path: root/drivers/input/misc/wm831x-on.c
2010-03-11Input: wm831x-on - convert to use genirqMark Brown
Now that the WM831x core has been converted to use genirq for the interrupt controller there is no need for the client drivers to use a WM831x-specific API rather than just calling genirq directly. Also fixes a leak of the IRQ during init failure - the error path free_irq() was using NULL rather than the driver data as the data pointer so free_irq() wouldn't have matched. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-17input: Add support for the WM831x ON pinMark Brown
The WM831x series of PMICs support control of initial power on through the ON pin on the device with soft control of the pin at other times. Represent this to userspace as KEY_POWER. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
