path: root/drivers/ide/ide-proc.c
2008-06-30ide: fix /proc/ide/ide?/mate reportingBartlomiej Zolnierkiewicz
Now that we support warm-plug mate port will be registered even if there are no devices attached to it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-10ide: remove the ide_etrax100 chipset typeAdrian Bunk
I forgot to remove the ide_etrax100 chipset type when removing the ETRAX_IDE driver. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27ide: remove now unused ide_pci_create_host_proc()Alexey Dobriyan
It creates files in proc with obsoleted ->get_info interface. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26IDE: Coding Style fixes to drivers/ide/ide-proc.cPaolo Ciarrocchi
Lot of errors and warnings removed. Compile tested. [bart: minor fixes, md5sum checked] Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters (take 2)Bartlomiej Zolnierkiewicz
* Remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters and update Documentation/ide/ide.txt. * Remove no longer needed ide_forced chipset type. v2: * is_chipset_set[] -> is_chipset_set in ide.c. * Documentation/ide/ide.txt fix. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE devices from /proc/ide/ before unregistering themBartlomiej Zolnierkiewicz
IDE devices need to be removed from /proc/ide/ _before_ being unregistered: * Drop 'ide_hwif_t *hwif' argument from destroy_proc_ide_device() and use drive->hwif instead. * Rename destroy_proc_ide_device() to ide_proc_unregister_device(). * Call ide_proc_unregister_device() in drive_release_dev(). * Remove no longer needed destroy_proc_ide_drives(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06Palmchip BK3710 IDE driverAnton Salnikov
This is Palmchip BK3710 IDE controller support. The IDE controller logic supports PIO, MultiWord-DMA and Ultra-DMA modes. Supports interface to Compact Flash (CF) configured in True-IDE mode. Bart: - remove dead code - fix ide_hwif_setup_dma() build problem Signed-off-by: Anton Salnikov <asalnikov@ru.mvista.com> Reviewed-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: move create_proc_ide_drives() call to ide_device_add_all()Bartlomiej Zolnierkiewicz
* Un-static create_proc_ide_drives() and call it from ide_device_add_all(). While at it: * Rename create_proc_ide_drives() to ide_proc_port_register_devices(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: move hwif->present check out from ide_proc_register_port()Bartlomiej Zolnierkiewicz
Move hwif->present check out from ide_proc_register_port() to ide_device_add_all(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requestsBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. Switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requests and make ide_wait_cmd() static. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: add ide_device_add()Bartlomiej Zolnierkiewicz
* Add ide_device_add() helper and convert host drivers to use it instead of open-coded variants. * Make ide_pci_setup_ports() and do_ide_setup_pci_device() take 'u8 *idx' argument instead of 'ata_index_t *index'. * Remove no longer needed ata_index_t. * Unexport probe_hwif_init() and make it static. * Unexport ide_proc_register_port(). There should be no functionality changes caused by this patch (sgiioc4.c: ide_proc_register_port() requires hwif->present to be set and it won't be set if probe_hwif_init() fails). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide: use mutex instead of ide_setting_sem semaphore in IDE driverMatthias Kaehlcke
The IDE driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> --
2007-05-24Add two missing chipsets to drivers/ide/ide-proc.cMika Kukkonen
Compiling with '-Wswitch-enum' I noticed following: CC drivers/ide/ide-proc.o drivers/ide/ide-proc.c: In function ‘proc_ide_read_imodel’: drivers/ide/ide-proc.c:54: warning: enumeration value ‘ide_etrax100’ not handled in switch drivers/ide/ide-proc.c:54: warning: enumeration value ‘ide_acorn’ not handled in switch How about the following patch? Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: add ide_proc_register_port()Bartlomiej Zolnierkiewicz
* create_proc_ide_interfaces() tries to add /proc entries for every probed and initialized IDE port, replace it by ide_proc_register_port() which does it only for the given port (also rename destroy_proc_ide_interface() to ide_proc_unregister_port() for consistency) * convert {create,destroy}_proc_ide_interface[s]() users to use new functions * pmac driver depended on proc_ide_create() to add /proc port entries, fix it * au1xxx-ide, swarm and cs5520 drivers depended indirectly on ide-generic driver (CONFIG_IDE_GENERIC=y) to add port /proc entries, fix them * there is now no need to add /proc entries for IDE ports in proc_ide_create() so don't do it * proc_ide_create() needs now to be called before drivers are probed - fix it, while at it make proc_ide_create() create /proc "ide" directory Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: move IDE settings handling to ide-proc.cBartlomiej Zolnierkiewicz
