path: root/drivers/iio/common
2017-03-30iio: hid-sensor-trigger: Change get poll value function order to avoid ↵Song Hongyan
sensor properties losing after resume from S3 commit 3bec247474469f769af41e8c80d3a100dd97dd76 upstream. In function _hid_sensor_power_state(), when hid_sensor_read_poll_value() is called, sensor's all properties will be updated by the value from sensor hardware/firmware. In some implementation, sensor hardware/firmware will do a power cycle during S3. In this case, after resume, once hid_sensor_read_poll_value() is called, sensor's all properties which are kept by driver during S3 will be changed to default value. But instead, if a set feature function is called first, sensor hardware/firmware will be recovered to the last status. So change the sensor_hub_set_feature() calling order to behind of set feature function to avoid sensor properties lose. Signed-off-by: Song Hongyan <hongyan.song@intel.com> Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18iio: hid-sensors: Increase the precision of scale to fix wrong reading ↵Song Hongyan
interpretation. commit 6f77199e9e4b84340c751c585691d7642a47d226 upstream. While testing, it was observed that on some platforms the scale value from iio sysfs for gyroscope is always 0 (E.g. Yoga 260). This results in the final angular velocity component values to be zeros. This is caused by insufficient precision of scale value displayed in sysfs. If the precision is changed to nano from current micro, then this is sufficient to display the scale value on this platform. Since this can be a problem for all other HID sensors, increase scale precision of all HID sensors to nano from current micro. Results on Yoga 260: name scale before scale now -------------------------------------------- gyro_3d 0.000000 0.000000174 als 0.001000 0.001000000 magn_3d 0.000001 0.000001000 accel_3d 0.000009 0.000009806 Signed-off-by: Song Hongyan <hongyan.song@intel.com> Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24iio: fix pressure data output unit in hid-sensor-attributesKweh, Hock Leong
commit 36afb176d3c9580651d7f410ed7f000ec48b5137 upstream. According to IIO ABI definition, IIO_PRESSURE data output unit is kilopascal: http://lxr.free-electrons.com/source/Documentation/ABI/testing/sysfs-bus-iio This patch fix output unit of HID pressure sensor IIO driver from pascal to kilopascal to follow IIO ABI definition. Signed-off-by: Kweh, Hock Leong <hock.leong.kweh@intel.com> Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-05Merge tag 'spi-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "Quite a lot of activity in SPI this cycle, almost all of it in drivers with a few minor improvements and tweaks in the core. - Updates to pxa2xx to support Intel Broxton and multiple chip selects. - Support for big endian in the bcm63xx driver. - Multiple slave support for the mt8173 - New driver for the auxiliary SPI controller in bcm2835 SoCs. - Support for Layerscale SoCs in the Freescale DSPI driver" * tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits) spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI spi: pxa2xx: Add support for Intel Broxton spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals spi: pxa2xx: Add output control for multiple Intel LPSS chip selects spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific spi: Add DSPI support for layerscape family spi: ti-qspi: improve ->remove() callback spi/spi-xilinx: Fix race condition on last word read spi: Drop owner assignment from spi_drivers spi: Add THIS_MODULE to spi_driver in SPI core spi: Setup the master controller driver before setting the chipselect spi: dw: replace magic constant by DW_SPI_DR spi: mediatek: mt8173 spi multiple devices support spi: mediatek: handle controller_data in mtk_spi_setup spi: mediatek: remove mtk_spi_config spi: mediatek: Update document devicetree bindings to support multiple devices spi: fix kernel-doc warnings about missing return desc in spi.c spi: fix kernel-doc warnings about missing return desc in spi.h spi: pxa2xx: Align a few defines spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select ...
