path: root/drivers/infiniband/hw/mthca/mthca_uar.c
2008-07-14RDMA: Remove subversion $Id tagsRoland Dreier
They don't get updated by git and so they're worse than useless. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/mthca: Don't use privileged UAR for kernel accessMichael S. Tsirkin
Make kernel use UAR2 instead of UAR1 for hardware access: this adds sanity checking from the hardware side, without any performance cost. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
