path: root/drivers/ieee1394/nodemgr.c
2007-04-30ieee1394: nodemgr: unify some error messagesStefan Richter
Shrinks object file size a little bit. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-04-30ieee1394: nodemgr: less noise in dmesgStefan Richter
Everytime when eth1394 or a libraw1394 client updates the configuration ROM, a certain sysfs attribute cannot be added since it already exists. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-04-30ieee1394: some more includesStefan Richter
2007-04-30ieee1394: drop csr1212's support for external compilationStefan Richter
csr1212 was written to be compiled either as part of the ieee1394 kernel driver or of an anticipated IEEE 1212 userspace library. We now drop support for the latter. The costs in terms of code footprint and depth of abstraction are not countered by any actual benefit. Also remove some obsolete #includes. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-04-30ieee1394: move some comments from declaration to definitionStefan Richter
2007-04-30ieee1394: remove declarations of nonexisting functionsStefan Richter
2007-04-27IEEE1394: remove rwsem use from ieee1394 coreGreg Kroah-Hartman
The subsystem rwsem is not used by the driver core at all, so the use of it in the ieee1394 code doesn't make any sense. They might possibly want to use a local lock, but as most of these operations are already protected by a local lock, it really doesn't look like it would be needed. Cc: Ben Collins <bcollins@debian.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: linux1394-devel <linux1394-devel@lists.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27uevent: use add_uevent_var() instead of open coding itEric Rannaud
Make use of add_uevent_var() instead of (often incorrectly) open coding it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Eric Rannaud <eric.rannaud@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-17ieee1394: fix another deadlock in nodemgrStefan Richter
A "modprobe ohci1394; sleep 1.5; modprobe -r ohci1394" could get stuck in uninterruptible state, especially if an external node was connected. http://bugzilla.kernel.org/show_bug.cgi?id=7792 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-02-08ieee1394: fix host device registering when nodemgr disabledStefan Richter
Since my commit 8252bbb1363b7fe963a3eb6f8a36da619a6f5a65 in 2.6.20-rc1, host devices have a dummy driver attached. Alas the driver was not registered before use if ieee1394 was loaded with disable_nodemgr=1. This resulted in non-functional FireWire drivers or kernel lockup. http://bugzilla.kernel.org/show_bug.cgi?id=7942 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-02-08the scheduled IEEE1394_OUI_DB removalAdrian Bunk
This patch contains the scheduled IEEE1394_OUI_DB removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Update: Also remove drivers/ieee1394/.gitignore. Remove now unused struct members in drivers/ieee1394/nodemgr.h. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: remove a kcallocStefan Richter
Was I sleepwalking when I wrote this? Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: Consolidate driver registeringBen Collins
This patch consolidates some bookkeeping for driver registering. It closely models what pci_register_driver() does. The main addition is that the owner of the driver is set, so we get a proper symlink for /sys/bus/ieee1394/driver/*/module. Also moves setting of name and bus type into nodemgr. Because of this, we can remove the EXPORT_SYMBOL for ieee1394_bus_type, since it's now only used in ieee1394.ko. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: spaces to tabsStefan Richter
whitespace pedantry Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: fix deadlock in shutdownStefan Richter
If "modprobe ohci1394" was quickly followed by "modprobe -r ohci1394", say with 1 second pause in between, the modprobe -r got stuck in uninterruptible sleep in kthread_stop. At the same time the knodemgrd slept uninterruptibly in bus_rescan_devices_helper. That's because driver_detach took the semaphore of the PCI device and bus_rescan_devices_helper wanted to take the semaphore of the FireWire host device's parent, which is the same semaphore. This was a regression since Linux 2.6.16, commit bf74ad5bc41727d5f2f1c6bedb2c1fac394de731, "Hold the device's parent's lock during probe and remove". The fix (or workaround) adds a dummy driver to the hpsb_host device. Now bus_rescan_devices_helper won't scan the host device anymore. This doesn't hurt since we have no drivers which will bind to these devices and it is unlikely that there will ever be such a driver. The dummy driver is befittingly presented as a representation of ieee1394 itself. Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=6706 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: remove duplicate assignmentStefan Richter
