path: root/drivers/ide
2009-04-08ide: move common code out of tf_load() methodSergei Shtylyov
Move device register masking (and setting drive->select) out of tf_load() method and into the only function that needs to use this code, do_rw_taskfile()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [bart: fix whitespace error] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: simplify 'struct ide_taskfile'Sergei Shtylyov
Make 'struct ide_taskfile' cover only 8 register values and thus put two such fields ('tf' and 'hob') into 'struct ide_cmd', dropping unnecessary 'tf_array' field from it. This required changing the prototype of ide_get_lba_addr() and ide_tf_dump(). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [bart: fix setting of ATA_LBA bit for LBA48 commands in __ide_do_rw_disk()] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: replace IDE_TFLAG_* flags by IDE_VALID_*Sergei Shtylyov
Replace IDE_TFLAG_{IN|OUT}_* flags meaning to the taskfile register validity on input/output by the IDE_VALID_* flags and introduce 4 symmetric 8-bit register validity indicator subfields, 'valid.{input/output}.{tf|hob}', into the 'struct ide_cmd' instead of using the 'tf_flags' field for that purpose (this field can then be turned from 32-bit into 8-bit one). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: fix intendation in cdrom_decode_status()Bartlomiej Zolnierkiewicz
Based on earlier work by Borislav Petkov. Fix intendation in cdrom_decode_status(), no real code changes. While at it: - beautify comments There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: unify handling of fs and pc requests in cdrom_decode_status()Bartlomiej Zolnierkiewicz
Based on earlier work by Borislav Petkov. Unify handling of fs and pc requests in cdrom_decode_status(). While at it: - remove unreachable code The only change in functionality is that for pc requests more detailed error message will be printed for following sense keys: * ILLEGAL_REQUEST * DATA_PROTECT * MEDIUM_ERROR * BLANK_CHECK Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: convert cdrom_decode_status() to use switch statementsBartlomiej Zolnierkiewicz
Based on earlier work by Borislav Petkov. Convert cdrom_decode_status() to use switch statements in preparation to unify handling of fs and pc requests. While at it: - remove superfluous comments and do minor CodingStyle fixups There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: update debugging supportBorislav Petkov
Signed-off-by: Borislav Petkov <petkovbb@gmail.com> [bart: extracted from "ide-cd: cleanup cdrom_decode_status" patch] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: respect REQ_QUIET for fs requests in cdrom_decode_status()Borislav Petkov
There should be no functional change resulting from this patch. Suggested-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: remove unused #include <linux/version.h>Huang Weiyi
Remove unused #include <linux/version.h> in drivers/ide/at91_ide.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08tx4939ide: Fix tx4939ide_{in,out}put_data_swap argumentAtsushi Nemoto
The commit adb1af9 ("ide: pass command instead of request to ide_pio_datablock()") missed tx4939ide driver. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08tx493[89]ide: Remove big endian version of tx493[89]ide_tf_{load,read}Atsushi Nemoto
Now tx493[89]ide_tf_{load,read} do not contain word I/O operations. They are endian-free now. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>, Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: carve out an ide_cd_breathe()-helper for fs write requestsBorislav Petkov
There should be no functional change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-cd: move status checking into the IRQ handlerBorislav Petkov
2009-04-08ide-h8300: remove custom tf_{read|load}() methodsSergei Shtylyov
Since tf_{read|load}() methods of this driver have now become identical to their standard counterparts using I/O port accesses, there's no need to override those anymore... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08at91_ide: remove custom tf_{read|load}() methodsSergei Shtylyov
Since tf_{read|load}() methods of this driver have now become identical to their standard counterparts using MMIO accesses, there's no need to override those anymore... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-h8300: remove mm_{inw|outw}()Sergei Shtylyov
