path: root/drivers/input/misc/ati_remote2.c
2011-05-05Input: ati_remote2 - return the error code from sysfs channel_mask storeVille Syrjala
If the channel_mask setup fails when configuring it through sysfs, return the error code to the caller instead of claiming success. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-01-31Input: switch completely over to the new versions of get/setkeycodeDmitry Torokhov
All users of old style get/setkeycode methids have been converted so it is time to retire them. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-09-15Input: ati_remote2 - switch to using new keycode interfaceDmitry Torokhov
Switch the code to use new style of getkeycode and setkeycode methods to allow retrieving and setting keycodes not only by their scancodes but also by index. Acked-by: Ville Syrjälä <syrjala@sci.fi> Tested-by: Jarod Wilson <jarod@wilsonet.com> Tested-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-11param: use ops in struct kernel_param, rather than get and set fns directlyRusty Russell
This is more kernel-ish, saves some space, and also allows us to expand the ops without breaking all the callers who are happy for the new members to be NULL. The few places which defined their own param types are changed to the new scheme (more which crept in recently fixed in following patches). Since we're touching them anyway, we change get() and set() to take a const struct kernel_param (which they really are). This causes some harmless warnings until we fix them (in following patches). To reduce churn, module_param_call creates the ops struct so the callers don't have to change (and casts the functions to reduce warnings). The modern version which takes an ops struct is called module_param_cb. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Alessandro Rubini <rubini@ipvvis.unipv.it> Cc: Michal Januszewski <spock@gentoo.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-kernel@vger.kernel.org Cc: linux-input@vger.kernel.org Cc: linux-fbdev-devel@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: netdev@vger.kernel.org
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Input: scancode in get/set_keycodes should be unsignedDmitry Torokhov
The HID layer has some scan codes of the form 0xffbc0000 for logitech devices which do not work if scancode is typed as signed int, so we need to switch to unsigned it instead. While at it keycode being signed does not make much sense either. Acked-by: Márton Németh <nm127@freemail.hu> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-05-19Input: ati_remote2 - use non-atomic bitopsVille Syrjala
No point in using atomic bitops when setting the input device keybits. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-01-29Input: ati_remote2 - check module paramsVille Syrjala
Validate that the values of the module parameters are within the supported range. Also print the values in hex since that seems like a better match for bitmasks than decimal. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-01-29Input: ati_remote2 - add per device attrsVille Syrjala
Add per device channel_mask and mode_mask attributes. They inherit the values from the module parameters when the device is registered. One additional benefit is that now runtime changes to channel_mask can actually affect the hardware channel setup like they should. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-01-29Input: ati_remote2 - complete suspend supportVille Syrjala
Add the missing reset_resume, pre_reset and post_reset hooks. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-30Input: ati_remote2 - add autosuspend supportVille Syrjala
2008-07-30Input: ati_remote2 - add loadable keymap supportVille Syrjala
Support for loadable keymaps. The driver now supports individual keymaps for each of the five modes (AUX1-AUX4 and PC) of the remote. To achieve this the keymap scancode is interpreted as a combination of the mode and actual button scancode. The original keycode patches were done by Peter Stokes <linux@dadeos.co.uk> but I modified it quite a lot. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-16Input: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Input: move USB miscellaneous devices under drivers/input/miscDmitry Torokhov
This will allow concentrating all input devices in one place in {menu|x|q}config. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
