path: root/drivers/input
2008-07-08Merge branches 'x86/numa-fixes', 'x86/apic', 'x86/apm', 'x86/bitops', ↵Ingo Molnar
'x86/build', 'x86/cleanups', 'x86/cpa', 'x86/cpu', 'x86/defconfig', 'x86/gart', 'x86/i8259', 'x86/intel', 'x86/irqstats', 'x86/kconfig', 'x86/ldt', 'x86/mce', 'x86/memtest', 'x86/pat', 'x86/ptemask', 'x86/resumetrace', 'x86/threadinfo', 'x86/timers', 'x86/vdso' and 'x86/xen' into x86/devel
2008-07-02drivers/input/ff-core.c needs <linux/sched.h>Geert Uytterhoeven
Commit 656acd2bbc4ce7f224de499ee255698701396c48 ("Input: fix locking in force-feedback core") causes the following regression on m68k: | linux/drivers/input/ff-core.c: In function 'input_ff_upload': | linux/drivers/input/ff-core.c:172: error: dereferencing pointer to incomplete type | linux/drivers/input/ff-core.c: In function 'erase_effect': | linux/drivers/input/ff-core.c:197: error: dereferencing pointer to incomplete type | linux/drivers/input/ff-core.c:204: error: dereferencing pointer to incomplete type | make[4]: *** [drivers/input/ff-core.o] Error 1 As the incomplete type is `struct task_struct', including <linux/sched.h> fixes it. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: fix locking in force-feedback core Input: add KEY_MEDIA_REPEAT definition
2008-06-30Input: fix locking in force-feedback coreDmitry Torokhov
The newly added event_lock spinlock in the input core disallows sleeping and therefore using mutexes in event handlers. Convert force-feedback core to rely on event_lock instead of mutex to protect slots allocated for fore-feedback effects. The original mutex is still used to serialize uploading and erasing of effects. Reported-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-25Merge commit 'v2.6.26-rc8' into x86/xenIngo Molnar
Conflicts: arch/x86/xen/enlighten.c arch/x86/xen/mmu.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-17Merge branch 'for-linus' of ↵tip-x86-pci-ioapic-boot-irq-quirks-2008-06-23_09.52_Montip-x86-mm-remove-arch-get-ram-range-2008-06-23_09.06_Montip-x86-mm-debug-2008-06-23_09.04_Montip-core-debugobjects-2008-06-23_08.51_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: appletouch - implement reset-resume logic Input: i8042 - retry failed CTR writes when resuming Input: i8042 - add Fujitsu-Siemens Amilo Pro V2030 to nomux table Input: pcspkr - remove negative dependency on snd-pcsp Manually fixed up trivial conflict in drivers/usb/core/quirks.c
2008-06-17Input: appletouch - implement reset-resume logicOliver Neukum
On some boxes the touchpad needs to be reinitialized after resume to make it function again. This fixes bugzilla #10825. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-17Input: i8042 - retry failed CTR writes when resumingJiri Kosina
There are systems that fail in i8042_resume() with i8042: Can't write CTR to resume as i8042_command(&i8042_ctr, I8042_CMD_CTL_WCTR) fails even though the controller claimed itself to be ready before. One retry after failing write fixes the problems on the failing systems. Reported-by: Helmut Schaa <hschaa@novell.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-16Merge branch 'linus' into x86/xentip-x86-xen-2008-06-16_09.21_MonIngo Molnar
2008-06-06Input: i8042 - add Fujitsu-Siemens Amilo Pro V2030 to nomux tableJiri Kosina
Fujitsu Siemens Amilo Pro V2030 needs nomux table entry, in addition to already existing entry for V2010 model (note that Fujitsu-Siemens changed the capitalization in the DMI data for product). Tested-by: Jiri Mleziva <jmleziva@tiscali.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-06Input: pcspkr - remove negative dependency on snd-pcspStas Sergeev
It should be possible to build pcspkr driver together with snd-pcsp, even though tehy can not be used together. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: rename SW_RADIO to SW_RFKILL_ALL Input: gtco - fix double kfree in error handling path Input: pxa27x_keypad - miscellaneous fixes Input: atkbd - mark keyboard as disabled when suspending/unloading Input: apanel - remove duplicate include Input: wm9713 - support five wire panels Input: wm97xx-core - fix race on PHY init Input: wm97xx-core - fix driver name Input: wm97xx-core - report a phys for WM97xx touchscreens Input: i8042 - make sure Dritek quirk is invoked at resume Input: i8042 - add Dritek quirk for Acer TravelMate 660
2008-05-30Input: gtco - fix double kfree in error handling pathDmitry Torokhov
The code would try to free 'report' twice upon input_register_device() failure. Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-28Input: pxa27x_keypad - miscellaneous fixesAntonio Ospite
