Commit fe333321 ("powerpc: Change u64/s64 to a long long integer
type") changed u64 from unsigned long to unsigned long long, which
means that printk formats for printing u64 values should use "ll"
instead of "l" to avoid warnings. Fix all the places affected by this
in ehca.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com>
Pavel Emelyanov <xemul@openvz.org> mentioned in <http://lkml.org/lkml/2008/3/17/131>
that the task_struct->tgid field is about to become deprecated, so the
uses in the ehca driver need to be fixed up.
However, all the uses in ehca are for some object ownership checking
that is not really needed, and anyway is implementing a policy that
should be in common code rather than a low-level driver. So just
remove all the checks.
Signed-off-by: Hoang-Nam Nguyen <hnguyen@de.ibm.com>
...because -12 is easier to read than FFFFFFF4.
Use Paul's new remap_4k_pfn() function to map our 4K firmware contexts
into user space on 64K-page machines without exposing neighboring
firmware contexts. Return the context's offset within a 64K page to
user space so it can determine the proper virtual address.
For details about remap_4k_pfn(), see commit 721151d0 or
http://patchwork.ozlabs.org/linuxppc/patch?id=10281
eHCA2 supports QP queues that can be as small as 512 bytes. This
greatly reduces memory overhead for consumers that use lots of QPs
with small queues (e.g. RDMA-only QPs). Apart from dealing with
firmware, this code needs to manage bite-sized chunks of kernel pages,
making sure that no kernel page is shared between different protection
domains.
Run the existing ehca code through checkpatch.pl and clean up the
worst of the coding style violations.
This eliminates lock contention among IRQs as well as the need to
disable IRQs around idr_find, because there are no IRQ writers.
Support SRQs on eHCA2. Since an SRQ is a QP for eHCA2, a lot of code
(structures, create, destroy, post_recv) can be shared between QP and SRQ.
This patch removes do_mmap() from ehca:
- Call remap_pfn_range() for hardware register block
- Use vm_insert_page() to register memory allocated for completion
queues and queue pairs
- The actual mmap() call/trigger is now controlled by user space,
ie. libehca
Add a driver for IBM GX bus InfiniBand adapters, which are usable with
some pSeries/System p systems.
Signed-off-by: Heiko J Schick <schickhj.ibm.com>
