path: root/drivers/ide/ide-lib.c
2008-07-23ide: add struct ide_tp_ops (take 2)Bartlomiej Zolnierkiewicz
* Add struct ide_tp_ops for transport methods. * Add 'const struct ide_tp_ops *tp_ops' to struct ide_port_info and ide_hwif_t. * Set the default hwif->tp_ops in ide_init_port_data(). * Set host driver specific hwif->tp_ops in ide_init_port(). * Export ide_exec_command(), ide_read_status(), ide_read_altstatus(), ide_read_sff_dma_status(), ide_set_irq(), ide_tf_{load,read}() and ata_{in,out}put_data(). * Convert host drivers and core code to use struct ide_tp_ops. * Remove no longer needed default_hwif_transport(). * Cleanup ide_hwif_t from methods that are now in struct ide_tp_ops. While at it: * Use struct ide_port_info in falconide.c and q40ide.c. * Rename ata_{in,out}put_data() to ide_{in,out}put_data(). v2: * Fix missing convertion in ns87415.c. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: filter out "default" transfer mode values in set_xfer_rate()Bartlomiej Zolnierkiewicz
* Filter out "default" transfer mode values (0x00 - default PIO mode, 0x01 - default PIO mode w/ IORDY disabled) in write handler for obsoleted /proc/ide/hd?/settings:current_speed setting. Allowing "default" transfer mode values is a dangerous thing to do as we don't support programming controller to the "default" transfer mode and devices often use different values for the default and maximum PIO mode (i.e. PIO2 default and PIO4 maximum) so the controller will stay programmed for higher PIO mode while device will use the lower PIO mode. There is no functionality loss as by using special IOCTLs device can still be programmed to "default" transfer modes (it is only useful for debugging/testing purposes anyway). * Remove no longer needed IDE_HFLAG_ABUSE_SET_DMA_MODE host flag, it was previously used by few host drivers to program the controller to PIO0 timings for "default" transfer mode == 0x01 (although some host drivers would program invalid PIO timings instead). * Cleanup ide_set_xfer_rate() and add BUG_ON(). Suggested-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: move PIO blacklist to ide-pio-blacklist.cBartlomiej Zolnierkiewicz
Move PIO blacklist to ide-pio-blacklist.c. While at it: - fix comment - fix whitespace damage There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: remove no longer used ide_pio_timings[]Bartlomiej Zolnierkiewicz
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: move ide_pio_cycle_time() to ide-timings.cBartlomiej Zolnierkiewicz
All ide_pio_cycle_time() users already select CONFIG_IDE_TIMINGS so move the function from ide-lib.c to ide-timings.c. While at it: - convert ide_pio_cycle_time() to use ide_timing_find_mode() - cleanup ide_pio_cycle_time() a bit There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: remove needless includes from ide-lib.cBartlomiej Zolnierkiewicz
2008-04-28ide: add ->tf_load and ->tf_read methodsBartlomiej Zolnierkiewicz
* Add ->tf_load and ->tf_read methods to ide_hwif_t and set the default methods in default_hwif_transport(). * Use ->tf_{load,read} instead o calling ide_tf_{load,read}() directly. * Make ide_tf_{load,read}() static. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_port_ops (take 2)Bartlomiej Zolnierkiewicz
* Move hooks for port/host specific methods from ide_hwif_t to 'struct ide_port_ops'. * Add 'const struct ide_port_ops *port_ops' to 'struct ide_port_info' and ide_hwif_t. * Update host drivers and core code accordingly. While at it: * Rename ata66_*() cable detect functions to *_cable_detect() to match the standard naming. (Suggested by Sergei Shtylyov) v2: * Fix build for bast-ide. (Noticed by Andrew Morton) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: sanitize handling of IDE_HFLAG_NO_SET_MODE host flagBartlomiej Zolnierkiewicz
