path: root/drivers/i2c
2012-09-19i2c-i801: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
commit 4a8f1ddde942e232387e6129ce4f4c412e43802f upstream. Add the SMBus Device IDs for the Intel Lynx Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19i2c-i801: Add device IDs for Intel Lynx PointSeth Heasley
commit 062737fb6d90c632439b1f77ad6a4965cfc84a20 upstream. Add the SMBus controller device IDs for the Intel Lynx Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-19i2c-designware: Fix build error if CONFIG_I2C_DESIGNWARE_PLATFORM=y && ↵Axel Lin
CONFIG_I2C_DESIGNWARE_PCI=y commit e68bb91baa0bb9817567bd45d560919e8e26373b upstream. This patch adds config I2C_DESIGNWARE_CORE in Kconfig, and let I2C_DESIGNWARE_PLATFORM and I2C_DESIGNWARE_PCI select I2C_DESIGNWARE_CORE. Because both I2C_DESIGNWARE_PLATFORM and I2C_DESIGNWARE_PCI can be built as built-in or module, we also need to export the functions in i2c-designware-core. This fixes below build error when CONFIG_I2C_DESIGNWARE_PLATFORM=y && CONFIG_I2C_DESIGNWARE_PCI=y: LD drivers/i2c/busses/built-in.o drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_clear_int': i2c-designware-core.c:(.text+0xa10): multiple definition of `i2c_dw_clear_int' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x928): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_init': i2c-designware-core.c:(.text+0x178): multiple definition of `i2c_dw_init' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x90): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `dw_readl': i2c-designware-core.c:(.text+0xe8): multiple definition of `dw_readl' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x0): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_isr': i2c-designware-core.c:(.text+0x724): multiple definition of `i2c_dw_isr' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x63c): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_xfer': i2c-designware-core.c:(.text+0x4b0): multiple definition of `i2c_dw_xfer' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x3c8): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_is_enabled': i2c-designware-core.c:(.text+0x9d4): multiple definition of `i2c_dw_is_enabled' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x8ec): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `dw_writel': i2c-designware-core.c:(.text+0x124): multiple definition of `dw_writel' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x3c): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_xfer_msg': i2c-designware-core.c:(.text+0x2e8): multiple definition of `i2c_dw_xfer_msg' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x200): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_enable': i2c-designware-core.c:(.text+0x9c8): multiple definition of `i2c_dw_enable' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x8e0): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_read_comp_param': i2c-designware-core.c:(.text+0xa24): multiple definition of `i2c_dw_read_comp_param' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x93c): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_disable': i2c-designware-core.c:(.text+0x9dc): multiple definition of `i2c_dw_disable' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x8f4): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_func': i2c-designware-core.c:(.text+0x710): multiple definition of `i2c_dw_func' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x628): first defined here drivers/i2c/busses/i2c-designware-pci.o: In function `i2c_dw_disable_int': i2c-designware-core.c:(.text+0xa18): multiple definition of `i2c_dw_disable_int' drivers/i2c/busses/i2c-designware-platform.o:i2c-designware-platdrv.c:(.text+0x930): first defined here make[3]: *** [drivers/i2c/busses/built-in.o] Error 1 make[2]: *** [drivers/i2c/busses] Error 2 make[1]: *** [drivers/i2c] Error 2 make: *** [drivers] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31i2c: davinci: Free requested IRQ in removeMarcus Folkesson
commit 9868a060ccf769c08ec378a9829137e272e9a92c upstream. The freed IRQ is not necessary the one requested in probe. Even if it was, with two or more i2c-controllers it will fails anyway. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31i2c: tegra: notify transfer-complete after clearing status.Laxman Dewangan
commit c889e91d2cc22123f20f40dde0c0a91856a20eea upstream. The notification of the transfer complete by calling complete() should be done after clearing all interrupt status. This avoids the race condition of misconfigure the i2c controller in multi-core environment. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31i2c-eg20t: change timeout value 50msec to 1000msecTomoya MORINAGA
