUy were SGIs, so the branch predictor
kicks in and speculates that irqnr will be <16 and we're likely to
head into handle_IPI. The prefetcher then grabs a speculative copy of
shared_data which contains a stale value.
Meanwhile, CPUx gets round to updating shared_data and asking the GIC
to send an SGI to CPUy. Internally, the GIC decides that the SGI is
more important than the peripheral interrupt (which hasn't yet been
ACKed) but doesn't need to do anything to CPUy, because the IRQ line
is already raised.
CPUy then reads the ACK register on the GIC, sees the SGI value which
confirms the branch prediction and we end up with a stale shared_data
value.
This patch fixes the problem by adding an smp_rmb() to the IPI entry
code in gic_handle_irq. As it turns out, the combination of a control
dependency and an ISB instruction from the EOI in the GICv3 driver is
enough to provide the ordering we need, so we add a comment there
justifying the absence of an explicit smp_rmb().
Some kind of Freescale Layerscape SoC provides a MSI
implementation which uses two SCFG registers MSIIR and
MSIR to support 32 MSI interrupts for each PCIe controller.
The patch is to support it.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Tested-by: Alexander Stein <alexander.stein@systec-electronic.com>
Plug the partitioning layer into the GICv3 PPI code, parsing the
DT and building the partition affinities and providing the generic
code with partition data and callbacks.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: devicetree@vger.kernel.org
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Rob Herring <robh+dt@kernel.org>
Link: http://lkml.kernel.org/r/1460365075-7316-5-git-send-email-marc.zyngier@arm.com
We've unfortunately started seeing a situation where percpu interrupts
are partitioned in the system: one arbitrary set of CPUs has an
interrupt connected to a type of device, while another disjoint
set of CPUs has the same interrupt connected to another type of device.
This makes it impossible to have a device driver requesting this interrupt
using the current percpu-interrupt abstraction, as the same interrupt number
is now potentially claimed by at least two drivers, and we forbid interrupt
sharing on per-cpu interrupt.
A solution to this is to turn things upside down. Let's assume that our
system describes all the possible partitions for a given interrupt, and
give each of them a unique identifier. It is then possible to create
a namespace where the affinity identifier itself is a form of interrupt
number. At this point, it becomes easy to implement a set of partitions
as a cascaded irqchip, each affinity identifier being the HW irq.
This allows us to keep a number of nice properties:
- Each partition results in a separate percpu-interrupt (with a restrictied
affinity), which keeps drivers happy.
- Because the underlying interrupt is still per-cpu, the overhead of
the indirection can be kept pretty minimal.
- The core code can ignore most of that crap.
For that purpose, we implement a small library that deals with some of
the boilerplate code, relying on platform-specific drivers to provide
a description of the affinity sets and a set of callbacks.
Link: http://lkml.kernel.org/r/1460365075-7316-4-git-send-email-marc.zyngier@arm.com
Commit 2a0787051182 ("irqchip/mips-gic: Use gic_vpes instead of
NR_CPUS") & commit 78930f09b940 ("irqchip/mips-gic: Clear percpu_masks
correctly when mapping") both introduce code which accesses gic_vpes
entries in the pcpu_masks array. However, this array has length NR_CPUS.
If NR_CPUS is less than gic_vpes (ie. the kernel supports use of less
CPUs than are present in the system) then we overrun the array, clobber
some other data & generally die pretty promptly.
Most notably this affects uniprocessor kernels running on any multicore
or multithreaded Malta with a GIC (ie. the vast majority of real Malta
boards).
Fix this by only accessing up to min(gic_vpes, NR_CPUS) entries in the
pcpu_masks array, preventing the array overrun.
Fixes: 2a0787051182 ("irqchip/mips-gic: Use gic_vpes instead of NR_CPUS")
Fixes: 78930f09b940 ("irqchip/mips-gic: Clear percpu_masks correctly when mapping")
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: Marc Zyngier <marc.zyngier@arm.com>
Link: http://lkml.kernel.org/r/1461234714-9975-1-git-send-email-paul.burton@imgtec.com
This config is selected by CONFIG_ARCH_HISI, so there is no point to have it
user configurable.
