path: root/drivers/input
2017-12-20Input: i8042 - add TUXEDO BU1406 (N24_25BU) to the nomux listDmitry Torokhov
[ Upstream commit a4c2a13129f7c5bcf81704c06851601593303fd5 ] TUXEDO BU1406 does not implement active multiplexing mode properly, and takes around 550 ms in i8042_set_mux_mode(). Given that the device does not have external AUX port, there is no downside in disabling the MUX mode. Reported-by: Paul Menzel <pmenzel@molgen.mpg.de> Suggested-by: Vojtech Pavlik <vojtech@suse.cz> Reviewed-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18Input: ims-psu - check if CDC union descriptor is saneDmitry Torokhov
commit ea04efee7635c9120d015dcdeeeb6988130cb67a upstream. Before trying to use CDC union descriptor, try to validate whether that it is sane by checking that intf->altsetting->extra is big enough and that descriptor bLength is not too big and not too small. Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15Input: elan_i2c - add ELAN060C to the ACPI tableKai-Heng Feng
commit cdea6a30c2689cc33b34c6691b57cca277f0c5dc upstream. ELAN060C touchpad uses elan_i2c as its driver. It can be found on Lenovo ideapad 320-14AST. BugLink: https://bugs.launchpad.net/bugs/1727544 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15Input: mpr121 - set missing event capabilityAkinobu Mita
[ Upstream commit 9723ddc8fe0d76ce41fe0dc16afb241ec7d0a29d ] This driver reports misc scan input events on the sensor's status register changes. But the event capability for them was not set in the device initialization, so these events were ignored. This change adds the missing event capability. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15Input: mpr121 - handle multiple bits change of status registerAkinobu Mita
[ Upstream commit 08fea55e37f58371bffc5336a59e55d1f155955a ] This driver reports input events on their interrupts which are triggered by the sensor's status register changes. But only single bit change is reported in the interrupt handler. So if there are multiple bits are changed at almost the same time, other press or release events are ignored. This fixes it by detecting all changed bits in the status register. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02Input: gtco - fix potential out-of-bound accessDmitry Torokhov
commit a50829479f58416a013a4ccca791336af3c584c7 upstream. parse_hid_report_descriptor() has a while (i < length) loop, which only guarantees that there's at least 1 byte in the buffer, but the loop body can read multiple bytes which causes out-of-bounds access. Reported-by: Andrey Konovalov <andreyknvl@google.com> Reviewed-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02Input: elan_i2c - add ELAN0611 to the ACPI tableKai-Heng Feng
commit 57a95b41869b8f0d1949c24df2a9dac1ca7082ee upstream. ELAN0611 touchpad uses elan_i2c as its driver. It can be found on Lenovo ideapad 320-15IKB. So add it to ACPI table to enable the touchpad. [Ido Adiv <idoad123@gmail.com> reports that the same ACPI ID is used for Elan touchpad in ideapad 520]. BugLink: https://bugs.launchpad.net/bugs/1723736 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27Input: i8042 - add Gigabyte P57 to the keyboard reset tableKai-Heng Feng
commit 697c5d8a36768b36729533fb44622b35d56d6ad0 upstream. Similar to other Gigabyte laptops, the touchpad on P57 requires a keyboard reset to detect Elantech touchpad correctly. BugLink: https://bugs.launchpad.net/bugs/1594214 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-09Input: trackpoint - assume 3 buttons when buttons detection failsOscar Campos
commit 293b915fd9bebf33cdc906516fb28d54649a25ac upstream. Trackpoint buttons detection fails on ThinkPad 570 and 470 series, this makes the middle button of the trackpoint to not being recogized. As I don't believe there is any trackpoint with less than 3 buttons this patch just assumes three buttons when the extended button information read fails. Signed-off-by: Oscar Campos <oscar.campos@member.fsf.org> Acked-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30Input: ALPS - fix two-finger scroll breakage in right side on ALPS touchpadMasaki Ota