* Check for IDE_HFLAG_NO_SET_MODE host flag in ide_set_pio(), ide_set_[pio,dma]_mode(), ide_set_xfer_rate() and set_pio_mode(). * Remove no longer needed IDE_HFLAG_NO_SET_MODE host flag checking from ide_tune_dma(). * Remove superfluous ->set_pio_mode checking from do_special(). This is a part of preparations for adding 'struct ide_port_ops'. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove PIO "downgrade" quirkBartlomiej Zolnierkiewicz
No need for it nowadays so remove quirk code from ide_get_best_pio_mode() and IDE_HFLAG_PIO_DOWNGRADE host flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-22ide: remove commented out entries from ide_pio_blacklist[]Bartlomiej Zolnierkiewicz
2008-02-11ide: remove stale comment from ide-lib.cBartlomiej Zolnierkiewicz
2008-02-06ide: add ide_read_error() inline helperBartlomiej Zolnierkiewicz
2008-02-01ide: keep pointer to struct device instead of struct pci_dev in ide_hwif_tBartlomiej Zolnierkiewicz
Keep pointer to struct device instead of struct pci_dev in ide_hwif_t. While on it: * Use *dev->dma_mask instead of pci_dev->dma_mask in ide_toggle_bounce(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: remove REQ_TYPE_ATA_CMDBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. All users are gone so we can finally remove it. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add IDE_HFLAG_ABUSE_SET_DMA_MODE host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_SET_DMA_MODE host flag and use it to decide what to do with transfer modes < XFER_PIO_0 in ide_set_xfer_rate(). * Set IDE_HFLAG_ABUSE_SET_DMA_MODE in host drivers that need it (aec62xx, amd74xx, cs5520, cs5535, hpt34x, hpt366, pdc202xx_old, serverworks, tc86c001 and via82cxxx) and cleanup ->set_dma_mode methods in host drivers that don't (IDE core code guarantees that ->set_dma_mode will be called only for modes which are present in SWDMA/MWDMA/UDMA masks). While at it: * Add IDE_HFLAGS_HPT34X/HPT3XX/PDC202XX/SVWKS define in hpt34x/hpt366/pdc202xx_old/serverworks host driver. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: kill duplicate code in ide_dump_{ata,atapi}_status()Bartlomiej Zolnierkiewicz
* Move the common code from ide_dump_{ata,atapi}_status() to ide_dump_status(). * ide_dump_{ata,atapi}_status() -> ide_dump_{ata,atapi}_error(). There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide-disk: use ide_get_lba_addr()Bartlomiej Zolnierkiewicz
* Export ide_get_lba_addr(). * Convert idedisk_{read_native,set}_max_address() to use ide_get_lba_addr(). * Remove incorrect comment from idedisk_read_native_max_address() (noticed by Sergei). There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: printk fixAndrew Morton
power4: drivers/ide/ide-lib.c: In function `ide_dump_sector': drivers/ide/ide-lib.c:516: warning: long long unsigned int format, u64 arg (arg 2) We don't know what type is used to implement u64 hence it must always be cast when printed. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add ide_tf_read() helperBartlomiej Zolnierkiewicz
* Factor out code reading taskfile registers from ide_end_drive_cmd() to the new ide_tf_read() helper. * Add IDE_TFLAG_IN_* taskfile flags to indicate the need to load particular IDE taskfile register in ide_tf_read(). * Update ide_end_drive_cmd() to set respective IDE_TFLAG_IN_* taksfile flags. * Add ide_get_lba_addr() for getting LBA sector address from taskfile struct. * Factor out code getting sector address from ide_dump_ata_status() to the new ide_dump_sector() function. * Convert ide_dump_sector() to use ide_tf_read() and ide_get_lba_addr(). * Remove no longer needed ide_read_24(). The only change in functionality caused by this patch is that ide_dump_ata_status() no longer prints "high"/"low" parts of LBA48 sector address (of course LBA48 sector address is still printed). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: fix registers loading order in ide_dump_ata_status()Bartlomiej Zolnierkiewicz