2015-10-28spi: Drop owner assignment from spi_driversAndrew F. Davis
An spi_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-12iio:measurement specialties core: Fix endian sparse warnings.Jonathan Cameron
This patch changes various types to the appropriate endian specific versions. Also introduces an additional local variable to avoid a single variable being used for both be and cpu endianness. These aren't bugs as such, but clearing them up does make the code clearer. Warning was: sparse warnings: (new ones prefixed by >>) >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:126:9: sparse: cast to restricted __be32 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:126:9: sparse: cast to restricted __be32 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:126:9: sparse: cast to restricted __be32 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:126:9: sparse: cast to restricted __be32 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:126:9: sparse: cast to restricted __be32 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:126:9: sparse: cast to restricted __be32 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:127:16: sparse: cast to restricted __be32 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:127:16: sparse: cast to restricted __be32 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:127:16: sparse: cast to restricted __be32 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:127:16: sparse: cast to restricted __be32 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:127:16: sparse: cast to restricted __be32 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:127:16: sparse: cast to restricted __be32 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:208:18: sparse: incorrect type in assignment (different base types) drivers/iio/common/ms_sensors/ms_sensors_i2c.c:208:18: expected unsigned short [unsigned] [addressable] [usertype] send_buf drivers/iio/common/ms_sensors/ms_sensors_i2c.c:208:18: got restricted __be16 [usertype] <noident> >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 >> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:216:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:230:18: sparse: incorrect type in assignment (different base types) drivers/iio/common/ms_sensors/ms_sensors_i2c.c:230:18: expected unsigned short [unsigned] [addressable] [usertype] send_buf drivers/iio/common/ms_sensors/ms_sensors_i2c.c:230:18: got restricted __be16 [usertype] <noident> drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 drivers/iio/common/ms_sensors/ms_sensors_i2c.c:239:19: sparse: cast to restricted __be64 Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-10-04Add meas-spec sensors common partLudovic Tancerel
Measurement specialties drivers common part. These functions are used by further drivers in the patchset: TSYS01, TSYS02D, HTU21, MS5637, MS8607 Signed-off-by: Ludovic Tancerel <ludovic.tancerel@maplehightech.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-16iio: st_sensors: add debugfs register read hookLinus Walleij
This adds a debugfs hook to read/write registers in the ST sensors using debugfs. Proved to be awesome help when trying to debug why IRQs do not arrive. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-08-12Merge tag 'iio-for-4.3b-2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: Second set of new device support, features and cleanup for the 4.3 cycle. Take 2 also includes a fix set that was too late for the 4.2 cycle. As we had a lot of tools and docs work in this set, I have broken those out into their own categories in this description. Fixes from the pull request '4th set of IIO fixes for the 4.2 cycle'. * Poll functions for both event chardev and the buffer one were returning negative error codes (via a positive value). * A recent change to lsiio adding some error handling that was wrong and stopped the tool working. * bmg160 was missing some dependencies in Kconfig * berlin2-adc had a misshandled register (wrote a value rather than a bitmap) New device support * TI opt3001 light sensor * TXC PA12 ALS and proximity sensor. * mcp3301 ADC support (in mcp320x driver) * ST lsm303agr accelerometer and magnetometer drivers (plus some st-sensors common support to allow different WHOAMI register addresses, devices with fixed scale and allow interrupt equiped magnetometers). * ADIS16305, ADIS16367, ADIS16445IMUs (in the adis16400 driver) * ADIS16266 gyro (in the adis16260 driver) * ADIS16137 gyro (in the adis16136 driver) New functionality * mmc35240 DT bindings. * Inverse unit conversion macros to aid handing of values written to sysfs attributes. Core cleanup * Forward declaration of struct iio_trigger to avoid a compile warning. Driver cleanup / fixes * mxs-lradc - Clarify which parts are supported. - Fix spelling erorrs. - Missing/extra includes - reorder includes - add datasheet name listings for all usable channels (to allow them to be bound by name from consumer drivers) * acpi-als - add some function prefixes as per general iio style. * bmc150_magn - replace a magic value with the existing define. * vf610 - determine possible sample frequencies taking into account the electrical characteristics (defining a minimum sample time) * dht11 - whitespace - additional docs - avoid mulitple assignments in one line - Use the new funciton ktime_get_resolution_ns to cleanup a nasty trick previously used for timing. * Fix all drivers that consider 0 a valid IRQ for historical reasons. * Export I2C module alias info where previously missing (to allow autoprobing) * Export OF module alias info