path: root/drivers/ide/pci/hpt34x.c
2007-05-10ide: add ide_tune_dma() helperBartlomiej Zolnierkiewicz
After reworking the code responsible for selecting the best DMA transfer mode it is now possible to add generic ide_tune_dma() helper. Convert some IDE PCI host drivers to use it (the ones left need more work). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: rework the code for selecting the best DMA transfer mode (v3)Bartlomiej Zolnierkiewicz
Depends on the "ide: fix UDMA/MWDMA/SWDMA masks" patch. * add ide_hwif_t.udma_filter hook for filtering UDMA mask (use it in alim15x3, hpt366, siimage and serverworks drivers) * add ide_max_dma_mode() for finding best DMA mode for the device (loosely based on some older libata-core.c code) * convert ide_dma_speed() users to use ide_max_dma_mode() * make ide_rate_filter() take "ide_drive_t *drive" as an argument instead of "u8 mode" and teach it to how to use UDMA mask to do filtering * use ide_rate_filter() in hpt366 driver * remove no longer needed ide_dma_speed() and *_ratemask() * unexport eighty_ninty_three() v2: * rename ->filter_udma_mask to ->udma_filter [ Suggested by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ] v3: * updated for scc_pata driver (fixes XFER_UDMA_6 filtering for user-space originated transfer mode change requests when 100MHz clock is used) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: add ide_set_dma() helper (v2)Bartlomiej Zolnierkiewicz
* add ide_set_dma() helper and make ide_hwif_t.ide_dma_check return -1 when DMA needs to be disabled (== need to call ->ide_dma_off_quietly) 0 when DMA needs to be enabled (== need to call ->ide_dma_on) 1 when DMA setting shouldn't be changed * fix IDE code to use ide_set_dma() instead if using ->ide_dma_check directly v2: * updated for scc_pata Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: disable DMA in ->ide_dma_check for "no IORDY" case (v2)Bartlomiej Zolnierkiewicz
If DMA is unsupported ->ide_dma_check should disable DMA. v2: * updated for scc_pata Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: add ide_use_fast_pio() helper (v3)Bartlomiej Zolnierkiewicz
* add ide_use_fast_pio() helper for use by host drivers * add DMA capability and hwif->autodma checks to ide_use_dma() - au1xxx-ide/it8213/it821x drivers didn't check for (id->capability & 1) [ for the IT8211/2 in SMART mode this check shouldn't be made but since in it821x_fixups() we set DMA bit explicitly: if(strstr(id->model, "Integrated Technology Express")) { /* In raid mode the ident block is slightly buggy We need to set the bits so that the IDE layer knows LBA28. LBA48 and DMA ar valid */ id->capability |= 3; /* LBA28, DMA */ we are better off using generic helper if we can ] - ide-cris driver didn't set ->autodma [ before the patch hwif->autodma was only checked in the chipset specific hwif->ide_dma_check implementations, for ide-cris it is cris_dma_check() function so there no behavior change here ] v2: * updated patch description (thanks to Alan Cox for the feedback) v3: * updated for scc_pata driver Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: remove write-only ide_hwif_t.no_dsc flagBartlomiej Zolnierkiewicz
2007-02-17hpt34x: hpt34x_tune_chipset() (->speedproc) fixBartlomiej Zolnierkiewicz
* remember to clear reg2 bits for the current device before setting mode * remove no longer needed hpt34x_clear_chipset() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-01-27ide: add missing __init tags to IDE PCI host driversBartlomiej Zolnierkiewicz
also change __devinit tag for sgiioc4.c:ioc4_ide_init() to __init Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in ide driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-13Fix up more strange byte writes to the PCI_ROM_ADDRESS config wordLinus Torvalds
It's a dword thing, and the value we write is a dword. Doing a byte write to it is nonsensical, and writes only the low byte, which only contains the enable bit. So we enable a nonsensical address (usually zero), which causes the controller no end of problems. Trivial fix, but nasty to find. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
