Driver for I2C interfaces in master mode on SH7760.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Split the handling of the I2C_RDWR and I2C_SMBUS ioctls to their own
functions. This limits the stack usage, saves one level of indentation
and makes the code more readable.
This patch allows the i2c-ibm_iic driver to be built either as an ocp
driver or an of_platform driver. This allows it to run under the powerpc
arch but maintains backward compatibility with the ppc arch.
Signed-off-by: Sean MacLennan <smaclennan@pikatech.com>
Change the log levels based on feedback from linxppc-dev.
Tested on a blackfin.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
The separation between algorithm and adapter was unsharp at places. This was
partly hidden by the fact, that the ISA-driver allowed just one instance and
had all private data in static variables. This patch makes neccessary
preparations to add a platform driver on top of the algorithm, while still
supporting ISA. Note: Due to lack of hardware, the ISA-driver could not be
tested except that it builds.
Concerning the core struct i2c_algo_pca_data:
- A private data field was added, all hardware dependant data may go here.
Similar to other algorithms, now a pointer to this data is passed to the
adapter's functions. In order to make as less changes as possible to the
ISA-driver, it leaves the private data empty and still only uses its static
variables.
- A "reset_chip" function pointer was added; such a functionality must come
from the adapter, not the algorithm.
- use a variable "i2c_clock" instead of a function pointer "get_clock",
allowing for write access to a default in case a wrong value was supplied.
In the algorithm-file:
- move "i2c-pca-algo.h" into "linux/i2c-algo-pca.h"
- now using per_instance timeout values (i2c_adap->timeout)
- error messages specify the device, not only the driver name
- restructure initialization to easily support "i2c_add_numbered_adapter"
- drop "retries" and "own" (i2c address) as they were unused
(The state-machine for I2C-communication was not touched.)
In the ISA-driver:
- adapt to new algorithm
Remove trailing whitespaces to make further patches more readable. Also remove
an unnecessary UTF-char for simplicity ("us" for microseconds is fine enough).
The algorithm drivers are helper drivers that are selected automatically
as needed. There's no point in listing them in the config menu, it can
only confuse users and waste their time.
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc
* 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc:
Deprecate the asm/semaphore.h files in feature-removal-schedule.
Convert asm/semaphore.h users to linux/semaphore.h
security: Remove unnecessary inclusions of asm/semaphore.h
lib: Remove unnecessary inclusions of asm/semaphore.h
kernel: Remove unnecessary inclusions of asm/semaphore.h
include: Remove unnecessary inclusions of asm/semaphore.h
fs: Remove unnecessary inclusions of asm/semaphore.h
drivers: Remove unnecessary inclusions of asm/semaphore.h
net: Remove unnecessary inclusions of asm/semaphore.h
arch: Remove unnecessary inclusions of asm/semaphore.h
'ns9x', 'orion', 'pxa', 'sa1100', 's3c' and 'sparsemem' into devel
two reasons:
1. GPIO namings and their mode definitions are conceptually not part
of the PXA register definitions
2. this is actually a temporary move in the transition of PXA2xx to
use MFP-alike APIs (as what PXA3xx is now doing), so that legacy
code will still work and new code can be added in step by step
Signed-off-by: eric miao <eric.miao@marvell.com>
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Make the tps65010 driver use gpiolib to expose its GPIOs.
Note: This patch will get merged via omap tree instead of I2C
as it will cause some board updates. This has been discussed
at on the I2C list:
http://lists.lm-sensors.org/pipermail/i2c/2008-March/003031.html
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: i2c@lm-sensors.org
I have recently bought some USB PIDs from EZPrototypes for my USB projects
and one will be for the i2c-tiny-usb. I have not yet started to use the new
one in the official i2c-tiny-usb firmware since i think it makes sense to get
the change into the kernel before releasing a modified firmware.
This patch adds support for the EZPrototypes USB vid/pid pair used in later
i2c-tiny-usb firmware versions (avrusb v1.06 and up, usbtiny v2.06 and up).
Signed-off-by: Till Harbaum <Till@Harbaum.org>
DAVINCI_I2C_STR_REG is a write 1 to clear register,
so don't use a read/modify/write cycle.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@gmail.com>
Signed-off-by: Kevin Hilman <khilman@mvista.com>
Noticed this when grepping for fast mode module params, the i2c-ibm_iic
driver was using a non-existent variable for MODULE_PARM_DESC. Fix it up
to reflect what it's actually supposed to be describing.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Reviewed-by: Tzachi Perelstein <tzachi@marvell.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Sometimes kernel-doc and xmlto conspire to create output that is invalid
and causes problems. Until I know a real/better solution, change the
source code that causes this.