While at it move the config option to the proper place in the alphabetically
sorted option list.
Requested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Ma Jun <majun258@huawei.com>
Cc: mark.rutland@arm.com
Cc: jason@lakedaemon.net
Cc: marc.zyngier@arm.com
Cc: Catalin.Marinas@arm.com
Cc: guohanjun@huawei.com
Cc: Will.Deacon@arm.com
Cc: huxinwei@huawei.com
Cc: lizefan@huawei.com
Cc: dingtianhong@huawei.com
Cc: zhaojunhua@hisilicon.com
Cc: liguozhu@hisilicon.com
Link: http://lkml.kernel.org/r/1458723993-21044-3-git-send-email-majun258@huawei.com
Each mbigen device is represented as a independent platform device. If the
devices belong to the same mbigen hardware module, then the register space for
these devices is the same. That leads to a resource conflict.
The solution for this is to represent the mbigen module as a platform device
and make the mbigen devices subdevices of that. The register space is
associated to the mbigen module and therefor the resource conflict is avoided.
[ tglx: Massaged changelog, cleaned up the code and removed the silly printk ]
Link: http://lkml.kernel.org/r/1458203641-17172-3-git-send-email-majun258@huawei.com
Current code calls irq_domain_alloc_irqs_parent() in .alloc,
so it should call irq_domain_free_irqs_parent() accordingly in .free.
Fix it by switching to use irq_domain_free_irqs_common() instead of
the open-coded private implementation.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: linux-tegra@vger.kernel.org
Link: http://lkml.kernel.org/r/1458477845.28679.1.camel@ingics.com
The "msi_domain" variable is NULL here so it leads to a NULL dereference. It
looks like we actually intended to free "middle_domain".
Fixes: e6b78f2c3e14 ('irqchip: Add the Alpine MSIX interrupt controller')
Cc: Antoine Tenart <antoine.tenart@free-electrons.com>
Cc: kernel-janitors@vger.kernel.org
Cc: Tsahee Zidenberg <tsahee@annapurnalabs.com>
Link: http://lkml.kernel.org/r/20160311081442.GE31887@mwanda
The of_io_request_and_map() returns a valid pointer in iomem region or
ERR_PTR(), check for NULL always fails and may cause a NULL pointer
dereference on error path.
Fixes: 25e34b44313b ("irqchip/mxs: Prepare driver for hardware with different offsets")
Cc: Oleksij Rempel <linux@rempel-privat.de>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Shawn Guo <shawnguo@kernel.org>
Link: http://lkml.kernel.org/r/1457486500-10237-1-git-send-email-vz@mleia.com
Fixes: 0e841b04c829 ("irqchip/sunxi-nmi: Switch to of_io_request_and_map() from of_iomap()")
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Link: http://lkml.kernel.org/r/1457486489-10189-1-git-send-email-vz@mleia.com
In the add-on file for the GIC dealing with the RealView family
we currently only handle the PB11MPCore, let's extend this to
manage the RealView EB ARM11MPCore as well. The Revision B of the
ARM11MPCore core tile is a bit special and needs special handling
as it moves a system control register around at random.
This patch adds the Alpine MSIX interrupt controller driver.
Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Signed-off-by: Tsahee Zidenberg <tsahee@annapurnalabs.com>
Always return IRQ_SET_MASK_OK_DONE instead of IRQ_SET_MASK_OK when the
affinity has been updated. When using stacked irqchips, returning
IRQ_SET_MASK_OK_DONE means skipping all descendant irqchips.
gicv3_init_bases() is the only caller for its_init(),
also it is a __init function, so mark its_init() as __init too,
then recursively mark the functions called as __init.
This will help to introduce ITS initialization using ACPI tables as
we will use acpi_table_parse_entries family functions there which
belong to __init section as well.
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Tomasz Nowicki <tn@semihalf.com>
The gic_root_node variable defined in ITS driver is not actually
used, so just remove it.