2006-12-07ieee1394: nodemgr: take it easy if bus_rescan_devices failsStefan Richter
This happens. No need to log a BUG trace. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07drivers/ieee1394/*: use kmemdup()Eric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: fix printk format warningRandy Dunlap
Fix printk format warning: drivers/ieee1394/nodemgr.c:364: warning: long long unsigned int format, u64 arg (arg 3) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: revise semaphore protection of driver core dataStefan Richter
- The list "struct class.children" is supposed to be protected by class.sem, not by class.subsys.rwsem. - nodemgr_remove_uds() iterated over nodemgr_ud_class.children without proper protection. This was never observed as a bug since the code is usually only accessed by knodemgrd. All knodemgrds are currently globally serialized. But userspace can trigger this code too by writing to /sys/bus/ieee1394/destroy_node. - Clean up access to the FireWire bus type's subsys.rwsem: Access it uniformly via ieee1394_bus_type. Shrink rwsem protected regions where possible. Expand them where necessary. The latter wasn't a problem so far because knodemgr is globally serialized. This should harden the interaction of ieee1394 with sysfs and lay ground for deserialized operation of multiple knodemgrds and for implementation of subthreads for parallelized scanning and probing. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: reflect which return values are errorsStefan Richter
Give better names to local variables. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: nodemgr: small fix after sysfs errors patchStefan Richter
One hunk in "ieee1394: handle sysfs errors" was wrong. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07ieee1394: handle sysfs errorsStefan Richter
Handle driver core errors with as much care as appropriate. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-08ieee1394: nodemgr: fix startup of knodemgrdStefan Richter
Revert a thinko in commit d2f119fe319528da8c76a1107459d6f478cbf28c: When knodemgrd starts, it needs to sleep until host->generation was incremented above its initial value of 0. My wrong logic caused it to start sending requests when the bus wasn't completely ready. Seen as "AT dma reset ctx=0, aborting transmission" messages in 2.6.19-rc1. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-09-17ieee1394: nodemgr: grab class.subsys.rwsem in nodemgr_resume_neStefan Richter
nodemgr_resume_ne was iterating over nodemgr_ud_class.children without protection by nodemgr_ud_class.subsys.rwsem. FIXME: Shouldn't we rather use class->sem there, not class->subsys.rwsem? Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-09-17ieee1394: nodemgr: fix rwsem recursionStefan Richter
nodemgr_update_pdrv grabbed an rw semaphore (as reader) which was already taken by its caller's caller, nodemgr_probe_ne (as reader too). Reported by Miles Lane, call path pointed out by Arjan van de Ven. FIXME: Shouldn't we rather use class->sem there, not class->subsys.rwsem? Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-09-17ieee1394: shrink tlabel pools, remove tpool semaphoresStefan Richter
This patch reduces the size of struct hpsb_host and also removes semaphores from ieee1394_transactions.c. On i386, struct hpsb_host shrinks from 10656 bytes to 6688 bytes. This is accomplished by - using a single wait_queue for hpsb_get_tlabel instead of many instances of semaphores, - using a single lock to serialize access to all tlabel pools (the protected code regions are small, i.e. lock contention very low), - omitting the sysfs attribute tlabels_allocations. Drawback: In the rare case that a process needs to sleep because all transaction labels for the node are temporarily exhausted, it is also woken up if a tlabel for a different node became free, checks for an available tlabel, and is put to sleep again. The check is not costly and the situation occurs extremely rarely. (Tlabels are typically only exhausted if there was no context switch to the khpsbpkt thread which recycles tlables.) Therefore the benefit of reduced tpool size outweighs this drawback. The sysfs attributes tlabels_free and tlabels_mask are not compiled anymore unless CONFIG_IEEE1394_VERBOSEDEBUG is set. The by far biggest member of struct hpsb_host, the struct csr_control csr (5272 bytes on i386), is now placed at the end of struct hpsb_host. Note, hpsb_get_tlabel calls the macro wait_event_interruptible with a condition argument which has a side effect (allocation of a tlabel and manipulation of the packet). This side effect happens only if the condition is true. The patch relies on wait_event_interruptible not evaluating the condition again after it became true. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-07-03[PATCH] ieee1394: nodemgr: convert nodemgr_serialize semaphore to mutexStefan Richter