where previously missing. * mmc35240 - switch some variables into arrays to improve readability. * mlx90614 - define some magic numbers for readability. * bmc150_magn - expand area locked by a mutex to cover all the use of the data->buffer. - use descriptive naming for a mask instead of a magic value. * berin2-adc - pass up an error code rather that a generic error - constify the iio_chan_spec - some other little tidy ups. * stk8312 - fix a dependency on triggered buffers in kconfig - add a check for invalid attribute values - improve error handling by returning error codes where possible and return immediately where relevant - rework macro defs to use GENMASK etc - change some variable types to reduce unnecessary casting - clean up code style - drop a local buffer copy for bulk reads and use the one in data->buffer instead. * adis16400 - the adis16448 gyroscope scale was wrong. * adis16480 - some more wrong scales for various parts. * adis16300 - has an undocumented product id and serial number registers so use them. * iio_simple_dummy - fix some wrong code indentation. * bmc150-accel - use the chip ID to detect the chip present rather than verifying the expected part was there. This was in response to a wrong ACPI entry on the WinBook TW100. * mma8452 - fix _get_hp_filter_index - drop a double include - pass up an error code rather than rewriting it - range check input values to attribute writes - register defs tidy up using GENMASK and reordering them to be easier to follow. - various coding style cleanups - put the Kconfig entry in the write place (alphabetically). Tools related * Tools cleanup - drop an explicity NULL comparison, some unnecessary braces, use the ARRAY_SIZE macro, send error messages to stderr instead of dropping them in the middle of normal output. * Fix tools to allow that scale and offset attributes are optional. * More tools fixes including allowing true 32bit data (previously an overflow prevented more than 31bits) * Drop a stray header guard that ended up in a c file. * Make calc_digits static as it isn't exported or in the header. * Set ci_array pointer to NULL after free as a protection against non safe usage of the tools core code. Also convert a double pointer to a single one as the extra level of indirection was unnecessary. Docs * DocBook introduction by Daniel Baluta. Glad we are beginning to draw together some more introductory docs to suplement the various tools / examples. * Drop bytes_per_datum sysfs attribute docs as it no longer exists. * A whole load of missing / fixing of kernel-doc for the core of IIO. * Document the trigger name sysfs attribute in the ABI docs. * Minor typos in the ABI docs related to power down modes.
2015-07-23iio: st-sensors: add support for single full scale deviceGiuseppe Barba
Some sensors could have only one full scale value. This means that the sensor hasn't a full scale register. This commit add a check on the configured full scale address to support such kind of sensors. Signed-off-by: Giuseppe Barba <giuseppe.barba@st.com> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-07-23iio: st-sensors: add configuration for WhoAmI addressGiuseppe Barba
This patch permits to configure the WhoAmI register address because some device could have not a standard address for this register. Signed-off-by: Giuseppe Barba <giuseppe.barba@st.com> Reviewed-by: Denis Ciocca <denis.ciocca@st.com> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-07-20Merge 4.2-rc3 into staging-nextGreg Kroah-Hartman
We need the staging fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-13Merge tag 'iio-fixes-for-4.2a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: First set of IIO fixes for the 4.2 cycle. * Fix a regression in hid sensors suspend time as a result of adding runtime pm. The normal flow of waking up devices in order to go into suspend (given the devices are normally suspended when not reading) to a regression in suspend time on some laptops (reports of an additional 8 seconds). Fix this by checking to see if a user action resulting in the wake up, and make it a null operation if it didn't. Note that for hid sensors, there is nothing useful to be done when moving into a full suspend from a runtime suspend so they might as well be left alone. * rochip_saradc: fix some missing MODULE_* data including the licence so that the driver does not taint the kernel incorrectly and can build as a module. * twl4030 - mark irq as oneshot as it always should have been. * inv-mpu - write formats for attributes not specified, leading to miss interpretation of the gyro scale channel when written. * Proximity ABI clarification. This had snuck through as a mess. Some drivers thought proximity went in one direction, some the other. We went with the most common option, documented it and fixed up the drivers going the other way. Fix for sx9500 included in this set. * ad624r - fix a wrong shift in the output data. * at91_adc - remove a false limit on the value of the STARTUP register applied by too small a type for the device tree parameter. * cm3323 - clear the bits when setting the integration time (otherwise we can only ever set more bits in the relevant field). * bmc150-accel - multiple triggers are registered, but on error were not being unwound in the opposite order leading to removal of triggers that had not yet successfully been registered (count down instead of up when unwinding). * tcs3414 - ensure right part of val / val2 pair read so that the integration time is not always 0. * cc10001_adc - bug in kconfig dependency. Use of OR when AND was intended.