commit 8a52f9f347da721b199b7f9dcc0168bbe7d0baae upstream. Currently, during i2c works alone, wait-event timeout is not occurred. However, as CPU load increases, timeout occurs frequently. So, I modified like this patch. Modifying like this patch, I've never seen the timeout event with high load test. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11i2c: pnx: Disable clk in suspendRoland Stigge
commit 6c557cfee08751d22aed34840f389b846f0f4508 upstream. In the driver's suspend function, clk_enable() was used instead of clk_disable(). This is corrected with this patch. Signed-off-by: Roland Stigge <stigge@antcom.de> Reviewed-by: Arnd Bergmann <arnd@arndb.de> [wsa: reworded commit header slightly] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-03-19i2c-algo-bit: Fix spurious SCL timeouts under heavy loadVille Syrjala
commit 8ee161ce5e0cfc689eb677f227a6248191165fac upstream. When the system is under heavy load, there can be a significant delay between the getscl() and time_after() calls inside sclhi(). That delay may cause the time_after() check to trigger after SCL has gone high, causing sclhi() to return -ETIMEDOUT. To fix the problem, double check that SCL is still low after the timeout has been reached, before deciding to return -ETIMEDOUT. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12i2c: mxs: only flag completion when queue is completely doneWolfram Sang
commit 844990daa2e69a4258049ba9c2bae1180657dac3 upstream. The hardware generates an interrupt for every completed command in the queue while the code assumed that it will only generate one interrupt when the queue is empty. So, explicitly check if the queue is really empty. This patch fixed problems which occurred due to high traffic on the bus. While we are here, move the completion-initialization after the parameter error checking. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25i2c-eg20t: modified the setting of transfer rate.Toshiharu Okada
commit ff35e8b18984ad2a82cbd259fc07f0be4b34b1aa upstream. This patch modified the setting value of I2C Bus Transfer Rate Setting Counter regisrer. Signed-off-by: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25I2C: OMAP: correct SYSC register offset for OMAP4Alexander Aring
commit 2727b1753934e154931d6b3bdf20c9b2398457a2 upstream. Correct OMAP_I2C_SYSC_REG offset in omap4 register map. Offset 0x20 is reserved and OMAP_I2C_SYSC_REG has 0x10 as offset. Signed-off-by: Alexander Aring <a.aring@phytec.de> [khilman@ti.com: minor changelog edits] Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25i2c: Fix error value returned by several bus driversJean Delvare
commit 7c1f59c9d5caf3a84f35549b5d58f3c055a68da5 upstream. When adding checks for ACPI resource conflicts to many bus drivers, not enough attention was paid to the error paths, and for several drivers this causes 0 to be returned on error in some cases. Fix this by properly returning a non-zero value on every error. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-18i2c-eg20t: correct the driver init order of pch_i2c_probe()Feng Tang
Before registering an adapter to i2c subsystem, we need make sure driver is ready for incoming i2c xfer, becasue the i2c_add_adapter() may trigger a i2c device driver's proble function which may start some real i2c xfer. I met this issue when integrating a TSC2007 i2c touch screen device with the i2c-eg20t driver. This patch will call request_irq() and hw init before calling i2c_add_adapter(). Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-18I2C: OMAP: fix FIFO usage for OMAP4Shubhrajyoti D
Currently the fifo depth is set to zero for OMAP4 which disables the FIFO usage. This patch enables the FIFO usage for I2C transactions on OMAP4 also. Tested on omap4430 and 3430. Tested-and-Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-18i2c-s3c2410: Fix return code of s3c24xx_i2c_parse_dt_gpioTushar Behera
s3c24xx_i2c_parse_dt_gpio is called when cfg_gpio is not defined in the platform data of the i2c device. When DT is not enabled, the above function always returns -EINVAL. Since there can be some i2c devices which don't need to configure any gpio lines, the probe of such devices would fail here. Changing the default return value to success would fix this issue. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-18i2c: i2c-s3c2410: Add a cpu_relax() to busy wait for bus idleMark Brown
