path: root/drivers/input/joydev.c
2010-11-30Input: use pr_fmt and pr_<level>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-21Input: joydev - fix JSIOCSAXMAP ioctlKenneth Waters
Fixed JSIOCSAXMAP ioctl to update absmap, the map from hardware axis to event axis in addition to abspam. This fixes a regression introduced by 999b874f. Signed-off-by: Kenneth Waters <kwwaters@gmail.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-02Input: switch to input_abs_*() access functionsDaniel Mack
Change all call sites in drivers/input to not access the ABS axis information directly anymore. Make them use the access helpers instead. Also use input_set_abs_params() when possible. Did some code refactoring as I was on it. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-15Input: change input handlers to use bool when possibleDmitry Torokhov
2010-05-20Input: use ABS_CNT rather than (ABS_MAX + 1)Daniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-03Input: joydev - allow binding to button-only devicesChristoph Fritz
Dance pads don't have an axis, so allow this kind of controllers to be used via legacy joystick interface. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-02-04Input: mark input interfaces as non-seekableDmitry Torokhov
Seeking does not make sense for input interfaces such as evdev and joydev so let's use nonseekable_open to mark them non-seekable. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-02-04Input: add match() method to input hanldersDmitry Torokhov
Get rid of blacklist in input handler structure and instead allow handlers to define their own match() method to perform fine-grained filtering of supported devices. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-27Input: joydev - validate axis/button maps before clobbering current onesStephen Kitt
Up to now axis and button map validation was done after the user-supplied values were copied over the driver's map. This patch copies the user-supplied values into temporary buffers and validated them before overwriting the driver's permanent maps. Also change JSIOCGBTNMAP and JSIOCGAXMAP to return number of bytes returned to userspace instead of 0. Signed-off-by: Stephen Kitt <steve@sk2.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-12Input: joydev - decouple axis and button map ioctls from input constantsStephen Kitt
The KEY_MAX change in 2.6.28 changed the values of the JSIOCSBTNMAP and JSIOCGBTNMAP constants; software compiled with the old values no longer works with kernels following 2.6.28, because the ioctl switch statement no longer matches the values given by the software. This patch handles these ioctls independently of the length of data specified, and applies the same treatment to JSIOCSAXMAP and JSIOCGAXMAP which currently depend on ABS_MAX. Signed-off-by: Stephen Kitt <steve@sk2.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-07-13Input: fix EVIOCGNAME/JSIOCGNAME regressionDaniel Mack
Commit 3d5cb60e ("Input: simplify name handling for certain input handles") introduced a regression for the EVIOCGNAME/JSIOCGNAME ioctl. Before this, patch, the platform device's name was given back to userspace which was good to identify devices. After this patch, the device is ("event%d", minor) which is not descriptive at all. This fixes the behaviour by taking dev->name. Reported-by: Sven Neumann <s.neumann@raumfeld.com> Signed-off-by: Daniel Mack <daniel@caiaq.de> Reviewed-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-06-11Merge commit 'v2.6.30' into nextDmitry Torokhov
2009-05-11Input: simplify name handling for certain input handlesThadeu Lima de Souza Cascardo
For evdev, joydev and mousedev, instead of having a separate character array holding name of the handle, use struct devce's name which is the same. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-05-07Input: joydev - blacklist digitizersTim Cole
BTN_TOUCH is not set by the wacom driver which causes it to be handled by the joydev driver while the resulting device is broken. This causes problems with applications that try to use a joystick device. Ubuntu BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/300143 Signed-off-by: Tim Cole <tim.cole@canonical.com> Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Acked-by: Tim Gardner <tim.gardner@canonical.com> Acked-by: Amit Kucheria <amit.kucheria@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-12-20Merge commit 'v2.6.28-rc9' into nextDmitry Torokhov
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30Input: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-01Input: make sure input interfaces pin parent input devicesDmitry Torokhov
Recent driver core change causes references to parent devices being dropped early, at device_del() time, as opposed to when all children are freed. This causes oops in evdev with grabbed devices. Take the reference to the parent input device ourselves to ensure that it stays around long enough. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13Input: use full RCU APIDmitry Torokhov