* move __ide_add_setting() ide_add_setting() __ide_remove_setting() auto_remove_settings() ide_find_setting_by_name() ide_read_setting() ide_write_setting() set_xfer_rate() ide_add_generic_settings() ide_register_subdriver() ide_unregister_subdriver() from ide.c to ide-proc.c * set_{io_32bit,pio_mode,using_dma}() cannot be marked static now, fix it * rename ide_[un]register_subdriver() to ide_proc_[un]register_driver(), update device drivers to use new names * add CONFIG_IDE_PROC_FS=n versions of ide_proc_[un]register_driver() and ide_add_generic_settings() * make ide_find_setting_by_name(), ide_{read,write}_setting() and ide_{add,remove}_proc_entries() static * cover IDE settings code in device drivers with CONFIG_IDE_PROC_FS #ifdef, also while at it cover with CONFIG_IDE_PROC_FS #ifdef ide_driver_t.proc * remove bogus comment from ide.h * cover with CONFIG_IDE_PROC_FS #ifdef .proc and .settings in ide_drive_t Besides saner code this patch results in the IDE core smaller by ~2 kB (on x86-32) and IDE disk driver by ~1 kB (ditto) when CONFIG_IDE_PROC_FS=n. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-27IDE: remove rwsem use from ide-proc coreGreg Kroah-Hartman
The subsystem rwsem is not used by the driver core at all, so the use of it in the ide-proc code of it doesn't make any sense. Perhaps a local lock might be needed, but I do not really think so. Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: linux ide <linux-ide@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] IDE core: driver layer error checkingRandy Dunlap
Check driver layer return values in IDE core. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-08[PATCH] optical /proc/ide/*/mediaAlexey Dobriyan
Sergey Vlasov reported that his "FUJITSU MCC3064AP, ATAPI OPTICAL drive" pops up as UNKNOWN in /proc/ide/*/media . Closes #4145. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Cleaned up AMD Au1200 IDE driver:Pete Popov
- converted to platform bus - removed pci dependencies - removed virt_to_phys/phys_to_virt calls System now can root off of a disk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/Documentation/mips/AU1xxx_IDE.README b/Documentation/mips/AU1xxx_IDE.README new file mode 100644
2005-05-26[PATCH] convert IDE device drivers to driver-modelBartlomiej Zolnierkiewicz
* add ide_bus_match() and export ide_bus_type * split ide_remove_driver_from_hwgroup() out of ide_unregister() * move device cleanup from ide_unregister() to drive_release_dev() * convert ide_driver_t->name to driver->name * convert ide_driver_t->{attach,cleanup} to driver->{probe,remove} * remove ide_driver_t->busy as ide_bus_type->subsys.rwsem protects against concurrent ->{probe,remove} calls * make ide_{un}register_driver() void as it cannot fail now * use driver_{un}register() directly, remove ide_{un}register_driver() * use device_register() instead of ata_attach(), remove ata_attach() * add proc_print_driver() and ide_drivers_show(), remove ide_drivers_op * fix ide_replace_subdriver() and move it to ide-proc.c * remove ide_driver_t->drives, ide_drives and drives_lock * remove ide_driver_t->drivers, drivers and drivers_lock * remove ide_drive_t->driver and DRIVER() macro Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-05-17[PATCH] ide proc destroy errorZhang, Yanmin
Kernel 2.6 has an ide proc destroy error. Run #modprobe ide-core and #rmmod ide-core, then kernel will dump stack information like below. **********Log****************** Badness in remove_proc_entry at fs/proc/generic.c:693 Call Trace: [<a0000001000117e0>] show_stack+0x80/0xa0 sp=3De0000003e05dfbe0 = bsp=3De0000003e05d0ea8 [<a0000001000120b0>] dump_stack+0x30/0x60 sp=3De0000003e05dfdb0 = bsp=3De0000003e05d0e90 [<a000000100183090>] remove_proc_entry+0x530/0x540 sp=3De0000003e05dfdb0 = bsp=3De0000003e05d0e20 [<a000000221cbd280>] proc_ide_destroy+0x120/0x140 [ide_core] sp=3De0000003e05dfdc0 = bsp=3De0000003e05d0df0 [<a000000221ca65f0>] cleanup_module+0x50/0xa0 [ide_core] sp=3De0000003e05dfdc0 = bsp=3De0000003e05d0dd0 [<a0000001000a9e10>] sys_delete_module+0x390/0x580 sp=3De0000003e05dfdc0 = bsp=3De0000003e05d0d50 [<a00000010000af40>] ia64_ret_from_syscall+0x0/0x20 sp=3De0000003e05dfe30 = bsp=3De0000003e05d0d50 [<a000000000010640>] _stext+0xffffffff00010640/0x400 sp=3De0000003e05e0000 = bsp=3De0000003e05d0d50 Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