Be a bit more friendly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-12-01Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7182/1: ARM cpu topology: fix warning ARM: 7181/1: Restrict kprobes probing SWP instructions to ARMv5 and below ARM: 7180/1: Change kprobes testcase with unpredictable STRD instruction ARM: 7177/1: GIC: avoid skipping non-existent PPIs in irq_start calculation ARM: 7176/1: cpu_pm: register GIC PM notifier only once ARM: 7175/1: add subname parameter to mfp_set_groupg callers ARM: 7174/1: Fix build error in kprobes test code on Thumb2 kernels ARM: 7172/1: dma: Drop GFP_COMP for DMA memory allocations ARM: 7171/1: unwind: add unwind directives to bitops assembly macros ARM: 7170/2: fix compilation breakage in entry-armv.S ARM: 7168/1: use cache type functions for arch_get_unmapped_area ARM: perf: check that we have a platform device when reserving PMU ARM: 7166/1: Use PMD_SHIFT instead of PGDIR_SHIFT in dma-consistent.c ARM: 7165/2: PL330: Fix typo in _prepare_ccr() ARM: 7163/2: PL330: Only register usable channels ARM: 7162/1: errata: tidy up Kconfig options for PL310 errata workarounds ARM: 7161/1: errata: no automatic store buffer drain ARM: perf: initialise used_mask for fake PMU during validation ARM: PMU: remove pmu_init declaration ARM: PMU: re-export release_pmu symbol to modules
2011-11-26ARM: 7175/1: add subname parameter to mfp_set_groupg callersAxel Lin
commit 798681bf "ARM: 7158/1: add new MFP implement for NUC900" adds subname parameter for mfp_set_groupg. Thus add subname parameter to the callers. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Wan Zongshun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-23i2c: Make i2cdev_notifier_call staticShubhrajyoti D
The function i2cdev_notifier_call is used only in i2c-dev file making it static. Also removes the following sparse warning drivers/i2c/i2c-dev.c:582:5: warning: symbol 'i2cdev_notifier_call' was not declared. Should it be static? Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-11-23i2c: Fix device name for 10-bit slave addressJean Delvare
10-bit addresses overlap with traditional 7-bit addresses, leading in device name collisions. Add an arbitrary offset to 10-bit addresses to prevent this collision. The offset was chosen so that the address is still easily recognizable. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-11-23i2c-algo-bit: Generate correct i2c address sequence for 10-bit targetJeffrey (Sheng-Hui) Chu
The wrong bits were put on the wire, fix that. This fixes kernel bug #42562. Signed-off-by: Sheng-Hui J. Chu <jeffchu@broadcom.com> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
2011-11-03Merge branch 'for-next' of git://git.infradead.org/users/sameo/mfd-2.6Linus Torvalds
* 'for-next' of git://git.infradead.org/users/sameo/mfd-2.6: (80 commits) mfd: Fix missing abx500 header file updates mfd: Add missing <linux/io.h> include to intel_msic x86, mrst: add platform support for MSIC MFD driver mfd: Expose TurnOnStatus in ab8500 sysfs mfd: Remove support for early drop ab8500 chip mfd: Add support for ab8500 v3.3 mfd: Add ab8500 interrupt disable hook mfd: Convert db8500-prcmu panic() into pr_crit() mfd: Refactor db8500-prcmu request_clock() function mfd: Rename db8500-prcmu init function mfd: Fix db5500-prcmu defines mfd: db8500-prcmu voltage domain consumers additions mfd: db8500-prcmu reset code retrieval mfd: db8500-prcmu tweak for modem wakeup mfd: Add db8500-pcmu watchdog accessor functions for watchdog mfd: hwacc power state db8500-prcmu accessor mfd: Add db8500-prcmu accessors for PLL and SGA clock mfd: Move to the new db500 PRCMU API mfd: Create a common interface for dbx500 PRCMU drivers mfd: Initialize DB8500 PRCMU regs ... Fix up trivial conflicts in arch/arm/mach-imx/mach-mx31moboard.c arch/arm/mach-omap2/board-omap3beagle.c arch/arm/mach-u300/include/mach/irqs.h drivers/mfd/wm831x-spi.c
2011-11-01Merge branch 'for-linus/i2c-3.2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/i2c-3.2' of git://git.fluff.org/bjdooks/linux: (47 commits) i2c-s3c2410: Add device tree support i2c-s3c2410: Keep a copy of platform data and use it i2c-nomadik: cosmetic coding style corrections i2c-au1550: dev_pm_ops conversion i2c-au1550: increase timeout waiting for master done i2c-au1550: remove unused ack_timeout i2c-au1550: remove usage of volatile keyword i2c-tegra: __iomem annotation fix i2c-eg20t: Add initialize processing in case i2c-error occurs i2c-eg20t: Fix flag setting issue i2c-eg20t: add stop sequence in case wait-event timeout occurs i2c-eg20t: Separate error processing i2c-eg20t: Fix 10bit access issue i2c-eg20t: Modify returned value s32 to long i2c-eg20t: Fix bus-idle waiting issue i2c-designware: Fix PCI core warning on suspend/resume i2c-designware: Add runtime power management support i2c-designware: Add support for Designware core behind PCI devices. i2c-designware: Push all register reads/writes into the core code. i2c-designware: Support multiple cores using same ISR ...