Fix registers loading order in ide_dump_ata_status()/ide_read_24(). Load registers in this order: * IDE_SECTOR_REG * IDE_LCYL_REG * IDE_HCYL_REG * IDE_SELECT_REG It shouldn't affect anything (just a usual paranoia to separate changes which change the way in which hardware is accessed from code cleanups). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove atapi_error_t (take 2)Bartlomiej Zolnierkiewicz
Remove atapi_error_t. While at it: * replace 'HWIF(drive)' by 'drive->hwif' v2: * Add {ILI,EOM,LFS}_ERR defines to <linux/hdreg.h>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove ata_status_t and atapi_status_tBartlomiej Zolnierkiewicz
Remove ata_status_t (unused) and atapi_status_t. While at it: * replace 'HWIF(drive)' by 'drive->hwif' (or just 'hwif' where possible) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove REQ_TYPE_ATA_TASKBartlomiej Zolnierkiewicz
2008-01-25ide: add struct ide_taskfile (take 2)Bartlomiej Zolnierkiewicz
* Don't set write-only ide_task_t.hobRegister[6] and ide_task_t.hobRegister[7] in idedisk_set_max_address_ext(). * Add struct ide_taskfile and use it in ide_task_t instead of tfRegister[] and hobRegister[]. * Remove no longer needed IDE_CONTROL_OFFSET_HOB define. * Add #ifndef/#endif __KERNEL__ around definitions of {task,hob}_struct_t. While at it: * Use ATA_LBA define for LBA bit (0x40) as suggested by Tejun Heo. v2: * Add missing newlines. (Noticed by Sergei) * Use ~ATA_LBA instead of 0xBF. (Noticed by Sergei) * Use unnamed unions for error/feature and status/command. (Suggested by Sergei). There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-12-12ide: DMA reporting and validity checking fixes (take 3)Bartlomiej Zolnierkiewicz
* ide_xfer_verbose() fixups: - beautify returned mode names - fix PIO5 reporting - make it return 'const char *' * Change printk() level from KERN_DEBUG to KERN_INFO in ide_find_dma_mode(). * Add ide_id_dma_bug() helper based on ide_dma_verbose() to check for invalid DMA info in identify block. * Use ide_id_dma_bug() in ide_tune_dma() and ide_driveid_update(). As a result DMA won't be tuned or will be disabled after tuning if device reports inconsistent info about enabled DMA mode (ide_dma_verbose() does the same checks while the IDE device is probed by ide-{cd,disk} device driver). * Remove no longer needed ide_dma_verbose(). This patch should fix the following problem with out-of-sync IDE messages reported by Nick Warne: hdd: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache<7>hdd: skipping word 93 validity check , UDMA(66) and later debugged by Mark Lord to be caused by: ide_dma_verbose() printk( ... "2048kB Cache"); eighty_ninty_three() printk(KERN_DEBUG "%s: skipping word 93 validity check\n"); ide_dma_verbose() printk(", UDMA(66)" Please note that as a result ide-{cd,disk} device drivers won't report the DMA speed used but this is intended since now DMA mode being used is always reported by IDE core code. v2: * fixes suggested by Randy: - use KERN_CONT for printk()-s in ide-{cd,disk}.c - don't remove argument name from ide_xfer_verbose() declaration v3: * Remove incorrect check for (id->field_valid & 1) from ide_id_dma_bug() (spotted by Sergei). * "XFER SLOW" -> "PIO SLOW" in ide_xfer_verbose() (suggested by Sergei). * Fix ide_find_dma_mode() to report the correct mode ('mode' after being limited by 'req_mode'). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Nick Warne <nick@ukfsn.org> Cc: Mark Lord <lkml@rtr.ca> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-13ide: add missing HOB bit clearing to ide_dump_ata_status()Bartlomiej Zolnierkiewicz
2007-10-16ide: remove ide_use_fast_pio()Bartlomiej Zolnierkiewicz
