Kernel source files need not include <linux/kconfig.h> explicitly
because the top Makefile forces to include it with:
-include $(srctree)/include/linux/kconfig.h
This commit removes explicit includes except the following:
* arch/s390/include/asm/facilities_src.h
* tools/testing/radix-tree/linux/kernel.h
These two are used for host programs.
Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Documentation improvements: conversion of all non-DocBook documents
to Sphinx and lots of fixes to the uAPI media book
- New PCI driver for Techwell TW5864 media grabber boards
- New SoC driver for ATMEL Image Sensor Controller
- Removal of some obsolete SoC drivers (s5p-tv driver and soc_camera
drivers)
- Addition of ST CEC driver
- Lots of drivers fixes, improvements and additions
* tag 'media/v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (464 commits)
[media] ttusb_dec: avoid the risk of go past buffer
[media] cx23885: Fix some smatch warnings
[media] si2165: switch to regmap
[media] si2165: use i2c_client->dev instead of i2c_adapter->dev for logging
[media] si2165: Remove legacy attach
[media] cx231xx: attach si2165 driver via i2c_client
[media] cx231xx: Prepare for attaching new style i2c_client DVB demod drivers
[media] cx23885: attach si2165 driver via i2c_client
[media] si2165: support i2c_client attach
[media] si2165: avoid division by zero
[media] rcar-vin: add R-Car gen2 fallback compatibility string
[media] lgdt3306a: remove 20*50 msec unnecessary timeout
[media] cx25821: Remove deprecated create_singlethread_workqueue
[media] cx25821: Drop Freeing of Workqueue
[media] cxd2841er: force 8MHz bandwidth for DVB-C if specified bw not supported
[media] redrat3: hardware-specific parameters
[media] redrat3: remove hw_timeout member
[media] cxd2841er: BER and SNR reading for ISDB-T
[media] dvb-usb: avoid link error with dib3000m{b,c|
[media] dvb-usb: split out common parts of dibusb
Another Lifebook machine that needs the same quirk as other similar
models to make the driver working.
Also let's reorder elantech_dmi_force_crc_enabled list so LIfebook enries
are in alphabetical order.
Reported-by: William Linna <william.linna@gmail.com>
Tested-by: William Linna <william.linna@gmail.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"You will get
- a new driver for Elan eKTF2127 touchscreen controllers
- a new "gpio-decoder" driver to read and report state of several
GPIO lines
- an ADC resistor ladder driver
- the ft6326 driver is removed because edt-ft5x06 handles the same
devices just fine.
.. plus the regular slew of driver fixes/enhancements"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (26 commits)
Input: elan_i2c - fix return tests of i2c_smbus_read_block_data()
Input: ektf2127 - mark PM functions as __maybe_unused
Input: snvs_pwrkey - drop input_free_device call if input_register_device fails
Input: add support for Elan eKTF2127 touchscreen controller
Input: serio - add hangup support
Input: tps65218-pwrbutton - add support for tps65217 variant
Input: jornada720_ts - get rid of mach/irqs.h and mach/hardware.h includes
Input: jornada720_kbd - remove unneeded mach/hardware.h include
Input: focaltech - mark focaltech_set_resolution() static
Input: wdt87xx_i2c - fix the flash erase issue
Input: gpio-keys-polled - don't use unit-address with button nodes
Input: add generic input driver to read encoded GPIO lines
Input: add ADC resistor ladder driver
Input: pegasus_notetaker - directly include workqueue header
Input: elants_i2c - get product id on recovery mode for FW update
Input: wm97xx - remove deprecated create_singletheread_workqueue
Input: mc13783_ts - remove deprecated create_singletheread_workqueue
Input: psmouse - remove deprecated create_singletheread_workqueue
Input: jornada720_kbd - switch to using dev_dbg
Input: jornada720_kbd - get rid of mach/irqs.h include
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Core framework:
- Add the MFD bindings doc to MAINTAINERS
New drivers:
- X-Powers AC100 Audio CODEC and RTC
- TI LP873x PMIC
- Rockchip RK808 PMIC
- Samsung Exynos Low Power Audio