If anyone has better fixes or can just explain what is happening here,
that would be great.
xmlto: input does not validate (status 1)
mmotm-2008-0314-1449/Documentation/DocBook/kernel-api.xml:71468: parser error : Opening and ending tag mismatch: programlisting line 71464 and para
</para><para>
mmotm-2008-0314-1449/Documentation/DocBook/kernel-api.xml:71480: parser error : Opening and ending tag mismatch: para line 71473 and programlisting
</programlisting></informalexample>
make[1]: *** [Documentation/DocBook/kernel-api.html] Error 1
If an I2C interrupt happens between disabling interface clock
and functional clock, the interrupt handler will produce an
external abort on non-linefetch error when trying to access
driver registers while interface clock is disabled.
This patch fixes the problem by saving and disabling i2c-omap
interrupt before turning off the clocks. Also disable functional
clock before the interface clock as suggested by Paul Walmsley.
Patch also renames enable/disable_clocks functions to unidle/idle
functions. Note that the driver is currently not taking advantage
of the idle interrupts. To use the idle interrupts, driver would
have to enable interface clock based on the idle interrupt
and dev->idle flag.
This patch has been tested in linux-omap tree with various omaps.
Cc: Paul Walmsley <paul@pwsan.com>
The i2c-bfin-twi driver doesn't support BF54x for now due to
missing header definitions causing the build to fail. Exclude
it for now, it will be enabled again later.
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Let driver authors know that drivers/i2c/chips is usually the wrong place
for new drivers.
Ensure that client->driver is set to NULL if the probe() returns an
error (this keeps client->driver and client->dev.driver in sync).
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This patch fixes an off-by-one error spotted by the Coverity checker.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Add the Intel ICH10 SMBus Controller DeviceID's and updates
Tolapai support.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
When probing i2c-pca-isa writes to legacy ioports, which crashes the kernel
if there is no device at that port.
This patch adds a check_legacy_ioport call, so probe fails gracefully
and thus prevents the oops.
Signed-off-by: Christian Krafft <krafft@de.ibm.com>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the
beginning of the declaration specifiers in a declaration is an
obsolescent feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
While working on the PCA9564-platform driver, I sometimes had a glimpse at the
pxa-driver. I found some suspicious places, and this patch contains my
suggestions. Note: They are not tested, due to no hardware.
[JD: Some more fixes.]
Tested-by: Mike Rapoport <mike@compulab.co.il>
Tested-by: Eric Miao <ymiao3@marvell.com>
This fixes two warnings:
* unused static defined function decode_ICR() when
compiled without CONFIG_I2C_PXA_SLAVE
* a sparse warning about a void function returning
something
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
Many I2C hwmon drivers define a driver ID but no other code references
these, meaning that they are useless. Discard them, along with a few
IDs which are defined but never used at all.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Use drivers/gpio/pca9539.c instead.
Acked-by: Ben Gardner <bgardner@wabtec.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
This patch converts users of pci_enable_device_bars() to the new
pci_enable_device_{io,mem} interface.
The new API fits nicely, except maybe for the QLA case where a bit of
code re-organization might be a good idea but I prefer sticking to the
simple patch as I don't have hardware to test on.
I'll also need some feedback on the cs5520 change.
* orion: (26 commits)
[ARM] Orion: implement power-off method for QNAP TS-109/209
[ARM] Orion: add support for QNAP TS-109/TS-209
[ARM] Orion: I2C support
[I2C] i2c-mv64xxx: Don't set i2c_adapter.retries
[I2C] Split mv643xx I2C platform support
[ARM] Orion: enable CONFIG_RTC_DRV_M41T80 for D-Link DNS-323
[ARM] Orion defconfig
[ARM] Orion: add support for Orion/MV88F5181 based D-Link DNS-323
[ARM] Orion: MV88F5181 support bits
[ARM] Orion: Buffalo/Revogear Kurobox Pro support
[ARM] OrionNAS RD board support
[ARM] Orion: support for Marvell Orion-2 (88F5281) Development Board
[ARM] Orion: common platform setup for Gigabit Ethernet port
[ARM] Orion: platform device registration for UART, USB and NAND
[ARM] Orion: system timer support
[ARM] Orion edge GPIO IRQ support
[ARM] Orion: IRQ support
[ARM] Orion: provide GPIO method for enabling hardware assisted blinking
[ARM] Orion: GPIO support
[ARM] Orion: programable address map support
arch/arm/Kconfig
arch/arm/Makefile
All the users of this driver explicitly specify the I2C bus numbers
to be used in their platform data. Make the driver respect that.