Remove ide_use_fast_pio() and just re-tune PIO unconditionally if DMA tuning has failed in ->ide_dma_check. All host drivers using ide_use_fast_pio() set drive->autotune so PIO is always tuned anyway and in some cases we _really_ need to re-tune PIO because PIO and DMA timings are shared. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-13ide: move ide_config_drive_speed() calls to upper layers (take 2)Bartlomiej Zolnierkiewicz
* Convert {ide_hwif_t,ide_pci_device_t}->host_flag to be u16. * Add IDE_HFLAG_POST_SET_MODE host flag to indicate the need to program the host for the transfer mode after programming the device. Set it in au1xxx-ide, amd74xx, cs5530, cs5535, pdc202xx_new, sc1200, pmac and via82cxxx host drivers. * Add IDE_HFLAG_NO_SET_MODE host flag to indicate the need to completely skip programming of host/device for the transfer mode ("smart" hosts). Set it in it821x host driver and check it in ide_tune_dma(). * Add ide_set_pio_mode()/ide_set_dma_mode() helpers and convert all direct ->set_pio_mode/->speedproc users to use these helpers. * Move ide_config_drive_speed() calls from ->set_pio_mode/->speedproc methods to callers. * Rename ->speedproc method to ->set_dma_mode, make it void and update all implementations accordingly. * Update ide_set_xfer_rate() comments. * Unexport ide_config_drive_speed(). v2: * Fix issues noticed by Sergei: - export ide_set_dma_mode() instead of moving ->set_pio_mode abuse wrt to setting DMA modes from sc1200_set_pio_mode() to do_special() - check IDE_HFLAG_NO_SET_MODE in ide_tune_dma() - check for (hwif->set_pio_mode) == NULL in ide_set_pio_mode() - check for (hwif->set_dma_mode) == NULL in ide_set_dma_mode() - return -1 from ide_set_{pio,dma}_mode() if ->set_{pio,dma}_mode == NULL - don't set ->set_{pio,dma}_mode on it821x in "smart" mode - fix build problem in pmac.c - minor fixes in au1xxx-ide.c/cs5530.c/siimage.c - improve patch description Changes in behavior caused by this patch: - HDIO_SET_PIO_MODE ioctl would now return -ENOSYS for attempts to change PIO mode if it821x controller is in "smart" mode - removal of two debugging printk-s (from cs5530.c and sc1200.c) - transfer modes 0x00-0x07 passed from user space may be programmed twice on the device (not really an issue since 0x00 is not supported correctly by any host driver ATM, 0x01 is not supported at all and 0x02-0x07 are invalid) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: use only ->set_pio_mode method for programming PIO modes (take 2)Bartlomiej Zolnierkiewicz
Use ->set_pio_mode method to program PIO modes in ide_set_xfer_rate() (the only place which used ->speedproc to program PIO modes) and remove handling of PIO modes from all ->speedproc implementations. v2: * Fix pmac_ide_tune_chipset() comment. There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: add ide_set{_max}_pio() (take 4)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_{PREFETCH,FAST_DEVSEL,DMA_MODES} flags and set them in ht6560, cmd640, cmd64x and sc1200 host drivers. * Add set_pio_mode_abuse() for checking if host driver has a non-standard ->tuneproc() implementation and use it in do_special(). * Add ide_set_pio() for setting PIO mode (it uses hwif->pio_mask to find the maximum PIO mode supported by the host), also add ide_set_max_pio() wrapper for ide_set_pio() to use for auto-tuning. Convert users of ->tuneproc to use ide_set{_max}_pio() where possible. This leaves only do_special(), set_using_pio(), ide_hwif_restore() and ide_set_pio() as a direct users of ->tuneproc. * Remove no longer needed ide_get_best_pio_mode() calls and printk-s reporting PIO mode selected from ->tuneproc implementations. * Rename ->tuneproc hook to ->set_pio_mode and make 'pio' argument const. * Remove stale comment from ide_config_drive_speed(). v2: * Fix "ata_" prefix (Noticed by Jeff). v3: * Minor cleanups/fixups per Sergei's suggestions. v4: * Fix compile problem in drivers/ide/pci/cmd640.c (Noticed by Andrew Morton). * Improve some ->set_pio_mode comments. Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: move ide_rate_filter() calls to the upper layer (take 2)Bartlomiej Zolnierkiewicz