Remove two no longer used functions that I've overlooked... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08tx4939ide: remove wmb()Atsushi Nemoto
* define CHECK_DMA_MASK * remove use of wmb() Reported-by: Grant Grundler <grundler@google.com> Reviewed-by: Grant Grundler <grundler@google.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
2009-04-08ide: remove wmb() from ide-dma-sff.c and scc_pata.cGrant Grundler
This patch: o replaces "mask" variable in ide_dma_end() with #define. o removes use of wmb() in ide-dma-sff.c and scc_pata.c. o is not tested - I don't have (or want) the HW. Signed-off-by: Grant Grundler <grundler@google.com> Cc: KOBAYASHI Yoshitake <yoshitake.kobayashi@toshiba.co.jp> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: falconide/q40ide - Use __ide_mm_{in,out}sw() for dataGeert Uytterhoeven
Both of commits f94116aeec7a299640dd692128e1d22178affa8d ("ide: cleanup <asm-m68k/ide.h>") and 15a453a955f89f6545118770c669b52e925368bd ("ide: include <asm/ide.h> only when needed") break falconide: | Uniform Multi-Platform E-IDE driver | ide: Falcon IDE controller | Probing IDE interface ide0... | hda: Sarge m68k, ATA DISK drive | ide0 at 0xfff00000 on irq 15 (serialized) | ide-gd driver 1.18 | hda: max request size: 128KiB | hda: 2118816 sectors (1084 MB) w/256KiB Cache, CHS=2102/16/63 | hda:<4>hda: lost interrupt This happens because falconide relies on {in,out}sw() being redefined in <asm/ide.h>, as included by <linux/ide.h>, which is no longer the case. Use __ide_mm_{in,out}sw() from <asm/ide.h> instead, just like ide_{in,out}put_data() do. The same problem seems to exist in q40ide. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide: Fix host drivers that need IRQF_SHAREDGeert Uytterhoeven
commit 255115fb35f80735c21a1cbe9809e9795a3af26e ("ide: allow host drivers to specify IRQ flags") added irq_flags fields to struct ide_port_info and struct ide_host. Drivers can now set ide_port_info.irq_flags = IRQF_SHARED, while init_irq() passes ide_host.irq_flags to request_irq(). Unfortunately ide_host.irq_flags is never set, causing (on ARAnyM): | Uniform Multi-Platform E-IDE driver | ide: Falcon IDE controller | Probing IDE interface ide0... | hda: Sarge m68k, ATA DISK drive | init_irq: sa = 0 | ide0: disabled, unable to get IRQ 15 | ide0: failed to initialize IDE interface | ide0: disabling port Solve this by copying ide_port_info.irq_flags to ide_host.irq_flags in ide_host_alloc(). This bug probably affects the following IDE host drivers: - buddha - delkin_cb - falconide - gayle - ide-cs - macide - q40ide - scc_pata - sgiioc4 Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31ide-floppy: do not complete rq's prematurelyBorislav Petkov
... and access them afterwards. Simplify rq completing code while at it. Spotted-by: Tejun Heo <tj@kernel.org> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: be able to build pmac driver without IDE built-inGilles Espinasse
No reason to need IDE built-in to be able to compile pmac driver. Tested to work on 2.6.29-rc8 and 2.6.28.8 with ide and pmac as modules inside an initramfs. Signed-off-by: Gilles Espinasse <g.esp@free.fr> Cc: sam@ravnborg.org Cc: benh@kernel.crashing.org [bart: remove now superfluous IDE check] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-pmac: IDE cable detection on Apple PowerBookTOMARI Hisanobu
As IDE cable used on Apple PowerBook/iBook laptops are always of "Short 40" type when the firmware says it's 80 conductor one, the cable detection should return ATA_CBL_PATA40_SHORT on those machines. This enables to automatically use UDMA5 even with drives that doesn't correctly detect those cables on Apple laptops. Signed-off-by: TOMARI Hisanobu <posco.grubb@gmail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: benh@kernel.crashing.org [bart: beautify patch description] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: inline SELECT_DRIVE()Sergei Shtylyov
Since SELECT_DRIVE() has boiled down to a mere dev_select() method call, it now makes sense to just inline it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn selectproc() method into dev_select() method (take 5)Sergei Shtylyov