Another trivial sem2mutex conversion. Side note: nodemgr_serialize's purpose, when introduced in linux1394's revision 529 in July 2002, was to protect several data structures which are now largely handled by or together with Linux' driver core and are now protected by the LDM's own mechanisms. It may very well be possible to remove this mutex now. But fully parallelized node scanning is on our long-term TODO list anyway; the mutex will certainly go away then. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-07-03[PATCH] ieee1394: nodemgr: switch to kthread api, replace reset semaphoreStefan Richter
Convert nodemgr's host thread from kernel_thread to kthread and its sleep/restart mechanism from a counting semaphore to a schedule()/ wake_up_process() scheme. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-07-03[PATCH] ieee1394: nodemgr: make module parameter ignore_drivers writableStefan Richter
Nodemgr's ignore_drivers variable is exposed as a module load parameter (therefore also as a sysfs attribute below /sys/module) and additionally as an attribute below /sys/bus/ieee1394. Since the latter is writable, make the former writable too. Note, the bus's attribute ignore_drivers is only relevant to newly added units, not to present or suspended or resuming units. Those have their own attribute ignore_driver. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-07-03[PATCH] ieee1394: nodemgr: do not spawn kernel_thread for sysfs rescanStefan Richter
nodemgr.c::fw_set_rescan() is used to re-run the driver core over nodemgr's representation of unit directories in order to initiate protocol driver probes. It is initiated via write access to one of nodemgr's sysfs attributes. The purpose is to attach drivers to units after switching a unit's ignore_driver attribute from 1 to 0. It is not really necessary to fork a kernel_thread for this job. The call to kernel_thread() can be eliminated to avoid the deprecated API and to simplify the code a bit. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-07-03[PATCH] ieee1394: nodemgr: remove unnecessary includesStefan Richter
2006-07-03[PATCH] ieee1394: update #include directives in midlayer header filesStefan Richter
Remove unnecessary includes, add missing includes. Use forward type declarations for some structs. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-07-03[PATCH] ieee1394: fix cosmetic problem in speed probeStefan Richter
If ieee1394.h::IEEE1394_SPEED_MAX is bigger than the actual speed of an 1394b host adapter and the speed to another 1394b node was probed, a bigger speed than actually used was kept in host->speed[n]. The only resulting problem so far was sbp2 displaying bogus values in the syslog, e.g. S3200 for actual S800 connections if IEEE1394_SPEED_MAX was S3200. But other high-level drivers which access this field could get into more trouble. (Eth1394 is the only other in-tree driver which does so. It seems it is not affected.) Nodemgr now clips this value according to the host adapter's link speed. A pointer expression in nodemgr_check_speed is also changed for clarity. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-06-25[PATCH] ieee1394: nodemgr: do not peek into struct semaphoreStefan Richter
Also revert patch "frv: ieee1394 is borken on frv", as it no longer is. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: David Howells <dhowells@redhat.com> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-12ieee1394: support for slow links or slow 1394b phy portsBen Collins