Signed-off-by: Kalle Pokki <kalle.pokki@eke.fi>
Cc: Bryan Wu <bryan.wu@analog.com>
Convert the i2c-au1550 bus driver to platform driver, and
register a platform device for the Alchemy Db/Pb series of
boards.
Zero-bytes transfers would leave the bus transaction unfinished
(no i2c stop is sent), with the following transfer actually
sending the slave address to the previously addressed device,
resulting in weird device failures (e.g. reset minute register
values in my RTC).
This patch instructs the controller to send an I2C STOP right after
the slave address in case of a zero-byte transfer.
Propagate the error values returned by i2c_wait() instead of overriding
them with a meaningless -1.
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
This adds a i2c_new_dummy() primitive to help work with devices
that consume multiple addresses, which include many I2C eeproms
and at least one RTC.
It is no longer required to hold adapter->clist_lock to call
i2c_check_addr.
Cc: David Brownell <david-b@pacbell.net>
We only need to hold adapter->clist_lock when we touch the client list.
This goes on top of the patch removing most i2c_adapter.clients usage,
updating i2c_attach_client:
- Don't call device_register() while holding clist_lock. This
removes a self-deadlock when on the i2c_driver.probe() path,
for drivers that need to attach new devices (e.g. dummies).
- Remove a redundant address check. The driver model core does
this as a consequence of guaranteeing unique names.
- Move the "device registered" diagnostic so that it never lies;
previously, on error paths it would falsely report success.
The i2c_adapter.clients list of i2c_client nodes duplicates driver
model state. This patch starts removing that list, letting us remove
most existing users of those i2c-core lists.
* The core I2C code now iterates over the driver model's list instead
of the i2c-internal one in some places where it's safe:
- Passing a command/ioctl to each client, a mechanims
used almost exclusively by DVB adapters;
- Device address checking, in both i2c-core and i2c-dev.
* Provide i2c_verify_client() to use with driver model iterators.
* Flag the relevant i2c_adapter and i2c_client fields as deprecated,
to help prevent new users from appearing.
For the moment the list needs to stick around, since some issues show
up when deleting devices created by legacy I2C drivers. (They don't
follow standard driver model rules. Removing those devices can cause
self-deadlocks.)
Add support for another variant of the VT8237. I couldn't test
I2C block support but I assume it is present as well.
Checking the PCI function number doesn't add any value, and it makes
adding dynamic IDs to the driver more difficult. Drop this check.
The i2c-amd756 and i2c-viapro drivers make use of the driver_data
field of the PCI device ID. When adding device IDs dynamically (by
writing to the new_id sysfs file) you cannot set the value of this
field by default. It has to be allowed explicitly. Do that, and
check the value so that the user can't crash the kernel accidentally.
Add polling I2C transfer implementation for PXA I2C. This is needed
for cases where I2C transactions have to occur at times interrups are
disabled.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: eric miao <eric.miao@marvell.com>
Allow i2c_transfer to be called in contexts where sleeping is not allowed.
It is the reponsability of the caller to ensure that the underlying i2c bus
driver will not sleep either.
The implementation is unsafe, and anyway one can achieve the same from
userspace using i2c-dev + i2cdetect.
Also tag i2c_sibyte_add_bus __init.
I2C block read is supported since the ICH5. I couldn't get it to work
using the block buffer, so it's using the old-style byte-by-byte mode
for now.
Note: I'm also updating the driver author... The i2c-i801 driver was
really written by Mark Studebaker, even though he based his work on
the i2c-piix4 driver which was written by Philip Edelbrock.
Clear special mode bits (PEC, block buffer) at driver load time,
you never know in which state the device was left by its last user.
Also make sure that we reset the block buffer mode at the end of every
transaction, not only when PEC was used.