Turn selectproc() method into dev_select() method by teaching it to write to the device register and moving it from 'struct ide_port_ops' to 'struct ide_tp_ops'. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: benh@kernel.crashing.org Cc: petkovbb@gmail.com [bart: add ->dev_select to at91_ide.c and tx4939.c (__BIG_ENDIAN case)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: move data register access out of tf_{read|load}() methods (take 2)Sergei Shtylyov
Move IDE_FTFLAG_{IN|OUT}_DATA flag handling out of tf_{read|load}() methods into the only two functions where these flags actually need to be handled: do_rw_taskfile() and ide_complete_cmd()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: call {in|out}put_data() methods from tf_{read|load}() methods (take 2)Sergei Shtylyov
Handle IDE_FTFLAG_{IN|OUT}_DATA flags in tf_{read|load}() methods by calling {in|out}put_data() methods to transfer 2 bytes -- this will allow us to move that handling out of those methods altogether... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-io-std: shorten ide_{in|out}put_data()Sergei Shtylyov
ide_{in|out|put_data() can be somewhat shortened by merging the paths doing 16-bit I/O... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: rename IDE_TFLAG_IN_[HOB_]FEATURESergei Shtylyov
The feature register has never been readable -- when its location is read, one gets the error register value; hence rename IDE_TFLAG_IN_[HOB_]FEATURE into IDE_TFLAG_IN_[HOB_]ERROR and introduce the 'hob_error' field into the 'struct ide_taskfile' (despite the error register not really depending on the HOB bit). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn set_irq() method into write_devctl() methodSergei Shtylyov
Turn set_irq() method with its software reset hack into write_devctl() method (for just writing a value into the device control register) at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: use ATA_HOBSergei Shtylyov
Make use of ATA_HOB instead of hard-coded value in the tf_read() method. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-disk: use ATA_ERRSergei Shtylyov
Make use of ATA_ERR instead of hard-coded value in idedisk_set_max_address() and idedisk_read_native_max_address(). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: add support for CFA specified transfer modes (take 3)Sergei Shtylyov
Add support for the CompactFlash specific PIO modes 5/6 and MWDMA modes 3/4. Since there were no PIO5 capable hard drives produced and one would also need 66 MHz IDE clock to actually get the difference WRT the address setup timings programmed, I decided to simply replace the old non-standard PIO mode 5 timings with the CFA specified ones. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: stf_xl@wp.pl Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-iops: only clear DMA words on setting DMA modeSergei Shtylyov
The bytes indicating current DMA mode in the identify data words 62, 63, and 88 should only change on setting a DMA mode, so stop clearing them on setting PIO mode in ide_config_drive_speed(). While at it, correct SW/MW DMA mode masks... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: identify data word 53 bit 1 doesn't cover words 62 and 63 (take 3)Sergei Shtylyov
The IDE code assumed for years that the bit 1 of the identify data word 53 also covers the validity of the SW/MW DMA information in words 62 and 63, but it has always covered only words 64 thru 70, with words 62 and 63 being defined in the original ATA spec, not in ATA-2... This fix however should only concern *very* old hard disks and rather old CF cards... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31au1xxx-ide: auide_{in|out}sw() should be staticSergei Shtylyov
Make auide_{insw|outsw}() 'static' and mark them 'inline' as there's only one call site for each: in the driver's {in|out}put_data() methods respectively... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-floppy: use ide_pio_bytes()Bartlomiej Zolnierkiewicz
* Fix ide_init_sg_cmd() setup for non-fs requests. * Convert ide_pc_intr() to use ide_pio_bytes() for floppy media. * Remove no longer needed ide_io_buffers() and sg/sg_cnt fields from struct ide_atapi_pc. * Remove partial completions; kill idefloppy_update_buffers(), as a result. * Add some more debugging statements. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-{floppy,tape}: fix padding for PIO transfersBartlomiej Zolnierkiewicz