commit 4a646580f793d19717f7e034c8d473b509c27d49 upstream. Fixed the issue that two finger scroll does not work correctly on V8 protocol. The cause is that V8 protocol X-coordinate decode is wrong at SS4 PLUS device. I added SS4 PLUS X decode definition. Mote notes: the problem manifests itself by the commit e7348396c6d5 ("Input: ALPS - fix V8+ protocol handling (73 03 28)"), where a fix for the V8+ protocol was applied. Although the culprit must have been present beforehand, the two-finger scroll worked casually even with the wrongly reported values by some reason. It got broken by the commit above just because it changed x_max value, and this made libinput correctly figuring the MT events. Since the X coord is reported as falsely doubled, the events on the right-half side go outside the boundary, thus they are no longer handled. This resulted as a broken two-finger scroll. One finger event is decoded differently, and it didn't suffer from this problem. The problem was only about MT events. --tiwai Fixes: e7348396c6d5 ("Input: ALPS - fix V8+ protocol handling (73 03 28)") Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com> Tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Paul Donohue <linux-kernel@PaulSD.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30Input: elan_i2c - add ELAN0602 ACPI ID to support Lenovo Yoga310KT Liao
commit 1d2226e45040ed4aee95b633cbd64702bf7fc2a1 upstream. Add ELAN0602 to the list of known ACPI IDs to enable support for ELAN touchpads found in Lenovo Yoga310. Signed-off-by: KT Liao <kt.liao@emc.com.tw> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30Input: trackpoint - add new trackpoint firmware IDAaron Ma
commit ec667683c532c93fb41e100e5d61a518971060e2 upstream. Synaptics add new TP firmware ID: 0x2 and 0x3, for now both lower 2 bits are indicated as TP. Change the constant to bitwise values. This makes trackpoint to be recognized on Lenovo Carbon X1 Gen5 instead of it being identified as "PS/2 Generic Mouse". Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24Input: elan_i2c - Add antoher Lenovo ACPI ID for upcoming Lenovo NBKT Liao
commit 76988690402dde2880bfe06ecccf381d48ba8e1c upstream. Add 2 new IDs (ELAN0609 and ELAN060B) to the list of ACPI IDs that should be handled by the driver. Signed-off-by: KT Liao <kt.liao@emc.com.tw> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24Input: elan_i2c - add ELAN0608 to the ACPI tableKai-Heng Feng
commit 1874064eed0502bd9bef7be8023757b0c4f26883 upstream. Similar to commit 722c5ac708b4f ("Input: elan_i2c - add ELAN0605 to the ACPI table"), ELAN0608 should be handled by elan_i2c. This touchpad can be found in Lenovo ideapad 320-14IKB. BugLink: https://bugs.launchpad.net/bugs/1708852 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27Input: i8042 - fix crash at boot timeChen Hong
commit 340d394a789518018f834ff70f7534fc463d3226 upstream. The driver checks port->exists twice in i8042_interrupt(), first when trying to assign temporary "serio" variable, and second time when deciding whether it should call serio_interrupt(). The value of port->exists may change between the 2 checks, and we may end up calling serio_interrupt() with a NULL pointer: BUG: unable to handle kernel NULL pointer dereference at 0000000000000050 IP: [<ffffffff8150feaf>] _spin_lock_irqsave+0x1f/0x40 PGD 0 Oops: 0002 [#1] SMP last sysfs file: CPU 0 Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.32-358.el6.x86_64 #1 QEMU Standard PC (i440FX + PIIX, 1996) RIP: 0010:[<ffffffff8150feaf>] [<ffffffff8150feaf>] _spin_lock_irqsave+0x1f/0x40 RSP: 0018:ffff880028203cc0 EFLAGS: 00010082 RAX: 0000000000010000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 0000000000000282 RSI: 0000000000000098 RDI: 0000000000000050 RBP: ffff880028203cc0 R08: ffff88013e79c000 R09: ffff880028203ee0 R10: 0000000000000298 R11: 0000000000000282 R12: 0000000000000050 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000098 FS: 0000000000000000(0000) GS:ffff880028200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 