Replace ASYNC_INITIALIZED bit in the tty_port::flags field with
TTY_PORT_INITIALIZED bit in the tty_port::iflags field. Introduce helpers
tty_port_set_initialized() and tty_port_initialized() to abstract
atomic bit ops.
Note: the transforms for test_and_set_bit() and test_and_clear_bit()
are unnecessary as the state transitions are already mutually exclusive;
the tty lock prevents concurrent open/close/hangup.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
In some condition we receive the break interrupt but nothing is putted
in the Rx FIFO and the correspondend bit in the status register is not
set. Thus, no-one clear the interrupt and the handler will be called
forever.
This patch clear the break interrupt as soon as it occurs. Then, if the
break character '\0' is putted in the fifo we will manage it.
We can also unmask the Break interrupt but its bit in ISR is still set
on break. So I think is better to keep the registers clean.
Signed-off-by: Federico Vaga <federico.vaga@cern.ch>
Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com>
The request for an IRQ handler must be done after whole configuration. This
was not the case for this driver which request the IRQ in the middle of
the configuration. Sometimes, it happens that something is not completely
configured, we recieve an interrupt thus we stumble into troubles in the
IRQ handler.
In some conditions (echo or particular sequence of special
characters), on buffer push, the tty layer calls the write operation
while we are holding the spinlock. This means deadlock within the same
process on kernels version < 3.12. It seems not a problem on recent
kernel, but the patch still valid as locking optimization.
The protected variables by the spinlock are: xmit_buf, nb_bytes,
pointer_read and pointer_write. So, this patch reduces the locked area
in the IRQ handler only to these variables. Most of the code inside the
locked area in the IRQ handler is not protected elsewhere; it means
that it is not protected at all.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg Kroah-Hartman:
"Here's the big char/misc driver patches for 3.9-rc1.
Nothing major here, just lots of different driver updates (mei,
hyperv, ipack, extcon, vmci, etc.).
All of these have been in the linux-next tree for a while."
* tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits)
w1: w1_therm: Add force-pullup option for "broken" sensors
w1: ds2482: Added 1-Wire pull-up support to the driver
vme: add missing put_device() after device_register() fails
extcon: max8997: Use workqueue to check cable state after completing boot of platform
extcon: max8997: Set default UART/USB path on probe
extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type
extcon: max8997: Set default of ADC debounce time during initialization
extcon: max8997: Remove duplicate code related to set H/W line path
extcon: max8997: Move defined constant to header file
extcon: max77693: Make max77693_extcon_cable static
extcon: max8997: Remove unreachable code
extcon: max8997: Make max8997_extcon_cable static
extcon: max77693: Remove unnecessary goto statement to improve readability
extcon: max77693: Convert to devm_input_allocate_device()
extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style
CREDITS: update email and address of Harald Hoyer
extcon: arizona: Use MICDET for final microphone identification
extcon: arizona: Always take the first HPDET reading as the final one
extcon: arizona: Clear _trig_sts bits after jack detection
extcon: arizona: Don't HPDET magic when headphones are enabled
Delete successive tests to the same location. The code tested the result
of a previous allocation, that itself was already tested. It is changed to
test the result of the most recent allocation.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
{ ... when forall
return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
when != \(XT_GETPAGE(...,y)\|WMI_CMD_BUF(...)\)
{ ... when forall
return ...; }
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Samuel Iglesias Gonsalvez <siglesias@igalia.com>
There was a bug in the code when managing a GE IP-OCTAL-485 board. The RX would
be enabled but we have a wrong state in the rx_enable flag.
Then, if the user changes the terminal settings, RX would not be enabled again.
Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com>
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
tty_insert_flip_char is the next one to proceed. This one is used all
over the code, so the patch is huge.
Added shutdown callback to disable RX and TX when there is no other client
accesing the device.
Thus, we don't enable RX when a termios setup has been called, as it could be
disabled previously.
As the control registers (Rx, Tx flags specifically) cannot be read from the
device, we keep this info in rx_enable.