* Return number of bytes left to transfer from idetape_{in,out}put_buffers() and number of bytes done from ide_tape_io_buffers(). * Fix padding for PIO transfers in ide_pc_intr() so read/write buffers are always completely processed and then the transfer is padded if necessary. * Remove invalid error messages. * Remove now superfluous padding from ide{_io_buffers,tape_input_buffers}(). While at it: * Set pc->bh to NULL in idetape_input_buffers() after all bh-s are done. * Cache !!(pc->flags & PC_FLAG_WRITING) in local variable in ide_pc_intr(). Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: remove CONFIG_BLK_DEV_IDEDOUBLER config optionBartlomiej Zolnierkiewicz
Nowadays it is not worth having a separate config option for Amiga IDE Doubler support so always include it (it still needs to be explicitly enabled by module parameter). Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: decrease size of ->pc_buf field in struct ide_atapi_pcBartlomiej Zolnierkiewicz
struct ide_atapi_pc is often allocated on the stack and size of ->pc_buf size is 256 bytes. However since only ide_floppy_create_read_capacity_cmd() and idetape_create_inquiry_cmd() require such size allocate buffers for these pc-s explicitely and decrease ->pc_buf size to 64 bytes. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: fix locking in drive_release_dev()Bartlomiej Zolnierkiewicz
* Request queue cleanup should happen before freeing drive->id and marking device as non-present. Fix it. * Remove superfluous hwif->lock acquiring/releasing. Cc: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: merge ide_arm and ide_generic host driversBartlomiej Zolnierkiewicz
There is no need for a separate ide_arm host driver nowadays so merge it into ide_generic one. While at it: - return -EBUSY from ide_generic_init() if I/O resources are busy - scale down ide_generic_check_pci_legacy_iobases() for CONFIG_PCI=n Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide-generic: remove no longer needed sysfs interfaceBartlomiej Zolnierkiewicz
Nowadays we have "ide_generic.probe_mask=" module parameter and ide_platform host driver so sysfs interface for adding IDE interfaces is no longer needed. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: sanitize ide_build_sglist() and ide_destroy_dmatable()Bartlomiej Zolnierkiewicz
* Move ide_map_sg() calls out from ide_build_sglist() to ide_dma_prepare(). * Pass command to ide_destroy_dmatable(). * Rename ide_build_sglist() to ide_dma_map_sg() and ide_destroy_dmatable() to ide_dma_unmap_sg(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: set/clear drive->waiting_for_dma flag in the core codeBartlomiej Zolnierkiewicz
Set/clear drive->waiting_for_dma flag in the core code instead of in ->dma_setup and ->dma_end methods. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: move ide_map_sg() call out of ->dma_setup method (take 2)Bartlomiej Zolnierkiewicz
Move ide_map_sg() call from ->dma_setup implementations and ide_destroy_dmatable() one from *_build_dmatable() to ide_dma_prepare(). There should be no functional changes caused by this patch. Sergei: Removed 'use_pio_instead' labels and replaced 'goto' with 'return 0' -- that required no changes to the follow-up patches... Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: add ->dma_check methodBartlomiej Zolnierkiewicz
* Add (an optional) ->dma_check method for checking if DMA can be used for a given command and fail DMA setup in ide_dma_prepare() if necessary. * Convert alim15x3 and trm290 host drivers to use ->dma_check. * Rename ali15x3_dma_setup() to ali_dma_check() while at it. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31trm290: use custom ->dma_{start,end} to handle trm290_prepare_drive()Bartlomiej Zolnierkiewicz
Use custom ->dma_{start,end} methods to handle trm290_prepare_drive() there instead of in ->dma_setup method. There should be no functional changes caused by this patch (DMA support is disabled currently in trm290.c). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ns87415: use custom ->dma_{start,end} to handle ns87415_prepare_drive()Bartlomiej Zolnierkiewicz
Use custom ->dma_{start,end} methods to handle ns87415_prepare_drive() there instead of in ->dma_setup method. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