2011-11-01Merge branches 'for-32/i2c/nomadik', 'for-32/i2c/s3c2410-dt' and ↵Ben Dooks
'for-32/i2c/tegra-iomem' into for-linus/i2c-3.2
2011-11-01Merge branch 'for-32/i2c/irqflags' into for-linus/i2c-3.2Ben Dooks
Conflicts: drivers/i2c/busses/i2c-designware-core.c Fixed up merge conflic
2011-11-01Merge branches 'for-32/i2c/omap-v4', 'for-32/i2c/imx-dt', ↵Ben Dooks
'for-32/i2c/eg20t-v4', 'for-32/i2c/designware-v5' and 'for-32/i2c/au1550' into for-linus/i2c-3.2
2011-10-31i2c: Add module.h to modular files prev. implicitly getting itPaul Gortmaker
These files use interfaces from linux/module.h, so they must include that file to avoid build errors when the implicit presence of module.h is removed. [with i2c-pxa-pci.c fix from Randy Dunlap <rdunlap@xenotime.net>] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31i2c: add export.h to i2c-boardinfo.c for EXPORT_SYMBOLPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-30i2c-algo-pca: Return standard fault codesJean Delvare
Adjust i2c-algo-pca to return fault codes compliant with Documentation/i2c/fault-codes, rather than the undocumented and vague -EREMOTEIO. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Wolfram Sang <w.sang@pengutronix.de>
2011-10-30i2c-algo-bit: Return standard fault codesJean Delvare
Adjust i2c-algo-bit to return fault codes compliant with Documentation/i2c/fault-codes, rather than the undocumented and vague -EREMOTEIO. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-10-30i2c-algo-bit: Be verbose on bus testing failureJean Delvare
If bus testing fails due to the bus being seen as busy, it might be helpful for developers to know which line is unexpectedly low. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
2011-10-30i2c-algo-bit: Let user test buses without failingJean Delvare
Always failing to register I2C buses when the line testing fails is a little harsh. While such a failure is definitely a bug in the driver that exposes the affected I2C bus, things may still work fine if the missing initialization steps are done later, before the I2C bus is used. So it seems a better debugging tool to just report the test failure by default. I introduce bit_test=2 if anyone really misses the original behavior of bit_test=1. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
2011-10-30i2c/scx200_acb: Fix section mismatch warning in scx200_pci_drvHarvey Yang
WARNING: drivers/i2c/busses/built-in.o(.data+0x47c8): Section mismatch in reference from the variable scx200_pci_drv to the function .devinit.text:scx200_probe() The variable scx200_pci_drv references the function __devinit scx200_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console Signed-off-by: Harvey Yang <harvey.huawei.yang@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-10-30i2c: I2C_ELEKTOR should depend on HAS_IOPORTGeert Uytterhoeven
On m68k, I get: drivers/i2c/busses/i2c-elektor.c: In function ‘pcf_isa_init’: drivers/i2c/busses/i2c-elektor.c:153: error: implicit declaration of function ‘ioport_map’ drivers/i2c/busses/i2c-elektor.c:153: warning: assignment makes pointer from integer without a cast drivers/i2c/busses/i2c-elektor.c: In function ‘elektor_probe’: drivers/i2c/busses/i2c-elektor.c:287: error: implicit declaration of function ‘ioport_unmap’ Since commit 82ed223c264def2b15ee4bec2e8c3048092ceb5f ("iomap: make IOPORT/PCI mapping functions conditional"), ioport_map() is only available on platforms that set HAS_IOPORT. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-10-29i2c-s3c2410: Add device tree supportThomas Abraham
Add device tree probe support for Samsung's s3c2410 i2c driver. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-s3c2410: Keep a copy of platform data and use itThomas Abraham
