path: root/drivers/iommu/omap-iommu.h
2015-08-03iommu/omap: Use BIT(x) macros in omap-iommu.hSuman Anna
Switch to using the BIT(x) macros in omap-iommu.h where possible. This eliminates the following checkpatch check warning: "CHECK: Prefer using the BIT macro" A couple of the warnings were ignored for better readability of the bit-shift for the different values. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-08-03iommu/omap: Remove unused union fieldsSuman Anna
There are couple of unions defined in the structures iotlb_entry and cr_regs. There are no usage/references to some of these union fields in the code, so clean them up and simplify the structures. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-08-03iommu/omap: Move debugfs functions to omap-iommu-debug.cSuman Anna
The main OMAP IOMMU driver file has some helper functions used by the OMAP IOMMU debugfs functionality, and there is already a dedicated source file omap-iommu-debug.c dealing with these debugfs routines. Move all these functions to the omap-iommu-debug.c file, so that all the debugfs related routines are in one place. The move required exposing some new functions and moving some definitions to the internal omap-iommu.h header file. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Do not export unneeded functionsSuman Anna
The following functions were exported previously for usage by the OMAP IOMMU debug module: omap_iommu_dump_ctx() omap_dump_tlb_entries() omap_iopgtable_store_entry() These functions need not be exported anymore as the OMAP IOMMU debugfs code is integrated with the OMAP IOMMU driver, and there won't be external users for these functions. So, remove the EXPORT_SYMBOL_GPL on these. The omap_iopgtable_store_entry() is also made internal only, after making the 'pagetable' debugfs entry read-only. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Remove couple of unused exported functionsSuman Anna
The exported functions omap_foreach_iommu_device() and omap_iotlb_cr_to_e() have been deleted, as they are no longer needed. The function omap_foreach_iommu_device() is not required after the consolidation of the OMAP IOMMU debug module, and the function omap_iotlb_cr_to_e() is not required after making the debugfs entry 'pagetable' read-only. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Integrate omap-iommu-debug into omap-iommuSuman Anna
The debugfs support for OMAP IOMMU is currently implemented as a module, warranting certain OMAP-specific IOMMU API to be exported. The OMAP IOMMU, when enabled, can only be built-in into the kernel, so integrate the OMAP IOMMU debug module into the OMAP IOMMU driver. This helps in eliminating the need to export most of the current OMAP IOMMU API. The following are the main changes: - The debugfs directory and entry creation logic is reversed, the calls are invoked by the OMAP IOMMU driver now. - The current iffy circular logic of adding IOMMU archdata to the IOMMU devices itself to get a pointer to the omap_iommu object in the debugfs support code is replaced by directly using the omap_iommu structure while creating the debugfs entries. - The debugfs root directory is renamed from the generic name "iommu" to a specific name "omap_iommu". - Unneeded headers have also been cleaned up while at this. - There will no longer be a omap-iommu-debug.ko module after this patch. - The OMAP_IOMMU_DEBUG Kconfig option is converted to boolean only, the OMAP IOMMU debugfs support is built alongside the OMAP IOMMU driver only when this option is enabled. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Consolidate OMAP IOMMU modulesSuman Anna
The OMAP IOMMU driver was originally designed as modules, and split into a core module and a thin arch-specific module through the OMAP arch-specific struct iommu_functions, to scale for both OMAP1 and OMAP2+ IOMMU variants. The driver can only be built for OMAP2+ platforms currently, and also can only be built-in after the adaptation to generic IOMMU API. The OMAP1 variant was never added and will most probably be never added (the code for the only potential user, its parent, DSP processor has already been cleaned up). So, consolidate the OMAP2 specific omap-iommu2 module into the core OMAP IOMMU driver - this eliminates the arch-specific ops structure and simplifies the driver into a single module that only implements the generic IOMMU API's iommu_ops. The following are the main changes: - omap-iommu2 module is completely eliminated, with the common definitions moved to the internal omap-iommu.h, and the ops implementations moved into omap-iommu.c - OMAP arch-specific struct iommu_functions is also eliminated, with the ops implementations directly absorbed into the calling functions - iotlb_alloc_cr() is no longer inlined and defined only when PREFETCH_IOTLB is defined - iotlb_dump_cr() is similarly defined only when CONFIG_OMAP_IOMMU_DEBUG is defined - Elimination of the OMAP IOMMU exported functions to register the arch ops, omap_install_iommu_arch() & omap_uninstall_iommu_arch() - Any stale comments about OMAP1 are also cleaned up Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Remove omap_iommu_arch_version() and version fieldSuman Anna