0000000000000050 CR3: 0000000001a85000 CR4: 00000000001407f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 1, threadinfo ffff88013e79c000, task ffff88013e79b500) Stack: ffff880028203d00 ffffffff813de186 ffffffffffffff02 0000000000000000 <d> 0000000000000000 0000000000000000 0000000000000000 0000000000000098 <d> ffff880028203d70 ffffffff813e0162 ffff880028203d20 ffffffff8103b8ac Call Trace: <IRQ> [<ffffffff813de186>] serio_interrupt+0x36/0xa0 [<ffffffff813e0162>] i8042_interrupt+0x132/0x3a0 [<ffffffff8103b8ac>] ? kvm_clock_read+0x1c/0x20 [<ffffffff8103b8b9>] ? kvm_clock_get_cycles+0x9/0x10 [<ffffffff810e1640>] handle_IRQ_event+0x60/0x170 [<ffffffff8103b154>] ? kvm_guest_apic_eoi_write+0x44/0x50 [<ffffffff810e3d8e>] handle_edge_irq+0xde/0x180 [<ffffffff8100de89>] handle_irq+0x49/0xa0 [<ffffffff81516c8c>] do_IRQ+0x6c/0xf0 [<ffffffff8100b9d3>] ret_from_intr+0x0/0x11 [<ffffffff81076f63>] ? __do_softirq+0x73/0x1e0 [<ffffffff8109b75b>] ? hrtimer_interrupt+0x14b/0x260 [<ffffffff8100c1cc>] ? call_softirq+0x1c/0x30 [<ffffffff8100de05>] ? do_softirq+0x65/0xa0 [<ffffffff81076d95>] ? irq_exit+0x85/0x90 [<ffffffff81516d80>] ? smp_apic_timer_interrupt+0x70/0x9b [<ffffffff8100bb93>] ? apic_timer_interrupt+0x13/0x20 To avoid the issue let's change the second check to test whether serio is NULL or not. Also, let's take i8042_lock in i8042_start() and i8042_stop() instead of trying to be overly smart and using memory barriers. Signed-off-by: Chen Hong <chenhong3@huawei.com> [dtor: take lock in i8042_start()/i8042_stop()] Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-29Input: i8042 - add Fujitsu Lifebook AH544 to notimeout listDaniel Drake
commit 817ae460c784f32cd45e60b2b1b21378c3c6a847 upstream. Without this quirk, the touchpad is not responsive on this product, with the following message repeated in the logs: psmouse serio1: bad data from KBC - timeout Add it to the notimeout list alongside other similar Fujitsu laptops. Signed-off-by: Daniel Drake <drake@endlessm.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14Input: elantech - add Fujitsu Lifebook E546/E557 to force crc_enabledUlrik De Bie
commit 47eb0c8b4d9eb6368941c6a9bb443f00847a46d7 upstream. The Lifebook E546 and E557 touchpad were also not functioning and worked after running: echo "1" > /sys/devices/platform/i8042/serio2/crc_enabled Add them to the list of machines that need this workaround. Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org> Reviewed-by: Arjan Opmeer <arjan@opmeer.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-03Input: i8042 - add Clevo P650RS to the i8042 reset listDmitry Torokhov
commit 7c5bb4ac2b76d2a09256aec8a7d584bf3e2b0466 upstream. Clevo P650RS and other similar devices require i8042 to be reset in order to detect Synaptics touchpad. Reported-by: Paweł Bylica <chfast@gmail.com> Tested-by: Ed Bordin <edbordin@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=190301 Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27Input: elantech - add Fujitsu Lifebook E547 to force crc_enabledThorsten Leemhuis
commit 704de489e0e3640a2ee2d0daf173e9f7375582ba upstream. Temporary got a Lifebook E547 into my hands and noticed the touchpad only works after running: echo "1" > /sys/devices/platform/i8042/serio2/crc_enabled Add it to the list of machines that need this workaround. Signed-off-by: Thorsten Leemhuis <linux@leemhuis.info> Reviewed-by: Ulrik De Bie <ulrik.debie-os@e2big.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21Input: xpad - add support for Razer Wildcat gamepadCameron Gutman
commit 5376366886251e2f8f248704adb620a4bc4c0937 upstream. Signed-off-by: Cameron Gutman <aicommander@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12Input: gpio_keys - add support for GPIO descriptorsGeert Uytterhoeven
[ Upstream commit 5feeca3c1e39c01f9ef5abc94dea94021ccf94fc ] GPIO descriptors are the preferred way over legacy GPIO numbers nowadays. Convert the driver to use GPIO descriptors internally but still allow passing legacy GPIO numbers from platform data to support existing platforms. Based on commits 633a21d80b4a2cd6 ("input: gpio_keys_polled: Add support for GPIO descriptors") and 1ae5ddb6f8837558 ("Input: gpio_keys_polled - request GPIO pin as input."). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: sur40 - validate number of endpoints before using themJohan Hovold
