path: root/drivers/infiniband/hw/cxgb3/iwch_ev.c
2010-10-22RDMA/cxgb3: When a user QP is marked in error, also mark the CQs in errorSteve Wise
The flushing of work requests for user QPs is implemented entirely in the user mode library. The only kernel interaction is to mark the user QP object indicating it is in error when the QP exits RTS. When the user QP operations are called by the application (eg: post_send, post_recv), the QP in error bit is checked and if set, the library flushes the QP. If, however, the application is not doing IO, but rather just polling the CQ, it will never get flushed work requests. This breaks some classes of applications. This patch adds logic to mark user CQs in error when a QP that is bound to the CQ is marked in error. The library poll code can then notice the CQ is in error and flush all the in error QPs bound to that CQ. Design: - add 1 extra CQE entry to the CQ memory that will be used to indicate in error status. - return the desired CQ memory size that should be mapped by the library - bump the ABI since the create_cq uverbs response changes. - detect older libraries and reduce the mmap size accordingly. (The ABI bump doesn't break old libraries, since they didn't check the ABI field anyway) Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-02-10RDMA/cxgb3: Connection termination fixesSteve Wise
The poll and flush code needs to handle all send opcodes: SEND, SEND_WITH_SE, SEND_WITH_INV, and SEND_WITH_SE_INV. Ignore TERM indications if the connection already gone. Ignore HW receive completions if the RQ is empty. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16IB: Replace remaining __FUNCTION__ occurrences with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-03-06RDMA/cxgb3: Squelch logging AE errorsSteve Wise
Only print one AE error for a given connection in the kernel log. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-16RDMA/cxgb3: Remove Open Grid Computing copyrights in iw_cxgb3 driverSteve Wise
Remove the Open Grid Computing copyright. It shouldn't be there. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-02-12RDMA/cxgb3: Add driver for Chelsio T3 RNICSteve Wise
Add an RDMA/iWARP driver for the Chelsio T3 1GbE and 10GbE adapters. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