2015-07-05iio: ssp_sensors: Remove redundant spi driver bus initializationAntonio Borneo
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_register_driver(), so we can drop the manual assignment. Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com> To: Jonathan Cameron <jic23@kernel.org> To: Lars-Peter Clausen <lars@metafoo.de> To: Karol Wrona <k.wrona@samsung.com> To: linux-iio@vger.kernel.org Cc: linux-kernel@vger.kernel.org Acked-by: Karol Wrona <k.wrona@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-06-10Merge tag 'iio-for-v4.2c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: Third round of new IIO drivers, cleanups and functionality for the 4.2 cycle. Given Linus announced a 4.8rc coming up, hopefully time for one more lot of IIO patches this cycle. Some of these are actually improvements / fixes for patches earlier in the cycle. New device support * st_accel driver - support devices with 8 bit channels. Cleanup * A general cleanup of the iio tools under /tools/ from Hartmut. I'm more than a little embarassed by how bad some of these were! Are well, much more refined and less bug prone now. These cover lots of stuff like unhandled error returns, memory leaks as well as general refactoring to tidy the code up. * iio_simple_dummy - fix memory leaks in the init functions, drop some pointless error returns from functions that never generate errors and make the module parameter explicitly unsigned. * More buffer handling reworks from Lars-Peter, this time targetting hardware buffers (a little used corner that looks likely to get more use in the near future). Specifically: - Always compute the masklength as inkernel buffer users may need it. - Add a means of labeling which buffer modes a given buffer implementation supports. - In the case of hardware buffers, require strict scan matching rather than matching to a superset. Currently the demux is bypassed by these drivers (this may well not change for efficiency reasons) so allowing a superset of channels to be selected would otherwise lead to more data than requested confusing userspace. Driver funcationality improvments * mmc35240 - adds a compensation to the raw values as borrowed form Memsic's own input driver. * mma8452 - event support - event debouncing - high pass filter configuration - triggers * vf610 - allow conversion mode to be adjusted Fixlets * mmc35240 - Off by one error that by coincidence had no real effect. - i2c_device_name should be lowercase. - Lack of null terminator at end of attributes array. - Avoid computing the fractional part of the magnetic field by moving the scaling into userspace where floating point is available to simplify the maths. - Use a smaller sleep before assuming the measurement is done. This is safe and improves the possible polling rate. - Fix sensitivity on z-axis - datasheet disagrees with Memsic's releasedd code and the value used in the code seems to be correct. * stk3310 - make a local variable signed to ensure error handling works. * twl4030 - fix calculation of the temperature sense current - bug unlikely to have ever been noticed as the difference is small. - Fix errors in descriptions.