commit 92461f5d723037530c1f36cce93640770037812c upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer or accessing memory that lie beyond the end of the endpoint array should a malicious device lack the expected endpoints. Fixes: bdb5c57f209c ("Input: add sur40 driver for Samsung SUR40... ") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: kbtab - validate number of endpoints before using themJohan Hovold
commit cb1b494663e037253337623bf1ef2df727883cb7 upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer should a malicious device lack endpoints. Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: cm109 - validate number of endpoints before using themJohan Hovold
commit ac2ee9ba953afe88f7a673e1c0c839227b1d7891 upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer should a malicious device lack endpoints. Fixes: c04148f915e5 ("Input: add driver for USB VoIP phones with CM109...") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: yealink - validate number of endpoints before using themJohan Hovold
commit 5cc4a1a9f5c179795c8a1f2b0f4361829d6a070e upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer should a malicious device lack endpoints. Fixes: aca951a22a1d ("[PATCH] input-driver-yealink-P1K-usb-phone") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: hanwang - validate number of endpoints before using themJohan Hovold
commit ba340d7b83703768ce566f53f857543359aa1b98 upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer should a malicious device lack endpoints. Fixes: bba5394ad3bd ("Input: add support for Hanwang tablets") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: ims-pcu - validate number of endpoints before using themJohan Hovold
commit 1916d319271664241b7aa0cd2b05e32bdb310ce9 upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer should a malicious device lack control-interface endpoints. Fixes: 628329d52474 ("Input: add IMS Passenger Control Unit driver") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: iforce - validate number of endpoints before using themJohan Hovold
commit 59cf8bed44a79ec42303151dd014fdb6434254bb upstream. Make sure to check the number of endpoints to avoid dereferencing a NULL-pointer or accessing memory that lie beyond the end of the endpoint array should a malicious device lack the expected endpoints. Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: i8042 - add noloop quirk for Dell Embedded Box PC 3000Kai-Heng Feng
commit 45838660e34d90db8d4f7cbc8fd66e8aff79f4fe upstream. The aux port does not get detected without noloop quirk, so external PS/2 mouse cannot work as result. The PS/2 mouse can work with this quirk. BugLink: https://bugs.launchpad.net/bugs/1591053 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Reviewed-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: elan_i2c - add ASUS EeeBook X205TA special touchpad fwMatjaz Hegedic
commit 92ef6f97a66e580189a41a132d0f8a9f78d6ddce upstream. EeeBook X205TA is yet another ASUS device with a special touchpad firmware that needs to be accounted for during initialization, or else the touchpad will go into an invalid state upon suspend/resume. Adding the appropriate ic_type and product_id check fixes the problem. Signed-off-by: Matjaz Hegedic <matjaz.hegedic@gmail.com> Acked-by: KT Liao <kt.liao@emc.com.tw> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: ALPS - fix trackstick button handling on V8 devicesMasaki Ota
commit 47e6fb4212d09f325c0847d05985dd3d71553095 upstream. Alps stick devices always have physical buttons, so we should not check ALPS_BUTTONPAD flag to decide whether we should report them. Fixes: 4777ac220c43 ("Input: ALPS - add touchstick support for SS5 hardware") Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com> Acked-by: Pali Rohar <pali.rohar@gmail.com> Tested-by: Paul Donohue <linux-kernel@PaulSD.com> Tested-by: Nick Fletcher <nick.m.fletcher@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30Input: ALPS - fix V8+ protocol handling (73 03 28)Masaki Ota