RT guys alerted me to the fact that in their tree spinlocks are preemptible and it is better to use full RCU API (rcu_read_lock()/rcu_read_unlock()) to be safe. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-12Input: fix open count handling in input interfacesOliver Neukum
If input_open_device() fails we should not leave interfaces marked as opened. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-08-30Input: joydev - implement proper lockingDmitry Torokhov
2007-07-10Input: convert from class devices to standard devicesDmitry Torokhov
2007-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: reduce raciness when input handlers disconnect Input: ucb1x00 - do not access input_dev->private directly Input: logips2pp - fix typo in Kconfig Input: db9 - do not ignore dev2 module parameter
2007-06-03Input: reduce raciness when input handlers disconnectDmitry Torokhov
There is a race between input handler's release() and disconnect() methods: when input handler disconnects it wakes up all regular users and then process to walk user list to wake up async. users. While disconnect() walks the list release() removes elements of the same list causing oopses. While this is not a substibute for proper locking we can reduce odds of getting an oops if we wake up normal readers after walking the list. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-05-04Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (65 commits) Input: gpio_keys - add support for switches (EV_SW) Input: cobalt_btns - convert to use polldev library Input: add skeleton for simple polled devices Input: update some documentation Input: wistron - fix typo in keymap for Acer TM610 Input: add input_set_capability() helper Input: i8042 - add Fujitsu touchscreen/touchpad PNP IDs Input: i8042 - add Panasonic CF-29 to nomux list Input: lifebook - split into 2 devices Input: lifebook - add signature of Panasonic CF-29 Input: lifebook - activate 6-byte protocol on select models Input: lifebook - work properly on Panasonic CF-18 Input: cobalt buttons - separate device and driver registration Input: ati_remote - make button repeat sensitivity configurable Input: pxa27x - do not use deprecated SA_INTERRUPT flag Input: ucb1400 - make delays configurable Input: misc devices - switch to using input_dev->dev.parent Input: joysticks - switch to using input_dev->dev.parent Input: touchscreens - switch to using input_dev->dev.parent Input: mice - switch to using input_dev->dev.parent ... Fixed up conflicts with core device model removal of "struct subsystem" manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-12Input: handlers - handle errors from input_open_device()Dmitry Torokhov
2007-04-12Input: handlers - rename 'list' to 'client'Dmitry Torokhov
The naming convention in input handlers was very confusing - client stuctures were called lists, regular lists were also called lists making anyone looking at the code go mad. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: rework handle creation codeDmitry Torokhov
- consolidate code for binding handlers to a device - return error codes from handlers connect() methods back to input core and log failures Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-09-14Input: make input_register_handler() return error codesDmitry Torokhov
2006-09-14Input: constify input coreDmitry Torokhov
2006-06-26Input: fix formatting to better follow CodingStyleDmitry Torokhov
2006-03-14Input: use kzalloc() throughout the codeEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28[PATCH] INPUT: Create symlinks for backwards compatibilityGreg Kroah-Hartman
This creates symlinks in /sys/class/input/ to the nested class devices to help userspace cope with the nesting. Unfortunatly udev still needs to be updated as it can't handle symlinks properly here :( Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] INPUT: rename input_dev_class to input_class to be correct.Greg Kroah-Hartman
2005-10-28[PATCH] INPUT: move the input class devices under their new input_dev devicesGreg Kroah-Hartman
2005-10-28[PATCH] Input: kill devfs referencesDmitry Torokhov
Input: remove references to devfs from input subsystem Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-11Input: joydev - remove custom conversion from jiffies to msecsTobias Klauser
Replace the MSECS() macro with the jiffies_to_msecs() function provided in jiffies.h Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-27Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/dtor/input.git manuallyLinus Torvalds
Some manual fixups required due to clashes with the PF_FREEZE cleanups.
2005-06-20[PATCH] INPUT: move to use the new class code, instead of class_simplegregkh@suse.de
2005-05-29Input: This patch implements compat_ioctl for joydev.Jeremy Fitzhardinge
I've tested it with a Logitech WingMan Rumblepad on an x86-64 machine, and on an ia32 machine to make sure I didn't break anything. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-05-28Input: Fix button mapping in joydev - BTN_TRIGGER was beingVojtech Pavlik
mapped twice, resulting in it being the last (instead of first) button on a joystick. Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
