The implementation in cy8ctmg110_probe() does not properly set reset_pin
and irq_pin from platform data. Let's fix it.
i2c_master_send returns negative errno, or else the number of bytes written.
There is a general move towards the use of dev_pm_ops rather than
bus specific suspend APIs as this simplifies both the bus and PM core
implementations. Convert the cy8ctmg110_ts driver over.
Compile tested only.
Without this the jitter on the touchscreen makes it hard to use for
most GUI toolkits.
Signed-off-by: James Ketrenos<jketreno@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
"ret" should be signed here or the error handling doesn't work.
Acked-by: Alan Cox <alan@linux.intel.com>
Add support for the cy8ctmg110 capacitive touchscreen used on some
embedded devices.
(Some clean up by Alan Cox)
