path: root/drivers/input/touchscreen/elo.c
2007-04-12Input: touchscreens - switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion, switch to using input_dev->dev.parent when specifying device position in sysfs tree. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: drivers/input/touchscreen - don't access dev->private directlyDmitry Torokhov
Use input_get_drvdata() and input_set_drvdata() instead. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-11-23Input: handle serio_register_driver() errorsAkinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-05Input: elo - add support for non-pressure-sensitive touchscreensShaun Jackman
- Use the touch status bit rather than the pressure bits to distinguish a BTN_TOUCH event. Non-pressure-sensitive touchscreens always report full pressure - Report ABS_PRESSURE information only if the touchscreen supports it Signed-off-by: Shaun Jackman <sjackman@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-08-05Input: elo - fix checksum calculationShaun Jackman
Fix 10-byte protocol checksum calculation and do not discard packet early unless it is missing lead in byte. Signed-off-by: Shaun Jackman <sjackman@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-08-05Input: elo - handle input_register_device() failuresDmitry Torokhov
2005-10-28[PATCH] drivers/input/touchscreen: convert to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/input/touchscreen to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-29Input: whitespace fixes in drivers/input/touchscreenDmitry Torokhov