1. Set input bits for direct keys codes 2. Set input bits for rotary encoder codes only if rotary encoder is enabled 3. Enable EV_REL only if rotary encoder is enabled and rel_codes are set up Signed-off-by: Antonio Ospite <ao2@openezx.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-28Input: atkbd - mark keyboard as disabled when suspending/unloadingDmitry Torokhov
This will shut off garbage that may come from KBD port during resume. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27xen pvfb: Dynamic mode support (screen resizing)Markus Armbruster
The pvfb backend indicates dynamic mode support by creating node feature_resize with a non-zero value in its xenstore directory. xen-fbfront sends a resize notification event on mode change. Fully backwards compatible both ways. Framebuffer size and initial resolution can be controlled through kernel parameter xen_fbfront.video. The backend enforces a separate size limit, which it advertises in node videoram in its xenstore directory. xen-kbdfront gets the maximum screen resolution from nodes width and height in the backend's xenstore directory instead of hardcoding it. Additional goodie: support for larger framebuffers (512M on a 64-bit system with 4K pages). Changing the number of bits per pixels dynamically is not supported, yet. Ported from http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/92f7b3144f41 http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/bfc040135633 Signed-off-by: Pat Campbell <plc@novell.com> Signed-off-by: Markus Armbruster <armbru@redhat.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-27xen pvfb: Module aliases to support module autoloadingMarkus Armbruster
These are mostly for completeness and consistency with the other frontends, as PVFB is typically compiled in rather than a module. Derived from http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/5e294e29a43e While there, add module descriptions. Signed-off-by: Markus Armbruster <armbru@redhat.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-27xen pvfb: Pointer z-axis (mouse wheel) supportMarkus Armbruster
Add z-axis motion to pointer events. Backward compatible, because there's space for the z-axis in union xenkbd_in_event, and old backends zero it. Derived from http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/57dfe0098000 http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/1edfea26a2a9 http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/c3ff0b26f664 Signed-off-by: Pat Campbell <plc@novell.com> Signed-off-by: Markus Armbruster <armbru@redhat.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-27Input: apanel - remove duplicate includeHuang Weiyi
Remove duplicate include file <linux/module.h>. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm9713 - support five wire panelsMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm97xx-core - fix race on PHY initMark Brown
The chip phy_init() function must be called before the dig_enable() function but dig_enable() is called when the device is opened and we only call phy_init() after having reigstered the device, meaning the two can race. Fix this by doing the phy_init() before we register the input device. Thanks to Rodolfo Giometti <giometti@enneenne.com> for the report. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm97xx-core - fix driver nameMark Brown
Fix driver name - thanks to Guennadi Liakhovetski <g.liakhovetski@gmx.de> for reporting this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm97xx-core - report a phys for WM97xx touchscreensMark Brown
phys is displayed in diagnostic output like that from evbug so ensure that it is set to something. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: i8042 - make sure Dritek quirk is invoked at resumeBruno Prémont
Also do not fail i8042 entire initialization if enabling dritek extension fails. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-21MODULE_LICENSE expects "GPL v2", not "GPLv2"Al Viro
... and we have few enough places using the latter to make it simpler to do search and replace... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20Input: i8042 - add Dritek quirk for Acer TravelMate 660Bruno Prémont
The Acer TravelMate 660 series also requires the Dritek quirk to enable the extra scancodes. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-18m68k: Return -ENODEV if no device is foundGeert Uytterhoeven
According to the tests in do_initcalls(), the proper error code in case no device is found is -ENODEV, not -ENXIO or -EIO. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Some input drivers do not check the platformGeert Uytterhoeven