commit e7348396c6d51b57c95c6646c390cd078e038e19 upstream. Devices identified as E7="73 03 28" use slightly modified version of V8 protocol, with lower count per electrode, different offsets, and different feature bits in OTP data. Fixes: aeaa881f9b17 ("Input: ALPS - set DualPoint flag for 74 03 28 devices") Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com> Acked-by: Pali Rohar <pali.rohar@gmail.com> Tested-by: Paul Donohue <linux-kernel@PaulSD.com> Tested-by: Nick Fletcher <nick.m.fletcher@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-23Input: elan_i2c - add ELAN0605 to the ACPI tableIHARA Hiroka
commit 722c5ac708b4f5c1fcfad5fed4c95234c8b06590 upstream. ELAN0605 has been confirmed to be a variant of ELAN0600, which is blacklisted in the hid-core to be managed by elan_i2c. This device can be found in Lenovo ideapad 310s (80U4000). Signed-off-by: Hiroka IHARA <ihara_h@live.jp> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14Input: uinput - fix crash when mixing old and new init styleDmitry Torokhov
commit 601bbbe0517303c9f8eb3d75e11d64efed1293c9 upstream. If user tries to initialize uinput device mixing old and new style initialization (i.e. using old UI_SET_ABSBIT instead of UI_ABS_SETUP, we forget to allocate input->absinfo and will crash when trying to send absolute events: ioctl(ui, UI_DEV_SETUP, &us); ioctl(ui, UI_SET_PHYS, "Test"); ioctl(ui, UI_SET_EVBIT, EV_ABS); ioctl(ui, UI_SET_ABSBIT, ABS_X); ioctl(ui, UI_SET_ABSBIT, ABS_Y); ioctl(ui, UI_DEV_CREATE, 0); Reported-by: Rodrigo Rivas Costa <rodrigorivascosta@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=191811 Fixes: fbae10db0940 ("Input: uinput - rework ABS validation") Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26Input: ALPS - fix TrackStick support for SS5 hardwarePaul Donohue
commit 864db9295b06837d11a260e5dacf99a3fdf6bce2 upstream. The current Alps SS5 (SS4 v2) code generates bogus TouchPad events when TrackStick packets are processed. This causes the xorg synaptics driver to print "unable to find touch point 0" and "BUG: triggered 'if (priv->num_active_touches > priv->num_slots)'" messages. It also causes unexpected TouchPad button release and re-click event sequences if the TrackStick is moved while holding a TouchPad button. This commit corrects the problem by adjusting alps_process_packet_ss4_v2() so that it only sends TrackStick reports when processing TrackStick packets. Reviewed-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Paul Donohue <linux-kernel@PaulSD.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19Input: elants_i2c - avoid divide by 0 errors on bad touchscreen dataGuenter Roeck
commit 1c3415a06b1016a596bfe59e0cfee56c773aa958 upstream. The following crash may be seen if bad data is received from the touchscreen. [ 2189.425150] elants_i2c i2c-ELAN0001:00: unknown packet ff ff ff ff [ 2189.430738] divide error: 0000 [#1] PREEMPT SMP [ 2189.434679] gsmi: Log Shutdown Reason 0x03 [ 2189.434689] Modules linked in: ip6t_REJECT nf_reject_ipv6 rfcomm evdi uinput uvcvideo cmac videobuf2_vmalloc videobuf2_memops snd_hda_codec_hdmi i2c_dev videobuf2_core snd_soc_sst_cht_bsw_rt5645 snd_hda_intel snd_intel_sst_acpi btusb btrtl btbcm btintel bluetooth snd_soc_sst_acpi snd_hda_codec snd_intel_sst_core snd_hwdep snd_soc_sst_mfld_platform snd_hda_core snd_soc_rt5645 memconsole_x86_legacy memconsole zram snd_soc_rl6231 fuse ip6table_filter iwlmvm iwlwifi iwl7000_mac80211 cfg80211 iio_trig_sysfs joydev cros_ec_sensors cros_ec_sensors_core industrialio_triggered_buffer kfifo_buf industrialio snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq snd_seq_device ppp_async ppp_generic slhc tun [ 2189.434866] CPU: 0 PID: 106 Comm: irq/184-ELAN000 Tainted: G W 3.18.0-13101-g57e8190 #1 [ 2189.434883] Hardware name: GOOGLE Ultima, BIOS Google_Ultima.7287.131.43 07/20/2016 [ 2189.434898] task: ffff88017a0b6d80 