Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* Add ATA_PIO[0-6] defines to <linux/ata.h>.
* Add ->pio_mask field to ide_pci_device_t and ide_hwif_t.
* Add PIO masks to host drivers.
<linux/ata.h> change ACK-ed by Jeff Garzik <jeff@garzik.org>.
The two CONFIG variables
CONFIG_ETRAX_IDE_CSE1_16_RESET
CONFIG_ETRAX_IDE_CSP0_8_RESET
appear to have been dead since way back in 2.5.xx days:
http://www.linuxhq.com/kernel/v2.5/75/arch/cris/drivers/Kconfig
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: Michael Starvik <starvik@axis.com>
This patch allows users to override both host and device side cable detection
with "ideX=ata66" kernel parameter. Thanks to this it should be now possible
to use UDMA > 2 modes on systems (laptops mainly) which use short 40-pin cable
instead of 80-pin one.
Next patches add automatic detection of some systems using short cables.
Changes:
* Rename hwif->udma_four to hwif->cbl and make it u8.
* Convert all existing users accordingly (use ATA_CBL_* defines while at it).
* Add ATA_CBL_PATA40_SHORT support to ide-iops.c:eighty_ninty_three().
* Use ATA_CBL_PATA40_SHORT for "ideX=ata66" kernel parameter.
Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Use ide_tune_dma() in ide-cris/it821x/pdc202xx_old/serverworks drivers.
Add "initializing" argument to ide_register_hw() and use it instead of ide.c
wide variable of the same name. Update all users of ide_register_hw()
accordingly.
Depends on the "ide: fix UDMA/MWDMA/SWDMA masks" patch.
* add ide_hwif_t.udma_filter hook for filtering UDMA mask
(use it in alim15x3, hpt366, siimage and serverworks drivers)
* add ide_max_dma_mode() for finding best DMA mode for the device
(loosely based on some older libata-core.c code)
* convert ide_dma_speed() users to use ide_max_dma_mode()
* make ide_rate_filter() take "ide_drive_t *drive" as an argument instead
of "u8 mode" and teach it to how to use UDMA mask to do filtering
* use ide_rate_filter() in hpt366 driver
* remove no longer needed ide_dma_speed() and *_ratemask()
* unexport eighty_ninty_three()
v2:
* rename ->filter_udma_mask to ->udma_filter
[ Suggested by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ]
v3:
* updated for scc_pata driver (fixes XFER_UDMA_6 filtering for user-space
originated transfer mode change requests when 100MHz clock is used)
* fix ->speedproc to set the drive speed
* this driver doesn't support SWDMA so use the correct ->swdma_mask
* BUG() if an unsupported mode is passed to ->speedproc
Signed-off-by: Alan Cox <alan@redhat.com>
* since ide_hwif_t.ide_dma_host_on is called either when drive->using_dma == 1
or when return value is discarded make it void, also drop "ide_" prefix
* make __ide_dma_host_on() void and drop "__" prefix
v2:
* while at it rename atiixp_ide_dma_host_on() to atiixp_dma_host_on()
and sgiioc4_ide_dma_host_on() to sgiioc4_dma_host_on().
[ Noticed by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ]
* since ide_hwif_t.ide_dma_{host_off,off_quietly} always return '0'
make these functions void and while at it drop "ide_" prefix
* fix comment for __ide_dma_off_quietly()
* make __ide_dma_{host_off,off_quietly,off}() void and drop "__" prefix
v2:
* while at it rename atiixp_ide_dma_host_off() to atiixp_dma_host_off(),
sgiioc4_ide_dma_{host_off,off_quietly}() to sgiioc4_dma_{host_off,off_quietly}()
and sl82c105_ide_dma_off_quietly() to sl82c105_dma_off_quietly()
* add ide_set_dma() helper and make ide_hwif_t.ide_dma_check return
-1 when DMA needs to be disabled (== need to call ->ide_dma_off_quietly)
0 when DMA needs to be enabled (== need to call ->ide_dma_on)
1 when DMA setting shouldn't be changed
* fix IDE code to use ide_set_dma() instead if using ->ide_dma_check directly
v2:
All users of ->mmio == 1 are gone so convert ->mmio into flag.
Noticed by Alan Cox.
v2:
* add ide_use_fast_pio() helper for use by host drivers
* add DMA capability and hwif->autodma checks to ide_use_dma()
- au1xxx-ide/it8213/it821x drivers didn't check for (id->capability & 1)
[ for the IT8211/2 in SMART mode this check shouldn't be made but since
in it821x_fixups() we set DMA bit explicitly:
if(strstr(id->model, "Integrated Technology Express")) {
/* In raid mode the ident block is slightly buggy
We need to set the bits so that the IDE layer knows
LBA28. LBA48 and DMA ar valid */
id->capability |= 3; /* LBA28, DMA */
we are better off using generic helper if we can ]
- ide-cris driver didn't set ->autodma
[ before the patch hwif->autodma was only checked in the chipset specific
hwif->ide_dma_check implementations, for ide-cris it is cris_dma_check()
function so there no behavior change here ]
v2:
* updated patch description (thanks to Alan Cox for the feedback)
v3:
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
* Added abstraction layer for subarchs.
* Added v32 support.
* Renamed driver.
Signed-off-by: Mikael Starvik <starvik@axis.com>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