Some input drivers do not check whether they're actually running on the correct platform, causing multi-platform kernels to crash if they are not. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (37 commits) SH: catch negative denormal_subf1() retval in denormal_add() sh: Fix DMAC base address for SH7709S sh: update smc91x platform data for se7206. sh: Stub in cpu_to_node() and friends for NUMA build. sh: intc register modify fix sh: no high level trigger on some sh3 cpus sh: clean up sh7710 and sh7720 intc tables sh: add interrupt ack code to sh3 sh: unify external irq pin code for sh3 sh-sci: avoid writing to nonexistent registers sh-sci: sh7722 lacks scsptr registers sh-sci: improve sh7722 support sh: reset hardware from early printk sh: drain and wait for early printk sh: use sci_out() for early printk sh: add memory resources to /proc/iomem sh: add kernel bss resource sh: fix sh7705 interrupt vector typo sh: update smc91x platform data for se7722 sh: update smc91x platform data for MigoR ...
2008-05-08input: i8042: sh64 IRQ definitions depend on cayman board.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-07pcspkr: fix dependanciesStas Sergeev
fix pcspkr dependancies: make the pcspkr platform drivers to depend on a platform device, and not the other way around. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> CC: Vojtech Pavlik <vojtech@suse.cz> CC: Michael Opdenacker <michael-lists@free-electrons.com> [fixed for 2.6.26-rc1 by tiwai] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05m68k: drivers/input/serio/hp_sdc.c needs <linux/semaphore.h>Geert Uytterhoeven
drivers/input/serio/hp_sdc.c: In function 'hp_sdc_take': drivers/input/serio/hp_sdc.c:198: error: implicit declaration of function 'up' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29input: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28usb input endianness annotations and fixesAl Viro
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: video drivers: add facility level sparc: tcx.c make tcx_init and tcx_exit static sparc: ffb.c make ffb_init and ffb_exit static sparc: cg14.c make cg14_init and cg15_exit static sparc: bw2.c fix bw2_exit sparc64: Fix accidental syscall restart on child return from clone/fork/vfork. sparc64: Clean up handling of pt_regs trap type encoding. sparc: Remove old style signal frame support. sparc64: Kill bogus RT_ALIGNEDSZ macro from signal.c sparc: sunzilog.c remove unused argument sparc: fix drivers/video/tcx.c warning sparc64: Kill unused local ISA bus layer. input: Rewrite sparcspkr device probing. sparc64: Do not ignore 'pmu' device ranges. sparc64: Kill ISA_FLOPPY_WORKS code. sparc64: Kill CONFIG_SPARC32_COMPAT sparc64: Cleanups and corrections for arch/sparc64/Kconfig sparc64: Fix wedged irq regression.
2008-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - fix build failure
2008-04-26input: Rewrite sparcspkr device probing.David S. Miller
Remove all dependencies on EBUS and ISA bus layers, which we'd like to remove as they are superfluous. While we're here, add support for proper frequency changing on BBC beep devices. Unlike the comments that were here, this device can in fact use a programmable frequency. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27Input: xpad - fix build failureDmitry Torokhov
If both CONFIG_JOYSTICK_XPAD_FF and CONFIG_JOYSTICK_XPAD_LEDS are unset xpad_bulk_out is not defined and build fails. Move it out of the #ifdef block so it is always defined. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (120 commits) usb: don't update devnum for wusb devices wusb: make ep0_reinit available for modules wusb: devices dont use a set address wusb: teach choose_address() about wireless devices wusb: add link wusb-usb device wusb: add authenticathed bit to usb_dev USB: remove unnecessary type casting of urb->context usb serial: more fixes and groundwork for tty changes USB: replace remaining __FUNCTION__ occurrences USB: usbfs: export the URB_NO_INTERRUPT flag to userspace USB: fix compile problems in ehci-hcd USB: ehci: qh_completions cleanup and bugfix USB: cdc-acm: signedness fix USB: add documentation about callbacks USB: don't explicitly reenable root-hub status interrupts USB: OHCI: turn off RD when remote wakeup is disabled USB: HCDs use the do_remote_wakeup flag USB: g_file_storage: ignore bulk-out data after invalid CBW USB: serial: remove endpoints setting checks from core and header USB: serial: remove unneeded number endpoints settings ...
