path: root/drivers/ide/ide-tape.c
2008-04-18ide: use generic ATAPI packet command flags in ide-{floppy,tape}Borislav Petkov
Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide-tape: convert driver to using generic ide_atapi_pcBorislav Petkov
2008-04-18ide-tape: remove atomic test/set macros for packet commandsBorislav Petkov
Removing the atomic tests for pc's is unobjectionable. Since this driver will probably go to /dev/null soon, the atomic tests for tape->flags are left in place for there are some situations where they're needed (chrdev DSC handling, low level pipeline operation and so on). While at it, rename all test/set flag bit defines explicitly to *_FLAG_* for clarity. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide-tape: move all struct and other defs at the topBorislav Petkov
Bart: - no need to move defines for tape flags around (they are completely rewritten by the next patch) Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE_*_REG macrosBartlomiej Zolnierkiewicz
* Add IDE_{ALTSTATUS,IREASON,BCOUNTL,BCOUNTH}_OFFSET defines. * Remove IDE_*_REG macros - this results in more readable and slightly smaller code. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add ide_atapi_{discard_data,write_zeros} inline helpersBartlomiej Zolnierkiewicz
Add ide_atapi_{discard_data,write_zeros} inline helpers to <linux/ide.h> and use them instead of home-brewn helpers in ide-{floppy,tape,scsi}. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-22Revert "ide-tape: schedule driver for removal after 6 months"Bartlomiej Zolnierkiewicz
This reverts commit d48567dd43868b3d2e1fcc33ee76dc2d38a1ddeb. Borislav is working on ide-tape "light" version instead. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-26ide-tape: schedule driver for removal after 6 monthsBorislav Petkov
2008-02-11ide-tape: remove never executed codeBartlomiej Zolnierkiewicz
rq->cmd[0] is never set to REQ_IDETAPE_READ_BUFFER so remove REQ_IDETAPE_READ_BUFFER handling from idetape_create_write_cmd() and the define itself. Then remove no longer used idetape_create_read_buffer_cmd() and IDETAPE_RETRIEVE_FAULTY_BLOCK define. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: bump minor driver versionBorislav Petkov
2008-02-06ide-tape: cleanup the remaining codestyle issuesBorislav Petkov
... thus decreasing checkpatch.pl errors to 0. Bart: - remove needless function prototypes while at it - remove needless parentheses while at it - add missing KERN_ level to ide_tape_probe() - other minor fixups Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: fix syntax error in idetape_identify_device()Borislav Petkov
Spotted by Sergei Shtylyov. CC: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: remove leftover OnStream support warningBorislav Petkov
2008-02-06ide-tape: collect module-related macro calls at the endBorislav Petkov
2008-02-06ide-tape: include proper headersBorislav Petkov
2008-02-06ide-tape: remove unused "length" arg from idetape_create_read_buffer_cmd()Borislav Petkov
2008-02-06ide-tape: remove struct idetape_id_gcwBorislav Petkov
2008-02-06ide-tape: cleanup and fix commentsBorislav Petkov
Also, remove redundant ones and cleanup whitespace. Bart: - minor fixups Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: shorten some function namesBorislav Petkov
2008-02-06ide-tape: remove idetape_increase_max_pipeline_stages()Borislav Petkov
This function was being used only at one place so fold it in there. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: struct idetape_tape_t: shorten member names v2Borislav Petkov
Shorten some member names not too aggressively since this driver might be gone anyway soon. Bart: - minor fixes Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: struct idetape_tape_t: remove unused membersBorislav Petkov
- last_frame_position: only being written to once - firmware_revision, product_id, vendor_id: used once, remove from struct idetape_tape_t and deal with them locally - firmware_revision_num: only written to once - tape_still_time_begin: completely unused - tape_still_time: never written to; remove corresponding code chunk - uncontrolled_last_pipeline_head: only once written to - blocks_in_buffer: only written to Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: remove typedef idetape_chrdev_direction_tBorislav Petkov
.. and replace it with plain enums. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: simplify code branching in the interrupt handlerBorislav Petkov
... by adding a new typedef function pointer idetape_io_buf in order to call the proper buffer i/o handler depending on the data direction. Bart: - move idetape_io_buf before idetape_pc_intr() comment Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: remove unreachable code chunkBorislav Petkov