2015-06-07iio: st_accel: support 8bit channel dataLinus Walleij
Some sensors like the LIS331DL only support 8bit data by a single register per axis. These utilize the MSB byte. Make it possible to register these apropriately. A oneliner change is needed in the ST sensors core to handle 8bit reads as this is the first supported 8bit sensor. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-06-02hid-sensor: Fix suspend/resume delaySrinivas Pandruvada
By default all the sensors are runtime suspended state (lowest power state). During Linux suspend process, all the run time suspended devices are resumed and then suspended. This caused all sensors to power up and introduced delay in suspend time, when we introduced runtime PM for HID sensors. The opposite process happens during resume process. To fix this, we do powerup process of the sensors only when the request is issued from user (raw or tiggerred). In this way when runtime, resume calls for powerup it will simply return as this will not match user requested state. Note this is a regression fix as the increase in suspend / resume times can be substantial (report of 8 seconds on Len's laptop!) Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Tested-by: Len Brown <len.brown@intel.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-05-18Merge 4.1-rc4 into staging-nextGreg Kroah-Hartman
We want the fixes in here for testing and merge issues. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-13Merge tag 'iio-fixes-for-4.1a-take2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: The usual mixed bag of fixes for IIO in the 4.1 cycle. Second version of this pull request as a small fix to a fix turned up before Greg pulled it for a cc10001 patch near the top of the tree. One core fix * Set updated for a iio kfifo was incorrectly set to false during a failed update, resulting in atttempts to repeat the failed operation appearing to succeed. This time I've decided to list the driver fixes in alphabetical order rather than 'randomly'. * axp288_adc - a recent change added a check for valid info masks when reading channels from consumer drivers. * bmp280 - temperature compensation was failing to read the tfine value, hence causing a temperature of 0 to always be returned and incorrect presure measurements. * cc10001 - Fix channel number mapping when some channels are reserved for remote CPUs. Fix an issue with the use of the power-up/power-down register (basically wrong polarity). Fix an issue due to the missinterpretting the return value from regulator_get_voltage. Add a delay before the start bit as recommended for the hardware to avoid data corruption. * hid pressure - fix channel spec of modfiied, but no modifier (which makes no sense!) * hid proximity - fix channel spec of modified, but no modifier (which makes no sense!). Fix a memory leak in the probe function. * mcp320x - occasional incorrect readings on dma using spi busses due to cacheline corruption. Fixed by forcing ___cacheline_aligned for the buffers. * mma9551 - buffer overrun fix (miss specified maximum length of buffers) * mma9553 - endian fix on status message. Add an enable element for activity channel. Input checking for activity period to avoid rather unpredictable results. * spmi-vadc - fix an overflow in the output value normalization seen on some boards. * st-snesors - oops due to use of a mutex that is not yet initialized during probe. * xilinx adc - Some wrong register addresses, a wrong address for vccaux channel, incorrect scale on VREFP and incorrect sign on VREFN.
2015-05-09Merge tag 'iio-for-v4.2a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First round of new drivers, functionality and cleanups for the 4.2 cycle New drivers / device support * st sensors driver, lsm303dlh magnetometer support. * ltr501 - support ltr301 and ltr559 chips. New functionality * IIO_CHAN_INFO_CALIBEMISSIVITY for thermopile sensors. * kxcjk1013 - make driver operational with external trigger. * Add iio targets to the tools Makefile. Cleanups * st sensors - more helpful error message if device id wrong or irq request fails, explicitly make the Block Data Update optional rather than relying on writes to address 0 not doing anything, make interrupt support optional (Not always wired, and not all devices actually have an interrupt line.) * kxcjk-1013 white space additions for readability, add the KXCJ9000 ACPI id as seen in the wild. * sx9500 - GPIO reset support, refactor the GPIO interrupt code, add power management, optimize power usage by powering down when possible, rename the gpio interrupt pin to be more useful, trivial return path simplification, trivial formatting fixes. * isl29018 - move towards ABI compliance with a view to moving this driver out of staging, add some brackets to ensure code works as expected. Note there is no actual bug as the condition being tested is always true (with current devices). * ltr501 - add regmap support to get caching etc for later patches, fix a parameter sanity check that always fails (bug introduced earlier in this series), ACPI enumeration support, interrupt rate control support, interrupt support in general and integration time control support, code alignment cleanups. * mma9553 - a number of little cleanups following a review from Hartmut after I'd already applied the original driver patch. * tmp006 - prefix some defines with TMP006 for consistency. * tsl4531 - cleanup some wrong prefixes, presumably from copy and paste. * mlx90614 - check for errors in read values, add power management, add emissivity setting, add device tree binding documentation, fix a duplicate const warning. * ti_am335x_adc - refactor the DT parsing into a separate function.