Following ACPI spec:
On systems supporting GICv3 and above, GICR Base Address in MADT GICC
structure holds the 64-bit physical address of the associated Redistributor.
If all of the GIC Redistributors are in the always-on power domain,
GICR structures should be used to describe the Redistributors instead,
and this field must be set to 0.
It means that we have two ways to initialize registirbutors map.
1. via GICD structure which can accommodate many redistributors as a region
2. via GICC which is able to describe single redistributor
This patch is going to add support for second option.
Considering redistributors, GICD and GICC subtables have be mutually
exclusive. While discovering and mapping redistributor, we need to know
its size in advance. For the GICC case, redistributor can be in
a power-domain that is off, thus we cannot relay on GICR TYPER register.
Therefore, we get GIC version from distributor register and map 2xSZ_64K
for GICv3 and 4xSZ_64K for GICv4.
With the refator of gic_of_init(), GICv3/4 can be initialized
by gic_init_bases() with gic distributor base address and gic
redistributor region(s).
So get the redistributor region base addresses from MADT GIC
redistributor subtable, and the distributor base address from
GICD subtable to init GICv3 irqchip in ACPI way.
Note: GIC redistributor base address may also be provided in
GICC structures on systems supporting GICv3 and above if the GIC
Redistributors are not in the always-on power domain, this
patch didn't implement such feature yet.
Isolate hardware abstraction (FDT) code to gic_of_init().
Rest of the logic goes to gic_init_bases() and expects well
defined data to initialize GIC properly. The same solution
is used for GICv2 driver.
This is needed for ACPI initialization later.
Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org>
The new property will allow to specify the range of GIC hwirqs to use for IPIs.
This is an optinal property. We preserve the previous behaviour of allocating
the last 2 * gic_vpes if it's not specified or DT is not supported.
Signed-off-by: Qais Yousef <qais.yousef@imgtec.com>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: <jason@lakedaemon.net>
Cc: <marc.zyngier@arm.com>
Cc: <jiang.liu@linux.intel.com>
Cc: <linux-mips@linux-mips.org>
Cc: <lisa.parratt@imgtec.com>
Cc: Qais Yousef <qsyousef@gmail.com>
Link: http://lkml.kernel.org/r/1449580830-23652-20-git-send-email-qais.yousef@imgtec.com
This commit does several things to avoid breaking bisectability.
1- Remove IPI init code from irqchip/mips-gic
2- Implement the new irqchip->send_ipi() in irqchip/mips-gic
3- Select GENERIC_IRQ_IPI Kconfig symbol for MIPS_GIC
4- Change MIPS SMP to use the generic IPI implementation
Only the SMP variants that use GIC were converted as it's the only irqchip that
will have the support for generic IPI for now.
Link: http://lkml.kernel.org/r/1449580830-23652-18-git-send-email-qais.yousef@imgtec.com
When setting the mapping for a hwirq, make sure we clear percpu_masks for
all other cpus in case it was set previously.
Link: http://lkml.kernel.org/r/1449580830-23652-16-git-send-email-qais.yousef@imgtec.com
NR_CPUS is set by Kconfig and could be much higher than what actually is in the
system.
gic_vpes should be a true representitives of the number of cpus in the system,
so use it instead.
Link: http://lkml.kernel.org/r/1449580830-23652-15-git-send-email-qais.yousef@imgtec.com
Now the root gic_irq_domain is split into device and IPI domains.
This form provides a better representation of how the root domain is split into
2. One for devices and one for IPIs.
Link: http://lkml.kernel.org/r/1449580830-23652-14-git-send-email-qais.yousef@imgtec.com
Add a new ipi domain on top of the normal domain.
MIPS GIC now supports dynamic allocation of an IPI.