ti: ffff88017a2bc000 task.ti: ffff88017a2bc000 [ 2189.434913] RIP: 0010:[<ffffffffbecc48d5>] [<ffffffffbecc48d5>] elants_i2c_irq+0x190/0x200 [ 2189.434937] RSP: 0018:ffff88017a2bfd98 EFLAGS: 00010293 [ 2189.434948] RAX: 0000000000000000 RBX: ffff88017a967828 RCX: ffff88017a9678e8 [ 2189.434962] RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000000 [ 2189.434975] RBP: ffff88017a2bfdd8 R08: 00000000000003e8 R09: 0000000000000000 [ 2189.434989] R10: 0000000000000000 R11: 000000000044a2bd R12: ffff88017a991800 [ 2189.435001] R13: ffffffffbe8a2a53 R14: ffff88017a0b6d80 R15: ffff88017a0b6d80 [ 2189.435011] FS: 0000000000000000(0000) GS:ffff88017fc00000(0000) knlGS:0000000000000000 [ 2189.435022] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 2189.435030] CR2: 00007f678d94b000 CR3: 000000003f41a000 CR4: 00000000001007f0 [ 2189.435039] Stack: [ 2189.435044] ffff88017a2bfda8 ffff88017a9678e8 646464647a2bfdd8 0000000006e09574 [ 2189.435060] 0000000000000000 ffff88017a088b80 ffff88017a921000 ffffffffbe8a2a53 [ 2189.435074] ffff88017a2bfe08 ffffffffbe8a2a73 ffff88017a0b6d80 0000000006e09574 [ 2189.435089] Call Trace: [ 2189.435101] [<ffffffffbe8a2a53>] ? irq_thread_dtor+0xa9/0xa9 [ 2189.435112] [<ffffffffbe8a2a73>] irq_thread_fn+0x20/0x40 [ 2189.435123] [<ffffffffbe8a2be1>] irq_thread+0x14e/0x222 [ 2189.435135] [<ffffffffbee8cbeb>] ? __schedule+0x3b3/0x57a [ 2189.435145] [<ffffffffbe8a29aa>] ? wake_threads_waitq+0x2d/0x2d [ 2189.435156] [<ffffffffbe8a2a93>] ? irq_thread_fn+0x40/0x40 [ 2189.435168] [<ffffffffbe87c385>] kthread+0x10e/0x116 [ 2189.435178] [<ffffffffbe87c277>] ? __kthread_parkme+0x67/0x67 [ 2189.435189] [<ffffffffbee900ac>] ret_from_fork+0x7c/0xb0 [ 2189.435199] [<ffffffffbe87c277>] ? __kthread_parkme+0x67/0x67 [ 2189.435208] Code: ff ff eb 73 0f b6 bb c1 00 00 00 83 ff 03 7e 13 49 8d 7c 24 20 ba 04 00 00 00 48 c7 c6 8a cd 21 bf eb 4d 0f b6 83 c2 00 00 00 99 <f7> ff 83 f8 37 75 15 48 6b f7 37 4c 8d a3 c4 00 00 00 4c 8d ac [ 2189.435312] RIP [<ffffffffbecc48d5>] elants_i2c_irq+0x190/0x200 [ 2189.435323] RSP <ffff88017a2bfd98> [ 2189.435350] ---[ end trace f4945345a75d96dd ]--- [ 2189.443841] Kernel panic - not syncing: Fatal exception [ 2189.444307] Kernel Offset: 0x3d800000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff) [ 2189.444519] gsmi: Log Shutdown Reason 0x02 The problem was seen with a 3.18 based kernel, but there is no reason to believe that the upstream code is safe. Fixes: 66aee90088da2 ("Input: add support for Elan eKTH I2C touchscreens") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19Input: i8042 - add Pegatron touchpad to noloop tableMarcos Paulo de Souza
commit 41c567a5d7d1a986763e58c3394782813c3bcb03 upstream. Avoid AUX loopback in Pegatron C15B touchpad, so input subsystem is able to recognize a Synaptics touchpad in the AUX port. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=93791 (Touchpad is not detected on DNS 0801480 notebook (PEGATRON C15B)) Suggested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19Input: xpad - use correct product id for x360w controllersPavel Rojtberg
commit b6fc513da50c5dbc457a8ad6b58b046a6a68fd9d upstream. currently the controllers get the same product id as the wireless receiver. However the controllers actually have their own product id. The patch makes the driver expose the same product id as the windows driver. This improves compatibility when running applications with WINE. see https://github.com/paroj/xpad/issues/54 Signed-off-by: Pavel Rojtberg <rojtberg@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-12Input: synaptics-rmi4 - unlock on errorDan Carpenter
commit 792f497b22afd0563b94dd8fa129a05f762a2c25 upstream. We should unlock before returning on this error path. Fixes: 3a762dbd5347 ('[media] Input: synaptics-rmi4 - add support for F54 diagnostics') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09Input: drv260x - fix input device's parent assignmentJingkui Wang