* Move ide_rate_filter() calls from host drivers to IDE core. * Make ide_rate_filter() static. * Make 'speed' argument of ->speedproc const. v2: * Fix it8213_tune_chipset() comment. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: mode limiting fixes for user requested speed changesBartlomiej Zolnierkiewicz
* Add an extra argument to ide_max_dma_mode() for passing requested transfer mode. Use it as an upper limit when finding the best DMA for device/host. * Rename ide_max_dma_mode() to ide_find_dma_mode() and at the same time add ide_max_dma_mode() wrapper which passes XFER_UDMA_6 as a requested mode to ide_find_dma_mode(). Also add inline ide_find_dma_mode() version for CONFIG_BLK_DEV_IDEDMA=n case. * Pass requested transfer mode from ide_find_dma_mode() to ide_get_mode_mask() to avoid false warning from eighty_ninty_three(). * Use ide_find_dma_mode() to limit the user requested transfer mode in ide_rate_filter(). Also limit the requested mode by host max PIO mode. Above changes make ide_rate_filter() to: * Clip desired transfer mode down if it is invalid (values 0x0F, 0x13-0x19 and 0x25-0x39, values > 0x46 were already clipped down, same for values 0x25-0x39 but iff UDMA was not supported by the host). * Clip desired transfer mode down if it is currently unsupported by IDE core (PIO6 and MWDMA3-4, the latter were already clipped down but iff UDMA was not supported by the host). * Clip desired transfer mode down according to the host capabilities (UDMA modes were already clipped down but MWDMA/SWDMA/PIO weren't, also ->atapi_dma flag was not respected). * Clip desired transfer mode down according to the device capabilities (except PIO modes for now which require mode work) - shouldn't be a problem since ide_set_xfer_rate() is called _after_ device has accepted given transfer mode. and also result in a number of host driver specific bugfixes: * icside - clip unsupported PIO5 mode down - fix unsupported/invalid modes being set in drive->current_speed * ide-cris - clip unsupported PIO5 and SWDMA0-2 modes down - clip DMA modes down for ATAPI devices - fix BUG() on unsupported/invalid modes * au1xxx-ide - clip unsupported PIO5, SWDMA0-2 and MWDMA0-2 (if BLK_DEV_IDE_AU1XXX_MDMA2_DBDMA=n) modes down * aec62xx - clip unsupported PIO5 and SWDMA0-2 modes down - clip DMA modes down for ATAPI devices - fix 0x00 being programmed as PIO timing for unsupported/invalid modes - fix unsupported/invalid modes being set on the device * alim15x3 - clip DMA modes down for ATAPI devices (chipset revision == 0x20 only) - fix theoretical OOPS for 0x0F mode - fix unsupported/invalid modes being set on the device * amd74xx - clip unsupported SWDMA0-2 (on COBRA_7401 revs <= 7) modes down - fix random PIO timings being set for unsupported/invalid modes - fix unsupported/invalid modes being set on the device * atiixp - clip unsupported PIO5 and SWDMA0-2 modes down - fix cached MWDMA mode being cleared for unsupported/invalid modes - fix PIO{0,2} timings being programmed for unsupported/invalid modes - fix theoretical OOPS for PIO5-6 and 0x0F modes - fix unsupported/invalid modes being set on the device * cmd64x - clip unsupported SWDMA0-2 modes down * cs5530 - clip unsupported PIO5 and SWDMA0-2 modes down - fix unsupported/invalid modes being set on the device - fix BUG() on unsupported/invalid modes (which happened if the device accepted the setting) * cs5535 - clip unsupported PIO5 and SWDMA0-2 modes down - fix unsupported/invalid modes being set on the device - fix theoretical OOPS for PIO5-6 and 0x0F modes * hpt34x - clip DMA modes down for ATAPI devices - fix invalid timings being programmed for unsupported/invalid modes - fix unsupported/invalid modes being set on the device * hpt366 - clip unsupported PIO5 and SWDMA0-2 modes down - fix PIO0 timings being programmed for unsupported/invalid modes - fix DMA timings being cleared for MWDMA3-4 and 0x25-0x39 modes - fix unsupported/invalid modes being set on the device * it8213 - clip unsupported PIO5, SWDMA0-1 and MWDMA0 modes down * it821x - clip unsupported PIO5 and SWDMA0-2 modes down - clip DMA modes down for ATAPI devices (chipset in smart mode and revision 0x10 in pass-through mode) * jmicron - clip unsupported SWDMA0-2 modes down - fix unsupported/invalid modes being set on the device * pdc202xx_new - clip unsupported PIO5 and SWDMA0-2 modes down - fix unsupported/invalid modes being set on the device * pdc202xx_old - clip unsupported PIO5 mode down - fix incorrect timings being set for unsupported/invalid modes - fix unsupported/invalid modes being set on the device * piix - clip unsupported PIO5, SWDMA0-1 and MWDMA0 modes down * sc1200 - clip unsupported PIO5 and SWDMA0-2 modes down - fix unsupported/invalid modes being set on the device - fix BUG() on unsupported/invalid modes (which happened if the device accepted the setting) * scc_pata - clip unsupported PIO5, SWDMA0-2 and MWDMA0-2 modes down * serverworks - clip unsupported PIO5 and SWDMA0-2 modes down - fix DMA/UDMA timings/settings being cleared for unsupported/invalid modes - fix unsupported/invalid modes being set on the device * siimage - clip unsupported PIO5 and SWDMA0-2 modes down - clip DMA modes down for ATAPI devices (SATA chipsets) * sis5513 - clip unsupported PIO5 mode down - fix BUG() on unsupported/invalid modes * sl82c105 - clip unsupported SWDMA0-2 modes down * slc90e66 - clip unsupported PIO5, SWDMA0-1 and MWDMA0 modes down * tc86c001 - clip unsupported PIO5 and SWDMA0-2 modes down - fix PIO0 timings being programmed for PIO5/0x0F/SWDMA0-2/0x13-0x19 modes - fix invalid 0x00 DMA timing being programmed for MWDMA3-4/0x25-0x39 modes - fix unsupported/invalid modes being set on the device * triflex - clip unsupported PIO5 mode down * via82cxxx - fix random PIO timings being set for unsupported/invalid modes - fix unsupported/invalid modes being set on the device * pmac - clip unsupported PIO5 and SWDMA0-2 modes down * cmd640/ht6560b - clip DMA modes down (if CONFIG_BLK_DEV_IDEDMA=y) - fix PIO5 being clipped to PIO4 (if CONFIG_BLK_DEV_IDEDMA=n) * opti621 - clip DMA modes down (if CONFIG_BLK_DEV_IDEDMA=y) - clip unsupported PIO4 to PIO3 (if CONFIG_BLK_DEV_IDEDMA=n) While at it: * Use ide_rate_filter() in cs5520.c::cs5520_tune_chipset(). * Remove no longer needed checks from hpt366.c::hpt3{6,7}x_tune_chipset(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: remove ide_find_best_pio_mode()Bartlomiej Zolnierkiewicz
* Add ->host_flags to ide_hwif_t to store ide_pci_device_t.host_flags, assign it in setup-pci.c:ide_pci_setup_ports(). * Add IDE_HFLAG_PIO_NO_{BLACKLIST,DOWNGRADE} to ide_pci_device_t.host_flags and teach ide_get_best_pio_mode() about them. Also remove needless !drive->id check while at it (drive->id is always present). * Convert amd74xx, via82cxxx and ide-timing.h to use ide_get_best_pio_mode() and then remove no longer needed ide_find_best_pio_mode(). There should be no functionality changes caused by this patch. Acked-by: Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: drop "PIO data" argument from ide_get_best_pio_mode()Bartlomiej Zolnierkiewicz
* Drop no longer needed "PIO data" argument from ide_get_best_pio_mode() and convert all users accordingly. * Remove no longer needed ide_pio_data_t. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: add ide_pio_cycle_time() helper (take 2)Bartlomiej Zolnierkiewicz
* Add ide_pio_cycle_time() helper. * Use it in ali14xx/ht6560b/qd65xx/cmd64{0,x}/sl82c105 and pmac host drivers (previously cycle time given by the device was only used for "pio" == 255). * Remove no longer needed ide_pio_data_t.cycle_time field. v2: * Fix "ata_" prefix (Noticed by Jeff). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: add ide_dev_has_iordy() helper (take 4)Bartlomiej Zolnierkiewicz