New device support:
- Add support for STMPE1600 variant to stmpe
- Add support for PM8018 PMIC to pm8921-core
- Add support for AXP806 PMIC in axp20x
- Add support for AXP209 GPIO in axp20x
New functionality:
- Add support for Reset to all STMPE variants
- Add support for MKBP event support to cros_ec
- Add support for USB to intel_soc_pmic_bxtwc
- Add support for IRQs and Power Button to tps65217
Fix-ups:
- Clean-up defunct author emails (da9063, max14577)
- Kconfig fixups (wm8350-i2c, as37220
- Constify (altera-a10sr, sm501)
- Supply PCI IDs (intel-lpss-pci)
- Improve clocking (qcom_rpm)
- Fix IRQ probing (ucb1x00-core)
- Ensure fault log is cleared (da9052)
- Remove NO_IRQ check (ucb1x00-core)
- Supply I2C properties (intel-lpss-acpi, intel-lpss-pci)
- Non standard declaration (tps65217, max8997-irq)
- Remove unused code (lp873x, db8500-prcmu, ab8500-debugfs,
cros_ec_spi)
- Make non-modular (altera-a10sr, intel_msic, smsc-ece1099,
sun6i-prcm, twl-core)
- OF bindings (ac100, stmpe, qcom-pm8xxx, qcom-rpm, rk808, axp20x,
lp873x, exynos5433-lpass, act8945a, aspeed-scu, twl6040, arizona)
Bugfixes:
- Release OF pointer (qcom_rpm)
- Avoid double shifting in suspend/resume (88pm80x)
- Fix 'defined but not used' error (exynos-lpass)
- Fix 'sleeping whilst attomic' (atmel-hlcdc)"
* tag 'mfd-for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (69 commits)
mfd: arizona: Handle probe deferral for reset GPIO
mfd: arizona: Remove arizona_of_get_named_gpio helper function
mfd: arizona: Add DT options for max_channels_clocked and PDM speaker config
mfd: twl6040: Register child device for twl6040-pdmclk
mfd: cros_ec_spi: Remove unused variable 'request'
mfd: omap-usb-host: Return value is not 'const int'
mfd: ab8500-debugfs: Remove 'weak' function suspend_test_wake_cause_interrupt_is_mine()
mfd: ab8500-debugfs: Remove ab8500_dump_all_banks_to_mem()
mfd: db8500-prcmu: Remove unused *prcmu_set_ddr_opp() calls
mfd: ab8500-debugfs: Prevent initialised field from being over-written
mfd: max8997-irq: 'inline' should be at the beginning of the declaration
mfd: rk808: Fix RK818_IRQ_DISCHG_ILIM initializer
mfd: tps65217: Fix nonstandard declaration
mfd: lp873x: Remove unused mutex lock from struct lp873x
mfd: atmel-hlcdc: Do not sleep in atomic context
mfd: exynos-lpass: Mark PM functions as __maybe_unused
mfd: intel-lpss: Add default I2C device properties for Apollo Lake
mfd: twl-core: Make it explicitly non-modular
mfd: sun6i-prcm: Make it explicitly non-modular
mfd: smsc-ece1099: Make it explicitly non-modular
Linux 4.8
* tag 'v4.8': (1761 commits)
Linux 4.8
ARM: 8618/1: decompressor: reset ttbcr fields to use TTBR0 on ARMv7
MIPS: CM: Fix mips_cm_max_vp_width for non-MT kernels on MT systems
include/linux/property.h: fix typo/compile error
ocfs2: fix deadlock on mmapped page in ocfs2_write_begin_nolock()
mm: workingset: fix crash in shadow node shrinker caused by replace_page_cache_page()
MAINTAINERS: Switch to kernel.org email address for Javi Merino
x86/entry/64: Fix context tracking state warning when load_gs_index fails
x86/boot: Initialize FPU and X86_FEATURE_ALWAYS even if we don't have CPUID
x86/vdso: Fix building on big endian host
x86/boot: Fix another __read_cr4() case on 486
sctp: fix the issue sctp_diag uses lock_sock in rcu_read_lock
sctp: change to check peer prsctp_capable when using prsctp polices
sctp: remove prsctp_param from sctp_chunk
sctp: move sent_count to the memory hole in sctp_chunk
tg3: Avoid NULL pointer dereference in tg3_io_error_detected()
x86/init: Fix cr4_init_shadow() on CR4-less machines
MIPS: Fix detection of unsupported highmem with cache aliases
MIPS: Malta: Fix IOCU disable switch read for MIPS64
MIPS: Fix BUILD_ROLLBACK_PROLOGUE for microMIPS
Instantiating the rmi4 I2C transport driver without interrupts assigned
(for example using manual i2c instantiation from the command line)
caused the driver to fail to load, but it does not clean up its regulator
or transport device registrations. Result is a crash at a later time,
for example when rebooting the system.