commit 5a8a6b89c15766446d845671d574a9243b6d8786 upstream. We were assigning I2C bus controller instead of client as parent device. Besides being logically wrong, it messed up with devm handling of input device. As a result we were leaving input device and event node behind after rmmod-ing the driver, which lead to a kernel oops if one were to access the event node later. Let's remove the assignment and rely on devm_input_allocate_device() to set it up properly for us. Signed-off-by: Jingkui Wang <jkwang@google.com> Fixes: 7132fe4f5687 ("Input: drv260x - add TI drv260x haptics driver") Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input fixes from Dmitry Torokhov: "We are disabling automatic probing of BYD touchpads as it results in too many false positives, and the hardware is not terribly popular and having the protocol support does not result in significantly improved user experience. We also change keycode for KEY_DATA to avoid clashing with KEY_FASTREVERSE. Luckily this newish code is used by CEC framework that is still in staging, so it is extremely unlikely that someone has already started using this keycode" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: change KEY_DATA from 0x275 to 0x277 Input: psmouse - disable automatic probing of BYD touchpads
2016-11-16Input: psmouse - disable automatic probing of BYD touchpadsDmitry Torokhov
BYD automatic protocol detection is extremely unreliable and is often triggers false positives on regular mice, Sentelic touchpads, and other devices. BYD has several documents that have recommended detection sequence, but they conflict with each other and, as far as I can see, still would not produce unique enough output to reliably differentiate BYD from other PS/2 devices. OEMs sourcing BYD devices also do not do us any favors by not supplying any reasonable DMI data and instead leaving turds like "To Be Filled By O.E.M." in place of vendor data, or "System Serial Number" as serial number. On top of that BYD is not truly modern multitouch controller, but rather a single-touch transitional device that only reports absolute coordinates at the beginning of finger contact and then reverts to reporting displacements, and thus not very precise; the only benefit from using BYD mode vs the legacy PS/2 mode is possibility of edge scrolling. Given the above, and the fact that BYD devices are somewhat uncommon, let's disable automatic detection of BYD devices. Users who know they have BYD trackpads or want to experiment can attempt to activate BYD protocol via sysfs: echo -n "byd" > /sys/bus/serio/devices/serio1/drvctl Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=151691 Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=175421 Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=120781 Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=121281 Fixes: 98ee37714493 ("Input: byd - add BYD PS/2 touchpad driver") Cc: stable@vger.kernel.org # 4.6+ Reviewed-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-11-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: psmouse - cleanup Focaltech code Input: i8042 - add XMG C504 to keyboard reset table
2016-10-24Input: psmouse - cleanup Focaltech codeDmitry Tunin
psmouse->name "Focaltech Touchpad" is an overkill. In xinput it is too long as "FocaltechPS/2 Focaltech Focaltech Touchpad" In focaltech_report_state() pointer to psmouse->dev is already stored as *dev Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-10-19Input: i8042 - add XMG C504 to keyboard reset tablePatrick Scheuring
The Schenker XMG C504 is a rebranded Gigabyte P35 v2 laptop. Therefore it also needs a keyboard reset to detect the Elantech touchpad. Otherwise the touchpad appears to be dead. With this patch the touchpad is detected: $ dmesg | grep -E "(i8042|Elantech|elantech)" [ 2.675399] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 [ 2.680372] i8042: Attempting to reset device connected to KBD port [ 2.789037] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 2.791586] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 2.813840] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4 [ 3.811431] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x361f0e) [ 