2015-05-07iio: st_sensors: make detection more helpfulLinus Walleij
The ST sensors are detected by reading a WhoAmI register and matching the number found to a sensor name string. To make it easier to figure out what happens when things go wrong, print the WhoAmI value and the device name we're trying to match. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-05-07iio: st_sensors: make BDU optionalLinus Walleij
Not all sensors support BDU (block data update) and in fact a bunch of the in-kernel sensor settings do not specify the BDU address field. Make this optional. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-05-07iio: st_sensors: make interrupt optionalLinus Walleij
Some sensors such as magnetometers and pressure sensors doesn't have interrupts at all, and thus no DRDY setting applies. Make the assignment of an interrupt optional, and do not call st_sensors_set_drdy_int_pin() if there is no drdy (data ready) pin specified. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-05-07iio: st_sensors: print error when failing to get IRQLinus Walleij
Print a proper error message if we're missing the trigger IRQ. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-04-26iio:st_sensors: Fix oops when probing SPI devicesAlban Bedel
In SPI mode the transfer buffer is locked with a mutex. However this mutex is only initilized after the probe, but some transfer needs to be done in the probe. To fix this bug we move the mutex initialization at the beginning of the device probe. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Acked-by: Denis Ciocca <denis.ciocca@st.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-04-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: - quite a few firmware fixes for RMI driver by Andrew Duggan - huion and uclogic drivers have been substantially overlaping in functionality laterly. This redundancy is fixed by hid-huion driver being merged into hid-uclogic; work done by Benjamin Tissoires and Nikolai Kondrashov - i2c-hid now supports ACPI GPIO interrupts; patch from Mika Westerberg - Some of the quirks, that got separated into individual drivers, have historically had EXPERT dependency. As HID subsystem matured (as well as the individual drivers), this made less and less sense. This dependency is now being removed by patch from Jean Delvare - Logitech lg4ff driver received a couple of improvements for mode switching, by Michal Malý - multitouch driver now supports clickpads, patches by Benjamin Tissoires and Seth Forshee - hid-sensor framework received a substantial update; namely support for Custom and Generic pages is being added; work done by Srinivas Pandruvada - wacom driver received substantial update; it now supports i2c-conntected devices (Mika Westerberg), Bamboo PADs are now properly supported (Benjamin Tissoires), much improved battery reporting (Jason Gerecke) and pen proximity cleanups (Ping Cheng) - small assorted fixes and device ID additions * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (68 commits) HID: sensor: Update document for custom sensor HID: sensor: Custom and Generic sensor support HID: debug: fix error handling in hid_debug_events_read() Input - mt: Fix input_mt_get_slot_by_key HID: logitech-hidpp: fix error return code HID: wacom: Add support for Cintiq 13HD Touch HID: logitech-hidpp: add a module parameter to keep firmware gestures HID: usbhid: yet another mouse with ALWAYS_POLL HID: usbhid: more mice with ALWAYS_POLL HID: wacom: set stylus_in_proximity before checking touch_down HID: wacom: use wacom_wac_finger_count_touches to set touch_down HID: wacom: remove hardcoded WACOM_QUIRK_MULTI_INPUT HID: pidff: effect can't be NULL HID: add quirk for PIXART OEM mouse used by HP HID: add HP OEM mouse to quirk ALWAYS_POLL HID: wacom: ask for a in-prox report when it was missed HID: hid-sensor-hub: Fix sparse warning HID: hid-sensor-hub: fix attribute read for logical usage id HID: plantronics: fix Kconfig default HID: pidff: support more than one concurrent effect ...