Fixes: 946c8432aab0 ("Input: synaptics-rmi4 - support regulator supplies")
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Instantiating the rmi4 SPI transport driver without an interrupt assigned
caused the driver to fail to load, but it does not clean up its transport
device registration. Result may be a crash at a later time, for example
Fixes: 8d99758dee31 ("Input: synaptics-rmi4 - add SPI transport driver")
Here we introduce logic in alps_identify to set the ALPS_DUALPOINT flag
for touchpad hardware responding to E7 report with 73 03 28, as is found
in the Dell Latitude E7470.
Tested-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Ben Gamari <ben@smart-cactus.org>
The SS5 hardware can report this.
While a button is held SS5 hardware will give us single-finger packets
with x, y, and pressure equal to zero. This causes annoying jumps in
pointer position if a touch is released while the button is held. Handle
this by claiming zero contacts to ensure that no position events are
provided to the user.
Reviewed-by: Pali Rohár <pali.rohar@gmail.com>
Add touchstick support for the so-called SS5 hardware, which uses a
variant of the SS4 protocol.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the "big" char and misc driver update for 4.9-rc1.
Lots of little things here, all over the driver tree for subsystems
that flow through me. Nothing major that I can discern, full details
are in the shortlog.
All have been in the linux-next tree with no reported issues"
* tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits)
drivers/misc/hpilo: Changes to support new security states in iLO5 FW
at25: fix debug and error messaging
misc/genwqe: ensure zero initialization
vme: fake: remove unexpected unlock in fake_master_set()
vme: fake: mark symbols static where possible
spmi: pmic-arb: Return an error code if sanity check fails
Drivers: hv: get rid of id in struct vmbus_channel
Drivers: hv: make VMBus bus ids persistent
mcb: Add a dma_device to mcb_device
mcb: Enable PCI bus mastering by default
mei: stop the stall timer worker if not needed
clk: probe common clock drivers earlier
vme: fake: fix build for 64-bit dma_addr_t
ttyprintk: Neaten and simplify printing
mei: me: add kaby point device ids
coresight: tmc: mark symbols static where possible
coresight: perf: deal with error condition properly
Drivers: hv: hv_util: Avoid dynamic allocation in time synch
fpga manager: Add hardware dependency to Zynq driver
Drivers: hv: utils: Support TimeSync version 4.0 protocol samples.
Just like Fujitsu CELSIUS H730, the H760 also has an Elantech touchpad with
the same quirks. Without this patch, the touchpad is useless out-of-the-box
as the mouse pointer won't move.
This patch makes the driver aware of both the crc_enabled=1 requirement and
the middle button, making the touchpad fully functional out-of-the-box.
Signed-off-by: Matti Kurkela <Matti.Kurkela@iki.fi>
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
Reviewed-by: Ulrik De Bie <ulrik.debie-os@e2big.org>
Prepare first round of input updates for 4.9 merge window.
i2c_smbus_read_block_data() returns negative errno else the number of
data bytes in the slave's response.
Checking for error not null means the function always fails if the device
answers properly.
So given that we read 3 bytes and access those, better check that we
actually read those 3 bytes.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
The newly added ektf2127 driver uses the SIMPLE_DEV_PM_OPS macro
to conditionally refer to the resume/suspend functions, which
causes a warning when CONFIG_PM_SLEEP is disabled:
drivers/input/touchscreen/ektf2127.c:168:12: error: 'ektf2127_resume' defined but not used [-Werror=unused-function]
drivers/input/touchscreen/ektf2127.c:156:12: error: 'ektf2127_suspend' defined but not used [-Werror=unused-function]
We could either put these functions inside of an #ifdef or
add __maybe_unused annotations. This uses the second approach,
which is generally more foolproof.