* Add ide_dev_has_iordy() helper and use it sl82c105 host driver. * Remove no longer needed ide_pio_data_t.use_iordy field. v2/v3: * Fix issues noticed by Sergei: - correct patch description - fix comment in ide_get_best_pio_mode() v4: * Fix "ata_" prefix (Noticed by Jeff). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: make ide_get_best_pio_mode() print info if overriding PIO modeBartlomiej Zolnierkiewicz
* Print info about overriding PIO mode in ide_get_best_pio_mode(). * Remove info about overriding PIO mode from cmd64{0,x} host drivers. * Remove no longer needed ide_pio_data_t.overridden field. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-16ide: remove ide_dma_enable()Bartlomiej Zolnierkiewicz
* check ->speedproc return value in ide_tune_dma() * use ide_tune_dma() in cmd64x/cs5530/sc1200/siimage/sl82c105/scc_pata drivers * remove no longer needed ide_dma_enable() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: cable detection fixes (take 2)Bartlomiej Zolnierkiewicz
Tejun's recent eighty_ninty_three() fix has inspired me to do more thorough review of the cable detection code... * print user-friendly warning about limiting the maximum transfer speed to UDMA33 (and the reason behind it) when 80-wire cable is not detected, also while at it cleanup eighty_ninty_three() a bit * use eighty_ninty_three() in ide_ata66_check(), this actually fixes 3 bugs: - bit 14 (word 93 validity check) == 1 && bit 13 (80-wire cable test) == 1 were used as 80-wire cable present test for CONFIG_IDEDMA_IVB=n case (please see FIXME comment in eighty_ninty_three() for more details) - CONFIG_IDEDMA_IVB=y/n cases were interchanged - check for SATA devices was missing * remove private cable warnings from pdc_202xx{old,new} drivers now that core code provides this functionality (plus, in pdc202xx_new case the test could give false warnings for ATAPI devices because pdc202xx_new driver doesn't even support ATAPI DMA) Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: rework the code for selecting the best DMA transfer mode (v3)Bartlomiej Zolnierkiewicz
Depends on the "ide: fix UDMA/MWDMA/SWDMA masks" patch. * add ide_hwif_t.udma_filter hook for filtering UDMA mask (use it in alim15x3, hpt366, siimage and serverworks drivers) * add ide_max_dma_mode() for finding best DMA mode for the device (loosely based on some older libata-core.c code) * convert ide_dma_speed() users to use ide_max_dma_mode() * make ide_rate_filter() take "ide_drive_t *drive" as an argument instead of "u8 mode" and teach it to how to use UDMA mask to do filtering * use ide_rate_filter() in hpt366 driver * remove no longer needed ide_dma_speed() and *_ratemask() * unexport eighty_ninty_three() v2: * rename ->filter_udma_mask to ->udma_filter [ Suggested by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ] v3: * updated for scc_pata driver (fixes XFER_UDMA_6 filtering for user-space originated transfer mode change requests when 100MHz clock is used) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-03-03ide: ide_get_best_pio_mode() returns incorrect IORDY setting (take 2)Sergei Shtylyov
The function ide_get_best_pio_mode() fails to return the correct IORDY setting for the explicitly specified modes -- fix this along with the heading comment, and also remove the long commented out code. Also, while at it, correct the misliading comment about the PIO cycle time in <linux/ide.h> -- it actually consists of only the active and recovery periods, with only some chips also including the address setup time into equation... [ bart: sl82c105 seems to be currently the only driver affected by this fix ] Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: add ide_use_fast_pio() helper (v3)Bartlomiej Zolnierkiewicz