2015-04-13Merge branch 'for-4.1/sensor-hub' into for-linusJiri Kosina
Conflicts: drivers/iio/common/hid-sensors/hid-sensor-trigger.c include/linux/hid-sensor-hub.h
2015-03-28iio: constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-02-23HID: hid-sensor-hub: Enhance feature report set APISrinivas Pandruvada
Current API only allows setting one offset in the field. This API is extended to set multiple offsets in the field report. Also update parameters in the users of this API. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-02-23HID: hid-sensor-hub: Enhance get feature report APISrinivas Pandruvada
Some hid sensor feature report can contain more than one reports. This API can now support receiving multiple values from the feature report. Also update the parameters in the users of this API. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-02-22iio: common: ssp_sensors: Protect PM-only functions to kill warningGeert Uytterhoeven
If CONFIG_PM_SLEEP=n: drivers/iio/common/ssp_sensors/ssp_dev.c:644: warning: ‘ssp_suspend’ defined but not used drivers/iio/common/ssp_sensors/ssp_dev.c:669: warning: ‘ssp_resume’ defined but not used Protect the unused functions by #ifdef CONFIG_PM_SLEEP to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Karol Wrona <k.wrona@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-01-31iio:common:ssp_sensors fix warnings due to 32 bit instead of 64 bit passed ↵Jonathan Cameron
to do_div Also change to div64_u64 in one place to avoid loss of precision (was dividing a 32 bit number by a 64 bit number, but casting this to 64 bit divided by 32 bit) Those divide functions certainly have esoteric naming! Fixes warnings with asm-generic/div64.h do_div such as: In file included from drivers/iio/common/ssp_sensors/ssp_iio.c:20:0: drivers/iio/common/ssp_sensors/ssp_iio_sensor.h: In function 'ssp_convert_to_freq': >> drivers/iio/common/ssp_sensors/ssp_iio_sensor.h:56:16: warning: comparison of distinct pointer types lacks a cast [enabled by default] drivers/iio/common/ssp_sensors/ssp_iio_sensor.h:56:2: warning: right shift count >= width of type [enabled by default] >> drivers/iio/common/ssp_sensors/ssp_iio_sensor.h:56:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] include/asm-generic/div64.h:35:17: note: expected 'uint64_t *' but argument is of type 'int *' drivers/iio/common/ssp_sensors/ssp_iio.c: In function 'ssp_common_process_data': include/linux/iio/buffer.h:142:32: warning: 'calculated_time' may be used uninitialized in this function [-Wuninitialized] drivers/iio/common/ssp_sensors/ssp_iio.c:83:10: note: 'calculated_time' was declared here Fixed by using straight coded version as per the description in the div64.h header, thus ensuring no issue with 32 bit integers. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-01-29iio: common: ssp_sensors: Add sensorhub iio commonsKarol Wrona
This patch adds common library for sensorhub iio drivers. Signed-off-by: Karol Wrona <k.wrona@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-01-29iio: common: ssp_sensors: Add sensorhub driverKarol Wrona
Sensorhub is MCU dedicated to collect data and manage several sensors. Sensorhub is a spi device which provides a layer for IIO devices. It provides some data parsing and common mechanism for sensorhub sensors. Adds common sensorhub library for sensorhub driver and iio drivers which uses sensorhub MCU to communicate with sensors. Signed-off-by: Karol Wrona <k.wrona@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2015-01-25iio: hid_sensor_hub: Common PM functionsSrinivas Pandruvada
To improvement power and performance, both regular and run time callbacks are introduced. Because of auto suspend delay, two consecutive read don't have to go through full power on/off procedure. The auto suspend time can be adjusted using regular power attributes of PM sysfs. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-12-12iio: common: remove unnecessary sizeof(u8)Fabian Frederick
sizeof(u8) is always 1. Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-11-05Merge tag 'iio-for-3.19a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First round of new drivers, features and cleanups for IIO in the 3.19 cycle. New drivers / supported parts * rockchip - rk3066-tsadc variant * si7020 humidity and temperature sensor * mcp320x - add mcp3001, mcp3002, mcp3004, mcp3008, mcp3201, mcp3202 * bmp280 pressure and temperature sensor * Qualcomm SPMI PMIC current ADC driver * Exynos_adc - support exynos7 New features * vf610-adc - add temperature sensor support * Documentation of current attributes, scaled pressure, offset and scaled humidity, RGBC intensity gain factor and scale applied to differential voltage channels. * Bring iio_event_monitor up to date with newer modifiers. * Add of_xlate function to allow for complex channel mappings from the device tree. * Add -g parameter to generic_buffer example to allow for devices with directly fed (no trigger) buffers. * Move exynos driver over to syscon for PMU register access. Cleanups, fixes for new drivers * lis3l02dq drop an unneeded else. * st sensors - renam st_sensors to st_sensor_settings (for clarity) * st sensors - drop an unused parameter from all the probe utility functions. * vf610 better error handling and tidy up. * si7020 - cleanups following merge * as3935 - drop some unnecessary semicolons. * bmp280 - fix the pressure calculation.