Fixes: 9ca5bf5029b6 ("Input: add support for Elan eKTF2127 touchscreen controller")
Pull input fix from Dmitry Torokhov:
"One small change to make joydev (which is used by older games) to bind
to devices that export Z axis but not X or Y (such as TRC rudder)"
Input: joydev - recognize devices with Z axis as joysticks
Current implementation of joydev's input_device_id table recognizes only
devices with ABS_X, ABS_WHEEL or ABS_THROTTLE axes as joysticks.
There are joystick devices that do not have those axes, for example TRC
Rudder device. The device in question has ABS_Z, ABS_RX and ABS_RY axes
causing it not being detected as joystick.
This patch adds ABS_Z to the input_device_id list allowing devices with
ABS_Z axis to be detected correctly.
Signed-off-by: Ville Ranki <ville.ranki@iki.fi>
Current code uses devm_input_allocate_device() so don't explicitly call
input_free_device if input_register_device fails.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This adds a driver for the Elan eKTF2127 touchscreen controller,
which speaks an i2c protocol which is distinctly different from
the already supported eKTH controllers.
Signed-off-by: Michel Verlaan <michel.verl@gmail.com>
Signed-off-by: Siebren Vroegindeweij <siebren.vroegindeweij@hotmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Pull input updates from Dmitry Torokhov:
"Just a fix up for the firmware handling to the Silead driver (which is
a new driver in this release)"
Input: silead_gsl1680 - use "silead/" prefix for firmware loading
Input: silead_gsl1680 - document firmware-name, fix implementation
The Pulse-Eight USB CEC adapter is a usb device that shows up as a ttyACM0
device. It requires that you run inputattach in order to communicate with
it via serio.
This all works well, but it would be nice to have a udev rule to
automatically start inputattach. That too works OK, but the problem comes
when the USB device is unplugged: the tty hangup is never handled by the
serio framework so the inputattach utility never exits and you have to kill
it manually.
By adding this hangup callback the inputattach utility now properly exits
as soon as the USB device is unplugged.
The udev rule I used on my Debian sid system is:
SUBSYSTEM=="tty", KERNEL=="ttyACM[0-9]*", ATTRS{idVendor}=="2548", ATTRS{idProduct}=="1002", ACTION=="add", TAG+="systemd", ENV{SYSTEMD_WANTS}+="pulse8-cec-inputattach@%k.service"
And /etc/systemd/system/pulse8-cec-inputattach@.service is as follows:
[Unit]
Description=inputattach for pulse8-cec device on %I
[Service]
Type=simple
ExecStart=/usr/local/bin/inputattach --pulse8-cec /dev/%I
KillMode=process
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Tested-by: Hans Verkuil <hans.verkuil@cisco.com>
Add copyright lines for Zodiac who paid for the V4L touch work.
Signed-off-by: Nick Dyer <nick@shmanahar.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
The newly added debug mode for the synaptics-rmi4 driver relies on
the v4l2 interface and vb2_vmalloc, but those might be configured
as loadable modules when the driver itself is built-in, resulting
in a link failure:
drivers/input/rmi4/rmi_core.o: In function `rmi_f54_remove':
rmi_f54.c:(.text.rmi_f54_remove+0x14): undefined reference to `video_unregister_device'
rmi_f54.c:(.text.rmi_f54_remove+0x20): undefined reference to `v4l2_device_unregister'
drivers/input/rmi4/rmi_core.o: In function `rmi_f54_vidioc_s_input':
rmi_f54.c:(.text.rmi_f54_vidioc_s_input+0x10): undefined reference to `video_devdata'
drivers/input/rmi4/rmi_core.o: In function `rmi_f54_vidioc_g_input':
rmi_f54.c:(.text.rmi_f54_vidioc_g_input+0x10): undefined reference to `video_devdata'
drivers/input/rmi4/rmi_core.o: In function `rmi_f54_vidioc_fmt':
rmi_f54.c:(.text.rmi_f54_vidioc_fmt+0x10): undefined reference to `video_devdata'
drivers/input/rmi4/rmi_core.o: In function `rmi_f54_vidioc_enum_input':
rmi_f54.c:(.text.rmi_f54_vidioc_enum_input+0x10): undefined reference to `video_devdata'
drivers/input/rmi4/rmi_core.o: In function `rmi_f54_vidioc_querycap':
The best workaround I could come up with is to disallow the debug
mode unless it's actually possible to call it.