* add ide_use_fast_pio() helper for use by host drivers * add DMA capability and hwif->autodma checks to ide_use_dma() - au1xxx-ide/it8213/it821x drivers didn't check for (id->capability & 1) [ for the IT8211/2 in SMART mode this check shouldn't be made but since in it821x_fixups() we set DMA bit explicitly: if(strstr(id->model, "Integrated Technology Express")) { /* In raid mode the ident block is slightly buggy We need to set the bits so that the IDE layer knows LBA28. LBA48 and DMA ar valid */ id->capability |= 3; /* LBA28, DMA */ we are better off using generic helper if we can ] - ide-cris driver didn't set ->autodma [ before the patch hwif->autodma was only checked in the chipset specific hwif->ide_dma_check implementations, for ide-cris it is cris_dma_check() function so there no behavior change here ] v2: * updated patch description (thanks to Alan Cox for the feedback) v3: * updated for scc_pata driver Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: unexport ide_set_xfer_rate() (v2)Bartlomiej Zolnierkiewicz
In cmd64x, siimage and scc_pata drivers: * don't set drive->init_speed as it should be already set by successful execution of ide_set_xfer_rate() * use hwif->speedproc functions directly Above changes allows removal of EXPORT_SYMBOL_GPL(ide_set_xfer_rate). v2: * updated for scc_pata driver Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: remove write-only ide_pio_data_t.blacklistedBartlomiej Zolnierkiewicz
2006-10-03[PATCH] ide_dma_speed() fixesSergei Shtylyov
ide_dma_speed() fails to actually honor the IDE drivers' mode support masks) because of the bogus checks -- thus, selecting the DMA transfer mode that the driver explicitly refuses to support is possible. Additionally, there is no check for validity of the UltraDMA mode data in the drive ID, and the function is misdocumented. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-06-26[PATCH] fix IDE deadlock in error reporting codeIngo Molnar
Michal Piotrowski reported the following validator assert: hdd: set_drive_speed_status: status=0x51 { DriveReady SeekComplete Error } hdd: set_drive_speed_status: error=0xb4 { AbortedCommand LastFailedSense=0x0b } ============================ [ BUG: illegal lock usage! ] ---------------------------- illegal {in-hardirq-W} -> {hardirq-on-W} usage. hdparm/1821 [HC0[0]:SC0[0]:HE1:SE1] takes: (ide_lock){++..}, at: [<c0268388>] ide_dump_opcode+0x13/0x9b [...] stack backtrace: [<c0104513>] show_trace+0x1b/0x20 [<c01045f1>] dump_stack+0x1f/0x24 [<c013976c>] print_usage_bug+0x1a5/0x1b1 [<c0139e90>] mark_lock+0x2ca/0x4f7 [<c013aa96>] __lockdep_acquire+0x47e/0xaa4 [<c013b536>] lockdep_acquire+0x67/0x7f [<c030552d>] _spin_lock+0x24/0x32 [<c0268388>] ide_dump_opcode+0x13/0x9b [<c02688b6>] ide_dump_status+0x4a6/0x4cc [<c0267ae6>] ide_config_drive_speed+0x32a/0x33a [<c0262dc5>] piix_tune_chipset+0x2ed/0x2f8 [<c0262e31>] piix_config_drive_xfer_rate+0x61/0xb5 [<c0263a82>] set_using_dma+0x2f/0x60 [<c0263bee>] ide_write_setting+0x4a/0xc3 [<c02647ca>] generic_ide_ioctl+0x8a/0x47f [<f886003a>] idecd_ioctl+0xfd/0x133 [ide_cd] [<c01f1fff>] blkdev_driver_ioctl+0x4b/0x5f [<c01f2783>] blkdev_ioctl+0x770/0x7bd [<c017dc0d>] block_ioctl+0x1f/0x21 [<c0189353>] do_ioctl+0x27/0x6e [<c0189604>] vfs_ioctl+0x26a/0x280 [<c0189667>] sys_ioctl+0x4d/0x7e [<c0305ed2>] sysenter_past_esp+0x63/0xa1 in ide_dump_opcode() takes the ide_lock in an irq-unsafe manner, i.e. this function expects to be called with irqs disabled. But ide_dump_ata[pi]_status() doesnt do that - it enables interrupts specifically. That is a no-no - what guarantees that another IDE port couldnt generate an IDE interrupt while we are dumping this error? The fix is to turn the irq-enabling in these functions into irq-disabling. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