The platform data is copied into driver's private data and the copy is used for all access to the platform data. This simpifies the addition of device tree support for the i2c-s3c2410 driver. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-nomadik: cosmetic coding style correctionsJonas Aaberg
This fixes a number of whitespace and punctuation problems around the Nomadik I2C driver. Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: dev_pm_ops conversionManuel Lauss
use newer dev_pm_ops for PM Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: increase timeout waiting for master doneManuel Lauss
Double the timeout in the loop which busy-waits for the "master-done" bit to be set. This bit indicates whether an i2c transaction has completed; on the DB1300 and DB1550 boards this timeout is slightly too short and causes transactions to the WM8731 codec to be falsely flagged as failed. The timeout itself is necessary since transactions to non-existant slaves never set this bit in the first place (and cause i2cdetect to hang). With this change the WM8731 codec on the DB1300/DB1550 boards is correctly detected and initialized. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: remove unused ack_timeoutManuel Lauss
The ack_timeout context member is unused, get rid of it. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: remove usage of volatile keywordManuel Lauss
Replace the usage of "volatile"s with register accessor functions. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-tegra: __iomem annotation fixOlof Johansson
drivers/i2c/busses/i2c-tegra.c:585:7: warning: incorrect type in assignment (different address spaces) drivers/i2c/busses/i2c-tegra.c:585:7: expected void *base drivers/i2c/busses/i2c-tegra.c:585:7: got void [noderef] <asn:2>* drivers/i2c/busses/i2c-tegra.c:619:16: warning: incorrect type in assignment (different address spaces) drivers/i2c/busses/i2c-tegra.c:619:16: expected void [noderef] <asn:2>*base drivers/i2c/busses/i2c-tegra.c:619:16: got void *base drivers/i2c/busses/i2c-tegra.c:689:10: warning: incorrect type in argument 1 (different address spaces) drivers/i2c/busses/i2c-tegra.c:689:10: expected void volatile [noderef] <asn:2>*addr drivers/i2c/busses/i2c-tegra.c:689:10: got void *base Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by; Stephen Warren <swarren@nvidia.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-eg20t: Add initialize processing in case i2c-error occursTomoya MORINAGA
In case disconnecting physical connection, need to initialize i2c device for retry access. This patch adds initialize process in case bus-idle fails and Lost arbitration. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-eg20t: Fix flag setting issueTomoya MORINAGA
Currently, in case occurring abnormal event, internal flag variable(=pch_event_flag) is not reset. This patch fixes the issue. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-eg20t: add stop sequence in case wait-event timeout occursTomoya MORINAGA
add stop sequence in case wait-event timeout in write processing. (read processing already had it) Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-eg20t: Separate error processingTomoya MORINAGA
Error processing for NACK or wait-event must be precessed separately. So divide wait-event error processing into NACK-receiving and timeout. Add arbitration lost processing. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-eg20t: Fix 10bit access issueTomoya MORINAGA
Reported-by: Jeffrey (Sheng-Hui) Chu <jeffchu@broadcom.com> Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-eg20t: Modify returned value s32 to longTomoya MORINAGA
Type of wait_event_timeout is long not s32. This patch replaces s32 with long. Additionally, delete negative processing(ret < 0). Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