The function omap_iommu_arch_version() is not used anymore, and is not required either, so remove it. The .version field in struct iommu_functions that this function uses is also removed, as it is not really an ops to retrieve a version and there won't be any usage for this field either. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Remove conditional definition of dev_to_omap_iommu()Suman Anna
The dev_to_omap_iommu() is local to the OMAP IOMMU modules, and need not be defined conditionally. The CONFIG_IOMMU_API dependency check was added in the past to fix a compilation issue back when the header resided in the arch/arm layers, and is no longer needed. While at this, fix the header against double inclusion as well. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Remove duplicate declarationsSuman Anna
The omap_iommu_save_ctx() and omap_iommu_restore_ctx() declarations are defined in include/linux/omap-iommu.h and do not belong in the internal drivers/iommu/omap-iommu.h header, so remove them. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Remove unused isr_priv field from omap_iommuSuman Anna
The isr_priv field is a left-over from before the IOMMU API adaptation, this was used to store the callback data. This is no longer relevant, so remove it. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-23iommu/omap: Remove refcount field from omap_iommu objectSuman Anna
The refcount field in omap_iommu object is primarily used to check if an IOMMU device has already been enabled, but this is already implicit in the omap_iommu_attach_dev() which ensures that only a single device can attach to an IOMMU. This field is redundant, and so has been cleaned up. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-09-25iommu/omap: Remove omap_iommu unused owner fieldLaurent Pinchart
The owner field is never set. Remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Suman Anna <s-anna@ti.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-07-29iommu/omap: Remove virtual memory managerLaurent Pinchart
The OMAP3 ISP driver was the only user of the OMAP IOVMM API. Now that is has been ported to the DMA API, remove the unused virtual memory manager. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-03-04iommu/omap: Enable bus-error back on supported iommusSuman Anna
The remoteproc MMUs in OMAP4+ SoCs have some additional debug registers that can give out the PC value in addition to the MMU fault address. The PC value can be extracted properly only on the DSP cores, and is not available on the ARM processors within the IPU sub-systems. Instead, the MMUs have been enhanced to throw a bus-error response back to the IPU processors. This functionality is programmable through the MMU_GP_REG register. The cores are simply stalled if the MMU_GP_REG.BUS_ERR_BACK_EN bit is not set. When set, a bus-error exception is raised allowing the processor to handle it as a bus fault and provide additional debug information. This feature is turned on by default by the driver on iommus supporting it. Signed-off-by: Subramaniam Chanderashekarapuram <subramaniam.ca@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-12-03iommu/omap: Adapt to runtime pmOmar Ramirez Luna
Use runtime PM functionality interfaced with hwmod enable/idle functions, to replace direct clock operations and sysconfig handling. Due to reset sequence, pm_runtime_[get|put]_sync must be used, to avoid possible operations with the module under reset. Because of this and given that the driver uses spin_locks to protect their critical sections, we must use pm_runtime_irq_safe in order for the runtime ops to be happy, otherwise might_sleep_if checks in runtime framework will complain. The remaining pm_runtime out of iommu_enable and iommu_disable corresponds to paths that can be accessed through debugfs, some of them doesn't work if the module is not enabled first, but in future if the mmu is idled withouth freeing, these are needed to debug. Signed-off-by: Omar Ramirez Luna <omar.luna@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-11-20ARM: OMAP2+: Make some definitions localIdo Yariv
Move some of the definitions in omap-iommu.h that can be made local to either drivers/iommu. Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Omar Ramirez Luna <omar.luna@linaro.org> Signed-off-by: Ido Yariv <ido@wizery.com> Acked-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Joerg Roedel <joro@8bytes.org> [tony@atomide.com: updated for header changes in the series] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-11-20ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.cTony Lindgren
This file should not be in arch/arm. Move it to drivers/iommu to allow making most of the header local to drivers/iommu. This is needed as we are removing plat and mach includes from drivers for ARM common zImage support. Cc: Ido Yariv <ido@wizery.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Omar Ramirez Luna <omar.luna@linaro.org> Cc: linux-media@vger.kernel.org Acked-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