2014-10-25Merge tag 'iio-fixes-for-3.18a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: First round of IIO fixes for the 3.18 cycle. * ad5933 - fix a null pointer dereference due to an old change that prevents different channels being registered for the buffer and used for sysfs interfaces. * ad5933 - Drop a bonus _raw from attribute names. * st-sensors - Makes sure the correct number of elements are copied when filling a local buffer copy. * mxs-lradc - Disable clocks in a failure path during probe so they aren't left running.
2014-10-04iio: st_sensors: Fix buffer copyRobin van der Gracht
Use byte_for_channel as iterator to properly initialize the buffer. Signed-off-by: Robin van der Gracht <robin@protonic.nl> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Cc: <Stable@vger.kernel.org>
2014-10-04iio:common: Set the device pointer into ST common sensors libraryDenis CIOCCA
Signed-off-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-10-04iio:imu: changed structure name from st_sensors to st_sensor_settingsDenis CIOCCA
This patch change structure name and related variables names. Signed-off-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-09-22Merge 3.17-rc6 into staging-next.Greg Kroah-Hartman
We want the fixes in there, and it resolves a merge issue with drivers/iio/accel/bma180.c Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-30iio: sensors-core: st: Check st_sensors_set_drdy_int_pin()'s return valueLee Jones
Value from st_sensors_set_drdy_int_pin() is assigned to err here, but that stored value is not used before it is overwritten. To fix this we're enforcing a check on st_sensors_set_drdy_int_pin()'s return value and if it's an error, we're returning right away. Cc: jic23@kernel.org Cc: linux-iio@vger.kernel.org Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-08-25iio: st_sensors: Fix indio_dev->trig assignmentSrinivas Pandruvada
This can result in wrong reference count for trigger device, call iio_trigger_get to increment reference. Refer to http://www.spinics.net/lists/linux-iio/msg13669.html for discussion with Jonathan. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Cc: Stable@vger.kernel.org
2014-08-25iio: hid_sensor_hub: Fix indio_dev->trig assignmentSrinivas Pandruvada
2014-07-11iio: st_sensors: add devicetree probing supportLinus Walleij
The I2C devices that make up the STMicroelectronics MEMS sensors may be sneakily enabled by cleverly giving the device node the same name as a string match from the platform device ID table. However the right method is to use the compatible string. On detection, the ST sensors use the ID string to probe and instatiate the right sensor driver, so pass the kernel-internal ID string in the .data field of the OF match table, and set the I2C client name to this name when a compatible match is used. This avoids having misc Linux-specific strings floating around in the device tree. Cc: Lee Jones <lee.jones@linaro.org> Cc: Denis CIOCCA <denis.ciocca@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-07iio: hid-sensors: make hid_sensor_get_reporting_interval staticDaniel Baluta
This fixes the following sparse warning: CHECK drivers/iio/common/hid-sensors/hid-sensor-attributes.c drivers/iio/common/hid-sensors/hid-sensor-attributes.c:346:5: warning: symbol 'hid_sensor_get_reporting_interval' was not declared. Should it be static? Signed-off-by: Daniel Baluta <daniel.baluta@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-07iio: st_sensors: get platform data from device treeLinus Walleij
Currently the STMicroelectronics sensors only support one single platform data item: configuration of the DRDY (data ready) pin for a particular design. Augment the core to prioritize and take this information from the device tree if the parent device has an assigned device node, else fall back to passed in platform data (usually the default data). Cc: Lee Jones <lee.jones@linaro.org> Cc: Denis CIOCCA <denis.ciocca@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-07-07iio:st sensors: remove custom sampling frequence attribute in favour of core ↵Jonathan Cameron
support. This allows in kernel client drivers to access this Signed-off-by: Jonathan Cameron <jic23@kernel.org> Cc: Denis Ciocca <denis.ciocca@st.com> Reviewed-by: Hartmut Knaack <knaack.h@gmx.de>
2014-07-05iio: hid-sensors: Fix compilation warningSachin Kamat
Move the 'static' keyword to beginning of definition to silence the following compilation warning: drivers/iio/common/hid-sensors/hid-sensor-attributes.c:34:1: warning: ‘static’ is not at beginning of declaration [-Wold-style-declaration] Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com> Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