Link: http://lkml.kernel.org/r/1449580830-23652-13-git-send-email-qais.yousef@imgtec.com
git://git.infradead.org/users/jcooper/linux into irq/core
Pull the second round of irqchip core changes for v4.6 from Jason Cooper:
- mvebu:
- Add odmi driver for Marvell 7K/8K SoCs
- Replace driver-specific set_affinity with generic version
- mips:
- Move ath79 MISC and CPU drivers from arch/ code to irqchip/
- tango:
- Add support for Sigma Designs SMP8[67]xx ctrl
into irq/core
Pull irqchip core changes for v4.6 from Jason Cooper:
- mvebu (armada-370-xp)
- MSI support
- Deconflict with mvebu's arm64 code
- ts4800
- Restrict when ts4800 driver can be built
- Make ts4800_ic_ops static const
- bcm2836: Drop superfluous memory barrier
Moving an SPI around doesn't require any extra work from the rest
of the stack, and specially not for MSI-generated SPIs.
It is then worth returning IRQ_SET_MASK_OK_DONE instead of
IRQ_SET_MASK_OK, and simplify the other irqchips that rely on
this behaviour (GICv2m and Marvell's ODMI controller).
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1455894029-17270-1-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This commits adds a new irqchip driver that handles the ODMI
controller found on Marvell 7K/8K processors. The ODMI controller
provide MSI interrupt functionality to on-board peripherals, much like
the GIC-v2m.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Link: https://lkml.kernel.org/r/1455888883-5127-1-git-send-email-thomas.petazzoni@free-electrons.com
ts4800_ic_ops is only referenced in this driver, so make it static.
In additional, it's never get modified thus also make it const.
Reviewed-by: Damien Riegel <damien.riegel@savoirfairelinux.com>
Link: https://lkml.kernel.org/r/1455457804.13175.1.camel@ingics.com
The writel() immediately after this has a barrier, anyway.
Signed-off-by: Eric Anholt <eric@anholt.net>
Link: https://lkml.kernel.org/r/1454620468-31303-1-git-send-email-eric@anholt.net
The Technologic Systems TS-4800 is an i.MX515 board, so its drivers
are useless unless building a SOC_IMX51 kernel, except for build
testing purposes.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Damien Riegel <damien.riegel@savoirfairelinux.com>
Link: https://lkml.kernel.org/r/20160209111920.1ec318bd@endymion
controller
This adds support for the secondary interrupt controller used in Sigma
Designs SMP86xx and SMP87xx chips.
Signed-off-by: Mans Rullgard <mans@mansr.com>
Link: https://lkml.kernel.org/r/1453313237-18570-2-git-send-email-mans@mansr.com
Function its_alloc_tables() maintains two local variables, "order" and
and "alloc_size", to hold memory size that has been allocated to
ITS_BASEn. We don't always refresh the variable alloc_size whenever
value of the variable order changes, causing the following two
problems.
- Cache flush operation with size more than required.
- Information reported by pr_info is not correct.
Use a helper macro that converts page order to size in bytes instead of
variable "alloc_size" to fix both the problems.
Signed-off-by: Alban Bedel <albeu@free.fr>
Link: https://lkml.kernel.org/r/1453553867-27003-2-git-send-email-albeu@free.fr
The driver stays the same but the initialization changes a bit.
For OF boards we now get the memory map from the OF node and use
a linear mapping instead of the legacy mapping. For legacy boards
we still use a legacy mapping and just pass down all the parameters
from the board init code.
Link: https://lkml.kernel.org/r/1453553867-27003-1-git-send-email-albeu@free.fr
The irq-armada-370-xp driver can only be built for ARM 32 bits. The mvebu
family had grown with a new ARM64 SoC which will also select the
ARCH_MEVBU configuration. Since "ARM: mvebu: use the ARMADA_370_XP_IRQ
option", the ARM32 mvebu SoC directly select this new option. Selecting
it by default when ARCH_MEVBU is selected is no more needed.
This patch removes this dependency, thanks to this, a kernel for ARM64
mvebu SoC can be built without error due this driver.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1454951660-13289-3-git-send-email-gregory.clement@free-electrons.com
Add support for allocating multiple MSIs at the same time, so that the
MSI_FLAG_MULTI_PCI_MSI flag can be added to the msi_domain_info
structure.
Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1455115621-22846-6-git-send-email-thomas.petazzoni@free-electrons.com
