path: root/drivers/ide/pci/sl82c105.c
2005-11-12[ARM] Ensure sl82c105 IDE interfaces are serialized when using DMARussell King
We don't want to reset the DMA state machine while the other channel is in use. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] Fix broken sl82c105 DMA preventionRussell King
We must _never_ _ever_ on pain of death enable IDE DMA on SL82C105 chipsets where the southbridge revision is <= 5, otherwise data corruption will occur. Strangely this used to work, but something has changed in the upper echelons of the IDE layer to break the hosts decision to deny DMA. Let's make it crystal clear to the IDE layer that we know best. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ide: hotplug mark __devinit sl82c105.cHerbert Xu
From: Herbert Xu <herbert@gondor.apana.org.au> mark the __init section __devinit. Splitted up from the Debian kernel patch. Signed-off-by: maximilian attems <janitor@sternwelten.at> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