Fixes: 3a762dbd5347 ("[media] Input: synaptics-rmi4 - add support for F54 diagnostics")
Acked-by: Nick Dyer <nick@shmanahar.org>
The newnly added debug mode for the atmel_mxt_ts driver relies on
in a link failure:
drivers/input/touchscreen/atmel_mxt_ts.o: In function `mxt_vidioc_querycap':
atmel_mxt_ts.c:(.text.mxt_vidioc_querycap+0x10): undefined reference to `video_devdata'
drivers/input/touchscreen/atmel_mxt_ts.o: In function `mxt_buffer_queue':
atmel_mxt_ts.c:(.text.mxt_buffer_queue+0x20): undefined reference to `vb2_plane_vaddr'
atmel_mxt_ts.c:(.text.mxt_buffer_queue+0x164): undefined reference to `vb2_buffer_done'
drivers/input/touchscreen/atmel_mxt_ts.o: In function `mxt_free_object_table':
atmel_mxt_ts.c:(.text.mxt_free_object_table+0x18): undefined reference to `video_unregister_device'
atmel_mxt_ts.c:(.text.mxt_free_object_table+0x20): undefined reference to `v4l2_device_unregister'
Fixes: ecfdd7e2660e ("[media] Input: atmel_mxt_ts - output diagnostic debug via V4L2 device")
The silead touch-controller ICs use a different firmware per digitizer /
tablet model. So there are going to be quite a few of then and they really
should be under a separate subdir.
This commit prefixes the default firmware names with "silead/" just like
we are already doing for devicetree specified firmware names.
The driver has supported touchscreen-fw-name to specify the firmware to
load since it has been merged, but this was omitted from the dt-binding
documentation.
During review of adding touchscreen-fw-name to the binding documentation
it was brought up that there is a standard property name called
"firmware-name" for this, which should be used.
Since there are no users of touchscreen-fw-name yet, this commit
adds documentation of "firmware-name" to the dt-binding documentation
and switches the driver over to use this.
This commit also makes the driver add a "silead/" prefix to the
firmware name from dt before calling request_firmware. That the
firmware files are stored under /lib/firmware/silead under Linux
is an implementation detail and does not belong in devicetree.
The power button found in tps65217 device is very similar to the tps65218,
so let's enhance the driver to support both variants.
This driver enables us to use tps65217's power button as KEY_POWER on
am335x boards (directly connected button in chiliboard, accessible pin
via expansion header in beaglebone). This patch has been tested with
chiliboard.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Switch the jornada720 touchscreen driver to obtain its gpio from
the platform device via gpiolib and derive the interrupt from the
GPIO, rather than via a hard-coded interrupt number obtained from
the mach/irqs.h and mach/hardware.h headers.
Tested-by: Adam Wysocki <armlinux@chmurka.net>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
The Jornada720 keyboard driver does not make use of anything from the
mach/hardware.h header, so this header can be removed.
We get 1 warning when building kernel with W=1:
drivers/input/mouse/focaltech.c:393:6: warning: no previous prototype for 'focaltech_set_resolution' [-Wmissing-prototypes]
In fact, this function is only used in the file in which it is
declared and don't need a declaration, but can be made static.
So this patch marks it 'static'.
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
The spec says that flash erase time is 30ms typical/200ms max, so let's
replace current 50ms wait with 200ms to avoid potential failures.
Signed-off-by: HungNien Chen <hn.chen@weidahitech.com>
We want the fixes in here for merging and testing.
Many modules call misc_register and misc_deregister in its module init
and exit methods without any additional code. This ends up being
boilerplate. This patch adds helper macro module_misc_device(), that
replaces module_init()/ module_exit() with template functions.
This patch also converts drivers to use new macro.
Change since v1:
Add device.h include in miscdevice.h as module_driver macro was not
available from other include files in some architectures.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
Because events other that keyboard ones will be handled by now on by
other drivers, stop directly handling interrupts and instead listen to
the new notifier in the MFD driver.