The function is already called in ipoctal_irq_rx()
We protect important data such as TX buffer pointer, nb_bytes counter and status
registers of the device, from accessing several times at the same time.
Due to the IRQ processing, we can generate another IRQ that can come before we
end the previous one, so we lost it. E.g. when transmitting a character.
To allow the processing in SMP machines, we ack the IRQ at the beginning of the
IRQ handler.
RX is enabled when the tty port is open, so no need to do it in initialization
time: it can allow the device to receive characters but no TTY client is
listening to them.
It produced an infinite number of IRQ as RxFIFO is not read to clear that
IRQ in the device, so it is still pending.
Depending of the device, it disables the TX mode in different places when there
is no more data to transmit.
This patch reorder them and disable the TX mode in the same place.
In case of several characters present in RxFIFO, they will have the flag of the
previous one, no matter if the actual character was received properly or not.
This patch fixes this bug.
Don't block the TTY client when sending characters.
Trying to setup the pppd server to use ipoctal's serial ports, it says the ports
are busy the first time. If the operation is repeated, a kernel bug due to a
dereference of a NULL pointer appears.
Removing the one-access-only setup from the driver, removes this kernel bug.
It is an unsigned int so that check is pointless.
Signed-off-by: Alberto Garcia <agarcia@igalia.com>
In order to transmit data, the driver enables Tx and sleeps until
*board_write is set to 1 by the interrupt handler.
It can happen, though, that the data is sent even before the process
is asleep. In this case *board_write must be set to 1 anyway,
otherwise we will be waiting for a condition that will never be true.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull TTY/Serial merge from Greg Kroah-Hartman:
"Here's the big tty/serial tree set of changes for 3.8-rc1.
Contained in here is a bunch more reworks of the tty port layer from
Jiri and bugfixes from Alan, along with a number of other tty and
serial driver updates by the various driver authors.
Also, Jiri has been coerced^Wconvinced to be the co-maintainer of the
TTY layer, which is much appreciated by me.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up some trivial conflicts in the staging tree, due to the fwserial
driver having come in both ways (but fixed up a bit in the serial tree),
and the ioctl handling in the dgrp driver having been done slightly
differently (staging tree got that one right, and removed both
TIOCGSOFTCAR and TIOCSSOFTCAR).
* tag 'tty-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (146 commits)
staging: sb105x: fix potential NULL pointer dereference in mp_chars_in_buffer()
staging/fwserial: Remove superfluous free
staging/fwserial: Use WARN_ONCE when port table is corrupted
staging/fwserial: Destruct embedded tty_port on teardown
staging/fwserial: Fix build breakage when !CONFIG_BUG
staging: fwserial: Add TTY-over-Firewire serial driver
drivers/tty/serial/serial_core.c: clean up HIGH_BITS_OFFSET usage
staging: dgrp: dgrp_tty.c: Audit the return values of get/put_user()
staging: dgrp: dgrp_tty.c: Remove the TIOCSSOFTCAR ioctl handler from dgrp driver
serial: ifx6x60: Add modem power off function in the platform reboot process
serial: mxs-auart: unmap the scatter list before we copy the data
serial: mxs-auart: disable the Receive Timeout Interrupt when DMA is enabled
serial: max310x: Setup missing "can_sleep" field for GPIO
tty/serial: fix ifx6x60.c declaration warning
serial: samsung: add devicetree properties for non-Exynos SoCs
serial: samsung: fix potential soft lockup during uart write
tty: vt: Remove redundant null check before kfree.
tty/8250 Add check for pci_ioremap_bar failure
tty/8250 Add support for Commtech's Fastcom Async-335 and Fastcom Async-PCIe cards
tty/8250 Add XR17D15x devices to the exar_handle_irq override
Its contents are merged into ipack.h. So this file is not needed.
Doing that, it simplifies the ipack-related driver development.
Move ipack header files to include/linux/ directory where they belong.
The ipack subsystem is cleaned up enough to now move out of the staging
tree, and into drivers/ipack.
Cc: Jens Taprogge <jens.taprogge@taprogge.org>