tape->speed_control is set to 1 in idetape_setup(), but, in calculate_speeds() its value is tested for being 0, 1, or 2. Remove the if-branches where tape->speed_control != 1 since they are never executed. Also, rename calculate_speeds() by adding driver's prefix as is with the other function names. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: remove struct idetape_read_position_result_tBorislav Petkov
There should be no functional changes resulting from this patch. Bart: - remove needless "!!" Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide-tape: refactor the debug logging facilityBorislav Petkov
Teach the debug logging macro to differentiate between log levels based on the type of debug level enabled specifically instead of a threshold-based one. Thus, convert tape->debug_level to a bitmask that is written to over /proc. Also, - cleanup and simplify the debug macro thus removing a lot of code lines, - get rid of unused debug levels, - adjust the loglevel at several places where it was simply missing (e.g. idetape_chrdev_open()) - move the tape ptr initialization up in idetape_chrdev_open() so that we can use it in the debug_log macro earlier in the function. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06ide: add ide_read_error() inline helperBartlomiej Zolnierkiewicz
2008-02-06ide: add ide_read_[alt]status() inline helpersBartlomiej Zolnierkiewicz
2008-02-02ide-tape: remove idetape_config_t typedefBorislav Petkov
Since this is used only in idetape_blkdev_ioctl(), remove the typedef and make the struct function-local. Bart: - s/sizeof(struct idetape_config)/sizeof(config)/ Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove mtio.h related commentsBorislav Petkov
Those are already in mtio.h. Bart: - undo 'unsigned int/unsigned long' -> 'uint/ulong' conversion Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: make function name more accurateBorislav Petkov
idetape_active_next_stage() was rather ambiguous wrt its purpose. Make that more explicit and remove superfluous comment. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove unused sense packet commands.Borislav Petkov
2008-02-02ide-tape: use generic byteorder macrosBorislav Petkov
This is not a network driver. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: use generic scsi commandsBorislav Petkov
Also, remove those which weren't used. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove struct idetape_block_size_page_tBorislav Petkov
2008-02-02ide-tape: remove structs os_partition_t, os_dat_entry_t, os_dat_tBorislav Petkov
They seem just to sit there completely unused. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove struct idetape_parameter_block_descriptor_tBorislav Petkov
Also, shorten function name idetape_get_blocksize_from_block_descriptor() and move its definition up thereby getting rid of its forward declaration. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove struct idetape_medium_partition_page_tBorislav Petkov
There should be no functional changes resulting from this patch. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove struct idetape_data_compression_page_tBorislav Petkov
2008-02-02ide-tape: remove struct idetape_inquiry_result_tBorislav Petkov
2008-02-02ide-tape: remove struct idetape_capabilities_page_tBorislav Petkov
All those 2-byte values denoting the different capabilities are being written to the local copy of the caps buffer without being converted to big endian for simplicity of usage and shorter code later. Also, we add some comments stating which are the fields of the caps page in question in order to alleviate the cryptic pointer casting exercises as in e.g. idetape_get_mode_sense_results(). There should be no functional changes resulting from this patch. Bart: - remove two needless "!!" Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove IDETAPE_DEBUG_BUGSBorislav Petkov
2008-02-02ide-tape: remove IDETAPE_DEBUG_INFOBorislav Petkov
The device capabilities are probed for during device initialization so this info is available through proc/ioctl() und it is redundant here. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: dump gcw fields on error in idetape_identify_device()Bartlomiej Zolnierkiewicz
Cc: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove struct idetape_mode_parameter_header_tBorislav Petkov
Bart: - remove 'capabilities->speed' chunk - re-add brackets to block_descrp assignment Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove struct idetape_request_sense_result_tBorislav Petkov
Bart: - remove unnecessary comment change - remove two needless "!!" Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: remove dead codeBorislav Petkov
2008-02-02ide-tape: move historical changelog to ↵Borislav Petkov
Documentation/ide/ChangeLog.ide-tape.1995-2002 Also, cleanup whitespace and update comments. Bart: - remove reference to drivers/block/ide.c - move driver documentation to Documentation/ide/ide-tape.txt Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide-tape: use ide_execute_command()Bartlomiej Zolnierkiewicz