3.825424] psmouse serio1: elantech: Synaptics capabilities query result 0x00, 0x15, 0x0f. [ 3.839424] psmouse serio1: elantech: Elan sample query result 03, 58, 74 [ 3.911349] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input6 Signed-off-by: Patrick Scheuring <patrick.scheuring.dev@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull some more input subsystem updates from Dmitry Torokhov: "An update to the ALPS driver to support the V8 protocol with touchstick, a change for i8042 to skip selftest on many Asus laptops which helps to keep their touchpads working after resume, and a couple other driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - skip selftest on ASUS laptops Input: melfas_mip4 - add ic_name sysfs attribute Input: melfas_mip4 - add maintainer information Input: melfas_mip4 - add devicetree binding documentations Input: elantech - add Fujitsu Lifebook E556 to force crc_enabled Input: synaptics-rmi4 - fix error handling in I2C transport driver Input: synaptics-rmi4 - fix error handling in SPI transport driver Input: ALPS - add V8 protocol documentation Input: ALPS - set DualPoint flag for 74 03 28 devices Input: ALPS - allow touchsticks to report pressure Input: ALPS - handle 0-pressure 1F events Input: ALPS - add touchstick support for SS5 hardware Input: elantech - force needed quirks on Fujitsu H760 Input: elantech - fix Lenovo version typo
2016-10-13Merge branch 'next' into for-linusDmitry Torokhov
Prepare second round of input updates for 4.9 merge window.
2016-10-11Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more updates from Andrew Morton: - a few block updates that fell in my lap - lib/ updates - checkpatch - autofs - ipc - a ton of misc other things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits) mm: split gfp_mask and mapping flags into separate fields fs: use mapping_set_error instead of opencoded set_bit treewide: remove redundant #include <linux/kconfig.h> hung_task: allow hung_task_panic when hung_task_warnings is 0 kthread: add kerneldoc for kthread_create() kthread: better support freezable kthread workers kthread: allow to modify delayed kthread work kthread: allow to cancel kthread work kthread: initial support for delayed kthread work kthread: detect when a kthread work is used by more workers kthread: add kthread_destroy_worker() kthread: add kthread_create_worker*() kthread: allow to call __kthread_create_on_node() with va_list args kthread/smpboot: do not park in kthread_create_on_cpu() kthread: kthread worker API cleanup kthread: rename probe_kthread_data() to kthread_probe_data() scripts/tags.sh: enable code completion in VIM mm: kmemleak: avoid using __va() on addresses that don't have a lowmem mapping kdump, vmcoreinfo: report memory sections virtual addresses ipc/sem.c: add cond_resched in exit_sme ...
2016-10-11Input: i8042 - skip selftest on ASUS laptopsMarcos Paulo de Souza
On suspend/resume cycle, selftest is executed to reset i8042 controller. But when this is done in Asus devices, subsequent calls to detect/init functions to elantech driver fails. Skipping selftest fixes this problem. An easier step to reproduce this problem is adding i8042.reset=1 as a kernel parameter. On Asus laptops, it'll make the system to start with the touchpad already stuck, since psmouse_probe forcibly calls the selftest function. This patch was inspired by John Hiesey's change[1], but, since this problem affects a lot of models of Asus, let's avoid running selftests on them. All models affected by this problem: A455LD K401LB K501LB K501LX R409L V502LX X302LA X450LCP X450LD X455LAB X455LDB X455LF Z450LA [1]: https://marc.info/?l=linux-input&m=144312209020616&w=2 Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend" (https://bugzilla.kernel.org/show_bug.cgi?id=107971) Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-10-11Input: melfas_mip4 - add ic_name sysfs attributeSangwon Jee
Add ic_name sysfs attribute for retrieving IC model name. Signed-off-by: Sangwon Jee <jeesw@melfas.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