Signed-off-by: Vic Yang <victoryang@google.com>
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Tested-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Add a driver to read group of GPIO lines and provide its status as a
numerical value as input event to the system. This will help in
interfacing devices, that can be connected over GPIOs, that provide
input to the system by driving GPIO lines connected to them like a
rotary dial or a switch.
For example, a rotary switch can be connected to four GPIO lines. The
status of the GPIO lines reflect the actual position of the rotary
switch dial. For example, if dial points to 9, then the four GPIO lines
connected to the switch will read HLLH(0b'1001 = 9). This value
can be reported as an ABS_* event to the input subsystem.
Signed-off-by: Vignesh R <vigneshr@ti.com>
A common way of multiplexing buttons on a single input in cheap devices is
to use a resistor ladder on an ADC. This driver supports that configuration
by polling an ADC channel provided by IIO.
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Pull input subsystem fixes from Dmitry Torokhov:
"Simply small driver fixups"
Input: ads7846 - remove redundant regulator_disable call
Input: synaptics-rmi4 - fix register descriptor subpacket map construction
Input: tegra-kbc - fix inverted reset logic
Input: silead - use devm_gpiod_get
Input: i8042 - set up shared ps2_cmd_mutex for AUX ports
According to the kernel's guidelines, let's directly include the
workqueue functions we use.
Signed-off-by: Martin Kepplinger <martink@posteo.de>
We use hw version to construct name of file holding touchscreen firmware,
so let's try reading it even if touchscreen initialization fails (the
firmware supports reading product/hardware id even when device is in
recovery/boot mode).
Signed-off-by: Johnny Chuang <johnny.chuang@emc.com.tw>
alloc_ordered_workqueue() replaces deprecated
create_singlethread_workqueue().
It queues work items via &wm->ts_reader and &wm->pen_event_work which map
to wm97xx_pen_irq_worker (handles a pen down interrupt) and
wm97xx_ts_reader (the touchscreen sample reader) respectively. Hence, an
ordered dedicated workqueue has been used.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
The workqueue "workqueue" has a single workitem(&priv->work) and hence
doesn't require ordering. Also, it is not being used on a memory reclaim
path. Hence, the singlethreaded workqueue has been replaced with the use
of system_wq.
System workqueues have been able to handle high level of concurrency
for a long time now and hence it's not required to have a singlethreaded
workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue
created with create_singlethread_workqueue(), system_wq allows multiple
work items to overlap executions even on the same CPU; however, a
per-cpu workqueue doesn't have any CPU locality or global ordering
guarantee unless the target CPU is explicitly specified and thus the
increase of local concurrency shouldn't make any difference.
Workitem is sync cancelled in mc13783_ts_remove() to ensure that there
are no workitems pending when the driver is disconnected.
alloc_ordered_workqueue() replaces the deprecated
There are multiple work items on the work queue viz
&priv->dev3_register_work, &priv->recalib_wq, &psmouse->resync_work,
which require execution ordering. Hence, an ordered workqueue has been
used.
The workqueue is not being used on a memory reclaim path. Hence,
WQ_MEM_RECLAIM has not been set.
Acked-by: Tejun Heo <tj@kernel.org>
The device hardware is always running at 60 FPS, so report this both via
PARM_IOCTL and ENUM_FRAMEINTERVALS.
[hans.verkuil@cisco.com: fix suspect indent checkpatch warning]
[mchehab@s-opensource.com: fix a trivial merge conflict]
Signed-off-by: Martin Kaltenbrunner <modin@yuri.at>
Signed-off-by: Florian Echtler <floe@butterbrot.org>
Support both V4L2_TCH_FMT_TU08 and V4L2_PIX_FMT_GREY for backwards
compatibility.
Function 54 implements access to various RMI4 diagnostic features.
This patch adds support for retrieving this data. It registers a V4L2
device to output the data to user space.
Tested-by: Andrew Duggan <aduggan@synaptics.com>
Tested-by: Chris Healy <cphealy@gmail.com>
There are different datatypes available from a maXTouch chip. Add
support to retrieve reference data as well.
The mXT1386 family of chips have a different architecture which splits
the diagnostic data into 3 columns.