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: wacom - add support for Cintiq 20WSX Input: ucb1400_ts - IRQ probe fix Input: at32psif - update MODULE_AUTHOR with new email Input: mac_hid - add lockdep annotation to emumousebtn Input: i8042 - fix incorrect usage of strncpy and strncat Input: bf54x-keys - add infrastructure for keypad wakeups Input: add MODULE_ALIAS() to hotpluggable platform modules Input: drivers/char/keyboard.c - use time_after Input: fix ordering in joystick Makefile Input: wm97xx-core - support use as a wakeup source Input: wm97xx-core - use IRQF_SAMPLE_RANDOM Input: wm97xx-core - only schedule interrupt handler if not already scheduled Input: add Zhen Hua driver Input: aiptek - add support for Genius G-PEN 560 tablet Input: wacom - implement suspend and autosuspend Input: xpad - set proper buffer length for outgoing requests Input: omap-keypad - fix build warning Input: gpio_keys - irq handling cleanup Input: add PS/2 serio driver for AVR32 devices Input: put ledstate in the keyboard notifier ...
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next: (52 commits) xen: add balloon driver xen: allow compilation with non-flat memory xen: fold xen_sysexit into xen_iret xen: allow set_pte_at on init_mm to be lockless xen: disable preemption during tlb flush xen pvfb: Para-virtual framebuffer, keyboard and pointer driver xen: Add compatibility aliases for frontend drivers xen: Module autoprobing support for frontend drivers xen blkfront: Delay wait for block devices until after the disk is added xen/blkfront: use bdget_disk xen: Make xen-blkfront write its protocol ABI to xenstore xen: import arch generic part of xencomm xen: make grant table arch portable xen: replace callers of alloc_vm_area()/free_vm_area() with xen_ prefixed one xen: make include/xen/page.h portable moving those definitions under asm dir xen: add resend_irq_on_evtchn() definition into events.c Xen: make events.c portable for ia64/xen support xen: move events.c to drivers/xen for IA64/Xen support xen: move features.c from arch/x86/xen/features.c to drivers/xen xen: add missing definitions in include/xen/interface/vcpu.h which ia64/xen needs ...
2008-04-24USB: convert away from urb->status in xpad driverOliver Neukum
USB is moving to transfering status as a parameter. To ease the transition urb->status is to be touched only once in a function. The xpad driver has been overlooked. Dmitry wants this to go through the USB tree. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24Input: wacom - add support for Cintiq 20WSXPing Cheng
Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24xen pvfb: Para-virtual framebuffer, keyboard and pointer driverMarkus Armbruster
This is a pair of Xen para-virtual frontend device drivers: drivers/video/xen-fbfront.c provides a framebuffer, and drivers/input/xen-kbdfront provides keyboard and mouse. The backends run in dom0 user space. The two drivers are not in two separate patches, because the intermediate step (one driver, not the other) is somewhat problematic: the backend in dom0 needs both drivers, and will refuse to complete device initialization unless they're both present. Signed-off-by: Markus Armbruster <armbru@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24Merge branch 'wm97xx'Dmitry Torokhov
2008-04-24Input: ucb1400_ts - IRQ probe fixVernon Sauder
The UCB1400 driver IRQ probe code fails to find an interrupt if all the interrupts in the range 0-31 are nonprobe-able. This patch removes the check of the return value so interrupts above 31 can be detected. Tested on InHand Fingertip4 PXA270 board. Signed-off-by: Vernon Sauder <vsauder@inhand.com> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: at32psif - update MODULE_AUTHOR with new emailHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
