path: root/drivers/input/joystick/analog.c
2013-03-14input/joystick: use get_cycles on ARMArnd Bergmann
ARM normally has an accurate clock source, so we can theoretically use analog joysticks more accurately and at the same time avoid the build warning #warning Precise timer not defined for this architecture. from the joystick driver. Now, why anybody would use that driver no ARM I have no idea, but Ben Dooks enabled it in the s3c2410_defconfig along with a bunch of other drivers, even though that platform has neither ISA nor PCI support. It still seems to be the right thing to fix this quirk. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Ben Dooks <ben-linux@fluff.org>
2013-02-04drivers/input/joystick/analog.c: enable precise timerChris Metcalf
Like nm10300, tile can just use get_cycles() for this. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-08-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: ad714x - read the interrupt status registers in a row Input: ad714x - use DMA-safe buffers for spi_write() Input: ad714x - fix endianness issues Input: ad714xx-spi - force SPI bus into the default 8-bit mode Input: ep93xx_keypad - add missing include of linux/module.h Input: tnetv107x-ts - add missing include of linux/module.h Input: max11801_ts - correct license statement Input: atmel_mxt_ts - report pressure information from the driver Input: bcm5974 - Add support for newer MacBookPro8,2 Input: wacom - report id 3 returns 4 bytes of data Input: wacom - add WAC_MSG_RETRIES define Input: wacom - add support for the Wacom Bamboo Pen (CTL-660/K) Input: tegra-kbc - correct call to input_free_device Input: mpu3050 - correct call to input_free_device Input: bcm5974 - add support for touchpads found in MacBookAir4,2 Input: mma8450 - fix module device table type Input: remove CLOCK_TICK_RATE from analog joystick driver
2011-08-04Input: remove CLOCK_TICK_RATE from analog joystick driverDeepak Saxena
The analog joystick driver is written for x86 systems. This patch updates it to use the PIT_TICK_RATE value instead of CLOCK_TICK_RATE as they are equivalent on x86 and we want to deprecate the latter. Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2010-03-02i8253: Convert i8253_lock to raw_spinlockThomas Gleixner
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can not be converted to a sleeping lock. Convert it to raw_spinlock and fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <20100217163751.030764372@linutronix.de>
2009-06-16time: move PIT_TICK_RATE to linux/timex.hArnd Bergmann
PIT_TICK_RATE is currently defined in four architectures, but in three different places. While linux/timex.h is not the perfect place for it, it is still a reasonable replacement for those drivers that traditionally use asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency. Note that for Alpha, the actual value changed from 1193182UL to 1193180UL. This is unlikely to make a difference, and probably can only improve accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE a few years ago, after which every existing instance was getting changed to 1193182. According to the specification, it should be 1193181.818181... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30Input: gameport - check return value of gameport_register_driver()Dmitry Torokhov
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-21Input: drop redundant includes of moduleparam.hJulia Lawall
Drop #include <linux/moduleparam.h> in files that also include linux/module.h, since module.h includes moduleparam.h already. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03Input: drivers/joystick - fix various sparse warningsDmitry Torokhov
Fix various issues pointed by sparse: - module_param_array_named() takes unsigned int as number of parameters argument - shadowing of global variables is not healthy. I think there was once a bug in db9 caused by it. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: joysticks - switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion, switch to using input_dev->dev.parent when specifying device position in sysfs tree. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: drivers/input/joystick - don't access dev->private directlyDmitry Torokhov
Use input_get_drvdata() and input_set_drvdata() instead. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-02-18Input: remove obsolete setup parameters from input driversDmitry Torokhov
They have been marked as __obsolete_setup() for several years, it is time for them to go. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-11-05Input: joysticks - handle errors when registering input devicesDmitry Torokhov
2006-06-26Input: fix potential overflows in driver/input/joystickDmitry Torokhov
Change all sprintfs into snprintfs to make sure we won't stomp on data adjacent to our buffers. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] drivers/input/joystick: convert to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/input/joystick to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-07[PATCH] input: convert kcalloc to kzallocPekka Enberg
This patch converts kcalloc(1, ...) calls to use the new kzalloc() function. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] x86: i8253/i8259A lock cleanupIngo Molnar
Introduce proper declarations for i8253_lock and i8259A_lock. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