Add support for the following types of hardware: + nodes that have a link speed < PHY speed + 1394b PHYs that are less than S800 capable + 1394b/1394a adapter cable between two 1394b PHYs Also, S1600 and S3200 are now supported if IEEE1394_SPEED_MAX is raised. A probing function is added to nodemgr's config ROM fetching routine which adjusts the allowable speed if an access problem was encountered. Pros and Cons of the approach: + minimum code footprint to support this less widely used hardware + nearly no overhead for unaffected hardware - ineffective before nodemgr began to read the ROM of affected nodes - ineffective if ieee1394 is loaded with disable_nodemgr=1 The speed map CSRs which are published to the bus are not touched by the patch. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Hakan Ardo <hakan@debian.org> Cc: Calculex <linux@calculex.com> Cc: Robert J. Kosinski <robk@cmcherald.com> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-01-05Merge with http://kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitJody McIntyre
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-12ieee1394: write broadcast_channel only to select nodes (fixes device ↵Stefan Richter
recognition) Some old 1394-1995 SBP-2 bridges would hang if they received a broadcast write request to BROADCAST_CHANNEL before the config ROM was read. Affected devices include Datafab MD2-FW2 2.5" HDD and SmartDisk VST FWCDRW-V8 portable CD writer. The write request is now directed to specific nodes instead of being broadcast to all nodes at once, and it is only performed if a previous read request at this register succeeded. Fixes an old interoperability problem which was perceived as a 2.6.14-specific regression: http://marc.theaimsgroup.com/?t=113190586800003 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@modernduck.com> (cherry picked from 61c7f775ca25ccfc0e51486103a724fb1a3a08f2 commit)
2005-12-12ieee1394: resume remote ports when starting a host (fixes device recognition)Stefan Richter
After initializing an IEEE 1394 host, broadcast a resume packet. This makes remote nodes visible which suspended their ports while the host was down. Such nodes had to be unplugged and replugged in order to be recognized. Motorola DCT6200 cable reciever was affected, probably other devices too. http://marc.theaimsgroup.com/?t=113202715800001 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@modernduck.com> (cherry picked from 14c0fa243b358c24040ff5f44b60c47aaf6430c3 commit)
2005-12-12ieee1394: run high-level updates before high-level probesStefan Richter
After a bus reset, let nodemgr call high-level update hooks first for nodes which do not need to be probed. The main benefit is for a bus with more than one SBP-2 device: SBP-2 reconnects will be performed before SBP-2 logins, thus have a much higher chance to succeed, and their SCSI devices will not be blocked much longer than necessary. This was demonstrated for Linux 2.4 by Dave Cinege a while ago. A better approach would be to perform time-consuming probes in parallel by a subthread. I actually plan to implement this for sbp2 but it may take a while to get that done and tested. Until then, this tweak is a huge improvement for users with multiple SBP-2 devices. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@modernduck.com>
2005-12-05ieee1394: write broadcast_channel only to select nodes (fixes device ↵Stefan Richter
2005-12-01ieee1394: add definitions for phy packet constantsStefan Richter
Introduce new macros related to phy packets and use them in ieee1394_core and nodemgr. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@modernduck.com>
2005-12-01ieee1394: resume remote ports when starting a host (fixes device recognition)Stefan Richter
2005-11-07kmalloc/kzalloc changes:Stefan Richter
dv1394, eth1394, ieee1394, ohci1394, pcilynx, raw1394, sbp2c, video1394: - use kzalloc - provide safer size arguments to kmalloc and kzalloc - omit some casts Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@modernduck.com>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-30[PATCH] ieee1394: skip unnecessary pause when scanning config ROMsJody McIntyre
Skip a superfluous pause that occured when the config ROM of a node was scanned unsuccessfully. This also occurs if a node without link wrongly enables its "link active" self ID flag. A GWCTech 6-port hub does this. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Cc: Ben Collins <bcollins@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-30[PATCH] ieee1394: reorder activities after bus reset (fixes device detection)Jody McIntyre
Units were not detected if the local IRM performed a bus reset. ("The root node is not cycle master capable; selecting a new root node and resetting...", often seen with iPods and other SBP-2 devices). Rearrange the order of IRM duties and node scanning. TODO: Audit the ROM caching and parsing code for underlying issues. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Cc: Ben Collins <bcollins@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
